Normalizing NICE CXone Pure Connect DTMF Sequences via Pure Connect APIs with Python
A Python service that constructs, validates, and applies DTMF normalization rules to Pure Connect IVR flows using atomic PATCH operations, tracks latency and success metrics, and syncs normalized sequences to external processors via webhooks. This tutorial uses the Pure Connect REST API surface with the requests library and explicit HTTP cycles. The implementation covers Python 3.9+.
- Pure Connect OAuth confidential client with scopes:
ivrfloes:read,ivrfloes:write,webhooks:write,telephony:read - Pure Connect API version:
v2 - Python runtime: 3.9 or higher
- External dependencies:
requests>=2.31.0,pydantic>=2.5.0,httpx>=0.25.0,tenacity>=8.2.0
Pure Connect uses standard OAuth 2.0 client credentials flow. The token endpoint returns a bearer token valid for a limited window. Production implementations must cache the token and refresh before expiration.
import requests
from typing import Optional
class PureConnectAuth:
def __init__(self, instance: str, client_id: str, client_secret: str, scope: str):
self.instance = instance
self.client_id = client_id
self.scope = scope
self.token_url = f"https://{instance}.pure.cloud.nice.com/api/v2/oauth/token"
self.expires_at: float = 0.0
def get_token(self) -> str:
if self.access_token and time.time() < self.expires_at - 30:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": self.scope
headers = {"Content-Type": "application/json"}
response = requests.post(self.token_url, json=payload, headers=headers)
response.raise_for_status()
data = response.json()
self.access_token = data["access_token"]
self.expires_at = time.time() + data["expires_in"]
The get_token method checks cache freshness. It requests a new token when expiration approaches. The response contains access_token and expires_in. Store the token securely and rotate credentials regularly.
Step 1: Construct Normalization Payload with Sequence References and Timeout Logic
DTMF normalization in Pure Connect occurs within IVR flow configuration blocks. The payload must define digit collection limits, inter-digit timeouts, and sequence transformation rules. The following function constructs a valid IVR flow update payload that enforces maximum digit string limits and inserts timeout gap logic.
from pydantic import BaseModel, field_validator
import re
class DtmfNormalizationConfig(BaseModel):
sequence_reference: str
max_digits: int = 15
inter_digit_timeout_ms: int = 3000
gap_insertion_threshold_ms: int = 2000
tone_matrix: List[str] = ["0-9", "*", "#", "A-D"]
standardize_directive: str = "trim_and_validate"
@field_validator("max_digits")
@classmethod
def validate_digit_limit(cls, v: int) -> int:
if v < 1 or v > 50:
raise ValueError("Telephony constraint violation: max_digits must be between 1 and 50")
return v
def construct_normalization_payload(config: DtmfNormalizationConfig) -> Dict[str, Any]:
"""Builds the IVR flow block configuration for DTMF normalization."""
"id": config.sequence_reference,
"type": "COLLECT_DTMF",
"properties": {
"maxDigits": config.max_digits,
"interDigitTimeout": config.inter_digit_timeout_ms,
"promptTimeout": 10000,
"normalize": {
"directive": config.standardize_directive,
"toneMatrix": config.tone_matrix,
"gapInsertion": {
"enabled": True,
"thresholdMs": config.gap_insertion_threshold_ms,
"fillCharacter": "T"
"truncation": {
"enabled": True,
"maxLength": config.max_digits,
"overflowAction": "DROP_TAIL"
The payload maps directly to Pure Connect IVR block schema. The maxDigits field enforces carrier constraints. The gapInsertion object handles multi-frequency signal decoding pauses. The truncation object triggers automatic sequence truncation when inputs exceed limits. Required scope: ivrfloes:write.
Step 2: Validate Normalization Schemas Against Telephony Constraints
Before sending configuration to Pure Connect, validate digit strings against ITU-T E.181 DTMF standards and simulate signal-to-noise verification. This step prevents normalizing failure and DTMF misrouting during scaling events.
import logging
logger = logging.getLogger("dtmf_normalizer")
VALID_DTMF_CHARS = set("0123456789*#ABCD")
def validate_dtmf_sequence(sequence: str, max_length: int, snr_threshold_db: float = 20.0) -> bool:
"""Validates DTMF input against telephony constraints and simulated SNR pipeline."""
if len(sequence) > max_length:
logger.warning("Sequence exceeds maximum digit string limit. Truncation will apply.")
return False
for char in sequence:
if char not in VALID_DTMF_CHARS:
raise ValueError(f"Invalid DTMF character: {char}. Carrier compliance check failed.")
# Simulated signal-to-noise verification pipeline
# In production, this would interface with telephony codec analysis or CXone telephony metrics
if snr_threshold_db < 15.0:
logger.error("Signal-to-noise ratio below verification threshold. Normalization blocked.")
return False
return True
def verify_format_and_truncate(sequence: str, max_length: int) -> str:
"""Applies automatic sequence truncation triggers for safe normalize iteration."""
clean_sequence = re.sub(r"[^0-9*#A-D]", "", sequence)
if len(clean_sequence) > max_length:
truncated = clean_sequence[:max_length]
logger.info("Automatic truncation triggered. Original length: %d, New length: %d", len(clean_sequence), max_length)
return truncated
return clean_sequence
The validation function rejects invalid characters and enforces length constraints. The truncation function strips non-DTMF characters and cuts overflow safely. This prevents 422 Unprocessable Entity responses from Pure Connect when malformed sequences reach the IVR engine.
Step 3: Atomic PATCH Operations with Retry Logic and Format Verification
Pure Connect supports atomic updates via PATCH. The following function applies the normalization payload to an existing IVR flow. It includes exponential backoff for 429 rate limits and verifies the response format.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
@retry(
stop=stop_after_attempt(5),
wait=wait_exponential(multiplier=1, min=2, max=60),
retry=retry_if_exception_type(httpx.HTTPStatusError),
reraise=True
def apply_normalization_patch(
base_url: str,
access_token: str,
flow_id: str,
payload: Dict[str, Any]
"""Applies DTMF normalization rules via atomic PATCH to Pure Connect IVR flow."""
url = f"{base_url}/api/v2/ivrfloes/{flow_id}"
headers = {
"Authorization": f"Bearer {access_token}",
"Accept": "application/json"
# Atomic PATCH: Pure Connect merges provided fields without overwriting unrelated blocks
patch_body = {
"op": "replace",
"path": "/blocks/0",
"value": payload
with httpx.Client(timeout=30.0) as client:
response = client.patch(url, json=patch_body, headers=headers)
raise httpx.HTTPStatusError("Rate limit exceeded", request=response.request, response=response)
result = response.json()
logger.info("Atomic PATCH successful. Flow ID: %s, Status: %s", flow_id, response.status_code)
return result
The PATCH request targets /api/v2/ivrfloes/{id}. Pure Connect merges the block configuration atomically. The tenacity decorator handles 429 responses with exponential backoff. The function raises on 4xx/5xx failures. Required scope: ivrfloes:write.
Step 4: Synchronize Normalizing Events via Webhooks and Track Metrics
After normalization applies, register a webhook to sync events with external IVR processors. Track latency and success rates for normalize efficiency. Generate audit logs for telephony governance.
import json
from dataclasses import dataclass, asdict
@dataclass
class NormalizationMetrics:
flow_id: str
latency_ms: float
success: bool
timestamp: str
audit_trail: str
def register_normalization_webhook(
base_url: str,
access_token: str,
callback_url: str,
flow_id: str
"""Creates a Pure Connect webhook to sync normalized DTMF sequences with external processors."""
url = f"{base_url}/api/v2/webhooks"
headers = {
webhook_config = {
"name": f"dtmf-normalizer-sync-{flow_id}",
"url": callback_url,
"enabled": True,
"eventTypes": ["ivr.flow.completed", "ivr.dtmf.collected"],
"filters": {
"flowId": flow_id
"headers": {
"X-Normalization-Source": "pure-connect-patch"
response = client.post(url, json=webhook_config, headers=headers)
return response.json()
def record_normalization_audit(metrics: NormalizationMetrics) -> None:
"""Generates normalizing audit logs for telephony governance."""
log_entry = json.dumps(asdict(metrics), indent=2)
logger.info("NORMALIZATION_AUDIT: %s", log_entry)
# In production, ship to SIEM, CloudWatch, or Pure Connect analytics pipeline
The webhook registers against /api/v2/webhooks. It filters events by flowId to align with the normalized sequence. The NormalizationMetrics dataclass captures latency, success state, and audit trails. Required scope: webhooks:write.
The following script combines authentication, payload construction, validation, atomic PATCH, webhook registration, and metrics tracking. Replace placeholder credentials before execution.
import os
import logging
import httpx
from typing import Dict, Any
class DtmfSequenceNormalizer:
def __init__(self, instance: str, client_id: str, client_secret: str):
self.base_url = f"https://{instance}.pure.cloud.nice.com"
self.auth = PureConnectAuth(instance, client_id, client_secret, "ivrfloes:read ivrfloes:write webhooks:write telephony:read")
def run_normalization_pipeline(self, flow_id: str, input_sequence: str, callback_url: str) -> Dict[str, Any]:
access_token = self.auth.get_token()
# Step 1: Construct payload
config = DtmfNormalizationConfig(
sequence_reference="main-menu-dtmf",
max_digits=12,
inter_digit_timeout_ms=2500,
gap_insertion_threshold_ms=1800,
standardize_directive="trim_and_validate"
payload = construct_normalization_payload(config)
# Step 2: Validate and truncate
start_time = time.time()
is_valid = validate_dtmf_sequence(input_sequence, config.max_digits, snr_threshold_db=22.0)
if not is_valid:
logger.warning("Validation failed. Applying truncation fallback.")
normalized_sequence = verify_format_and_truncate(input_sequence, config.max_digits)
# Step 3: Atomic PATCH
patch_result = apply_normalization_patch(
self.base_url, access_token, flow_id, payload
success = True
logger.error("PATCH failed: %s - %s", e.response.status_code, e.response.text)
success = False
patch_result = {"error": str(e)}
# Step 4: Webhook sync and audit
if success:
webhook_result = register_normalization_webhook(
self.base_url, access_token, callback_url, flow_id
logger.error("Webhook registration failed: %s", e)
webhook_result = {"error": str(e)}
else:
webhook_result = {"skipped": "patch_failed"}
metrics = NormalizationMetrics(
flow_id=flow_id,
sequence_reference=config.sequence_reference,
latency_ms=round(latency_ms, 2),
success=success,
timestamp=time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
audit_trail=f"Input:{input_sequence} -> Normalized:{normalized_sequence}"
record_normalization_audit(metrics)
"patch_result": patch_result,
"webhook_result": webhook_result,
"metrics": asdict(metrics),
"normalized_sequence": normalized_sequence
INSTANCE = os.getenv("PURE_CONNECT_INSTANCE")
CLIENT_ID = os.getenv("PURE_CONNECT_CLIENT_ID")
CLIENT_SECRET = os.getenv("PURE_CONNECT_CLIENT_SECRET")
FLOW_ID = os.getenv("PURE_CONNECT_FLOW_ID")
CALLBACK_URL = os.getenv("EXTERNAL_IVR_CALLBACK_URL")
normalizer = DtmfSequenceNormalizer(INSTANCE, CLIENT_ID, CLIENT_SECRET)
result = normalizer.run_normalization_pipeline(FLOW_ID, "1*2#A999", CALLBACK_URL)
print(json.dumps(result, indent=2))
The script executes the full normalization pipeline. It handles authentication, validation, atomic updates, webhook registration, and audit logging. It requires environment variables for credentials and identifiers.
- Cause: Expired OAuth token, invalid client credentials, or missing
ivrfloes:writescope. - Fix: Verify client secret rotation. Ensure the scope string includes
ivrfloes:write. Add token refresh logic before expiration. - Code fix: The
PureConnectAuthclass caches tokens and refreshes whenexpires_inapproaches. Callauth.get_token()before each API interaction.
Error: 409 Conflict
- Cause: Concurrent PATCH operations on the same IVR flow version. Pure Connect enforces version control on flow updates.
- Fix: Retrieve the current flow version via
GET /api/v2/ivrfloes/{id}, include the version in the PATCH header, or use Pure Connect merge semantics instead of full replace. - Code fix: Add
If-Matchheader with the ETag from the GET response. Implement retry with version bump on 409.
Error: 422 Unprocessable Entity
- Cause: Invalid DTMF characters,
maxDigitsexceeding carrier limits, or malformed JSON Patch structure. - Fix: Validate sequences against ITU-T E.181 before submission. Ensure
maxDigitsstays within 1-50. Verify JSON Patchop,path, andvaluefields. - Code fix: The
validate_dtmf_sequenceandverify_format_and_truncatefunctions prevent illegal characters and overflow. Checkresponse.json()for field-level validation errors.
- Cause: Exceeding Pure Connect rate limits during bulk normalization or rapid PATCH cycles.
- Fix: Implement exponential backoff. Throttle requests to 10-15 per second per tenant. Batch normalization where possible.
- Code fix: The
@retrydecorator onapply_normalization_patchhandles 429 automatically withwait_exponential. MonitorRetry-Afterheaders for precise backoff timing.
