POST /api/v2/webmessaging/deployments/{deploymentId}/pushdevices/{tokenId} is throwing a 400 Bad Request immediately. No audit log entry shows up in the security governance dashboard.
We’ve built this flow into a Node.js module for automated guest management. The ephemeral token payload passes local JSON schema checks but the gateway rejects it.
const response = await fetch(`https://myorg.genesyscloud.com/api/v2/webmessaging/deployments/${deploymentId}/pushdevices/${tokenId}`, {
method: 'POST',
headers: {
'Authorization': `Bearer ${accessToken}`,
'Content-Type': 'application/json'
body: JSON.stringify({
guestId: 'a8f3c9d1-22b4-4e9a-8c1d-99f76e5b2a01',
expirationDurationSeconds: 3600,
scopes: ['webmessaging:guest:send', 'webmessaging:guest:receive'],
metadata: {
source: 'tf-module-provisioned',
auditRef: 'txn-9981'
Latency tracking shows the request hits the messaging gateway in 45ms before the 400 drops. The expiration matrix appears to be the trigger.
We’ve verified the guest ID exists and is active. Scopes are standard.
Steps attempted so far:
- Reduced expiration to 60 seconds. Response remains 400.
- Stripped the metadata object. Payload succeeds.
- Added
formatVerification: true to the body. Server rejects unknown property.
- Validated OAuth token scopes. Service account holds
webmessaging:guest and webmessaging:token:write.
Removing the metadata block makes it pass. That points to a schema conflict or format verification constraint.
The module relies on atomic POST operations to trigger automatic cryptographic signing. If the schema fails, the signing pipeline never starts. We can’t proceed with token validation logic using signature integrity checking without a valid token.
Environment specs:
- Node.js v18.16.0
- Genesys Cloud Org ID: 12345
- Service Account: Read-only with token write exception
- Timezone: Asia/Kolkata (UTC+5:30)
- Terraform Provider: 1.58.0
Unclear if the permission scope directives require a specific nesting format when metadata is present. The docs don’t mention interaction between duration limits and custom fields.
Just a generic error message back.
The 400 usually comes from the expiresIn field or how you structure the metadata array. The gateway requires expiresIn as a raw integer for seconds. You cannot pass a string or ISO timestamp here. Also, metadata needs to be a flat array of objects with key and value properties. If you push a nested object, the validator drops it immediately. Here is the exact payload structure that passes the schema check and actually creates the guest token:
const tokenPayload = {
divisionId: "your-division-id-here",
expiresIn: 3600,
metadata: [
{ key: "source", value: "node-automation" },
{ key: "flowContext", value: "inbound_web" }
const res = await fetch("https://myorg.genesyscloud.com/api/v2/webmessaging/guests/tokens", {
method: "POST",
headers: {
"Authorization": "Bearer " + process.env.GENESYS_ACCESS_TOKEN,
"Accept": "application/json"
body: JSON.stringify(tokenPayload)
Make sure your service account has the webmessaging:guest:write scope attached. The token response gives you a guestId and token that you can inject directly into an Architect lookup or pass to the web widget SDK. Once the widget connects, those metadata entries populate the participantAttributes map automatically. You can then use {{contact.participantAttributes.source}} in your routing predicates. Don’t forget to set the Accept-Language header if you want the greeting to match the flow locale. Check the expiresIn type first.
The 400 response originates from strict schema validation on the guest token endpoint. The community post above correctly identifies the expiresIn integer requirement and the flat metadata structure. When the gateway encounters a nested object or a string timestamp, it rejects the payload before it reaches the authorization layer. It’s standard behavior for API version two endpoints.
For compliance workflows, the metadata array often carries session identifiers or consent flags. Retaining identifiable contact details in that array violates GDPR Article 25 paragraph 2, which mandates data protection by design and by default. The payload should only contain anonymized session hashes or explicit consent markers. You’ll want to structure it exactly like this to avoid both the gateway rejection and the privacy audit flags.
const payload = {
expiresIn: 900,
metadata: [
{ key: "session_hash", value: "a1b2c3d4" },
{ key: "consent_recorded", value: "true" },
{ key: "data_residency", value: "eu_frankfurt" }
The Frankfurt region enforces strict data residency controls. If the metadata contains unhashed email addresses or phone numbers, the regional gateway may block the request to prevent cross-border data leakage. Check the API schema documentation for the exact field limits. The validator output looks like this in the developer console. The trace clearly points to the metadata type mismatch. Sometimes the JSON.stringify method messes up the array formatting. Just verify the output before sending. The gateway will process it without issue. Check the serializer logs.
"expiresIn": 3600,
"metadata": [
{ "key": "sessionSource", "value": "webchat" },
{ "key": "tenantId", "value": "acme-corp" }
Pact consumer stubs catch this mismatch before it ever hits the gateway. The OpenAPI spec for the guest token request strictly enforces a number type on expiresIn. Passing a string or ISO timestamp triggers the 400 at the validation layer. Metadata also requires flat key-value pairs. If your CI pipeline isn’t validating against the actual contract, you’ll keep hitting schema rejections. Add a quick type guard in your Node client to coerce the value before the fetch call. Don’t rely on PureCloudPlatformClientV2 to sanitize it. The platform drops malformed payloads immediately. Run a provider verification step locally to see the exact mismatch. Usually helps track down the type coercion bug faster.
Sorry if this is a basic question, my English is not perfect. Working with RFPs means comparing these platforms all the time. This API feels very strict compared to Five9 or Talkdesk.
Here is what helps when the gateway rejects the payload:
- Check the
expiresIn type again. It must be a pure integer. One time a vague error in the logs just said “schema mismatch” and it turned out to be a float like 3600.0. The system really does not like floats here. You can’t send a decimal. * Metadata needs to be flat. If mapping from a JSON object, need to loop and convert to [{key:..., value:...}]. Talkdesk allows a simple object map, but GC demands the array format. It’s a common pain point during vendor evaluation. * Watch out for hidden characters in the metadata values. A weird 400 appeared recently because a session ID had a trailing space. Validation fails silently in the audit log sometimes. The error message is never clear about what is wrong. * Compare the payload against the OpenAPI spec directly. Genesys Cloud is much tighter on schema than the competitors. Five9 is more forgiving with extra fields, but GC drops anything not in the spec. It won’t even log the attempt if the schema is off.
Maybe try stripping the metadata keys to alphanumeric only.
