Node.js consumer dropping Kafka messages for GC analytics stream
stuck on a node.js consumer that misses streaming analytics notification events pushed to kafka. the gc python ci/cd scripts work fine, but this consumer drops packets when throughput spikes. here is the consumer config:
 groupId: 'gc-analytics',
 fromBeginning: false,
 sessionTimeout: 10000
is there a specific offset commit strategy i need to apply to avoid data loss during high-volume event bursts from the platform api?
My usual workaround is to switching from auto-commit to explicit manual commits in the consumer configuration. The default behavior often commits offsets before the message processing logic completes, which causes data loss during throughput spikes.
In n8n workflows, I enforce this by ensuring the HTTP node handles the payload before the next offset is acknowledged. For a Node.js consumer, set autoCommit: false and manually commit after successful processing. This aligns with how I handle GC analytics streams in self-hosted pipelines to prevent silent drops.
const consumer = new KafkaConsumer({
 autoCommit: false, // Critical for high-volume bursts
consumer.on('message', async (msg) => {
 await processAnalyticsPayload(msg.value);
 await msg.commit(); // Explicit commit only after success
 } catch (err) {
 // Handle error, potentially requeue or log to dead letter queue
 console.error('Processing failed:', err);
This ensures that the offset is only advanced when the platform API data is fully handled.
have you tried adjusting the max.poll.interval.ms? manual commits are fine but if your node process hangs during heavy analytics parsing, the consumer gets kicked out of the group anyway. set it higher than your worst case processing time.
 maxPollIntervalMs: 600000, // 10 mins
 autoCommit: false
If I remember correctly, Node.js event loop blocking is the real issue here, not just offset commits. You are likely parsing large JSON payloads synchronously while the poll interval ticks, causing the consumer to drop out of the group.
Use async processing with a bounded concurrency limit to prevent backpressure. This Python pattern using asyncio.Semaphore illustrates the control flow you need to replicate in Node to ensure offsets are only committed after the event loop has actually processed the data.
import asyncio
import purecloudplatformclientv2 as pc2
# Simulate bounded concurrency to prevent event loop starvation
async def process_analytics_batch(events, semaphore):
 async with semaphore:
 for event in events:
 # Heavy parsing logic here
 await asyncio.sleep(0.1)
 # Only commit offset after successful batch processing
 print("Offset committed for batch")
semaphore = asyncio.Semaphore(10) # Limit concurrent processing tasks
asyncio.run(process_analytics_batch(large_payload, semaphore))
If I remember correctly, error: 429 too many requests. setting autoCommit: false fixes the offset but not the throughput spike. you need to handle backpressure. use a semaphore in node.js to limit concurrent processing. if you don’t, the event loop blocks and kafka kicks you out. check your pre-request scripts for proper oauth handling too.
