need help with Java TServer library 5.0
Hi there,
has anybody developed using tha java TServer 5.0 api?
How do you implemente an agent login into a queue? Normally to make and answer calls through TServer I would use ts.RegisterAddress, but that doesn’t log the user into any queue. I found a function that is ts.AgentLogin but I dunno which parameters I need to provide
AgentLogin
public int AgentLogin(
String queue,
String dn,
int agent_type,
String agent_id,
String passwd,
int workmode,
TKVList reasons,
TKVList extensions)
what is agent_type? what is workmode? do I still need to call ts.registerAddres before or no? Any help greatly appreciated.
A.
The information you have to provide for AgentLogin depends on the PBX that you are using?
regards.
