I am using voice platform sdk 7.6, I would need some help in regards of the logical scenario:
When the agent logs/registered, i need to fetch all the unavailable reason codes configured on the switch T server.
A sample program implemented for Ayava AIC:
public java.util.Map<String, String> retrieveUnavailableReasonCodes() throws CtiException {
java.util.Map<String, String> reasonCodes = new java.util.TreeMap<String, String> ();
CodesList cl = ctiSession.getAuxReasonCodes();
Collection col = (Collection)cl.getCodes();
Iterator iter = col.iterator();
while(iter.hasNext()) {
Code code = (Code)iter.next();
reasonCodes.put(code.getId(), code.getDisplayName());
return reasonCodes;
Here we use a “ctiSession” object to get the AuxReason codes.. Could you please guide me which genesys voice platform object would be helpfull in fetching the Reason Codes for unavailable configured in the genesys T server switch.
Could you kindly provide me a sample program for the following approach.
Are you really sure the code you posted is the right one? I’m not.. Why?
1/ You wrote that you need code for Voice Platform SDK but posted code uses Agent Desktop .NET Toolkit SDK (BTW that SDK is EOL now).
2/ You wrote that you want to get list of reason codes configured (enabled) on T-Server. Again, the code you posted here won’t give you such information…
3/ Last note - agent:DnEventReason won’t return you current AUX code - it is enum with 3 values - LOGGED_IN, STATUS_CHANGED, INFO_CHANGED.
