Need help on ivr driver development
hi, i am developing an ivr driver ap for local chinese ivr, and got the following error.
when i call ilConnectionOpenConfigServer(), my ivr driver just hang there and no return.
here is the iver driver log:
IVR Library current working directory is D:\Genesys_Connect\ivr_sample\ivr_sampl
e\VC6\GTest
IVR Library did not find the “ivrlibrary.ini” file, programmed defaults will be
used
11/06/08 10:14:46.765 AP>ffffffff|AVPIVR::::: Initiate IVR=AVPIVR
11/06/08 10:14:46.765 AP<ffffffff|AVPIVR::::: Initiate rc=TRUE ILibrary Version
7.5.004.00
11/06/08 10:14:46.765 AP>ffffffff|AVPIVR:::192.168.8.98:2020: ConnectionOpen co
nfig server host=192.168.8.98, port=2020, app name=IVRDriver, time out=5000
11/06/08 10:14:46.937 FL|ffffffff|AVPIVR:::192.168.8.98:2020: Initializing logg
ing with host=192.168.8.98, port=2020, application=IVRDriver, IVR=AVPIVR
Connecting to the log server
Common: error -instance is not initialized
ERROR: conn_delete_timer(0), timer not found
11/06/08 10:14:47.140 FL|ffffffff|AVPIVR:::192.168.8.98:2020: Opened initial lo
gging with host=192.168.8.98, port=2020, application=IVRDriver
addp-trace off
(addp_xconfig) local OFF, remote OFF, trace off
11/06/08 10:14:47.328 FL|ffffffff|AVPIVR:::192.168.8.98:2020: Opened connection
to config server socket=1944, host=192.168.8.98, port=2020, application=IVRDriv
er
11/06/08 10:14:47.343 FL|ffffffff|AVPIVR:::192.168.8.96:9101: Created socket AV
PIVR:9101:192.168.8.96
11/06/08 10:14:47.343 FL|ffffffff|AVPIVR:::192.168.8.96:9101: Checking socket w
ith port = 9101, host = 192.168.8.96 against the existing socket list
11/06/08 10:14:47.359 FL|ffffffff|AVPIVR::::: List of sockets a
vailable for use:
socket name = AVPIVR:9101:192.168.8.96, port = 9101, host = 192.168.8.96
10:14:47.359 Trc 04112 The Log Output of type ‘stdout’ has been created and open
ed
10:14:47.359 Trc 04112 The Log Output of type ‘c:\ivr_driver_log’ has been creat
ed and opened
11/06/08 10:14:47.375 FL|ffffffff|AVPIVR::::: Agent List table size=0
11/06/08 10:14:47.375 FL|ffffffff|AVPIVR::::: Configuration definitions:
I-Library Version… = 7.5.004.00
IVR Name… = AVPIVR
Cfg Mgr Host… = 192.168.8.98
Cfg Mgr Port… = 2020
App Name… = IVRDriver
load_sharing_iservers… = 192.168.8.96:9101
DriverRetryTimeout… = 30
DTD version… = 4.0
log_print_date… = yes
log_print_hb… = no
log_print_name… = yes
log_print_recv… = yes
log_print_send… = yes
log_print_time… = yes
log_print_time_ms… = yes
log_print_timeouts… = no
log_print_udata… = no
log_print_login_requests. = yes
log_print_driver_selector = 0
time_recon_is… = 2000
socket_activity_timer… = 20000
LegacyMode… = true
DriverIgnoreReady… = false
verbose… = all
log_print_level… = xml
DriverReadyWorkMode… = ManualIn
all… = c:\ivr_driver_log,stdout
11/06/08 10:14:47.421 FL|ffffffff|AVPIVR::::: Obtained LCA info host=192.168.8.
10:14:47.437 Trc 04110 Option ‘MessageFile’ has been set to the value ‘ivrlibrar
y.lms’
10:14:47.437 Std 04107 Unable to load Log Messages file ‘ivrlibrary.lms’, error
code 30
11/06/08 10:14:47.437 FL|ffffffff|AVPIVR::::: Configured logging host=192.168.8
It’s hard to say what is wrong based on provided log. Could you post here snippet of your code? What operating system platform does your IVR use - Windows, Solaris etc.?
