Mute NICE CXone Web Messaging Agent Participants via Python SDK
You will build a production-grade Python module that mutes agent participants in NICE CXone Web Messaging conversations using atomic PATCH operations. The code constructs validated mute payloads, enforces duration limits, verifies conversation locks and escalation rules, triggers guest notifications, syncs state with external quality monitors via webhooks, tracks latency and success rates, and generates structured audit logs.
  • NICE CXone OAuth 2.0 Client Credentials grant type with scopes: messaging:participants:write, messaging:conversations:read, messaging:messages:write, quality:analytics:read
  • NICE CXone Python SDK (cxone) v2.3+
  • Python 3.9+ runtime
  • External dependencies: requests, pydantic, tenacity, logging
  • Active CXone tenant subdomain and valid client credentials
NICE CXone uses a standard OAuth 2.0 Client Credentials flow. The SDK handles token caching and automatic refresh, but you must configure the initial credentials correctly. The following code initializes the SDK with explicit token management and scope verification.
import os
import logging
from cxone import ApiClient, Configuration
from cxone.apis.messaging_api import MessagingApi
from cxone.apis.conversations_api import ConversationsApi
logger = logging.getLogger("cxone_muter")
def initialize_cxone_client() -> tuple[MessagingApi, ConversationsApi]:
    """Initialize CXone SDK with OAuth client credentials and required scopes."""
    tenant_subdomain = os.getenv("CXONE_TENANT_SUBDOMAIN")
    client_id = os.getenv("CXONE_CLIENT_ID")
    client_secret = os.getenv("CXONE_CLIENT_SECRET")
    if not all([tenant_subdomain, client_id, client_secret]):
        raise ValueError("Missing required CXone environment variables.")
    configuration = Configuration(
        host=f"https://{tenant_subdomain}.api.cxone.com",
        client_id=client_id,
        client_secret=client_secret,
        scopes=["messaging:participants:write", "messaging:conversations:read", "messaging:messages:write"]
    api_client = ApiClient(configuration)
    # Force initial token fetch to validate credentials early
    api_client.refresh_access_token()
    messaging_api = MessagingApi(api_client)
    conversations_api = ConversationsApi(api_client)
    logger.info("CXone SDK initialized successfully with OAuth token.")
    return messaging_api, conversations_api
Muting requires a strictly typed payload containing the participant reference, agent matrix context, and mute directive. You must validate the mute duration against CXone messaging constraints (maximum 300 seconds for web messaging) and verify the state transition is legal. Pydantic enforces these constraints before any network call.
import pydantic
from typing import Optional
class MuteDirective(pydantic.BaseModel):
    muted: bool
    mute_duration_seconds: int = pydantic.Field(ge=1, le=300)
    state: str = pydantic.Field(pattern=r"^(active|muted|paused|closed)$")
    supervisor_approved: bool = False
class ParticipantReference(pydantic.BaseModel):
    participant_id: str
    conversation_id: str
    role: str = pydantic.Field(pattern=r"^(agent|guest|bot|supervisor)$")
class AgentMatrix(pydantic.BaseModel):
    skill_group: str
    queue_name: str
    escalation_level: int = pydantic.Field(ge=0, le=5)
class MutePayload(pydantic.BaseModel):
    directive: MuteDirective
    reference: ParticipantReference
    matrix: AgentMatrix
    reason_code: str = "quality_review"
    def validate_transition(self) -> None:
        if self.directive.muted and self.directive.state != "muted":
            raise ValueError("State must be 'muted' when directive.muted is true.")
        if self.directive.mute_duration_seconds > 300:
            raise ValueError("Web messaging mute duration cannot exceed 300 seconds.")
        if self.reference.role != "agent":
            raise ValueError("Only agent participants can be muted programmatically.")
Step 2: Conversation Lock Checking and Escalation Rule Verification
Before issuing a mute command, you must verify the conversation is not locked by a supervisor and that escalation rules permit the action. CXone returns conversation state via GET /api/v2/messaging/conversations/{conversationId}. The following code checks lock status and escalation thresholds.
def verify_conversation_state(conversations_api: ConversationsApi, conversation_id: str, escalation_level: int) -> bool:
    """Check conversation lock status and escalation rules before muting."""
        response = conversations_api.get_conversation(conversation_id)
        logger.error("Failed to fetch conversation state: %s", e)
        raise
    conversation_state = response.state
    is_locked = getattr(response, "locked", False)
    if is_locked:
        logger.warning("Conversation %s is locked. Supervisor approval required.", conversation_id)
        return False
    if escalation_level > 2 and conversation_state in ["escalated", "supervisor_review"]:
        logger.warning("Conversation %s is in escalation state. Mute blocked by policy.", conversation_id)
        return False
    return True
Step 3: Atomic PATCH Operation with State Transition and Retry Logic
The mute action executes as an atomic PATCH /api/v2/messaging/participants/{participantId}. CXone enforces optimistic concurrency via the if-match header or state validation. You must implement exponential backoff for 429 rate limits and handle 409 state transition conflicts.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import requests
class CxoneRateLimitError(Exception):
    pass
@retry(
    stop=stop_after_attempt(3),
    wait=wait_exponential(multiplier=1, min=2, max=10),
    retry=retry_if_exception_type((CxoneRateLimitError, requests.exceptions.ConnectionError))
def execute_mute_patch(messaging_api: MessagingApi, payload: MutePayload) -> dict:
    """Execute atomic mute PATCH with retry logic and full HTTP cycle visibility."""
    participant_id = payload.reference.participant_id
    request_body = payload.directive.model_dump()
    # Log full HTTP request cycle for debugging
    logger.info("PATCH /api/v2/messaging/participants/%s | Body: %s", participant_id, request_body)
    logger.info("Headers: Authorization=Bearer *** | Content-Type=application/json | X-Request-ID=%s",
                time.time())
        # SDK method maps to PATCH /api/v2/messaging/participants/{participantId}
        response = messaging_api.patch_participant(participant_id, body=request_body)
        # Log full HTTP response cycle
        logger.info("Response Status: 200 OK | Body: %s", response.to_dict())
        return response.to_dict()
        status_code = getattr(e, "status", 0)
        if status_code == 429:
            logger.warning("Rate limit 429 encountered. Retrying...")
            raise CxoneRateLimitError("429 Too Many Requests")
        elif status_code == 409:
            raise ValueError(f"State transition conflict 409: {e.body}")
        elif status_code == 422:
            raise ValueError(f"Validation failure 422: {e.body}")
        else:
            raise
Step 4: Guest Notification Triggers and Webhook Synchronization
After a successful mute, CXone requires explicit guest notification to maintain transparency. You send a system message to the guest participant and POST to an external quality monitor webhook to sync the mute event.
def notify_guest_and_sync(messaging_api: MessagingApi, conversation_id: str, webhook_url: str) -> dict:
    """Trigger guest notification and sync with external quality monitor."""
    # Send system message to guest via POST /api/v2/messaging/messages
    message_body = {
        "conversationId": conversation_id,
        "type": "text",
        "content": {
            "text": "Your agent has been temporarily muted for quality review. You may continue typing."
        "from": {"type": "system"}
        msg_response = messaging_api.post_message(body=message_body)
        logger.info("Guest notification sent: %s", msg_response.to_dict())
        logger.error("Failed to send guest notification: %s", e)
    # Sync with external quality monitor via webhook
    webhook_payload = {
        "event": "participant_muted",
        "conversation_id": conversation_id,
        "timestamp": time.time(),
        "action": "mute_enforced",
        "compliance_flag": True
        requests.post(webhook_url, json=webhook_payload, timeout=5)
        logger.info("Quality monitor webhook synchronized successfully.")
    except requests.RequestException as e:
        logger.error("Webhook sync failed: %s", e)
    return {"notification_sent": True, "webhook_synced": True}
Step 5: Latency Tracking, Success Rate Calculation, and Audit Logging
Production muting operations require telemetry. You track wall-clock latency, calculate rolling success rates, and write structured JSON audit logs for governance compliance.
import json
class MuteTelemetry:
    def __init__(self):
        self.success_count = 0
        self.failure_count = 0
        self.latencies = []
        self.audit_log_path = "cxone_mute_audit.log"
    def record_attempt(self, success: bool, latency_ms: float, payload: MutePayload) -> None:
        self.latencies.append(latency_ms)
        if success:
            self.success_count += 1
        else:
            self.failure_count += 1
        audit_entry = {
            "participant_id": payload.reference.participant_id,
            "conversation_id": payload.reference.conversation_id,
            "success": success,
            "duration_seconds": payload.directive.mute_duration_seconds,
            "supervisor_approved": payload.directive.supervisor_approved,
            "success_rate": round(self.success_count / (self.success_count + self.failure_count) * 100, 2) if (self.success_count + self.failure_count) > 0 else 0.0
        with open(self.audit_log_path, "a") as f:
            f.write(json.dumps(audit_entry) + "\n")
        logger.info("Audit log written: %s", audit_entry)
The following module combines all components into a single, runnable ParticipantMuter class. Replace the environment variables with your CXone credentials before execution.
import os
import logging
import requests
import pydantic
# --- Models ---
    muted: bool
    participant_id: str
    skill_group: str
    queue_name: str
    matrix: AgentMatrix
    pass
class ParticipantMuter:
    def __init__(self, tenant_subdomain: str, client_id: str, client_secret: str, webhook_url: str):
        self.messaging_api = MessagingApi(api_client)
        self.conversations_api = ConversationsApi(api_client)
        self.latencies = []
    def _verify_conversation_state(self, conversation_id: str, escalation_level: int) -> bool:
            response = self.conversations_api.get_conversation(conversation_id)
            raise
        if is_locked:
            return False
        if escalation_level > 2 and response.state in ["escalated", "supervisor_review"]:
            return False
        return True
    @retry(stop=stop_after_attempt(3), wait=wait_exponential(multiplier=1, min=2, max=10), retry=retry_if_exception_type((CxoneRateLimitError, requests.exceptions.ConnectionError)))
    def _execute_mute_patch(self, payload: MutePayload) -> dict:
            response = self.messaging_api.patch_participant(participant_id, body=request_body)
            raise
    def _notify_and_sync(self, conversation_id: str) -> dict:
        message_body = {
            "type": "text",
            "content": {"text": "Your agent has been temporarily muted for quality review."},
            self.messaging_api.post_message(body=message_body)
            logger.error("Guest notification failed: %s", e)
            requests.post(self.webhook_url, json={"event": "participant_muted", "conversation_id": conversation_id}, timeout=5)
    def mute_agent(self, payload: MutePayload) -> dict:
            payload.validate_transition()
            if not self._verify_conversation_state(payload.reference.conversation_id, payload.matrix.escalation_level):
                raise ValueError("Conversation state or escalation rules block mute operation.")
            result = self._execute_mute_patch(payload)
            sync_result = self._notify_and_sync(payload.reference.conversation_id)
            audit = {
                "success": True,
            with open("cxone_mute_audit.log", "a") as f:
                f.write(json.dumps(audit) + "\n")
            return {"status": "success", "mute_result": result, "sync": sync_result, "telemetry": audit}
            audit = {
                "success": False,
                "error": str(e),
            raise
# --- Execution ---
    muter = ParticipantMuter(
        tenant_subdomain=os.getenv("CXONE_TENANT_SUBDOMAIN"),
        client_id=os.getenv("CXONE_CLIENT_ID"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET"),
        webhook_url="https://quality-monitor.example.com/api/v1/events"
    test_payload = MutePayload(
        directive=MuteDirective(muted=True, mute_duration_seconds=120, state="muted", supervisor_approved=True),
        reference=ParticipantReference(participant_id="agent-uuid-12345", conversation_id="conv-uuid-67890", role="agent"),
        matrix=AgentMatrix(skill_group="support_tier2", queue_name="web_messaging_main", escalation_level=1)
        result = muter.mute_agent(test_payload)
        print("Mute operation completed:", result)
        print("Mute operation failed:", e)
  • Cause: Expired OAuth token or invalid client credentials. The SDK cache may hold a stale token.
  • Fix: Force token refresh before the API call using api_client.refresh_access_token(). Verify the CXONE_CLIENT_ID and CXONE_CLIENT_SECRET environment variables match the registered OAuth application in the CXone admin portal.
  • Code: Add api_client.refresh_access_token() immediately before self.messaging_api.patch_participant().
Error: 403 Forbidden
  • Cause: Missing OAuth scope. Muting requires messaging:participants:write. Reading conversation state requires messaging:conversations:read.
  • Fix: Update the OAuth application scopes in CXone and re-authenticate. Ensure the Configuration object includes all required scopes.
  • Code: Verify scopes=["messaging:participants:write", "messaging:conversations:read", "messaging:messages:write"] in the Configuration constructor.
Error: 409 Conflict
  • Cause: State transition conflict. The participant is already muted, paused, or the conversation state changed between validation and execution.
  • Fix: Implement idempotent checks. If the participant is already muted, return success without retrying. Use the if-match header with the participant ETag if available.
  • Code: Check response.state before calling patch_participant. Skip PATCH if current_state == "muted".
Error: 422 Unprocessable Entity
  • Cause: Payload schema validation failure. Duration exceeds 300 seconds, state mismatch, or invalid participant role.
  • Fix: Validate payloads locally using Pydantic before network transmission. Ensure mute_duration_seconds stays within 1-300 and state matches muted.
  • Code: The payload.validate_transition() method catches these errors before the HTTP request.
  • Cause: CXone rate limit exceeded. Web messaging APIs enforce per-tenant and per-endpoint throttling.
  • Fix: Use exponential backoff. The tenacity retry decorator handles this automatically. Reduce batch mute frequency if processing multiple participants.
  • Code: The @retry decorator on _execute_mute_patch implements wait_exponential(multiplier=1, min=2, max=10).
