Multiplexing Genesys Cloud WebSocket subscriptions by developing a Go connector that establishes a single persistent connection, registers interest in multiple routing and media event streams, demultiplexes incoming frames using topic routing tables, and forwards filtered payloads to internal message queues via the SDK
- A Go service that opens one persistent WebSocket to Genesys Cloud and receives real-time routing and media events without opening multiple network sockets.
- This uses the Genesys Cloud WebSocket API (
/api/v2/events) and theplatformclientgoSDK for OAuth token management and REST fallback. - The implementation uses Go 1.21+ with
gorilla/websocketfor transport and standard channels as internal message queues.
- OAuth client type: Confidential Client (Client Credentials) with scopes:
event:read,routing:queue:read,analytics:conversation:read - SDK version:
github.com/mypurecloud/platformclientgo v3.36.0 - Language/runtime: Go 1.21 or later
- External dependencies:
github.com/gorilla/websocket,encoding/json,net/http,context,sync,time
Genesys Cloud WebSocket endpoints require a valid OAuth 2.0 Bearer token. The token must contain the event:read scope to permit subscription to real-time event streams. The Go SDK provides client.AuthClient to handle the client credentials flow. You must cache the token and refresh it before expiration to prevent WebSocket handshake failures.
The following function obtains a token, caches it with an expiration buffer, and returns the raw string. It handles network failures and 401 responses from the token endpoint.
package main
import (
"context"
"fmt"
"log"
"sync"
"time"
"github.com/mypurecloud/platformclientgo"
"github.com/mypurecloud/platformclientgo/configuration"
"github.com/mypurecloud/platformclientgo/client"
type TokenCache struct {
mu sync.RWMutex
token string
expiresAt time.Time
func NewTokenCache() *TokenCache {
return &TokenCache{}
func (tc *TokenCache) GetToken(ctx context.Context, env, clientID, clientSecret string) (string, error) {
tc.mu.RLock()
if tc.token != "" && time.Until(tc.expiresAt) > 5*time.Minute {
token := tc.token
tc.mu.RUnlock()
return token, nil
tc.mu.RUnlock()
tc.mu.Lock()
defer tc.mu.Unlock()
return tc.token, nil
cfg := configuration.NewConfiguration()
cfg.BasePath = fmt.Sprintf("https://%s.mypurecloud.com", env)
authClient := client.NewAuthClient(cfg)
tokenResponse, _, err := authClient.GetClientCredentialsWithTimeout(ctx, clientID, clientSecret, []string{"event:read", "routing:queue:read", "analytics:conversation:read"})
if err != nil {
return "", fmt.Errorf("oauth token request failed: %w", err)
if tokenResponse == nil || tokenResponse.AccessToken == nil {
return "", fmt.Errorf("oauth response missing access token")
tc.token = *tokenResponse.AccessToken
tc.expiresAt = time.Now().Add(time.Duration(tokenResponse.ExpiresIn) * time.Second)
The buffer prevents race conditions where a token expires mid-stream. The mutex ensures only one goroutine fetches a new token at a time.
Step 1: Initialize SDK and Obtain Bearer Token
The SDK configuration sets the environment base path. The authentication client handles the POST to /api/v2/oauth/token. You must pass the environment string (e.g., us-east-1) and your client credentials. The response contains the access token and expiration duration.
type ConnectorConfig struct {
Environment string
ClientID string
ClientSecret string
QueueBufferSize int
func NewConnector(cfg ConnectorConfig) (*EventConnector, error) {
if cfg.QueueBufferSize <= 0 {
cfg.QueueBufferSize = 1024
tc := NewTokenCache()
token, err := tc.GetToken(context.Background(), cfg.Environment, cfg.ClientID, cfg.ClientSecret)
if err != nil {
return nil, fmt.Errorf("initial authentication failed: %w", err)
return &EventConnector{
cfg: cfg,
tokenCache: tc,
topicQueues: make(map[string]chan []byte),
subscriptionTopics: []string{
"routing:queue:member:status:changed",
"routing:conversation:wrapup:code:changed",
"analytics:conversation:detail",
"media:call:status:changed",
}, nil
The EventConnector struct holds the configuration, token cache, topic-to-channel routing table, and the list of topics to subscribe to. The routing table maps topic strings to buffered channels that act as internal message queues.
Step 2: Establish Persistent WebSocket Connection
Genesys Cloud WebSocket endpoints require the access token as a query parameter. The connection URL follows the pattern wss://{environment}.mypurecloud.com/api/v2/events?access_token={token}. You must configure ping/pong handlers to keep the connection alive and detect silent drops.
import (
"github.com/gorilla/websocket"
"net/url"
"time"
type EventConnector struct {
cfg ConnectorConfig
tokenCache *TokenCache
conn *websocket.Conn
topicQueues map[string]chan []byte
subscriptionTopics []string
closeChan chan struct{}
wg sync.WaitGroup
func (ec *EventConnector) Connect(ctx context.Context) error {
token, err := ec.tokenCache.GetToken(ctx, ec.cfg.Environment, ec.cfg.ClientID, ec.cfg.ClientSecret)
if err != nil {
return fmt.Errorf("failed to acquire token: %w", err)
u := url.URL{
Scheme: "wss",
Host: fmt.Sprintf("%s.mypurecloud.com", ec.cfg.Environment),
Path: "/api/v2/events",
RawQuery: "access_token=" + token,
dialer := websocket.Dialer{
HandshakeTimeout: 10 * time.Second,
header := http.Header{}
header.Set("User-Agent", "gen-ws-connector/1.0")
conn, resp, err := dialer.Dial(u.String(), header)
if err != nil {
if resp != nil {
if resp.StatusCode == 401 {
return fmt.Errorf("401 unauthorized: token expired or missing event:read scope")
if resp.StatusCode == 403 {
return fmt.Errorf("403 forbidden: client lacks WebSocket API permissions")
return fmt.Errorf("websocket dial failed: %w", err)
ec.conn = conn
ec.conn.SetReadLimit(1024 * 1024) // 1MB frame limit
ec.closeChan = make(chan struct{})
ec.wg.Add(1)
go ec.readLoop(ctx)
return nil
The dialer enforces a handshake timeout. The response status code is checked explicitly. A 401 indicates a scope or expiration issue. A 403 indicates the OAuth client lacks the WebSockets API permission in the Genesys Cloud admin console. The readLoop goroutine handles incoming frames asynchronously.
Step 3: Register Interest in Multiple Event Streams
After the connection opens, you must send a subscription message. Genesys Cloud expects a JSON object with a type field set to subscribe and a topics array containing the event stream identifiers. The server responds with a subscribed message confirming registration.
type SubscribeMessage struct {
Type string `json:"type"`
Topics []string `json:"topics"`
type ServerResponse struct {
Status string `json:"status,omitempty"`
Message string `json:"message,omitempty"`
func (ec *EventConnector) Subscribe(ctx context.Context) error {
if ec.conn == nil {
return fmt.Errorf("connection not established")
subMsg := SubscribeMessage{
Type: "subscribe",
Topics: ec.subscriptionTopics,
payload, err := json.Marshal(subMsg)
if err != nil {
return fmt.Errorf("marshal subscribe message failed: %w", err)
err = ec.conn.WriteMessage(websocket.TextMessage, payload)
if err != nil {
return fmt.Errorf("write subscribe message failed: %w", err)
// Wait for confirmation
ec.conn.SetReadDeadline(time.Now().Add(5 * time.Second))
_, msg, err := ec.conn.ReadMessage()
ec.conn.SetReadDeadline(time.Time{})
if err != nil {
return fmt.Errorf("read subscription response failed: %w", err)
var resp ServerResponse
if err := json.Unmarshal(msg, &resp); err != nil {
return fmt.Errorf("unmarshal subscription response failed: %w", err)
if resp.Type != "subscribed" {
return fmt.Errorf("unexpected subscription response: %s", resp.Message)
// Initialize routing table queues
for _, topic := range ec.subscriptionTopics {
ec.topicQueues[topic] = make(chan []byte, ec.cfg.QueueBufferSize)
return nil
The subscription call is synchronous until confirmation arrives. The routing table queues are initialized after successful subscription. Each topic gets a dedicated buffered channel. The buffer size prevents backpressure from blocking the read loop during high-volume periods.
Step 4: Demultiplex Frames Using Topic Routing Tables
Incoming frames arrive as JSON text messages. Each frame contains a topic field that identifies the event stream. The demultiplexer parses the frame, extracts the topic, looks it up in the routing table, and dispatches the raw payload to the corresponding channel.
type EventFrame struct {
Topic string `json:"topic"`
Timestamp string `json:"timestamp"`
Data json.RawMessage `json:"data"`
func (ec *EventConnector) readLoop(ctx context.Context) {
defer ec.wg.Done()
defer ec.conn.Close()
for {
select {
case <-ctx.Done():
return
case <-ec.closeChan:
return
default:
_, payload, err := ec.conn.ReadMessage()
if err != nil {
if websocket.IsUnexpectedCloseError(err, websocket.CloseGoingAway, websocket.CloseNormalClosure) {
log.Printf("WebSocket read error: %v", err)
// Trigger reconnection logic in production
return
var frame EventFrame
if err := json.Unmarshal(payload, &frame); err != nil {
log.Printf("Failed to parse event frame: %v", err)
if frame.Type != "data" {
queue, exists := ec.topicQueues[frame.Topic]
if !exists {
log.Printf("Received unregistered topic: %s", frame.Topic)
// Non-blocking send to prevent read loop stall
select {
case queue <- payload:
default:
log.Printf("Queue full for topic %s, dropping frame", frame.Topic)
The json.RawMessage type preserves the nested structure without premature unmarshaling. The routing table lookup uses a direct map access. The non-blocking channel send prevents consumer lag from blocking the WebSocket read goroutine. Dropped frames are logged for monitoring. In production, you would implement exponential backoff reconnection when readLoop exits due to network errors.
Step 5: Forward Filtered Payloads to Internal Message Queues
Consumer goroutines read from the topic channels, apply business filters, and forward valid payloads to downstream systems. Filtering reduces downstream processing load and prevents queue accumulation for irrelevant events.
type Consumer struct {
Topic string
Queue chan []byte
Handler func([]byte) error
func (ec *EventConnector) StartConsumers(ctx context.Context) {
for topic, queue := range ec.topicQueues {
ec.wg.Add(1)
go func(t string, q chan []byte) {
defer ec.wg.Done()
for {
select {
case <-ctx.Done():
return
return
case raw := <-q:
if err := ec.processEvent(t, raw); err != nil {
log.Printf("Consumer error for %s: %v", t, err)
}(topic, queue)
func (ec *EventConnector) processEvent(topic string, raw []byte) error {
if err := json.Unmarshal(raw, &frame); err != nil {
return fmt.Errorf("unmarshal failed: %w", err)
// Example filter: skip analytics events with empty conversation IDs
if topic == "analytics:conversation:detail" {
var convData struct {
ConversationID string `json:"conversationId"`
if err := json.Unmarshal(frame.Data, &convData); err == nil {
if convData.ConversationID == "" {
return nil // Filter out incomplete records
// Forward to internal queue or downstream service
log.Printf("Forwarding %s event: %s", topic, frame.Timestamp)
return nil
The consumer loop uses a select statement to respect context cancellation. The processEvent function demonstrates payload filtering. It unmarshals only the necessary fields to apply business rules. This approach avoids allocating full domain objects for events that will be discarded. The filter logic is topic-specific and can be extended with a strategy pattern for complex routing.
The following script combines authentication, connection, subscription, demultiplexing, and consumption into a single runnable module. Replace the environment variables with your Genesys Cloud credentials.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"os"
"sync"
"time"
mu sync.RWMutex
token string
expiresAt time.Time
tc.mu.RLock()
token := tc.token
tc.mu.RUnlock()
return token, nil
tc.mu.RUnlock()
tc.mu.Lock()
if err != nil {
cfg ConnectorConfig
wg sync.WaitGroup
Environment string
ClientID string
ClientSecret string
QueueBufferSize int
if err != nil {
cfg: cfg,
tokenCache: tc,
}, nil
func main() {
env := os.Getenv("GENESYS_ENV")
clientID := os.Getenv("GENESYS_CLIENT_ID")
clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
if env == "" || clientID == "" || clientSecret == "" {
log.Fatal("Missing GENESYS_ENV, GENESYS_CLIENT_ID, or GENESYS_CLIENT_SECRET")
cfg := ConnectorConfig{
Environment: env,
ClientID: clientID,
ClientSecret: clientSecret,
QueueBufferSize: 2048,
ec, err := NewConnector(cfg)
if err != nil {
log.Fatalf("Failed to initialize connector: %v", err)
ctx, cancel := context.WithCancel(context.Background())
defer cancel()
if err := ec.Connect(ctx); err != nil {
log.Fatalf("Failed to connect: %v", err)
if err := ec.Subscribe(ctx); err != nil {
log.Fatalf("Failed to subscribe: %v", err)
ec.StartConsumers(ctx)
log.Println("Connector running. Press Ctrl+C to exit.")
select {}
if err != nil {
u := url.URL{
Scheme: "wss",
if err != nil {
if resp != nil {
ec.conn = conn
ec.wg.Add(1)
go ec.readLoop(ctx)
return nil
if ec.conn == nil {
Type: "subscribe",
if err != nil {
if err != nil {
if err != nil {
return nil
defer ec.wg.Done()
for {
select {
case <-ctx.Done():
return
return
default:
if err != nil {
return
if !exists {
select {
default:
ec.wg.Add(1)
defer ec.wg.Done()
for {
select {
case <-ctx.Done():
return
return
case raw := <-q:
}(topic, queue)
return nil
return nil
- Cause: The OAuth token has expired, lacks the
event:readscope, or was generated with a different environment. - Fix: Verify the token expiration timestamp. Ensure the OAuth client credentials include
event:read. Refresh the token before the WebSocket handshake. - Code: The
TokenCacheenforces a 5-minute buffer. If errors persist, check the admin console for client scope assignments.
Error: 403 Forbidden
- Cause: The OAuth client is not authorized to use the WebSocket API, or the IP address is blocked by environment firewall rules.
- Fix: Navigate to the Genesys Cloud admin console, locate the OAuth client, and enable the
WebSocketsAPI permission. Verify network egress rules allowwss://traffic to*.mypurecloud.com. - Code: The dialer captures the HTTP response status. Log the status code immediately after
dialer.Dialto isolate authentication versus network failures.
Error: JSON Unmarshal Panic or Topic Mismatch
- Cause: Genesys Cloud updates event schemas, or the routing table lacks a newly subscribed topic.
- Fix: Use
json.RawMessagefor theDatafield to tolerate schema changes. Validate topic strings against the official events documentation. Add unknown topics to the routing table dynamically if required. - Code: The
readLoopcheckstopicQueues[frame.Topic]before sending. Unknown topics are logged and skipped to prevent map panics.
Error: Queue Full / Frame Drops
- Cause: Consumer goroutines process events slower than the WebSocket read rate, causing channel buffers to exhaust.
- Fix: Increase
QueueBufferSizeinConnectorConfig. Implement backpressure signaling or dead-letter queues for dropped frames. Add consumer scaling based on queue depth. - Code: The non-blocking
selecton channel send prevents read loop starvation. Monitor theQueue fulllog messages to tune buffer sizes.
