Multiplexing Genesys Cloud Web SDK Screen Shares with Python Orchestration
A Python orchestration service that validates and directs WebRTC screen share multiplexing payloads from the Genesys Cloud Web SDK. This implementation uses the Genesys Cloud Meetings API, Webhooks API, and the @genesyscloud/purecloud-webrtc-sdk for stream extraction. The tutorial covers JavaScript for the Web SDK frontend and Python for the backend controller, including VP9 synchronization, bandwidth validation, and external recorder alignment.
- OAuth client type: Confidential Client (Backend)
- Required scopes:
meeting:read,meeting:write,webhook:read,webhook:write,analytics:read - SDK/API version: Genesys Cloud REST API v2,
@genesyscloud/purecloud-webrtc-sdkv3.0+ - Language/runtime requirements: Python 3.9+, Node.js 18+, modern Chromium-based browser
- External dependencies:
requests,pydantic,flask,websockets,uuid,datetime
The Python backend requires a bearer token with the specified scopes. The following code demonstrates secure token acquisition with automatic retry logic for rate limiting.
import requests
from typing import Dict, Optional
GENESYS_AUTH_URL = "https://api.mypurecloud.com/oauth/token"
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
SCOPES = "meeting:read meeting:write webhook:read webhook:write analytics:read"
def fetch_genesys_token(retries: int = 3, backoff: float = 1.0) -> Dict[str, str]:
payload = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET,
"scope": SCOPES
for attempt in range(retries):
response = requests.post(GENESYS_AUTH_URL, data=payload, headers=headers)
if response.status_code == 200:
return response.json()
elif response.status_code == 429:
retry_after = float(response.headers.get("Retry-After", backoff * (2 ** attempt)))
print(f"Rate limited. Retrying in {retry_after} seconds.")
time.sleep(retry_after)
else:
response.raise_for_status()
raise RuntimeError("Failed to acquire OAuth token after maximum retries")
# Cache token with expiration tracking
class TokenManager:
def __init__(self):
self._token: Optional[Dict] = None
self._expires_at: float = 0.0
def get_token(self) -> str:
if self._token and time.time() < self._expires_at:
return self._token["access_token"]
self._token = fetch_genesys_token()
self._expires_at = time.time() + (self._token.get("expires_in", 3600) - 60)
token_manager = TokenManager()
Step 1: Python Backend Payload Validation & Bandwidth Constraints
The multiplex payload must validate against strict bandwidth and resolution limits before the Web SDK attempts stream merging. The following Pydantic schema enforces maximum resolution, bitrate caps, and codec verification.
from pydantic import BaseModel, field_validator
import uuid
class StreamMatrix(BaseModel):
stream_id: str
resolution: str
bitrate_kbps: int
codec: str
participant_id: str
class MergeDirective(BaseModel):
target_resolution: str
spatial_scaling: str
vp9_keyframe_interval_ms: int
max_combined_bitrate_kbps: int
class MultiplexPayload(BaseModel):
meeting_id: str
share_references: List[str]
stream_matrix: List[StreamMatrix]
merge_directive: MergeDirective
request_id: str = uuid.uuid4().hex
@field_validator("stream_matrix")
@classmethod
def validate_bandwidth_and_resolution(cls, v: List[StreamMatrix]) -> List[StreamMatrix]:
max_width, max_height = 1920, 1080
max_bitrate = 5000
for stream in v:
width, height = map(int, stream.resolution.split("x"))
if width > max_width or height > max_height:
raise ValueError(f"Resolution {stream.resolution} exceeds maximum limit of {max_width}x{max_height}")
if stream.bitrate_kbps > max_bitrate:
raise ValueError(f"Stream bitrate {stream.bitrate_kbps} exceeds bandwidth constraint of {max_bitrate} kbps")
if stream.codec not in ("vp9", "h264"):
raise ValueError("Codec negotiation failed. Only VP9 and H.264 are permitted for multiplexing")
return v
@field_validator("merge_directive")
@classmethod
def validate_scaling_logic(cls, v: MergeDirective) -> MergeDirective:
if v.spatial_scaling not in ("crop", "pad", "stretch", "letterbox"):
raise ValueError("Invalid spatial scaling mode requested")
if v.vp9_keyframe_interval_ms < 500 or v.vp9_keyframe_interval_ms > 5000:
raise ValueError("VP9 keyframe interval must be between 500ms and 5000ms for synchronization stability")
return v
Step 2: Web SDK Stream Extraction & postMessage Control
The frontend captures the screen share stream, extracts WebRTC parameters, and transmits metadata to the Python backend via postMessage. The backend responds with validation results and merge directives.
import { WebSDK } from '@genesyscloud/purecloud-webrtc-sdk';
const sdk = new WebSDK({
region: 'mypurecloud.com',
clientId: 'YOUR_CLIENT_ID',
clientSecret: 'YOUR_CLIENT_SECRET',
scopes: ['meeting:read', 'meeting:write']
async function captureAndValidateScreenShare(meetingId) {
const meeting = await sdk.meeting.getMeeting(meetingId);
const stream = await navigator.mediaDevices.getDisplayMedia({
video: { width: 1920, height: 1080, frameRate: 30 }
const videoTrack = stream.getVideoTracks()[0];
const settings = videoTrack.getSettings();
const payload = {
type: 'MULTIPLEX_REQUEST',
meeting_id: meeting.id,
share_references: [meeting.id],
stream_matrix: [{
stream_id: videoTrack.id,
resolution: `${settings.width}x${settings.height}`,
bitrate_kbps: Math.round(settings.frameRate * 150),
codec: 'vp9',
participant_id: sdk.user.id
merge_directive: {
target_resolution: '1920x1080',
spatial_scaling: 'crop',
vp9_keyframe_interval_ms: 2000,
max_combined_bitrate_kbps: 8000
window.parent.postMessage(payload, 'https://multiplexer-backend.example.com');
return { stream, videoTrack };
window.addEventListener('message', (event) => {
if (event.origin !== 'https://multiplexer-backend.example.com') return;
const directive = event.data;
if (directive.type === 'MULTIPLEX_DIRECTIVE') {
applyMultiplexConfiguration(directive);
Step 3: VP9 Keyframe Synchronization & Bitrate Reduction Triggers
The Python backend processes the validation, calculates latency, and returns an atomic directive. The frontend applies VP9 keyframe alignment and triggers automatic bitrate reduction when constraints are approached.
import requests
import json
from flask import Flask, request, jsonify
app = Flask(__name__)
VALIDATION_URL = "https://multiplexer-backend.example.com/validate"
RECORDER_SYNC_URL = "https://external-recorder.example.com/api/sync"
@app.route("/validate", methods=["POST"])
def validate_multiplex():
payload_data = request.json
payload = MultiplexPayload(**payload_data)
return jsonify({"status": "validation_failed", "error": str(e)}), 400
start_time = datetime.now(timezone.utc)
# Simulate backend processing latency tracking
processing_latency_ms = (datetime.now(timezone.utc) - start_time).total_seconds() * 1000
directive = {
"type": "MULTIPLEX_DIRECTIVE",
"request_id": payload.request_id,
"approved": True,
"spatial_scaling": payload.merge_directive.spatial_scaling,
"vp9_keyframe_interval_ms": payload.merge_directive.vp9_keyframe_interval_ms,
"bitrate_reduction_trigger": payload.merge_directive.max_combined_bitrate_kbps * 0.8,
"timestamp": start_time.isoformat()
# Audit log generation
audit_entry = {
"event": "multiplex_validation",
"meeting_id": payload.meeting_id,
"streams_validated": len(payload.stream_matrix),
"processing_latency_ms": round(processing_latency_ms, 2),
"status": "approved",
print(f"AUDIT_LOG: {json.dumps(audit_entry)}")
return jsonify(directive), 200
def apply_multiplex_configuration(directive):
"""Frontend handler for atomic postMessage directive application"""
# VP9 Keyframe synchronization
videoTrack = window.currentStream?.getVideoTracks()[0];
if (videoTrack) {
const sender = window.currentPeerConnection?.getSenders().find(s => s.track?.kind === 'video');
if (sender) {
const params = sender.getParameters();
params.encodings[0].maxBitrate = directive.bitrate_reduction_trigger * 1000;
sender.setParameters(params).then(() => {
console.log("Bitrate reduction trigger applied successfully");
// Spatial scaling application
const videoElement = document.getElementById('multiplex-output');
if (videoElement) {
videoElement.style.objectFit = directive.spatial_scaling === 'crop' ? 'cover' : 'contain';
Step 4: Webhook Synchronization, Latency Tracking & Audit Logging
The backend registers a Genesys Cloud webhook to synchronize multiplexing events with external recording servers. It also queries analytics to track merge success rates and latency metrics.
import requests
import json
from datetime import datetime, timezone, timedelta
GENESYS_API_BASE = "https://api.mypurecloud.com/api/v2"
def register_multiplex_webhook():
token = token_manager.get_token()
headers = {
webhook_config = {
"name": "ScreenShareMultiplexSync",
"description": "Synchronizes multiplexing events with external recorder",
"apiVersion": "v2",
"enabled": True,
"event": "meeting:participant:screen-share:started",
"address": "https://multiplexer-backend.example.com/webhook/callback",
"type": "httpPost",
"contact": {
"name": "Multiplex Orchestrator",
"email": "ops@example.com"
response = requests.post(f"{GENESYS_API_BASE}/webhooks", headers=headers, json=webhook_config)
def query_multiplex_analytics(meeting_id: str, start_time: str, end_time: str):
headers = {
query = {
"viewId": "conversations-default",
"dateFrom": start_time,
"dateTo": end_time,
"filter": {
"type": "or",
"clauses": [
{"type": "eq", "field": "meetingId", "value": meeting_id}
"groupBy": ["meetingId"],
"aggregations": [
{"type": "count", "name": "total_merges"},
{"type": "avg", "name": "avg_latency", "field": "latency"}
f"{GENESYS_API_BASE}/analytics/conversations/details/query",
headers=headers,
json=query
retry_after = float(response.headers.get("Retry-After", 2.0))
return query_multiplex_analytics(meeting_id, start_time, end_time)
@app.route("/webhook/callback", methods=["POST"])
def handle_multiplex_webhook():
payload = request.json
meeting_id = payload.get("meetingId")
participant_id = payload.get("participantId")
# Sync with external recorder
sync_payload = {
"meeting_id": meeting_id,
"participant_id": participant_id,
"event": "screen_share_started",
"multiplex_active": True
recorder_response = requests.post(RECORDER_SYNC_URL, json=sync_payload)
recorder_response.raise_for_status()
return jsonify({"status": "synced", "meeting_id": meeting_id}), 200
The following module combines authentication, validation, webhook registration, and Flask routing into a single executable orchestrator. Replace placeholder credentials and endpoints before execution.
import requests
import json
import uuid
from typing import Dict, Optional, List
# --- Authentication ---
def fetch_genesys_token(retries: int = 3) -> Dict[str, str]:
payload = {
"scope": SCOPES
time.sleep(float(response.headers.get("Retry-After", 2 ** attempt)))
else:
raise RuntimeError("OAuth token acquisition failed")
class TokenManager:
def __init__(self):
# --- Validation Schema ---
stream_id: str
resolution: str
bitrate_kbps: int
codec: str
participant_id: str
meeting_id: str
@classmethod
max_bitrate = 5000
for stream in v:
raise ValueError(f"Resolution {stream.resolution} exceeds maximum limit")
raise ValueError(f"Bitrate {stream.bitrate_kbps} exceeds bandwidth constraint")
raise ValueError("Codec negotiation failed. Only VP9 and H.264 permitted")
return v
# --- Flask Application ---
payload = MultiplexPayload(**request.json)
directive = {
"approved": True,
audit_entry = {
@app.route("/register-webhook", methods=["POST"])
def register_webhook():
webhook_config = {
"name": "MultiplexSync",
"enabled": True,
"type": "httpPost",
"contact": {"name": "Ops", "email": "ops@example.com"}
return jsonify({"webhook_id": response.json()["id"]}), 201
def handle_webhook():
sync_data = {
"meeting_id": payload.get("meetingId"),
"participant_id": payload.get("participantId"),
# External recorder sync would go here
print(f"RECORDER_SYNC: {json.dumps(sync_data)}")
return jsonify({"status": "synced"}), 200
app.run(host="0.0.0.0", port=5000)
- What causes it: The OAuth token expired or the client credentials lack the required scopes.
- How to fix it: Verify
client_idandclient_secretmatch a Confidential Client in Genesys Cloud. Ensure the token cache checks expiration before reuse. - Code showing the fix: The
TokenManagerclass automatically refreshes whentime.time() >= self._expires_at. Add explicit scope validation during token fetch by checkingresponse.json().get("scope").
- What causes it: Exceeding Genesys Cloud API rate limits during webhook registration or analytics queries.
- How to fix it: Implement exponential backoff with jitter. Read the
Retry-Afterheader. - Code showing the fix: The
fetch_genesys_tokenfunction includes a retry loop withtime.sleep(float(response.headers.get("Retry-After", 2 ** attempt))). Apply the same pattern to allrequests.postcalls.
Error: VP9 Keyframe Desynchronization
- What causes it: The Web SDK receives a merge directive before the encoder generates a keyframe, causing green screens or freezing.
- How to fix it: Enforce a minimum
vp9_keyframe_interval_msof 1000ms in the validation schema. Trigger a manual keyframe request viaRTCRtpSender.getParameters()before applying scaling changes. - Code showing the fix: The Pydantic validator rejects intervals below 500ms. The frontend
apply_multiplex_configurationfunction waits forsender.setParameters()resolution before updating the video element.
Error: Spatial Scaling Artifacts
- What causes it: Mismatched aspect ratios between the source stream and the
target_resolutiondirective. - How to fix it: Use
letterboxorpadscaling modes when source and target aspect ratios differ. Validate resolution ratios during payload construction. - Code showing the fix: The
MergeDirectiveschema restrictsspatial_scalingto valid modes. The frontend appliesobject-fit: containfor letterbox/pad andobject-fit: coverfor crop.
