Monitoring Genesys Cloud Data Actions Execution Queues via Python SDK and WebSocket
  • Build an asynchronous Python service that monitors Data Actions execution queues by subscribing to real-time WebSocket events and falling back to REST polling when required.
  • Use the official Genesys Cloud Python SDK for OAuth token acquisition and the websockets library for atomic text operations over the execution stream.
  • Cover Python 3.9+ with httpx, websockets, pydantic, and structured audit logging for data governance compliance.
  • OAuth 2.0 client credentials flow with required scopes: dataaction:execute, dataaction:read, realtime:websocket
  • SDK version: genesyscloud_python_sdk>=2.1.0
  • Runtime: Python 3.9 or higher
  • External dependencies: httpx>=0.24.0, websockets>=12.0, pydantic>=2.0, structlog>=23.0
Genesys Cloud requires a valid bearer token for both REST endpoints and WebSocket handshakes. The Python SDK handles token acquisition and automatic refresh when configured correctly. The following code initializes the SDK, requests a token, and extracts the raw bearer string for downstream HTTP and WebSocket clients.
import os
from genesyscloud_python_sdk import PureCloudPlatformClientV2, Configuration
from genesyscloud_python_sdk.api_client import ApiClient
def initialize_auth(env: str, client_id: str, client_secret: str) -> str:
    """Acquire and return a valid OAuth 2.0 bearer token."""
    config = Configuration(
        host=f"https://api.{env}",
        client_id=client_id,
        client_secret=client_secret,
        access_token=""
    api_client = ApiClient(config)
    platform_client = PureCloudPlatformClientV2()
    platform_client.set_environment(config.host)
    platform_client.client_id = client_id
    platform_client.client_secret = client_secret
        platform_client.login()
        return platform_client.access_token
        raise RuntimeError(f"Authentication failed: {e}")
# Usage
TOKEN = initialize_auth(
    env="mypurecloud.com",
    client_id=os.getenv("GENESYS_CLIENT_ID"),
    client_secret=os.getenv("GENESYS_CLIENT_SECRET")
The platform_client.login() method executes the client credentials grant against /api/v2/oauth/token. The returned token remains valid for one hour. The SDK automatically refreshes the token on subsequent REST calls, but WebSocket connections require manual token injection during the initial handshake.
Step 1: Construct Monitoring Payload and Validate Schema
The monitoring payload must contain the target queueRef, a statusMatrix defining which execution states trigger notifications, and a pollDirective controlling fallback REST polling behavior. Genesys Cloud enforces WebSocket message size limits and maximum concurrent listener constraints. The payload schema below validates these constraints before transmission.
import pydantic
class PollDirective(pydantic.BaseModel):
    intervalMs: int = pydantic.Field(ge=1000, le=30000)
    maxRetries: int = pydantic.Field(ge=1, le=10)
    fallbackEnabled: bool = True
class MonitoringPayload(pydantic.BaseModel):
    queueRef: str = pydantic.Field(min_length=1, max_length=255)
    statusMatrix: List[str] = pydantic.Field(
        min_length=1, max_length=10,
        pattern=r"^(QUEUED|RUNNING|COMPLETED|FAILED|ABORTED)$"
    pollDirective: PollDirective
    maxListeners: int = pydantic.Field(ge=1, le=50)
    def validate_websocket_constraints(self) -> None:
        if len(self.json()) > 65536:
            raise ValueError("Payload exceeds WebSocket maximum frame size.")
        if self.pollDirective.intervalMs < 2000 and self.maxListeners > 10:
            raise ValueError("High listener count requires longer poll intervals to prevent 429 rate limits.")
# Example validation
payload = MonitoringPayload(
    queueRef="data-actions-queue-prod-01",
    statusMatrix=["QUEUED", "RUNNING", "COMPLETED", "FAILED"],
    pollDirective=PollDirective(intervalMs=5000, maxRetries=3),
    maxListeners=25
payload.validate_websocket_constraints()
SUBSCRIPTION_MSG = payload.json()
The validate_websocket_constraints method enforces platform limits. Genesys Cloud returns HTTP 429 when subscription requests exceed rate thresholds. The schema prevents malformed subscriptions before they reach the API.
Step 2: WebSocket Connection and Heartbeat Backlog Logic
The execution stream lives at wss://api.{env}/api/v2/dataactions/execution/websocket. The connection requires a Authorization: Bearer <token> header. Atomic text operations ensure that heartbeat pings and backlog evaluations do not race with incoming execution events.
import asyncio
import websockets
import json
@dataclass
class BacklogEvaluator:
    expected_throughput: float = 0.0
    received_count: int = 0
    last_timestamp: float = field(default_factory=time.time)
    def record_event(self) -> float:
        now = time.time()
        self.received_count += 1
        elapsed = now - self.last_timestamp
        self.last_timestamp = now
        return elapsed if elapsed > 0 else 0.0
async def connect_execution_stream(env: str, token: str, payload_json: str, evaluator: BacklogEvaluator):
    uri = f"wss://api.{env}/api/v2/dataactions/execution/websocket"
    async with websockets.connect(uri, extra_headers=headers) as ws:
        await ws.send(payload_json)
        print("Subscription established. Monitoring queue events.")
        while True:
                raw_message = await asyncio.wait_for(ws.recv(), timeout=30.0)
                event = json.loads(raw_message)
                # Atomic backlog evaluation
                latency = evaluator.record_event()
                print(f"Event received: {event.get('type')} | Latency: {latency:.3f}s")
                # Heartbeat calculation: Genesys Cloud sends periodic keep-alives.
                # We track missed heartbeats to detect stale connections.
                if event.get("type") == "heartbeat":
                    print("Heartbeat acknowledged. Connection healthy.")
            except asyncio.TimeoutError:
                print("WebSocket idle timeout reached. Sending explicit ping.")
                await ws.ping()
                await asyncio.sleep(2)
            except websockets.ConnectionClosed as e:
                print(f"WebSocket closed: {e.code} {e.reason}. Reconnecting required.")
                break
The BacklogEvaluator tracks message arrival intervals. Genesys Cloud streams execution state changes asynchronously. The timeout mechanism triggers an explicit ping when no messages arrive within thirty seconds. This prevents silent connection drops during scaling events.
Step 3: Poll Directive Latency Tracking and Alert Escalation
When the WebSocket stream experiences high latency or disconnects, the system falls back to REST polling using the pollDirective parameters. The following code implements exponential backoff retry logic for HTTP 429 responses and tracks poll success rates.
import httpx
import structlog
async def fallback_poll(env: str, token: str, queue_ref: str, directive: PollDirective):
    base_url = f"https://api.{env}/api/v2/dataactions/execution/queue/{queue_ref}"
    headers = {"Authorization": f"Bearer {token}", "Accept": "application/json"}
    poll_successes = 0
    poll_attempts = 0
    for attempt in range(directive.maxRetries):
        poll_attempts += 1
        async with httpx.AsyncClient() as client:
                response = await client.get(base_url, headers=headers, timeout=10.0)
                latency = time.perf_counter() - start_time
                if response.status_code == 200:
                    poll_successes += 1
                    data = response.json()
                    logger.info("poll_success", queue_ref=queue_ref, latency_ms=latency*1000, status=data.get("status"))
                    return data
                elif response.status_code == 429:
                    retry_after = int(response.headers.get("Retry-After", directive.intervalMs / 1000))
                    logger.warning("rate_limited", status_code=429, retry_after_s=retry_after)
                else:
                    logger.error("poll_failed", status_code=response.status_code, body=response.text)
                logger.error("request_error", error=str(e))
                await asyncio.sleep(min(2 ** attempt, 30))
    success_rate = poll_successes / poll_attempts if poll_attempts > 0 else 0
    if success_rate < 0.5:
        await trigger_alert(queue_ref, success_rate, "Low poll success rate detected")
    return None
async def trigger_alert(queue_ref: str, metric_value: float, reason: str):
    """Escalation trigger for external observability platform."""
    alert_payload = {
        "queueRef": queue_ref,
        "metric": metric_value,
        "reason": reason,
        "timestamp": time.time(),
        "severity": "critical" if metric_value < 0.3 else "warning"
    logger.critical("alert_escalated", **alert_payload)
    # Webhook sync handled in Step 4
The retry loop respects the Retry-After header returned by Genesys Cloud during rate limiting. Latency is measured using time.perf_counter() for sub-millisecond precision. The success rate calculation determines whether the alert escalation pipeline activates.
Step 4: Throughput Verification Audit Logging and Webhook Sync
Data governance requirements mandate immutable audit logs for all monitoring events. The following pipeline verifies throughput against baseline expectations, formats structured audit logs, and synchronizes metrics to an external observability webhook.
import json
class AuditLogger:
    def __init__(self, log_file: str = "dataactions_monitor_audit.jsonl"):
        self.log_file = log_file
    def log_event(self, event_type: str, payload: dict) -> None:
        audit_record = {
            "eventType": event_type,
            "payload": payload,
            "governanceHash": self._compute_hash(payload)
        with open(self.log_file, "a") as f:
            f.write(json.dumps(audit_record) + "\n")
    @staticmethod
    def _compute_hash(data: dict) -> str:
        import hashlib
        return hashlib.sha256(json.dumps(data, sort_keys=True).encode()).hexdigest()
async def sync_to_observability(webhook_url: str, metrics: dict) -> None:
    headers = {"Content-Type": "application/json", "X-Source": "genesys-queue-monitor"}
            resp = await client.post(webhook_url, json=metrics, headers=headers, timeout=5.0)
            if resp.status_code not in (200, 201, 202):
                logger.warning("webhook_sync_failed", status_code=resp.status_code)
            logger.error("webhook_request_error", error=str(e))
async def verify_throughput(evaluator: BacklogEvaluator, audit: AuditLogger, webhook_url: str):
    current_throughput = evaluator.received_count / max((time.time() - evaluator.last_timestamp), 0.01)
    metrics = {
        "queueRef": "data-actions-queue-prod-01",
        "throughput_eps": round(current_throughput, 3),
        "events_processed": evaluator.received_count,
        "window_seconds": time.time() - evaluator.last_timestamp
    audit.log_event("throughput_verification", metrics)
    await sync_to_observability(webhook_url, metrics)
    if current_throughput < 0.1:
        await trigger_alert("data-actions-queue-prod-01", current_throughput, "Throughput below baseline threshold")
The AuditLogger writes append-only JSONL records with cryptographic hashes for tamper detection. The throughput verification pipeline compares event arrival rates against expected baselines and pushes metrics to external observability platforms via HTTP POST. This ensures alignment between Genesys Cloud execution state and enterprise monitoring dashboards.
import asyncio
import os
import structlog
structlog.configure(
    processors=[structlog.processors.JSONRenderer()],
    wrapper_class=structlog.make_filtering_bound_logger("INFO"),
    context_class=dict,
    logger_factory=structlog.PrintLoggerFactory()
# Configuration
ENV = os.getenv("GENESYS_ENV", "mypurecloud.com")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
WEBHOOK_URL = os.getenv("OBSERVABILITY_WEBHOOK_URL", "https://hooks.example.com/metrics")
async def main():
    # 1. Authentication
    platform_client.set_environment(f"https://api.{ENV}")
    platform_client.client_id = CLIENT_ID
    platform_client.client_secret = CLIENT_SECRET
    token = platform_client.access_token
    logger.info("auth_complete", token_expiry=platform_client.token_expiry)
    # 2. Payload Construction
    class PollDirective(BaseModel):
        intervalMs: int = Field(ge=1000, le=30000)
        maxRetries: int = Field(ge=1, le=10)
    class MonitoringPayload(BaseModel):
        queueRef: str = Field(min_length=1, max_length=255)
        statusMatrix: List[str] = Field(min_length=1, max_length=10, pattern=r"^(QUEUED|RUNNING|COMPLETED|FAILED|ABORTED)$")
        maxListeners: int = Field(ge=1, le=50)
        maxListeners=25
    sub_msg = payload.json()
    # 3. Initialize Trackers
        def __init__(self):
            self.received_count = 0
            self.last_timestamp = time.time()
            now = time.time()
    evaluator = BacklogEvaluator()
    audit = AuditLogger("monitor_audit.jsonl")
    # 4. WebSocket Connection
    import websockets
    import json
    uri = f"wss://api.{ENV}/api/v2/dataactions/execution/websocket"
            await ws.send(sub_msg)
            logger.info("websocket_connected", queue_ref=payload.queueRef)
            while True:
                    raw = await asyncio.wait_for(ws.recv(), timeout=30.0)
                    event = json.loads(raw)
                    logger.info("event_received", type=event.get("type"), latency_ms=latency*1000)
                        logger.debug("heartbeat_acknowledged")
                    await ws.ping()
                # Periodic throughput verification and audit sync
                if evaluator.received_count % 10 == 0:
                    await verify_throughput(evaluator, audit, WEBHOOK_URL)
        logger.error("websocket_disconnected", code=e.code, reason=e.reason)
        # Trigger fallback polling
        await fallback_poll(ENV, token, payload.queueRef, payload.pollDirective)
    asyncio.run(main())
The script runs as a standalone async process. It authenticates, validates the subscription payload, establishes the WebSocket stream, tracks latency and backlog, verifies throughput at regular intervals, writes immutable audit logs, and syncs metrics to an external webhook. Replace environment variables with valid credentials before execution.
Common Errors and Debugging
Error: HTTP 401 Unauthorized
  • Cause: Expired OAuth token or missing dataaction:read scope.
  • Fix: Regenerate the token using platform_client.login() and verify the client credentials grant includes all required scopes. WebSocket handshakes fail immediately if the bearer token is invalid.
  • Code Fix: Add token refresh logic before WebSocket connection initialization.
Error: HTTP 403 Forbidden
  • Cause: The OAuth client lacks permissions to access the specified queueRef or the environment is misconfigured.
  • Fix: Assign the Data Actions Administrator or Data Actions Viewer role to the service account in the Genesys Cloud admin console. Verify the env parameter matches the organization domain.
  • Code Fix: Log the full response body to identify the specific permission denial message.
  • Cause: Poll directive interval is too aggressive or WebSocket subscription rate exceeds platform limits.
  • Fix: Increase pollDirective.intervalMs to at least 5000 milliseconds. Implement exponential backoff in the fallback poller. Check the Retry-After header for exact wait duration.
  • Code Fix: The fallback_poll function already parses Retry-After and applies sleep delays. Ensure maxListeners does not exceed ten when intervals fall below two seconds.
Error: WebSocket Stale Connection or Silent Drop
  • Cause: Network timeout, idle connection pruning by Genesys Cloud edge proxies, or unhandled ping/pong frames.
  • Fix: Enable explicit ping timeouts in the websockets client. Monitor heartbeat events from the stream. Reconnect automatically when ConnectionClosed occurs.
  • Code Fix: Wrap the ws.recv() call in asyncio.wait_for with a thirty-second timeout. Send an explicit ping on timeout. Catch ConnectionClosed and trigger the REST fallback pipeline.
