Monitoring Genesys Cloud Codec Negotiation Mismatches and Media Quality with Java
This tutorial builds a Java service that queries Genesys Cloud conversation analytics to detect codec negotiation mismatches, validate media constraints, and trigger quality degradation alerts. The implementation uses the Genesys Cloud Java SDK and the Analytics API to retrieve media metrics. All code is written in Java 17+ using Maven dependencies.
  • OAuth client type: Service Account or Public/Private Key with analytics:conversation:read scope
  • SDK version: PureCloudPlatformClientV2 v22.3.0 or newer
  • Runtime: Java 17+
  • External dependencies: com.genesiscloud:PureCloudPlatformClientV2, com.google.code.gson:gson, org.slf4j:slf4j-api
The Genesys Cloud Java SDK handles OAuth 2.0 client credentials flow automatically. You must configure the client with your environment, client ID, and client secret. The SDK caches the access token and refreshes it transparently when it expires. You must handle ApiException to catch authentication failures before they cascade into your monitoring loop.
import com.genesiscloud.platform.client.api.analytics.AnalyticsApi;
import com.genesiscloud.platform.client.api.exception.ApiException;
import com.genesiscloud.platform.client.auth.OAuthClient;
import com.genesiscloud.platform.client.PureCloudPlatformClientV2;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class CodecMonitorAuth {
    private static final Logger logger = LoggerFactory.getLogger(CodecMonitorAuth.class);
    public static PureCloudPlatformClientV2 initializeClient(String environment, String clientId, String clientSecret) {
        PureCloudPlatformClientV2 client = new PureCloudPlatformClientV2();
        client.setEnvironment(environment);
        OAuthClient oauth = new OAuthClient(client);
        oauth.setClientId(clientId);
        oauth.setClientSecret(clientSecret);
            oauth.login();
            logger.info("OAuth authentication successful for environment: {}", environment);
        } catch (ApiException e) {
            logger.error("OAuth authentication failed with status {}: {}", e.getCode(), e.getMessage());
            throw new RuntimeException("Authentication failed. Verify client credentials and scope: analytics:conversation:read", e);
        return client;
Step 1: Construct and Validate Monitoring Payloads
You must define a monitoring configuration that specifies allowed codecs, maximum mismatch thresholds, and latency limits. The payload validation prevents the monitor from querying against invalid constraints that would cause API rejection or meaningless results.
import com.google.gson.annotations.SerializedName;
import java.util.List;
import java.util.regex.Pattern;
public class CodecMonitorConfig {
    private List<String> allowedCodecs;
    private int maxMismatchThreshold;
    private double maxJitterMs;
    private double maxLatencyMs;
    private String alertWebhookUrl;
    // Constructor, getters, setters omitted for brevity
    public boolean isValid() {
        if (allowedCodecs == null || allowedCodecs.isEmpty()) return false;
        if (maxMismatchThreshold <= 0 || maxMismatchThreshold > 100) return false;
        if (maxJitterMs < 0 || maxJitterMs > 100) return false;
        if (maxLatencyMs < 0 || maxLatencyMs > 500) return false;
        if (alertWebhookUrl == null || !alertWebhookUrl.matches("^https://.*")) return false;
        return true;
Step 2: Query Media Analytics and Detect Codec Mismatches
The Analytics API endpoint /api/v2/analytics/conversations/details/query returns conversation media details. You must construct a JSON query body, handle pagination, and implement retry logic for 429 Too Many Requests responses. The SDK method conversationsDetailsQuery executes the POST request.
import com.genesiscloud.platform.client.api.analytics.model.ConversationsDetailsQueryRequest;
import com.genesiscloud.platform.client.api.analytics.model.ConversationsDetailsQueryResponse;
import com.genesiscloud.platform.client.api.analytics.model.ConversationDetail;
import com.genesiscloud.platform.client.api.analytics.model.MediaDetail;
import com.google.gson.Gson;
import com.google.gson.JsonObject;
import java.time.OffsetDateTime;
import java.time.temporal.ChronoUnit;
public class MediaQueryService {
    private final AnalyticsApi analyticsApi;
    private final Gson gson = new Gson();
    public MediaQueryService(AnalyticsApi analyticsApi) {
        this.analyticsApi = analyticsApi;
    public ConversationsDetailsQueryResponse fetchMediaDetails(OffsetDateTime dateFrom, OffsetDateTime dateTo) throws ApiException {
        String queryJson = String.format(
            "{\"query\":{\"dateFrom\":\"%s\",\"dateTo\":\"%s\",\"filter\":{\"conversation.type EQ \"voice\"}},\"groupBy\":[\"conversation\"],\"size\":100}",
            dateFrom.toString(), dateTo.toString()
        ConversationsDetailsQueryRequest request = new ConversationsDetailsQueryRequest();
        request.setBody(gson.fromJson(queryJson, JsonObject.class));
        // Retry logic for 429 rate limits
        int maxRetries = 3;
        int retryCount = 0;
        ConversationsDetailsQueryResponse response = null;
        while (retryCount <= maxRetries) {
                response = analyticsApi.conversationsDetailsQuery(request);
                break;
                if (e.getCode() == 429 && retryCount < maxRetries) {
                    long waitMs = (long) Math.pow(2, retryCount) * 1000;
                    try { Thread.sleep(waitMs); } catch (InterruptedException ie) { Thread.currentThread().interrupt(); }
                    retryCount++;
                } else {
                    throw e;
        return response;
Step 3: Correlate Latency Spikes and Transcoding Events
After retrieving the response, you must parse the media object for each conversation. The SDK exposes MediaDetail objects containing codec, jitter, latency, and packetLoss. You must detect G.711 to Opus transcoding mismatches, compare values against your configured thresholds, and flag degradation events.
import java.util.ArrayList;
public class MediaAnalyzer {
    private final CodecMonitorConfig config;
    public MediaAnalyzer(CodecMonitorConfig config) {
        this.config = config;
    public List<MediaAlertEvent> analyzeConversations(List<ConversationDetail> conversations) {
        List<MediaAlertEvent> alerts = new ArrayList<>();
        for (ConversationDetail conv : conversations) {
            if (conv.getMedia() == null || conv.getMedia().isEmpty()) continue;
            for (MediaDetail media : conv.getMedia()) {
                String actualCodec = media.getCodec();
                if (actualCodec == null) continue;
                boolean isMismatch = !config.getAllowedCodecs().contains(actualCodec);
                boolean isTranscoding = (actualCodec.contains("G711") || actualCodec.contains("PCMU") || actualCodec.contains("PCMA"))
                                      && config.getAllowedCodecs().contains("Opus");
                double jitter = media.getJitter() != null ? media.getJitter().doubleValue() : 0.0;
                double latency = media.getLatency() != null ? media.getLatency().doubleValue() : 0.0;
                if (isMismatch || isTranscoding || jitter > config.getMaxJitterMs() || latency > config.getMaxLatencyMs()) {
                    alerts.add(new MediaAlertEvent(
                        conv.getConversationId(),
                        actualCodec,
                        isTranscoding,
                        jitter,
                        latency,
                        System.currentTimeMillis()
        return alerts;
Step 4: Sync Alerts to External Dashboards and Generate Audit Logs
You must push mismatch events to an external QoS dashboard via webhook and record an audit trail for media governance. The webhook payload must contain the codec reference, negotiation matrix status, and alert directive. The audit log must capture the query timestamp, result count, and alert success rate.
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.URL;
import java.util.Map;
import java.util.HashMap;
public class AlertSyncService {
    private final String webhookUrl;
    public AlertSyncService(String webhookUrl) {
        this.webhookUrl = webhookUrl;
    public boolean pushAlerts(List<MediaAlertEvent> events) {
        if (events.isEmpty()) return true;
        Map<String, Object> payload = new HashMap<>();
        payload.put("directive", "CODEC_MISMATCH_ALERT");
        payload.put("timestamp", System.currentTimeMillis());
        payload.put("events", events);
        payload.put("monitoringMatrix", Map.of(
            "thresholdBreach", events.size(),
            "totalProcessed", events.size()
            URL url = new URL(webhookUrl);
            HttpURLConnection conn = (HttpURLConnection) url.openConnection();
            conn.setRequestMethod("POST");
            conn.setRequestProperty("Content-Type", "application/json");
            conn.setDoOutput(true);
            try (OutputStream os = conn.getOutputStream()) {
                os.write(gson.toJson(payload).getBytes());
            int status = conn.getResponseCode();
            return status == 200 || status == 201 || status == 204;
        } catch (Exception e) {
            System.err.println("Webhook delivery failed: " + e.getMessage());
            return false;
    public void logAudit(String queryId, int totalConversations, int alertCount, boolean webhookSuccess) {
        String logEntry = String.format(
            "AUDIT|%s|conversations=%d|alerts=%d|webhook=%s|latency_ms=%d",
            queryId, totalConversations, alertCount, webhookSuccess ? "SUCCESS" : "FAILED", System.currentTimeMillis()
        System.out.println(logEntry);
The following class combines authentication, payload validation, API querying, analysis, and alert synchronization into a single executable monitor. You must replace the credential placeholders before running.
import java.time.ZoneOffset;
public class GenesysCodecMonitor {
    private static final Logger logger = LoggerFactory.getLogger(GenesysCodecMonitor.class);
        // 1. Authentication
        client.setEnvironment("us-east-1");
        oauth.setClientId("YOUR_CLIENT_ID");
        oauth.setClientSecret("YOUR_CLIENT_SECRET");
            oauth.login();
            logger.error("Authentication failed: {}", e.getMessage());
            return;
        // 2. Configuration & Validation
        CodecMonitorConfig config = new CodecMonitorConfig();
        config.setAllowedCodecs(List.of("Opus", "G722"));
        config.setMaxMismatchThreshold(5);
        config.setMaxJitterMs(30.0);
        config.setMaxLatencyMs(150.0);
        config.setAlertWebhookUrl("https://your-qos-dashboard.internal/webhooks/codec-alerts");
        if (!config.isValid()) {
            logger.error("Invalid monitoring configuration. Aborting.");
            return;
        // 3. Initialize Services
        AnalyticsApi analyticsApi = new AnalyticsApi(client);
        MediaQueryService queryService = new MediaQueryService(analyticsApi);
        MediaAnalyzer analyzer = new MediaAnalyzer(config);
        AlertSyncService syncService = new AlertSyncService(config.getAlertWebhookUrl());
        // 4. Execute Monitoring Loop
        OffsetDateTime dateFrom = OffsetDateTime.now(ZoneOffset.UTC).minusHours(1);
        OffsetDateTime dateTo = OffsetDateTime.now(ZoneOffset.UTC);
            int totalProcessed = 0;
            int totalAlerts = 0;
            // Handle pagination
            String nextPageToken = null;
            do {
                var response = queryService.fetchMediaDetails(dateFrom, dateTo);
                List<ConversationDetail> conversations = response.getConversations();
                if (conversations == null) conversations = List.of();
                List<MediaAlertEvent> alerts = analyzer.analyzeConversations(conversations);
                totalProcessed += conversations.size();
                totalAlerts += alerts.size();
                boolean webhookOk = syncService.pushAlerts(alerts);
                syncService.logAudit(System.currentTimeMillis() + "", totalProcessed, totalAlerts, webhookOk);
                nextPageToken = response.getNextPageToken();
            } while (nextPageToken != null);
            logger.info("Monitoring cycle complete. Processed: {}, Alerts: {}", totalProcessed, totalAlerts);
            logger.error("Analytics API failed with status {}: {}", e.getCode(), e.getMessage());
            logger.error("Unexpected error during monitoring: {}", e.getMessage(), e);
  • What causes it: The OAuth client credentials are invalid, expired, or lack the analytics:conversation:read scope.
  • How to fix it: Verify your client ID and secret in the Genesys Cloud admin console. Ensure the service account has the required analytics scope assigned.
  • Code showing the fix: The authentication setup block catches ApiException with code 401 and throws a descriptive runtime exception. Add explicit scope validation in your admin console before deployment.
  • What causes it: The Analytics API enforces strict rate limits per tenant and per client. High-frequency monitoring loops trigger throttling.
  • How to fix it: Implement exponential backoff with jitter. The fetchMediaDetails method includes a retry loop that sleeps 2^retryCount seconds before retrying.
  • Code showing the fix: The retry logic in Step 2 catches e.getCode() == 429, waits, and retries up to three times before propagating the exception.
Error: 400 Bad Request (Invalid Query Payload)
  • What causes it: The JSON query body contains malformed date formats, unsupported filters, or missing required fields.
  • How to fix it: Use ISO 8601 offset dates (OffsetDateTime.toString()). Ensure the filter syntax matches Genesys Cloud query language standards.
  • Code showing the fix: The fetchMediaDetails method constructs the JSON payload using String.format with validated OffsetDateTime instances. Wrap the query construction in a try-catch and log the raw JSON before sending if validation fails.
Error: Null Pointer in MediaDetail Parsing
  • What causes it: Not all conversations contain media objects, or the media array is empty for non-voice interactions.
  • How to fix it: Add null checks before iterating. The analyzeConversations method explicitly checks conv.getMedia() == null || conv.getMedia().isEmpty() before proceeding.
  • Code showing the fix: The null guard in Step 3 prevents NullPointerException when processing mixed conversation types.
