Monitoring Genesys Cloud Client SDK Audio Input Levels with C#
A production-grade audio input monitor that samples decibel levels from the Genesys Cloud Client SDK, validates configuration against engine constraints, detects voice activity using a noise floor pipeline, triggers automatic mute on threshold breaches, and streams diagnostic telemetry to external webhooks. This tutorial uses the Genesys Cloud Client SDK for .NET. The implementation is written in C# 10 targeting .NET 8.
- OAuth2 client credentials grant with
client:audio:monitorandanalytics:queryscopes GenesysCloud.Client.Sdkv1.2.0+ (NuGet)- .NET 8 SDK
System.Text.Json,Microsoft.Extensions.Logging,Polly(NuGet)- A reachable HTTP endpoint for webhook diagnostics
The Client SDK requires a valid bearer token to initialize the engine. You must acquire the token using the OAuth2 client credentials flow before passing it to the SDK configuration. The following example demonstrates token acquisition with retry logic for transient 429 or 5xx responses.
using System;
using System.Net.Http;
using System.Text;
using System.Text.Json;
using System.Threading.Tasks;
using Polly;
public class OAuthTokenProvider
private readonly HttpClient _httpClient;
private readonly string _baseUrl;
private readonly string _clientId;
private readonly string _clientSecret;
public OAuthTokenProvider(string baseUrl, string clientId, string clientSecret)
_httpClient = new HttpClient();
_baseUrl = baseUrl.TrimEnd('/');
_clientId = clientId;
_clientSecret = clientSecret;
public async Task<string> AcquireTokenAsync()
var policy = Policy
.Handle<HttpRequestException>()
.OrResult<HttpResponseMessage>(r => r.StatusCode is System.Net.HttpStatusCode.TooManyRequests or System.Net.HttpStatusCode.InternalServerError)
.WaitAndRetryAsync(3, retry => TimeSpan.FromSeconds(Math.Pow(2, retry)));
var response = await policy.ExecuteAsync(async () =>
var content = new FormUrlEncodedContent(new[]
new KeyValuePair<string, string>("grant_type", "client_credentials"),
new KeyValuePair<string, string>("client_id", _clientId),
new KeyValuePair<string, string>("client_secret", _clientSecret),
new KeyValuePair<string, string>("scope", "client:audio:monitor analytics:query")
return await _httpClient.PostAsync($"{_baseUrl}/oauth/token", content);
if (!response.IsSuccessStatusCode)
var errorBody = await response.Content.ReadAsStringAsync();
throw new InvalidOperationException($"OAuth token acquisition failed: {response.StatusCode} - {errorBody}");
var json = await response.Content.ReadAsStringAsync();
var doc = JsonDocument.Parse(json);
return doc.RootElement.GetProperty("access_token").GetString()
?? throw new InvalidOperationException("Access token missing in OAuth response.");
Step 1: Configuration Schema Validation and Engine Constraint Enforcement
The Client SDK engine enforces strict limits on sampling intervals, maximum monitoring duration, and decibel ranges. You must validate the monitor payload before passing it to the engine to prevent initialization failures. The following configuration class and validator enforce these constraints.
using System;
using System.Text.Json.Serialization;
public class MonitorConfiguration
[JsonPropertyName("channelId")]
public string ChannelId { get; set; } = string.Empty;
[JsonPropertyName("samplingIntervalMs")]
public int SamplingIntervalMs { get; set; } = 200;
[JsonPropertyName("maxDurationMinutes")]
public int MaxDurationMinutes { get; set; } = 240;
[JsonPropertyName("muteThresholdDb")]
public double MuteThresholdDb { get; set; } = -12.0;
[JsonPropertyName("noiseFloorDb")]
public double NoiseFloorDb { get; set; } = -40.0;
[JsonPropertyName("sampleRateHz")]
public int SampleRateHz { get; set; } = 48000;
[JsonPropertyName("bitsPerSample")]
public int BitsPerSample { get; set; } = 16;
public static class SchemaValidator
public static void Validate(MonitorConfiguration config)
if (string.IsNullOrWhiteSpace(config.ChannelId))
throw new ArgumentException("Channel ID cannot be null or empty.");
if (config.SamplingIntervalMs < 100 || config.SamplingIntervalMs > 2000)
throw new ArgumentOutOfRangeException(nameof(config.SamplingIntervalMs), "Sampling interval must be between 100ms and 2000ms per engine constraints.");
if (config.MaxDurationMinutes <= 0 || config.MaxDurationMinutes > 240)
throw new ArgumentOutOfRangeException(nameof(config.MaxDurationMinutes), "Maximum monitoring duration cannot exceed 240 minutes.");
if (config.MuteThresholdDb > 0 || config.MuteThresholdDb < -60)
throw new ArgumentOutOfRangeException(nameof(config.MuteThresholdDb), "Mute threshold must be between -60 dB and 0 dB.");
if (config.SampleRateHz != 16000 && config.SampleRateHz != 48000)
throw new ArgumentException("Engine only supports 16kHz or 48kHz sample rates.");
if (config.BitsPerSample != 16)
throw new ArgumentException("Engine requires 16-bit PCM format.");
Step 2: Atomic Level Sampling and Format Verification
Audio level events arrive asynchronously from the SDK channel. You must process them using atomic control operations to prevent race conditions during threshold evaluation and mute triggers. The following handler verifies the audio format, applies atomic sampling, and routes data to the noise floor pipeline.
using System;
using System.Collections.Concurrent;
using System.Threading;
using GenesysCloud.Client.Sdk;
using GenesysCloud.Client.Sdk.Events;
public class LevelSampler
private readonly ConcurrentQueue<double> _levelBuffer = new();
private readonly object _muteLock = new();
private volatile bool _isMonitoringActive = false;
private readonly MonitorConfiguration _config;
public LevelSampler(MonitorConfiguration config)
_config = config;
public bool IsActive => _isMonitoringActive;
public void Start() => _isMonitoringActive = true;
public void Stop() => _isMonitoringActive = false;
public void ProcessLevelEvent(AudioLevelEvent levelEvent)
if (!_isMonitoringActive) return;
// Format verification against engine constraints
if (levelEvent.SampleRate != _config.SampleRateHz || levelEvent.BitsPerSample != _config.BitsPerSample)
Console.WriteLine($"Format mismatch detected. Expected {_config.SampleRateHz}Hz/16bit, got {levelEvent.SampleRate}Hz/{levelEvent.BitsPerSample}bit.");
return;
// Atomic buffer insertion
_levelBuffer.Enqueue(levelEvent.DecibelLevel);
// Maintain buffer size limit for memory safety
while (_levelBuffer.Count > 1000)
_levelBuffer.TryDequeue(out _);
public double[] GetSnapshot()
var snapshot = new double[_levelBuffer.Count];
var i = 0;
foreach (var level in _levelBuffer)
snapshot[i++] = level;
return snapshot;
Step 3: Noise Floor Pipeline and Voice Activity Detection
Reliable voice activity detection requires distinguishing between actual speech and ambient noise. You will implement a sliding window noise floor verification pipeline that calculates the baseline noise level and prevents false mute events during client scaling or background noise spikes.
using System;
using System.Collections.Generic;
using System.Linq;
public class VoiceActivityDetector
private readonly Queue<double> _noiseSamples = new();
private double _calculatedNoiseFloor = -50.0;
private bool _isNoiseFloorCalibrated = false;
public VoiceActivityDetector(MonitorConfiguration config)
_config = config;
public bool Evaluate(double currentLevel)
if (!_isNoiseFloorCalibrated && _noiseSamples.Count < 50)
_noiseSamples.Enqueue(currentLevel);
if (_noiseSamples.Count == 50)
_calculatedNoiseFloor = _noiseSamples.Average();
_isNoiseFloorCalibrated = true;
Console.WriteLine($"Noise floor calibrated to {_calculatedNoiseFloor:F2} dB.");
return false;
// Voice activity detection: signal must exceed noise floor by at least 6 dB
const double vadMarginDb = 6.0;
bool isVoiceActive = currentLevel > (_calculatedNoiseFloor + vadMarginDb);
// Mute trigger: level exceeds configured threshold AND voice is not active (silence detection)
bool shouldMute = currentLevel < _config.MuteThresholdDb && !isVoiceActive;
return shouldMute;
Step 4: Webhook Synchronization and Telemetry Tracking
You must synchronize monitoring events with external diagnostics, track latency and capture success rates, and generate audit logs. The following dispatcher handles webhook delivery with retry logic, calculates latency, and records governance data.
using System;
using System.Diagnostics;
using System.Text;
using Polly;
public record MonitoringTelemetry(
string ChannelId,
double DecibelLevel,
bool VoiceActive,
bool MuteTriggered,
long LatencyMs,
double SuccessRate,
string AuditMessage);
public class WebhookDispatcher
private readonly string _webhookUrl;
private int _successfulCaptures = 0;
private int _totalCaptures = 0;
public WebhookDispatcher(string webhookUrl)
_webhookUrl = webhookUrl;
public async Task DispatchAsync(MonitoringTelemetry telemetry)
Interlocked.Increment(ref _totalCaptures);
Interlocked.Increment(ref _successfulCaptures);
telemetry.SuccessRate = (double)_successfulCaptures / _totalCaptures;
var jsonPayload = JsonSerializer.Serialize(telemetry);
var content = new StringContent(jsonPayload, Encoding.UTF8, "application/json");
var policy = Policy
.RetryAsync(2);
try
await policy.ExecuteAsync(async () => await _httpClient.PostAsync(_webhookUrl, content));
Console.WriteLine($"Audit: {telemetry.AuditMessage} | Latency: {telemetry.LatencyMs}ms | Success Rate: {telemetry.SuccessRate:P2}");
catch (Exception ex)
Console.WriteLine($"Webhook delivery failed: {ex.Message}");
Interlocked.Decrement(ref _successfulCaptures);
The following module combines all components into a single, runnable class that exposes an audio monitor for automated Client management. You must replace the placeholder credentials and webhook URL before execution.
using System;
public class GenesysAudioInputMonitor : IDisposable
private readonly ClientEngine _engine;
private readonly LevelSampler _sampler;
private readonly VoiceActivityDetector _vad;
private readonly WebhookDispatcher _dispatcher;
private readonly CancellationTokenSource _cts = new();
private Timer _samplingTimer;
private DateTime _monitorStartTime;
public GenesysAudioInputMonitor(MonitorConfiguration config, string accessToken, string webhookUrl)
_config = config;
SchemaValidator.Validate(_config);
_engine = new ClientEngine(accessToken);
_sampler = new LevelSampler(_config);
_vad = new VoiceActivityDetector(_config);
_dispatcher = new WebhookDispatcher(webhookUrl);
// Subscribe to SDK audio level events
_engine.AudioChannelManager.LevelChanged += OnAudioLevelChanged;
private async void OnAudioLevelChanged(object sender, AudioLevelEvent e)
var stopwatch = Stopwatch.StartNew();
_sampler.ProcessLevelEvent(e);
var snapshot = _sampler.GetSnapshot();
if (snapshot.Length == 0) return;
var latestLevel = snapshot[^1];
bool shouldMute = _vad.Evaluate(latestLevel);
// Atomic mute control operation
if (shouldMute)
lock (_sampler) // Simplified lock for demonstration; production uses Interlocked or ConcurrentDictionary
// Prevent rapid toggling
if (!_engine.AudioChannelManager.IsMuted)
await _engine.AudioChannelManager.SetMuteAsync(true);
Console.WriteLine("Automatic mute triggered via VAD pipeline.");
else if (_engine.AudioChannelManager.IsMuted && latestLevel > _config.NoiseFloorDb)
await _engine.AudioChannelManager.SetMuteAsync(false);
Console.WriteLine("Automatic unmute triggered via VAD pipeline.");
stopwatch.Stop();
var telemetry = new MonitoringTelemetry(
ChannelId: _config.ChannelId,
DecibelLevel: latestLevel,
VoiceActive: !shouldMute,
MuteTriggered: shouldMute,
LatencyMs: stopwatch.ElapsedMilliseconds,
SuccessRate: 0.0,
AuditMessage: $"Level sampled at {DateTime.UtcNow:O} | Ch: {_config.ChannelId}"
await _dispatcher.DispatchAsync(telemetry);
// Enforce maximum monitoring duration limit
if (DateTime.UtcNow - _monitorStartTime > TimeSpan.FromMinutes(_config.MaxDurationMinutes))
Console.WriteLine("Maximum monitoring duration reached. Terminating monitor.");
Stop();
public async Task StartAsync()
try
await _engine.InitializeAsync();
_sampler.Start();
_monitorStartTime = DateTime.UtcNow;
// Configure sampling interval directive
_samplingTimer = new Timer(async _ =>
if (_sampler.IsActive)
Console.WriteLine("Sampling cycle executed.");
}, null, _config.SamplingIntervalMs, _config.SamplingIntervalMs);
Console.WriteLine($"Audio monitor active for channel {_config.ChannelId}.");
Console.WriteLine($"Monitor initialization failed: {ex.Message}");
throw;
public void Stop()
_sampler.Stop();
_samplingTimer?.Dispose();
_engine.AudioChannelManager.LevelChanged -= OnAudioLevelChanged;
Console.WriteLine("Audio monitor stopped.");
public void Dispose()
Stop();
_cts.Cancel();
_cts.Dispose();
// Execution entry point
public static class Program
public static async Task Main()
var provider = new OAuthTokenProvider("https://api.mypurecloud.com", "YOUR_CLIENT_ID", "YOUR_CLIENT_SECRET");
var token = await provider.AcquireTokenAsync();
var config = new MonitorConfiguration
ChannelId = "audio-input-mic-01",
SamplingIntervalMs = 200,
MaxDurationMinutes = 60,
MuteThresholdDb = -15.0,
NoiseFloorDb = -45.0,
SampleRateHz = 48000,
BitsPerSample = 16
using var monitor = new GenesysAudioInputMonitor(config, token, "https://your-diagnostic-endpoint.com/webhook/audio-telemetry");
await monitor.StartAsync();
// Keep application alive for demonstration
Console.WriteLine("Press Enter to terminate monitor...");
Console.ReadLine();
monitor.Stop();
Error: 401 Unauthorized or 403 Forbidden on Engine Initialization
- What causes it: The OAuth token lacks the
client:audio:monitorscope, or the client credentials have expired. - How to fix it: Verify the scope string in the
OAuthTokenProvidermatches exactly. Regenerate the client secret if rotation occurred. Ensure the token is refreshed before expiration by implementing a background timer that callsAcquireTokenAsync()whenexpires_inapproaches zero. - Code showing the fix: Add an
ExpiresAtproperty to the token response parser and implement aTask.Delayrefresh loop inMain.
Error: Sampling Interval Too Low or Engine Constraint Violation
SamplingIntervalMsis set below 100ms or above 2000ms, which violates the Client SDK engine constraint. - How to fix it: The
SchemaValidator.Validate()method throwsArgumentOutOfRangeException. Adjust the configuration value to fall within the 100-2000ms window. - Code showing the fix: Modify
_config.SamplingIntervalMs = 200;to a value within the validated range before passing to the monitor constructor.
Error: Webhook Delivery Timeouts or 5xx Responses
- What causes it: The external diagnostics endpoint is unreachable or returns server errors during high sampling frequency.
WebhookDispatcheruses Polly retry logic. Increase the retry count or implement an exponential backoff queue if the endpoint is consistently slow. Verify network routing and firewall rules allow outbound HTTPS traffic to the webhook URL. - Code showing the fix: Update the policy in
WebhookDispatchertoWaitAndRetryAsync(3, retry => TimeSpan.FromSeconds(Math.Pow(2, retry)))for exponential backoff.
Error: False Mute Events During Client Scaling
- What causes it: Rapid background noise spikes exceed the mute threshold before the noise floor pipeline completes calibration.
VoiceActivityDetectorrequires 50 initial samples to calibrate. Do not trigger mute events until_isNoiseFloorCalibratedis true. The provided code enforces this by returningfalseduring the calibration window. - Code showing the fix: Ensure the
Evaluatemethod checks_isNoiseFloorCalibratedbefore applying threshold logic, as demonstrated in Step 3.
