Monitor NICE CXone Agent Assist Activity with Go and Real-Time WebSocket Streams
- This script constructs validated monitoring payloads, subscribes to real-time agent assist events via WebSocket, calculates anomaly scores, filters false positives, syncs alerts to external quality management webhooks, and generates governance audit logs.
- The implementation uses the NICE CXone v2 REST API for authentication and agent assist session validation, combined with the CXone real-time events WebSocket stream for live monitoring.
- The code is written in Go 1.21+ using the standard library and the gorilla/websocket package for production-grade streaming.
- OAuth 2.0 Confidential Client registered in the NICE CXone developer portal
- Required scopes:
agentassist:read,quality:read,events:subscribe,webhook:write - NICE CXone API version: v2
- Go runtime: 1.21 or higher
- External dependencies:
github.com/gorilla/websocket,github.com/go-resty/resty/v2 - Access to a CXone tenant with Agent Assist rules enabled and real-time event streaming authorized
NICE CXone uses a standard OAuth 2.0 client credentials flow. The token endpoint requires your tenant subdomain, client ID, client secret, and the requested scopes. Tokens expire after one hour, so production code must implement caching and automatic refresh on 401 Unauthorized responses.
package main
import (
"bytes"
"encoding/json"
"fmt"
"net/http"
"time"
type OAuthResponse struct {
Scope string `json:"scope"`
func fetchOAuthToken(tenant, clientID, clientSecret string) (*OAuthResponse, error) {
url := fmt.Sprintf("https://%s.api.nicecv.com/api/v2/oauth/token", tenant)
payload := map[string]string{
"client_id": clientID,
"client_secret": clientSecret,
"scope": "agentassist:read quality:read events:subscribe webhook:write",
jsonBody, err := json.Marshal(payload)
if err != nil {
return nil, fmt.Errorf("failed to marshal oauth payload: %w", err)
req, err := http.NewRequest("POST", url, bytes.NewBuffer(jsonBody))
if err != nil {
return nil, fmt.Errorf("failed to create oauth request: %w", err)
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return nil, fmt.Errorf("oauth token request failed with status %d", resp.StatusCode)
var tokenResp OAuthResponse
return nil, fmt.Errorf("failed to decode oauth response: %w", err)
return &tokenResp, nil
The fetchOAuthToken function handles the initial handshake. In a long-running monitor, you would cache this token and refresh it when resp.StatusCode == 401 or when time.Since(tokenAcquiredTime) > time.Duration(resp.ExpiresIn-300)*time.Second. The scope string explicitly declares the permissions required for agent assist reads, event subscriptions, and webhook writes.
Step 1: Construct Monitoring Payloads with activity-ref, agent-matrix, and observe Directives
The monitoring payload defines what the system tracks. The activity-ref field binds the monitor to a specific CXone session or conversation identifier. The agent-matrix defines routing constraints, skill requirements, and concurrent session limits. The observe directive configures the real-time event subscription filters.
type ActivityRef struct {
SessionID string `json:"session_id"`
AgentID string `json:"agent_id"`
Channel string `json:"channel"`
type AgentMatrix struct {
SkillSet []string `json:"skill_set"`
MaxConcurrent int `json:"max_concurrent_sessions"`
RoutingGroup string `json:"routing_group"`
AgentConstraints string `json:"agent_constraints"`
MaxMonitoringWindow int `json:"maximum_monitoring_window_minutes"`
type ObserveDirective struct {
EventTypes []string `json:"event_types"`
AggregationWindow string `json:"aggregation_window"`
AnomalyThreshold float64 `json:"anomaly_threshold"`
FormatVerification bool `json:"format_verification"`
type MonitoringPayload struct {
ActivityRef ActivityRef `json:"activity_ref"`
AgentMatrix AgentMatrix `json:"agent_matrix"`
ObserveDirective ObserveDirective `json:"observe"`
func buildMonitoringPayload(sessionID, agentID, channel, routingGroup string, skills []string, maxConcurrent, maxWindow int) *MonitoringPayload {
return &MonitoringPayload{
ActivityRef: ActivityRef{
SessionID: sessionID,
AgentID: agentID,
Channel: channel,
AgentMatrix: AgentMatrix{
SkillSet: skills,
MaxConcurrent: maxConcurrent,
RoutingGroup: routingGroup,
AgentConstraints: "standard_compliance",
MaxMonitoringWindow: maxWindow,
ObserveDirective: ObserveDirective{
EventTypes: []string{"agentassist:trigger", "agentassist:complete", "conversation:status_change"},
AggregationWindow: "PT2M",
AnomalyThreshold: 2.5,
FormatVerification: true,
Timestamp: time.Now(),
The buildMonitoringPayload function centralizes configuration. The observe directive specifies which CXone real-time event types to subscribe to, the sliding window for event aggregation, and the statistical threshold for anomaly detection. The format_verification flag enables strict JSON schema validation on incoming WebSocket frames.
Step 2: Validate Monitoring Schemas Against agent-constraints and maximum-monitoring-window Limits
Before subscribing to live streams, the payload must pass validation against CXone agent constraints and monitoring window limits. This prevents monitoring failures caused by exceeding concurrent session caps or violating compliance windows.
func validateMonitoringPayload(payload *MonitoringPayload, httpClient *http.Client, tenant, token string) error {
if payload.AgentMatrix.MaxMonitoringWindow > 240 {
return fmt.Errorf("maximum_monitoring_window exceeds CXone limit of 240 minutes")
if payload.AgentMatrix.MaxConcurrent < 1 || payload.AgentMatrix.MaxConcurrent > 5 {
return fmt.Errorf("max_concurrent_sessions must be between 1 and 5")
// Verify agent exists and is active via CXone API
agentURL := fmt.Sprintf("https://%s.api.nicecv.com/api/v2/users/%s", tenant, payload.ActivityRef.AgentID)
req, _ := http.NewRequest("GET", agentURL, nil)
resp, err := httpClient.Do(req)
if err != nil {
return fmt.Errorf("agent validation request failed: %w", err)
time.Sleep(2 * time.Second)
return validateMonitoringPayload(payload, httpClient, tenant, token)
return fmt.Errorf("agent validation failed with status %d", resp.StatusCode)
var agentData map[string]interface{}
if err := json.NewDecoder(resp.Body).Decode(&agentData); err != nil {
return fmt.Errorf("failed to decode agent data: %w", err)
if status, ok := agentData["state"].(string); !ok || status != "ONLINE" {
return fmt.Errorf("agent %s is not in ONLINE state", payload.ActivityRef.AgentID)
return nil
The validation function enforces hard limits defined by CXone architecture. It checks the maximum-monitoring-window against the platform limit of 240 minutes, validates the max_concurrent_sessions range, and performs a live API call to verify the agent exists and holds an ONLINE state. The function includes a retry mechanism for 429 responses to handle rate-limit cascades safely.
Step 3: Handle Event Aggregation and Anomaly Detection via Atomic WebSocket Operations
Real-time monitoring requires a persistent WebSocket connection to the CXone events stream. The client must parse incoming frames atomically, aggregate events within the configured window, and calculate anomaly scores using deviation from baseline metrics.
import (
"encoding/json"
"fmt"
"log"
"math"
"sync"
"time"
"github.com/gorilla/websocket"
type EventRecord struct {
EventType string `json:"event_type"`
Payload map[string]interface{} `json:"payload"`
type AggregationBuffer struct {
mu sync.Mutex
events []EventRecord
window time.Duration
scores []float64
func (b *AggregationBuffer) AddEvent(evt EventRecord) {
b.mu.Lock()
defer b.mu.Unlock()
b.events = append(b.events, evt)
b.pruneOldEvents()
b.calculateAnomalyScore()
func (b *AggregationBuffer) pruneOldEvents() {
cutoff := time.Now().Add(-b.window)
valid := make([]EventRecord, 0)
for _, e := range b.events {
if !e.Timestamp.Before(cutoff) {
valid = append(valid, e)
b.events = valid
func (b *AggregationBuffer) calculateAnomalyScore() {
if len(b.events) < 3 {
return
sum := 0.0
if dur, ok := e.Payload["duration"].(float64); ok {
sum += dur
mean := sum / float64(len(b.events))
variance := 0.0
variance += math.Pow(dur-mean, 2)
stdDev := math.Sqrt(variance / float64(len(b.events)))
if stdDev > 0 {
anomaly := mean / stdDev
b.scores = append(b.scores, anomaly)
func startWebSocketStream(tenant, token string, payload *MonitoringPayload, buffer *AggregationBuffer) {
wsURL := fmt.Sprintf("wss://%s.api.nicecv.com/api/v2/events/stream", tenant)
header := http.Header{}
header.Set("Authorization", "Bearer "+token)
header.Set("Accept", "application/json")
conn, _, err := websocket.DefaultDialer.Dial(wsURL, header)
if err != nil {
log.Fatalf("WebSocket connection failed: %v", err)
defer conn.Close()
// Send subscription directive
subPayload := map[string]interface{}{
"action": "subscribe",
"filters": map[string]interface{}{
"event_types": payload.ObserveDirective.EventTypes,
"agent_id": payload.ActivityRef.AgentID,
if err := conn.WriteJSON(subPayload); err != nil {
log.Printf("Failed to send subscription: %v", err)
return
for {
_, message, err := conn.ReadMessage()
if err != nil {
log.Printf("WebSocket read error: %v", err)
break
var evt map[string]interface{}
if err := json.Unmarshal(message, &evt); err != nil {
if payload.ObserveDirective.FormatVerification {
log.Printf("Format verification failed: %v", err)
record := EventRecord{
EventType: evt["type"].(string),
Payload: evt,
buffer.AddEvent(record)
The WebSocket handler establishes a persistent connection to wss://{tenant}.api.nicecv.com/api/v2/events/stream. It sends a subscription payload filtering by event type and agent ID. Incoming frames are unmarshaled, validated against the format_verification flag, and pushed into an AggregationBuffer. The buffer uses a mutex to ensure atomic updates, prunes events outside the aggregation_window, and calculates a Z-score-like anomaly metric based on duration variance. When the score exceeds the anomaly_threshold, the system triggers downstream alerts.
Step 4: Implement Inactive-Session Checking and False-Positive Verification Pipelines
Raw anomaly scores generate excessive noise during agent breaks, system handoffs, or idle periods. The verification pipeline filters inactive sessions and suppresses false positives before alerting.
type AlertConfig struct {
Threshold float64
InactiveSuppression bool
FalsePositiveWindow time.Duration
func verifyAlert(buffer *AggregationBuffer, config AlertConfig, payload *MonitoringPayload) (bool, string) {
buffer.mu.Lock()
defer buffer.mu.Unlock()
if len(buffer.scores) == 0 {
return false, "no_scores"
latestScore := buffer.scores[len(buffer.scores)-1]
if latestScore < config.Threshold {
return false, "below_threshold"
// Inactive session check
lastEvent := buffer.events[len(buffer.events)-1]
if state, ok := lastEvent.Payload["agent_state"].(string); ok && config.InactiveSuppression {
if state == "IDLE" || state == "BREAK" || state == "OFFLINE" {
return false, "inactive_session"
// False positive verification: check if anomaly persists across window
sustained := false
for i := len(buffer.scores) - 1; i >= 0 && i >= len(buffer.scores)-3; i-- {
if buffer.scores[i] >= config.Threshold {
sustained = true
if !sustained {
return false, "transient_spike"
return true, "confirmed_anomaly"
The verifyAlert function enforces strict alerting hygiene. It checks the latest anomaly score against the threshold, verifies the agent is not in an IDLE, BREAK, or OFFLINE state, and confirms the anomaly persists across at least three consecutive buffer cycles. This pipeline eliminates alert fatigue during CXone scaling events or routine agent state transitions.
Step 5: Synchronize with External QM Webhooks, Track Latency, and Generate Audit Logs
Confirmed anomalies must synchronize with external quality management systems via webhooks. The monitor tracks latency, records success rates, and writes structured audit logs for governance compliance.
type AuditLog struct {
Event string `json:"event"`
LatencyMs int64 `json:"latency_ms"`
Success bool `json:"success"`
ErrorMessage string `json:"error_message,omitempty"`
var (
latencyTracker []int64
successCounter int
totalAttempts int
func syncToExternalQM(webhookURL, token string, payload *MonitoringPayload, auditLogs *[]AuditLog) error {
start := time.Now()
totalAttempts++
qmPayload := map[string]interface{}{
"source": "cxone_agent_monitor",
"session_id": payload.ActivityRef.SessionID,
"alert_type": "anomaly_detected",
"timestamp": time.Now().UTC().Format(time.RFC3339),
"compliance_ref": payload.AgentMatrix.AgentConstraints,
jsonBody, _ := json.Marshal(qmPayload)
req, _ := http.NewRequest("POST", webhookURL, bytes.NewBuffer(jsonBody))
resp, err := http.DefaultClient.Do(req)
latency := time.Since(start).Milliseconds()
latencyTracker = append(latencyTracker, latency)
if err != nil || resp.StatusCode >= 400 {
totalAttempts++
logEntry := AuditLog{
AgentID: payload.ActivityRef.AgentID,
SessionID: payload.ActivityRef.SessionID,
Event: "webhook_sync_failed",
LatencyMs: latency,
Success: false,
ErrorMessage: err.Error(),
*auditLogs = append(*auditLogs, logEntry)
return fmt.Errorf("webhook sync failed: %v", err)
successCounter++
Event: "webhook_sync_success",
LatencyMs: latency,
Success: true,
return nil
func getMonitorEfficiency() (float64, float64) {
if len(latencyTracker) == 0 {
return 0, 0
var sum int64
for _, l := range latencyTracker {
sum += l
avgLatency := float64(sum) / float64(len(latencyTracker))
successRate := float64(successCounter) / float64(totalAttempts) * 100
return avgLatency, successRate
The syncToExternalQM function posts confirmed alerts to an external quality management webhook. It tracks request latency, increments success/failure counters, and appends structured audit logs. The getMonitorEfficiency function calculates average latency and success rate for operational visibility. This data supports governance reviews and monitor optimization during high-volume CXone deployments.
package main
import (
"bytes"
"encoding/json"
"fmt"
"log"
"math"
"net/http"
"sync"
"time"
mu sync.Mutex
scores []float64
Threshold float64
var (
successCounter int
totalAttempts int
jsonBody, _ := json.Marshal(payload)
req, _ := http.NewRequest("POST", url, bytes.NewBuffer(jsonBody))
if err != nil {
return nil, err
return nil, fmt.Errorf("oauth failed: %d", resp.StatusCode)
var tok OAuthResponse
json.NewDecoder(resp.Body).Decode(&tok)
return &tok, nil
func validateMonitoringPayload(payload *MonitoringPayload, tenant, token string) error {
return fmt.Errorf("maximum_monitoring_window exceeds 240 minutes")
if err != nil {
return err
return validateMonitoringPayload(payload, tenant, token)
return fmt.Errorf("agent validation failed: %d", resp.StatusCode)
var agent map[string]interface{}
json.NewDecoder(resp.Body).Decode(&agent)
if status, ok := agent["state"].(string); !ok || status != "ONLINE" {
return fmt.Errorf("agent not online")
return nil
b.mu.Lock()
defer b.mu.Unlock()
b.events = valid
if len(b.events) >= 3 {
sum := 0.0
sum += dur
variance := 0.0
if stdDev > 0 {
b.scores = append(b.scores, mean/stdDev)
func verifyAlert(buffer *AggregationBuffer, config AlertConfig) bool {
buffer.mu.Lock()
return false
latest := buffer.scores[len(buffer.scores)-1]
if latest < config.Threshold {
return false
last := buffer.events[len(buffer.events)-1]
if state, ok := last.Payload["agent_state"].(string); ok && config.InactiveSuppression {
return false
return true
start := time.Now()
totalAttempts++
*auditLogs = append(*auditLogs, AuditLog{
Timestamp: time.Now(), AgentID: payload.ActivityRef.AgentID, SessionID: payload.ActivityRef.SessionID,
Event: "webhook_failed", LatencyMs: latency, Success: false, ErrorMessage: err.Error(),
return err
successCounter++
Event: "webhook_success", LatencyMs: latency, Success: true,
return nil
func main() {
tenant := "your-tenant"
clientID := "your-client-id"
clientSecret := "your-client-secret"
agentID := "agent-12345"
sessionID := "sess-67890"
webhookURL := "https://your-external-qm.com/api/alerts"
tok, err := fetchOAuthToken(tenant, clientID, clientSecret)
if err != nil {
log.Fatalf("Auth failed: %v", err)
payload := &MonitoringPayload{
ActivityRef: ActivityRef{SessionID: sessionID, AgentID: agentID, Channel: "voice"},
SkillSet: []string{"support", "billing"},
MaxConcurrent: 3,
RoutingGroup: "tier1",
AgentConstraints: "standard",
MaxMonitoringWindow: 120,
EventTypes: []string{"agentassist:trigger", "conversation:status_change"},
if err := validateMonitoringPayload(payload, tenant, tok.AccessToken); err != nil {
log.Fatalf("Validation failed: %v", err)
buffer := &AggregationBuffer{window: 2 * time.Minute}
config := AlertConfig{Threshold: payload.ObserveDirective.AnomalyThreshold, InactiveSuppression: true}
var auditLogs []AuditLog
header.Set("Authorization", "Bearer "+tok.AccessToken)
if err != nil {
log.Fatalf("WS failed: %v", err)
defer conn.Close()
sub := map[string]interface{}{"action": "subscribe", "filters": map[string]interface{}{"agent_id": agentID}}
conn.WriteJSON(sub)
for {
_, msg, err := conn.ReadMessage()
if err != nil {
log.Printf("WS read error: %v", err)
break
if err := json.Unmarshal(msg, &evt); err != nil {
buffer.AddEvent(EventRecord{Timestamp: time.Now(), EventType: evt["type"].(string), Payload: evt})
if verifyAlert(buffer, config) {
syncToExternalQM(webhookURL, tok.AccessToken, payload, &auditLogs)
avgLat, successRate := 0.0, 0.0
if len(latencyTracker) > 0 {
var sum int64
sum += l
avgLat = float64(sum) / float64(len(latencyTracker))
successRate = float64(successCounter) / float64(totalAttempts) * 100
fmt.Printf("Monitor stopped. Avg Latency: %.2fms, Success Rate: %.2f%%\n", avgLat, successRate)
Error: 401 Unauthorized during WebSocket handshake or REST calls
- Cause: The OAuth token expired or was rejected by the CXone gateway.
- Fix: Implement token caching with a 5-minute early refresh buffer. When a
401response occurs, immediately callfetchOAuthTokenagain, update the cached token, and retry the failed request. - Code adjustment: Wrap REST and WebSocket send operations in a retry loop that checks
resp.StatusCode == 401and triggers a fresh token fetch before reattempting.
Error: 429 Too Many Requests during agent validation or event polling
- Cause: Exceeding CXone rate limits, typically 100 requests per minute per client ID for REST endpoints.
- Fix: Implement exponential backoff with jitter. The
validateMonitoringPayloadfunction already includes a 2-second sleep and recursive retry on429. For high-volume production deployments, add a token bucket limiter to throttle outbound requests. - Code adjustment: Use
time.Sleep(time.Duration(backoff)*time.Second)wherebackoffdoubles on consecutive429responses, capped at 30 seconds.
Error: WebSocket frame format verification failure
- Cause: CXone sends control frames or malformed JSON during stream initialization or tenant scaling events.
- Fix: Enable
format_verificationin theObserveDirectiveand silently discard unparseable frames. Log the error for audit purposes without breaking the connection loop. - Code adjustment: The
json.Unmarshalblock in the main loop already continues on error. Add structured logging to capture frame payloads for platform support tickets if corruption persists.
Error: Anomaly detection triggers false positives during agent state transitions
- Cause: Agents switching to
BREAKorIDLEcause duration metrics to spike artificially. - Fix: The
verifyAlertfunction checksagent_stateand suppresses alerts when the state isIDLE,BREAK, orOFFLINE. Ensure the CXone real-time event stream includes accurate state payloads. - Code adjustment: Verify that the
agent_statefield exists in thePayloadmap before comparison. Add a fallback toconversation:status_changeevents if agent state payloads are delayed.
