Monitor Cognigy.AI Webhook Health via Python SDK with Threshold Alerting and Retry Logic
  • A Python module that creates, validates, and polls Cognigy.AI webhook health monitors, enforces alert thresholds, and tracks latency and uptime metrics.
  • This implementation uses the Cognigy.AI v3 REST API surface with httpx as the transport layer, matching the official cognigy SDK architecture.
  • The code covers Python 3.9+ with production-grade error handling, schema validation, exponential backoff, and APM callback synchronization.
  • OAuth2 client credentials with scopes: webhooks:read monitors:manage
  • Cognigy.AI v3 API access (tenant URL format: https://{tenant}.cognigy.ai)
  • Python 3.9 or higher
  • External dependencies: httpx, pydantic, aiofiles, tenacity
  • Install dependencies: pip install httpx pydantic aiofiles tenacity
Cognigy.AI uses an OAuth2 client credentials flow for programmatic access. The token endpoint requires your client identifier and secret. The following code demonstrates token acquisition, caching, and automatic refresh logic.
import httpx
from typing import Optional
class CognigyAuth:
    def __init__(self, tenant: str, client_id: str, client_secret: str):
        self.base_url = f"https://{tenant}.cognigy.ai"
        self.client_id = client_id
        self.expires_at: float = 0.0
        if self.token and time.time() < self.expires_at:
            return self.token
            response = await client.post(
                f"{self.base_url}/api/v3/auth/token",
                data={
                    "client_id": self.client_id,
                    "scope": "webhooks:read monitors:manage"
            response.raise_for_status()
            payload = response.json()
            self.token = payload["access_token"]
            self.expires_at = time.time() + payload["expires_in"] - 30
            return self.token
The token cache prevents unnecessary authentication calls. The thirty-second buffer ensures the token does not expire mid-request. The required scope monitors:manage is mandatory for monitor creation and status polling.
Step 1: Validate Monitor Count Limits and List Existing Monitors
Cognigy.AI enforces a maximum monitor count per tenant to prevent observability engine overload. You must check existing monitors before creating new ones. The /api/v3/monitors endpoint supports pagination via the limit and offset parameters.
import httpx
class CognigyMonitorClient:
    def __init__(self, auth: CognigyAuth):
        self.auth = auth
        self.base_url = auth.base_url
        self.max_monitors = 50
    async def list_monitors(self, limit: int = 50, offset: int = 0) -> Dict[str, Any]:
        token = await self.auth.get_token()
        headers = {
            "Accept": "application/json"
        params = {"limit": limit, "offset": offset}
        async with httpx.AsyncClient(timeout=15.0) as client:
            response = await client.get(
                f"{self.base_url}/api/v3/monitors",
                headers=headers,
                params=params
            return response.json()
    async def check_monitor_capacity(self) -> bool:
        result = await self.list_monitors(limit=1, offset=0)
        total_count = result.get("total", 0)
        return total_count < self.max_monitors
The response structure follows Cognigy standard pagination:
  "items": [
      "id": "mon_8f3a2c1d",
      "name": "payment-webhook-health",
      "endpointUrl": "https://api.example.com/payments/verify",
      "status": "active",
      "lastChecked": "2024-05-15T10:32:00Z"
  "total": 12,
  "limit": 1,
  "offset": 0
Step 2: Construct Monitor Payload and Validate Against Schema
The monitor payload requires an endpoint URL reference, health metric matrix, and alert threshold directives. Pydantic enforces schema validation before submission to prevent observability engine rejection.
from pydantic import BaseModel, HttpUrl, Field, validator
class HealthMetricMatrix(BaseModel):
    timeout_ms: int = Field(..., ge=100, le=30000)
    retry_count: int = Field(..., ge=0, le=5)
    success_codes: list[int] = Field(default_factory=lambda: [200, 201, 204])
class AlertThresholdDirective(BaseModel):
    failure_rate_percent: float = Field(..., ge=0.0, le=100.0)
    consecutive_failures: int = Field(..., ge=1, le=10)
    latency_threshold_ms: int = Field(..., ge=100, le=60000)
class MonitorPayload(BaseModel):
    name: str = Field(..., min_length=3, max_length=100)
    endpointUrl: HttpUrl
    health_metrics: HealthMetricMatrix
    alert_thresholds: AlertThresholdDirective
    tags: list[str] = Field(default_factory=list)
    @validator("name")
    def name_must_be_alphanumeric(cls, v: str) -> str:
        if not v.replace("-", "").replace("_", "").isalnum():
            raise ValueError("Monitor name must contain only alphanumeric characters, hyphens, or underscores")
        return v
The payload construction maps directly to Cognigy observability constraints. The health_metrics object defines timeout detection checking and response code verification pipelines. The alert_thresholds object defines when the system triggers failure alerts.
import httpx
import json
    # ... previous methods ...
    async def create_monitor(self, payload: MonitorPayload) -> Dict[str, Any]:
        if not await self.check_monitor_capacity():
            raise RuntimeError("Maximum monitor count limit reached. Delete inactive monitors before creating new ones.")
        headers = {
        body = payload.dict(by_alias=True)
                headers=headers,
                content=json.dumps(body)
                await self._handle_rate_limit(response)
    async def _handle_rate_limit(self, response: httpx.Response) -> None:
        retry_after = int(response.headers.get("Retry-After", 5))
        raise httpx.HTTPStatusError("Rate limit exceeded. Retry after backoff.", request=response.request, response=response)
The request cycle includes:
  • Method: POST
  • Path: /api/v3/monitors
  • Headers: Authorization, Content-Type, Accept
  • Body: Validated JSON payload
  • Response: Monitor creation confirmation with assigned identifier
Step 3: Poll Monitor Status with Atomic GET Operations and Retry Logic
Status polling requires atomic GET operations with format verification and automatic retry triggers for safe monitor iteration. The tenacity library handles exponential backoff for transient failures and 429 rate limits.
import asyncio
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
    @retry(
        stop=stop_after_attempt(5),
        wait=wait_exponential(multiplier=1, min=2, max=30),
        retry=retry_if_exception_type((httpx.HTTPStatusError, httpx.TimeoutException))
    async def poll_monitor_status(self, monitor_id: str) -> Dict[str, Any]:
        headers = {
                f"{self.base_url}/api/v3/monitors/{monitor_id}",
                headers=headers
                await asyncio.sleep(float(response.headers.get("Retry-After", 3)))
                raise httpx.HTTPStatusError("Rate limited during polling", request=response.request, response=response)
            data = response.json()
            self._validate_monitor_schema(data)
            return data
    def _validate_monitor_schema(self, data: Dict[str, Any]) -> None:
        required_fields = ["id", "status", "lastCheckResult", "latencyMs", "uptimePercentage"]
        missing = [f for f in required_fields if f not in data]
        if missing:
            raise ValueError(f"Monitor response missing required fields: {', '.join(missing)}")
The polling response structure:
  "status": "healthy",
  "lastCheckResult": {
    "statusCode": 200,
    "responseTimeMs": 142,
    "timestamp": "2024-05-15T10:35:00Z",
    "errorMessage": null
  "latencyMs": 142,
  "uptimePercentage": 99.87,
  "consecutiveFailures": 0
Step 4: Process Results, Track Metrics, and Sync to APM Callbacks
The final step processes latency and uptime rates, triggers alert callbacks when thresholds are breached, and generates audit logs for endpoint governance.
import aiofiles
from datetime import datetime
from typing import Callable, Awaitable
    async def evaluate_health_and_sync(
        self,
        monitor_id: str,
        apm_callback: Callable[[Dict[str, Any]], Awaitable[None]]
        monitor_data = await self.poll_monitor_status(monitor_id)
        latency = monitor_data["latencyMs"]
        uptime = monitor_data["uptimePercentage"]
        status = monitor_data["status"]
        audit_entry = {
            "timestamp": datetime.utcnow().isoformat() + "Z",
            "monitor_id": monitor_id,
            "status": status,
            "latency_ms": latency,
            "uptime_percentage": uptime,
            "consecutive_failures": monitor_data["consecutiveFailures"]
        await self._write_audit_log(audit_entry)
        alert_triggered = False
        if status == "degraded" or status == "down":
            alert_triggered = True
        elif uptime < 99.0:
        elif latency > 5000:
        if alert_triggered:
            await apm_callback({
                "event": "webhook_health_alert",
                "severity": "critical" if status == "down" else "warning",
                "metrics": {
                    "uptime_pct": uptime,
                    "failures": monitor_data["consecutiveFailures"]
        return audit_entry
    async def _write_audit_log(self, entry: Dict[str, Any]) -> None:
        timestamp = datetime.utcnow().strftime("%Y%m%d")
        filename = f"audit_{timestamp}.jsonl"
        async with aiofiles.open(filename, mode="a", encoding="utf-8") as f:
            await f.write(json.dumps(entry) + "\n")
The callback handler synchronizes monitoring events with external APM dashboards. The audit log maintains endpoint governance records in JSON Lines format for easy ingestion by log aggregators.
import asyncio
import httpx
import json
from typing import Dict, Any
# Import classes defined above
# from cognigy_monitor import CognigyAuth, CognigyMonitorClient, MonitorPayload, HealthMetricMatrix, AlertThresholdDirective
async def main():
    # Configuration
    TENANT = "your-tenant"
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    WEBHOOK_URL = "https://api.example.com/payments/verify"
    APM_ENDPOINT = "https://apm.example.com/webhooks/alerts"
    auth = CognigyAuth(TENANT, CLIENT_ID, CLIENT_SECRET)
    client = CognigyMonitorClient(auth)
    # Define monitor configuration
    payload = MonitorPayload(
        name="payment-webhook-health",
        endpointUrl=WEBHOOK_URL,
        health_metrics=HealthMetricMatrix(timeout_ms=5000, retry_count=3, success_codes=[200, 201]),
        alert_thresholds=AlertThresholdDirective(failure_rate_percent=5.0, consecutive_failures=2, latency_threshold_ms=3000),
        tags=["production", "payments", "critical"]
    # Create monitor
    print("Creating monitor...")
    created = await client.create_monitor(payload)
    monitor_id = created["id"]
    print(f"Monitor created: {monitor_id}")
    # Async APM callback handler
    async def send_to_apm(alert_data: Dict[str, Any]) -> None:
        async with httpx.AsyncClient(timeout=10.0) as apm_client:
            await apm_client.post(
                APM_ENDPOINT,
                json=alert_data,
                headers={"Content-Type": "application/json", "X-Source": "cognigy-monitor"}
    # Poll and evaluate
    print("Polling monitor status...")
    result = await client.evaluate_health_and_sync(monitor_id, send_to_apm)
    print(f"Health evaluation complete: {json.dumps(result, indent=2)}")
    asyncio.run(main())
The script initializes authentication, constructs a validated monitor payload, creates the monitor on Cognigy.AI, polls its status with retry logic, evaluates health against thresholds, triggers APM callbacks when necessary, and writes audit logs. Replace the placeholder credentials and endpoints before execution.
  • What causes it: Expired access token, invalid client credentials, or missing scope in the token request.
  • How to fix it: Verify the client_id and client_secret match your Cognigy tenant configuration. Ensure the token request includes webhooks:read monitors:manage. The CognigyAuth class automatically refreshes tokens before expiration.
  • Code showing the fix: The get_token method checks time.time() < self.expires_at and re-fetches when the buffer expires.
Error: 403 Forbidden
  • What causes it: The OAuth client lacks the required scope, or the tenant enforces role-based access control that blocks monitor creation.
  • How to fix it: Grant the monitors:manage scope to the OAuth client in the Cognigy tenant settings. Verify the service account has the Monitor Administrator role.
  • Code showing the fix: Adjust the scope parameter in CognigyAuth.__init__ to include monitors:manage.
  • What causes it: Exceeding Cognigy API rate limits during monitor creation or rapid polling.
  • How to fix it: Implement exponential backoff. The _handle_rate_limit method reads the Retry-After header. The tenacity decorator on poll_monitor_status automatically retries with increasing delays.
  • Code showing the fix: The @retry decorator configuration uses wait_exponential(multiplier=1, min=2, max=30) and catches httpx.HTTPStatusError.
Error: 400 Bad Request (Schema Validation Failure)
  • What causes it: Payload violates observability engine constraints, such as timeout values outside the 100-30000ms range or invalid monitor names.
  • How to fix it: Use the Pydantic models to validate before submission. The MonitorPayload class enforces field constraints and raises descriptive errors.
  • Code showing the fix: payload = MonitorPayload(...) raises pydantic.ValidationError with exact field details before any network call occurs.
Error: 504 Gateway Timeout
  • What causes it: The target webhook endpoint does not respond within the configured timeout, or Cognigy infrastructure experiences transient latency.
  • How to fix it: Increase timeout_ms in HealthMetricMatrix to match your endpoint performance profile. The polling logic treats 504 as a transient failure and retries via the tenacity configuration.
  • Code showing the fix: Set timeout_ms=10000 in the HealthMetricMatrix constructor for slow endpoints.
