Hi, I am sure this is a really obvious problem, but I am stuck.
I need help with getting MOH to play on my SIP phone!
I am using X-lite simphones to test SIP TServer and can’t get MOH to work. Can someone please help?
Here is the log of me calling from 6000 to 6002 and then trying to place call on hold!
6000 : 172.30.0.115
6002: 172.30.0.128
MOH and SIP Tserver: 172.30.0.222
Why or why is it not working?
Best regards,
sipcs: 20:15:44.281 dispatchDE: dlg[161]
sipcs: dialog [161:07@016b6300]: << Event 27 << TRN[191]
Response (0): for CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5
– RegisterQueue: CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5 01B9F090 21073[0,1]
20:15:44.281 — CIFace::Request —
sipcs: 20:15:44.421 Received [368,UDP] 759 bytes from 172.30.0.128:51646 <<<<<
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bKF7ED18EE-BA12-4D78-8D50-DAF6B93AF672-89
Contact: sip:6002@172.30.0.128:51646;rinstance=3a3dbffae576e057
To: sip:6002@172.30.0.222;tag=3e78fe4b
From: "Ali2"sip:6000@172.30.0.222:5060;tag=6cd9f616a3fb4960a795ca8e464b88e1;epid=0331eed221
Call-ID: 29AF4546-C3FC-4C30-9A91-AF82B0F1CDED-75@172.30.0.222
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
Content-Type: application/sdp
User-Agent: X-Lite release 1006e stamp 34025
Content-Length: 187
v=0
o=- 7 3 IN IP4 172.30.0.128
s=CounterPath X-Lite 3.0
c=IN IP4 172.30.0.128
t=0 0
m=audio 44882 RTP/AVP 0 8 3 101
a=fmtp:101 0-15
a=recvonly
a=rtpmap:101 telephone-event/8000
sipcs: 20:15:44.421 dispatchDE: dlg[161]
sipcs: dialog [161:07@016b6300]: << Event 33 << TRN[191]
sipcs: 20:15:44.421 Stored This SDP [161]
sipcs: Acknowledgement
sipcs: 20:15:44.421 Sending [368,UDP] 393 bytes to 172.30.0.128:51646 >>>>>
ACK sip:6002@172.30.0.128:51646;rinstance=3a3dbffae576e057 SIP/2.0
From: “Ali2” sip:6000@172.30.0.222:5060;tag=6cd9f616a3fb4960a795ca8e464b88e1;epid=0331eed221
CSeq: 2 ACK
Content-Length: 0
sipcs: dialog [161:07@016b6300]: << Event 29 << TRN[191]
sipcs: =unmonitor 4[161]
sipcs: =unmonitor 1[161]
sipcs: 20:15:45.046 Sending [368,UDP] 736 bytes to 172.30.0.115:9969 >>>>>
INVITE sip:172.30.0.115:9969 SIP/2.0
From: sip:6002@172.30.0.222;tag=909F66E0-C255-4669-BFED-93464F7B08A4-86
To: “Ali2” sip:6000@172.30.0.222:5060;tag=6cd9f616a3fb4960a795ca8e464b88e1;epid=0331eed221
Call-ID: 025dbca0b1494c4ca26222962301226f@172.30.0.115
CSeq: 1 INVITE
Content-Length: 187
Via: SIP/2.0/UDP 172.30.0.222:5060;branch=z9hG4bKF7ED18EE-BA12-4D78-8D50-DAF6B93AF672-88
Contact: sip:172.30.0.222:5060
Max-Forwards: 70
Session-Expires: 1800;refresher=uac
Min-SE: 90
Supported: 100rel,timer
v=0
o=- 7 2 IN IP4 172.30.0.128
t=0 0
a=fmtp:101 0-15
a=sendonly
sipcs: 20:15:45.578 Received [368,UDP] 4 bytes from 172.30.0.222:8630 <<<<<
sipcs: 20:15:46.250 Sending [368,UDP] 736 bytes to 172.30.0.115:9969 >>>>>
CSeq: 1 INVITE
Content-Length: 187
Max-Forwards: 70
Min-SE: 90
v=0
t=0 0
a=fmtp:101 0-15
a=sendonly
sipcs: 20:15:46.531 Received [368,UDP] 393 bytes from 172.30.0.115:1050 <<<<<
SIP/2.0 100 Trying
CSeq: 1 INVITE
User-Agent: RTC/1.2
Content-Length: 0
sipcs: 20:15:46.531 dispatchDE: dlg[160]
sipcs: dialog [160:07@016f35d0]: << Event 32 << TRN[190]
sipcs: 20:15:46.578 Received [368,UDP] 704 bytes from 172.30.0.115:1050 <<<<<
SIP/2.0 200 OK
CSeq: 1 INVITE
Contact: sip:172.30.0.115:9969
User-Agent: RTC/1.2
Content-Length: 248
v=0
o=- 0 0 IN IP4 172.30.0.115
s=session
c=IN IP4 172.30.0.115
b=CT:1000
t=0 0
m=audio 20386 RTP/AVP 0 8 3 101
a=recvonly
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
sipcs: 20:15:46.578 dispatchDE: dlg[160]
sipcs: dialog [160:07@016f35d0]: << Event 33 << TRN[190]
sipcs: 20:15:46.578 Stored This SDP [160]
sipcs: 20:15:46.578 Sending [368,UDP] 384 bytes to 172.30.0.115:9969 >>>>>
ACK sip:172.30.0.115:9969 SIP/2.0
CSeq: 1 ACK
Content-Length: 0
sipcs: dialog [160:07@016f35d0]: << Event 29 << TRN[190]
sipcs: =unmonitor 4[160]
20:15:46.578 +++ CIFace::Event +++
+++ Pre-event +++
Type EventHeld
Devices: <6000/6000> <6002/6002> <-/->
Calls: 7/006e016782820007/7.016B7488/c:2/r:1 0/none
Parties: <d6000/6000-006e016782820007>.01B9F690/l:1/r:1/Established,Active,Origination
<d6002/6002-006e016782820007>.01B9F320/l:2/r:0/Established,Active,Destination
none
Flags: divert=0 hook=1 postCall=0 active=1 moveAll=1 callType=1
— Pre-event —
Matched with CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5
SetContext: for party 6000.01B9F690-006e016782820007.016B7488
+++ Held +++
SetHeld: party 6000.01B9F690-006e016782820007.016B7488, cause Null
@20:15:46.5780 [0] 7.2.001.18 distribute_response: message EventHeld
AttributeEventSequenceNumber 0000000000000085
AttributeTimeinuSecs 578000
AttributeTimeinSecs 1165922146 (20:15:46)
AttributeReferenceID 5
AttributeOtherDNRole 2
AttributeOtherDN ‘6002’
AttributeDNIS ‘6002’
AttributeCallUUID ‘A2EA2E7C-664B-4923-BDAB-F9E76E5B31DE’
AttributeConnID 006e016782820007
AttributeCallID 7
AttributeCallType 1
AttributeCallState 0
AttributeThisDNRole 1
AttributeAgentID ‘10001’
AttributeThisDN ‘6000’
@20:15:46.5780 [ISCC] Debug: Translate: ‘’ → ‘’; result 1 ()
20:15:46.578 Int 04544 Interaction message “EventHeld” generated
20:15:46.578 Trc 04542 EventHeld sent to 404 (0008 CTISIP_Client)
20:15:46.578 Trc 04542 EventHeld sent to 384 (0002 StatServer)
– TellHeld
— Held —
FinishRequest CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5
IFace stats: q=8 s=4294967288
– complete
+++ Post-event +++
Type EventHeld
Calls: 7/006e016782820007/7.016B7488/c:2/r:0 0/none
Parties: <d6000/6000-006e016782820007>.01B9F690/l:1/r:0/Established,Held,Origination
none
— Post-event —
– deleted: CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5
– AckQueues(): CRequest@01B9E1F0 RequestHoldCall-CTISIP_Client[404]/5 01B9F090
20:15:46.578 — CIFace::Event —
sipcs: =unmonitor 1[160]
SIP/2.0 200 OK
CSeq: 1 INVITE
User-Agent: RTC/1.2
Content-Length: 248
v=0
s=session
b=CT:1000
t=0 0
a=recvonly
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
CSeq: 1 ACK
Content-Length: 0
SIP/2.0 200 OK
CSeq: 1 INVITE
User-Agent: RTC/1.2
Content-Length: 248
v=0
s=session
b=CT:1000
t=0 0
a=recvonly
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
CSeq: 1 ACK
Content-Length: 0
