Modulating Genesys Cloud SIP Codecs and RTP Settings via Telephony API with Go
A production-grade Go module that programmatically configures SIP codecs, jitter buffers, and packetization intervals for a Genesys Cloud telephony edge, validates network constraints, executes atomic updates with fallback triggers, and logs audit events. This tutorial uses the Genesys Cloud Telephony API and the official Go SDK. The implementation covers Go 1.21+.
  • OAuth Client Credentials flow configured in the Genesys Cloud Admin Console
  • Required OAuth scopes: telephony:edge:read, telephony:edge:write
  • Go runtime version 1.21 or higher
  • Official Genesys Cloud Go SDK: github.com/mypurecloud/platform-client-sdk-go/v139
  • Standard library dependencies: net/http, context, encoding/json, time, fmt, log, os
The Genesys Cloud Go SDK manages OAuth token acquisition and refresh automatically when configured with client credentials. You must initialize the configuration object with your environment URL, client ID, and client secret. The SDK caches the access token and handles expiration transparently.
package main
import (
    "github.com/mypurecloud/platform-client-sdk-go/v139/platformclientv2"
func NewGenesysClient(environment, clientId, clientSecret string) *platformclientv2.Configuration {
    cfg := &platformclientv2.Configuration{
        BasePath: "https://" + environment + ".mypurecloud.com",
        AuthConfig: map[string]platformclientv2.Authentication{
            "default": platformclientv2.NewClientCredentialsAuthentication(
                clientId,
                clientSecret,
                "https://"+environment+".mypurecloud.com/oauth/token",
    return cfg
The authentication flow exchanges client credentials for a bearer token. The SDK attaches the token to every subsequent request. You do not need to manually manage token refresh cycles. If the token expires, the SDK intercepts the 401 response and re-authenticates before retrying the original request.
Step 1: Fetch Current Telephony Configuration
You must retrieve the existing telephony settings for the target edge before modification. This ensures you preserve unchanged configuration fields and prevents accidental overwrites. The endpoint returns a Telephony model containing SIP, RTP, and carrier-specific settings.
func GetCurrentTelephonyConfig(cfg *platformclientv2.Configuration, edgeId string) (*platformclientv2.Telephony, error) {
    telephonyApi := platformclientv2.NewTelephonyApi(cfg)
    ctx := context.Background()
    telephony, _, err := telephonyApi.GetTelephonyEdgeTelephony(ctx, edgeId)
    if err != nil {
        return nil, err
    return telephony, nil
Expected Response Structure:
  "sip": {
    "codecs": ["G711Ulaw", "G729"],
    "jitterBuffer": {
      "minSize": 0,
      "maxSize": 200,
      "adjustmentIncrement": 10,
      "adjustmentDecrement": 10,
      "initialSize": 100
    "packetizationInterval": 20,
    "dtmfMode": "RFC2833"
  "rtp": {
    "ipAddress": "10.0.1.5",
    "startPort": 10000,
    "endPort": 20000
Step 2: Construct Modulation Payload
You will build a configuration payload that defines the codec reference array, bandwidth matrix limits, and SDP negotiation directives. The payload must align with Genesys Cloud schema requirements. You will also define jitter buffer parameters and packetization intervals.
type CodecModulationPayload struct {
    Codecs                []string `json:"codecs"`
    BandwidthMatrix       map[string]int `json:"bandwidthMatrix"`
    NegotiateDirective    string   `json:"negotiateDirective"`
    JitterBuffer          JitterConfig `json:"jitterBuffer"`
    PacketizationInterval int        `json:"packetizationInterval"`
type JitterConfig struct {
    MinSize          int `json:"minSize"`
    MaxSize          int `json:"maxSize"`
    AdjustmentInc    int `json:"adjustmentIncrement"`
    AdjustmentDec    int `json:"adjustmentDecrement"`
    InitialSize      int `json:"initialSize"`
You populate the payload with validated values. The NegotiateDirective field controls SDP offer/answer behavior. Setting it to strict forces the edge to reject incompatible carrier codecs. The BandwidthMatrix maps codec identifiers to maximum kilobit-per-second limits.
func BuildModulationPayload(targetCodecs []string, maxPacketLoss float64) CodecModulationPayload {
    return CodecModulationPayload{
        Codecs: targetCodecs,
        BandwidthMatrix: map[string]int{
            "G711Ulaw": 64,
            "G711Alaw": 64,
            "G729":     8,
            "OPUS":     50,
        NegotiateDirective: "strict",
        JitterBuffer: JitterConfig{
            MinSize:       20,
            MaxSize:       300,
            AdjustmentInc: 20,
            AdjustmentDec: 10,
            InitialSize:   120,
        PacketizationInterval: 20,
Step 3: Validate Against Network Constraints and Packet Loss Limits
Before submission, you must validate the payload against network constraints. This step prevents modulation failure caused by incompatible jitter buffer sizes or excessive packetization intervals. You will also verify that the maximum packet loss threshold aligns with the selected codecs.
func ValidateModulationPayload(payload CodecModulationPayload, maxPacketLoss float64) error {
    if payload.JitterBuffer.MinSize > payload.JitterBuffer.MaxSize {
        return fmt.Errorf("jitter buffer min size must not exceed max size")
    if payload.JitterBuffer.InitialSize < payload.JitterBuffer.MinSize || payload.JitterBuffer.InitialSize > payload.JitterBuffer.MaxSize {
        return fmt.Errorf("jitter buffer initial size must fall within defined bounds")
    if payload.PacketizationInterval < 10 || payload.PacketizationInterval > 60 {
        return fmt.Errorf("packetization interval must be between 10 and 60 milliseconds")
    for _, codec := range payload.Codecs {
        if _, exists := payload.BandwidthMatrix[codec]; !exists {
            return fmt.Errorf("missing bandwidth definition for codec %s", codec)
        if codec == "G729" && maxPacketLoss > 0.05 {
            return fmt.Errorf("G729 requires packet loss below 5 percent, current threshold is %.2f", maxPacketLoss)
    return nil
Step 4: Execute Atomic PUT with Fallback Logic
You will perform an atomic update using the Telephony API. The request must include the full telephony model to preserve unrelated settings. You will implement a fallback mechanism that reverts to the previous configuration if the update fails due to SDP incompatibility or edge rejection.
func ApplyModulation(cfg *platformclientv2.Configuration, edgeId string, payload CodecModulationPayload, fallback *platformclientv2.Telephony) error {
    // Convert payload to SDK-compatible Telephony model
    newTelephony := &platformclientv2.Telephony{}
    if fallback != nil {
        *newTelephony = *fallback
    sipSettings := &platformclientv2.Sipsettings{
        Codecs:                &payload.Codecs,
        JitterBuffer:          &platformclientv2.Jitterbuffer{
            MinSize:             &payload.JitterBuffer.MinSize,
            MaxSize:             &payload.JitterBuffer.MaxSize,
            AdjustmentIncrement: &payload.JitterBuffer.AdjustmentInc,
            AdjustmentDecrement: &payload.JitterBuffer.AdjustmentDec,
            InitialSize:         &payload.JitterBuffer.InitialSize,
        PacketizationInterval: &payload.PacketizationInterval,
        DtmfMode:              platformclientv2.PtrString("RFC2833"),
    newTelephony.Sip = sipSettings
    // Execute atomic PUT
    _, httpResponse, err := telephonyApi.PutTelephonyEdgeTelephony(ctx, edgeId, newTelephony)
    if err != nil {
        if httpResponse != nil && httpResponse.StatusCode == 409 {
            // Fallback trigger: revert to previous configuration
            _, _, revertErr := telephonyApi.PutTelephonyEdgeTelephony(ctx, edgeId, fallback)
            if revertErr != nil {
                return fmt.Errorf("modulation failed and revert also failed: %w", revertErr)
            return fmt.Errorf("modulation failed with conflict, reverted to fallback: %w", err)
        return err
    return nil
Full HTTP Request Cycle:
PUT /api/v2/telephony/providers/edges/{edgeId}/telephony HTTP/1.1
Host: api.mypurecloud.com
Accept: application/json
  "sip": {
    "codecs": ["G711Ulaw", "G729", "OPUS"],
    "jitterBuffer": {
      "minSize": 20,
      "maxSize": 300,
      "adjustmentIncrement": 20,
      "initialSize": 120
  "rtp": {
    "startPort": 10000,
    "endPort": 20000
Expected Response:
HTTP/1.1 200 OK
  "sip": {
    "jitterBuffer": {
      "minSize": 20,
      "maxSize": 300,
      "initialSize": 120
  "rtp": {
    "startPort": 10000,
    "endPort": 20000
Step 5: Synchronize Modulating Events via Webhooks and Track Latency
You will notify external PSTN carrier systems about codec changes and record latency metrics. This ensures carrier-side SDP parsers align with the new edge configuration. You will also calculate negotiation success rates for governance reporting.
type ModulationAudit struct {
    Timestamp        string  `json:"timestamp"`
    EdgeId           string  `json:"edgeId"`
    PayloadHash      string  `json:"payloadHash"`
    LatencyMs        float64 `json:"latencyMs"`
    Success          bool    `json:"success"`
    FallbackTriggered bool   `json:"fallbackTriggered"`
func NotifyCarrierWebhook(webhookUrl string, payload CodecModulationPayload) error {
    jsonData, _ := json.Marshal(payload)
    req, err := http.NewRequest("POST", webhookUrl, bytes.NewBuffer(jsonData))
    if err != nil {
        return err
    req.Header.Set("X-Genesys-Event", "codec-modulation-sync")
    resp, err := client.Do(req)
    if err != nil {
        return err
    defer resp.Body.Close()
    if resp.StatusCode >= 400 {
        return fmt.Errorf("webhook notification failed with status %d", resp.StatusCode)
    return nil
func RecordAuditLog(edgeId string, payloadHash string, latencyMs float64, success bool, fallback bool) {
    audit := ModulationAudit{
        Timestamp:         time.Now().UTC().Format(time.RFC3339),
        EdgeId:            edgeId,
        PayloadHash:       payloadHash,
        LatencyMs:         latencyMs,
        Success:           success,
        FallbackTriggered: fallback,
    logData, _ := json.Marshal(audit)
    fmt.Println(string(logData))
    // In production, write to structured logging pipeline or audit database
Step 6: Implement Retry Logic for Rate Limiting
Genesys Cloud enforces API rate limits. You must implement exponential backoff for 429 responses to prevent cascade failures during bulk edge updates.
func RetryWithBackoff(fn func() error) error {
    maxRetries := 3
    for attempt := 0; attempt < maxRetries; attempt++ {
        err := fn()
        if err == nil {
            return nil
        // Parse 429 response and extract retry-after if present
        // For simplicity, we apply standard exponential backoff
        backoff := time.Duration(1<<uint(attempt)) * time.Second
        time.Sleep(backoff)
    return fmt.Errorf("max retries exceeded")
The following script combines all components into a single executable module. It authenticates, fetches the current configuration, validates the modulation payload, applies the update with fallback protection, notifies external webhooks, and records audit logs.
package main
import (
    "bytes"
    "context"
    "encoding/json"
    "fmt"
    "hash/fnv"
    "log"
    "net/http"
    "os"
    "time"
                clientId,
                clientSecret,
    return cfg
    return telephony, err
func BuildModulationPayload(targetCodecs []string) CodecModulationPayload {
            "G711Ulaw": 64,
            "G711Alaw": 64,
            "G729":     8,
            "OPUS":     50,
            MinSize:       20,
            MaxSize:       300,
            AdjustmentInc: 20,
            AdjustmentDec: 10,
            InitialSize:   120,
    return nil
    if err != nil {
        return err
    return nil
    if err != nil {
        return err
    if err != nil {
        return err
    return nil
        EdgeId:            edgeId,
        Success:           success,
    maxRetries := 3
        err := fn()
        if err == nil {
            return nil
        time.Sleep(backoff)
func main() {
    environment := os.Getenv("GENESYS_ENVIRONMENT")
    clientId := os.Getenv("GENESYS_CLIENT_ID")
    clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
    edgeId := os.Getenv("GENESYS_EDGE_ID")
    webhookUrl := os.Getenv("CARRIER_WEBHOOK_URL")
    if environment == "" || clientId == "" || clientSecret == "" || edgeId == "" {
        log.Fatal("Missing required environment variables")
    cfg := NewGenesysClient(environment, clientId, clientSecret)
    // Step 1: Fetch current configuration
    currentConfig, err := GetCurrentTelephonyConfig(cfg, edgeId)
    if err != nil {
        log.Fatalf("Failed to fetch current telephony config: %v", err)
    // Step 2: Build and validate payload
    targetCodecs := []string{"G711Ulaw", "G729", "OPUS"}
    payload := BuildModulationPayload(targetCodecs)
    if err := ValidateModulationPayload(payload, 0.03); err != nil {
        log.Fatalf("Payload validation failed: %v", err)
    // Generate hash for audit tracking
    hash := fnv.New32a()
    hash.Write([]byte(fmt.Sprintf("%v", payload)))
    payloadHash := fmt.Sprintf("%x", hash.Sum32())
    // Step 3: Apply modulation with retry and fallback
    start := time.Now()
    err = RetryWithBackoff(func() error {
        return ApplyModulation(cfg, edgeId, payload, currentConfig)
    latency := time.Since(start).Seconds() * 1000.0
    fallbackTriggered := false
    if err != nil {
        log.Printf("Modulation failed: %v", err)
        fallbackTriggered = true
        RecordAuditLog(edgeId, payloadHash, latency, false, fallbackTriggered)
        return
    // Step 4: Notify carriers and log success
    if webhookUrl != "" {
        if webErr := NotifyCarrierWebhook(webhookUrl, payload); webErr != nil {
            log.Printf("Webhook notification failed: %v", webErr)
    RecordAuditLog(edgeId, payloadHash, latency, true, fallbackTriggered)
    fmt.Println("Codec modulation applied successfully.")
  • Cause: Invalid client credentials, expired OAuth token, or missing telephony:edge:read scope.
  • Fix: Verify the client ID and secret match the Genesys Cloud app registration. Ensure the OAuth app has the required scopes assigned. The SDK handles token refresh automatically, so persistent 401 errors indicate credential misconfiguration.
  • Code Check: Confirm the AuthConfig map uses the correct environment URL for the token endpoint.
Error: 403 Forbidden
  • Cause: The authenticated user or service account lacks the telephony:edge:write scope or does not have Telephony Admin permissions.
  • Fix: Grant the required scope in the OAuth application settings. Assign the user to a security role with Telephony Edge Management permissions.
  • Debugging: Use the /api/v2/oauth/me endpoint to verify active scopes before executing the PUT request.
Error: 409 Conflict
  • Cause: The telephony configuration is locked by another concurrent update, or the SDP negotiation directive conflicts with active carrier sessions.
  • Fix: The fallback logic in the complete example automatically reverts to the previous configuration. Implement queueing for bulk edge updates to prevent concurrent writes.
  • Prevention: Read the current configuration immediately before writing. Use optimistic concurrency by comparing the version field in the response.
  • Cause: Exceeded Genesys Cloud API rate limits during bulk modulation or rapid retry cycles.
  • Fix: The RetryWithBackoff function implements exponential backoff. Parse the Retry-After header from the 429 response for precise timing.
  • Optimization: Batch edge updates and stagger requests using a worker pool with semaphore concurrency limits.
Error: 503 Service Unavailable
  • Cause: The target telephony edge is undergoing maintenance or experiencing network partitioning.
  • Fix: Wait for the edge to return to RUNNING status. Query /api/v2/telephony/providers/edges/{edgeId} to verify edge health before attempting modulation.
  • Fallback: Route traffic to a secondary edge while the primary edge recovers.
