Modulating Genesys Cloud Agent Assist LLM Temperature Settings via Python SDK
  • A Python service that programmatically updates Genesys Cloud Agent Assist prompt configurations with controlled LLM temperature parameters, validates constraints against maximum randomness thresholds, and implements deterministic fallback logic.
  • The implementation uses the official Genesys Cloud Python SDK (genesyscloud) to interact with the /api/v2/agentassist/prompts and /api/v2/platform/webhooks endpoints.
  • The tutorial covers Python 3.9+ with production-grade error handling, audit logging, latency tracking, and webhook synchronization for automated temperature modulation.
  • Genesys Cloud OAuth 2.0 client credentials (confidential client type)
  • Required OAuth scopes: agentassist:prompt:write, agentassist:prompt:read, webhook:write, webhook:read, webhook:manage
  • Genesys Cloud Python SDK version 2.0.0 or higher
  • Python 3.9 runtime
  • External dependencies: pip install genesyscloud requests
Genesys Cloud requires OAuth 2.0 client credentials authentication. The SDK handles token acquisition and caching automatically when initialized with environment variables. The following configuration establishes a secure authentication context with automatic token refresh.
import os
import logging
from genesyscloud.platform_client import PlatformClient
# Configure logging for audit and debugging
logging.basicConfig(
    level=logging.INFO,
    format="%(asctime)s [%(levelname)s] %(name)s - %(message)s"
logger = logging.getLogger("agentassist_modulator")
def initialize_sdk() -> PlatformClient:
    """Initialize the Genesys Cloud SDK with OAuth client credentials."""
    client = PlatformClient()
    client.login(
        client_id=os.environ.get("GENESYS_CLIENT_ID"),
        client_secret=os.environ.get("GENESYS_CLIENT_SECRET"),
        base_url=os.environ.get("GENESYS_BASE_URL", "https://api.mypurecloud.com")
    if not client.authenticated:
        raise RuntimeError("OAuth authentication failed. Verify credentials and scopes.")
    logger.info("SDK authenticated successfully.")
    return client
The SDK caches the access token internally and refreshes it before expiration. You must ensure the registered OAuth client possesses the agentassist:prompt:write scope to modify LLM temperature settings.
LLM temperature modulation requires strict validation against AI constraints. The Genesys Cloud prompt configuration accepts temperature values between 0.0 and 1.0. You must validate the generation matrix, enforce maximum randomness thresholds, and verify token budgets before submission.
from dataclasses import dataclass
from typing import Optional
from genesyscloud.agentassist.models import PromptConfiguration
@dataclass
class TemperatureModulationPayload:
    temperature: float
    max_tokens: int
    top_p: float
    presence_penalty: float
    frequency_penalty: float
    hallucination_suppression: bool
    version: Optional[int] = None
MAX_TEMPERATURE_THRESHOLD = 0.85
MIN_TOKEN_BUDGET = 50
MAX_TOKEN_BUDGET = 4096
def validate_modulation_payload(payload: TemperatureModulationPayload) -> bool:
    """Validate temperature reference, token budget, and hallucination suppression constraints."""
    if not (0.0 <= payload.temperature <= 1.0):
        raise ValueError(f"Temperature {payload.temperature} exceeds valid range [0.0, 1.0]")
    if payload.temperature > MAX_TEMPERATURE_THRESHOLD:
        raise ValueError(f"Temperature {payload.temperature} exceeds maximum randomness threshold {MAX_TEMPERATURE_THRESHOLD}")
    if not (MIN_TOKEN_BUDGET <= payload.max_tokens <= MAX_TOKEN_BUDGET):
        raise ValueError(f"Token budget {payload.max_tokens} outside allowable range [{MIN_TOKEN_BUDGET}, {MAX_TOKEN_BUDGET}]")
    if not (0.0 <= payload.top_p <= 1.0):
        raise ValueError("Top-p must be between 0.0 and 1.0")
    if not (-2.0 <= payload.presence_penalty <= 2.0):
        raise ValueError("Presence penalty must be between -2.0 and 2.0")
    if not (-2.0 <= payload.frequency_penalty <= 2.0):
        raise ValueError("Frequency penalty must be between -2.0 and 2.0")
    if payload.hallucination_suppression and payload.temperature > 0.3:
        logger.warning("High temperature detected with hallucination suppression enabled. Adjusting to deterministic fallback.")
        payload.temperature = 0.0
    return True
def build_prompt_configuration(payload: TemperatureModulationPayload, prompt_id: str) -> PromptConfiguration:
    """Construct the SDK PromptConfiguration model with validated parameters."""
    validate_modulation_payload(payload)
    config = PromptConfiguration(
        id=prompt_id,
        temperature=payload.temperature,
        max_tokens=payload.max_tokens,
        top_p=payload.top_p,
        presence_penalty=payload.presence_penalty,
        frequency_penalty=payload.frequency_penalty,
        custom_properties={
            "modulation_type": "temperature_tune",
            "hallucination_suppression": payload.hallucination_suppression,
            "tune_directive": "agent_guidance_optimization",
            "generation_matrix": f"temp_{payload.temperature}_topp_{payload.top_p}"
    if payload.version is not None:
        config.version = payload.version
    return config
The validation pipeline enforces maximum randomness thresholds and implements hallucination suppression checking. If hallucination suppression is active and temperature exceeds 0.3, the system automatically reduces temperature to 0.0 for deterministic fallback evaluation.
Step 2: Atomic Update Logic and Deterministic Fallback
Genesys Cloud uses optimistic concurrency control via the version field. You must handle version conflicts, implement retry logic for rate limits, and ensure deterministic fallback when the API rejects the modulation payload.
import requests
from genesyscloud.api_exception import ApiException
def update_prompt_with_fallback(
    client: PlatformClient,
    prompt_id: str,
    max_retries: int = 3
) -> dict:
    """Update Agent Assist prompt with retry logic and deterministic fallback."""
    prompt_api = client.platform_client.prompt_api
    attempt = 0
    last_exception = None
    while attempt < max_retries:
            config = build_prompt_configuration(payload, prompt_id)
            start_time = time.time()
            response = prompt_api.put_prompt_configuration(
                prompt_id=prompt_id,
                prompt_configuration=config
            logger.info(f"Prompt {prompt_id} updated successfully. Latency: {latency_ms:.2f}ms")
                "status": "success",
                "prompt_id": prompt_id,
                "temperature": payload.temperature,
                "version": response.version,
                "latency_ms": latency_ms,
                "attempt": attempt + 1
        except ApiError as e:
            last_exception = e
            if e.status_code == 409:
                # Version conflict: refresh current configuration and retry
                logger.warning(f"Version conflict on prompt {prompt_id}. Fetching latest version.")
                current = prompt_api.get_prompt_configuration(prompt_id=prompt_id)
                payload.version = current.version
            elif e.status_code == 429:
                # Rate limit: exponential backoff
                backoff = 2 ** attempt
                logger.warning(f"Rate limited. Retrying in {backoff}s.")
                time.sleep(backoff)
            elif e.status_code in (400, 422):
                # Validation failure: trigger deterministic fallback
                logger.error(f"Validation failed for prompt {prompt_id}. Applying deterministic fallback.")
                payload.hallucination_suppression = True
            else:
                logger.error(f"API error {e.status_code}: {e.body}")
                break
            attempt += 1
            logger.error(f"Unexpected error: {str(e)}")
            break
    # Deterministic fallback evaluation logic
    if last_exception:
        logger.info("Applying deterministic fallback configuration.")
        return prompt_api.put_prompt_configuration(prompt_id=prompt_id, prompt_configuration=config)
    raise RuntimeError(f"Failed to update prompt {prompt_id} after {max_retries} attempts.")
The update function handles 409 version conflicts by fetching the latest configuration, implements exponential backoff for 429 rate limits, and triggers automatic prompt regeneration with deterministic parameters when validation fails.
Step 3: Webhook Synchronization and Audit Logging
Synchronizing modulation events with external AI gateways requires webhook registration and structured audit logging. You will create a webhook that triggers on prompt updates and log all modulation actions for AI governance.
from genesyscloud.platformwebhook.models import Webhook, WebhookApplication, WebhookRequest
def register_modulation_webhook(client: PlatformClient, webhook_url: str) -> str:
    """Register a webhook to synchronize temperature modulation events."""
    webhook_api = client.platform_client.webhook_api
    webhook = Webhook(
        name="agentassist_temperature_modulator",
        description="Synchronizes LLM temperature modulation events with external AI gateways",
        enabled=True,
        application=WebhookApplication(
            name="external_ai_gateway",
            url=webhook_url,
            auth_method="bearer_token"
        request=WebhookRequest(
            method="POST",
            headers={"Content-Type": "application/json"},
            body_template="""{
                "event_type": "agentassist_prompt_modulated",
                "timestamp": "{{timestamp}}",
                "prompt_id": "{{resource.id}}",
                "temperature": "{{resource.temperature}}",
                "latency_ms": "{{metadata.latency_ms}}",
                "version": "{{resource.version}}"
        resource="agentassist_prompt_configuration",
        events=["update"]
    response = webhook_api.post_platform_webhooks(webhook=webhook)
    logger.info(f"Webhook registered successfully with ID: {response.id}")
    return response.id
def generate_audit_log(modulation_result: dict, action: str) -> str:
    """Generate structured audit log for AI governance compliance."""
    audit_entry = {
        "timestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
        "action": action,
        "prompt_id": modulation_result.get("prompt_id"),
        "temperature": modulation_result.get("temperature"),
        "version": modulation_result.get("version"),
        "latency_ms": modulation_result.get("latency_ms"),
        "status": modulation_result.get("status"),
        "attempt": modulation_result.get("attempt"),
        "compliance_check": "passed"
    log_string = str(audit_entry)
    logger.info(f"AUDIT: {log_string}")
    return log_string
The webhook registration uses the /api/v2/platform/webhooks endpoint to push modulation events to an external AI gateway. The audit logging function captures latency, success rates, and version information for governance tracking.
The following script combines authentication, validation, update logic, webhook synchronization, and audit logging into a single executable module. Replace the environment variables with your Genesys Cloud credentials before execution.
import os
import logging
from genesyscloud.api_exception import ApiError
# Import helper functions from previous steps
# In production, organize these into separate modules
def main():
    # Configuration
    PROMPT_ID = os.environ.get("AGENTASSIST_PROMPT_ID")
    WEBHOOK_URL = os.environ.get("AI_GATEWAY_WEBHOOK_URL")
    if not all([PROMPT_ID, WEBHOOK_URL]):
        raise ValueError("Missing required environment variables: AGENTASSIST_PROMPT_ID, AI_GATEWAY_WEBHOOK_URL")
    # Initialize SDK
    client = initialize_sdk()
    # Register webhook for synchronization
        webhook_id = register_modulation_webhook(client, WEBHOOK_URL)
        logger.error(f"Webhook registration failed: {e.body}")
        webhook_id = None
    # Define modulation payload
    payload = TemperatureModulationPayload(
        temperature=0.75,
        max_tokens=1024,
        top_p=0.9,
        presence_penalty=0.1,
        frequency_penalty=0.1,
        hallucination_suppression=True,
        version=None
    # Execute modulation with fallback logic
        result = update_prompt_with_fallback(client, PROMPT_ID, payload)
        result["latency_ms"] = latency_ms
        # Generate audit log
        audit_log = generate_audit_log(result, "temperature_modulation_update")
        logger.info(f"Modulation complete. Success: {result['status']}, Latency: {latency_ms:.2f}ms")
        logger.error(f"Modulation failed: {str(e)}")
        raise
    # Cleanup
    if webhook_id and os.environ.get("DELETE_WEBHOOK_ON_EXIT", "false").lower() == "true":
            client.platform_client.webhook_api.delete_platform_webhook(webhook_id=webhook_id)
            logger.info(f"Webhook {webhook_id} deleted.")
            logger.warning(f"Failed to delete webhook: {e}")
    main()
Run the script with the required environment variables set. The module validates the temperature reference, applies the generation matrix, handles version conflicts, triggers deterministic fallback when necessary, synchronizes via webhook, and generates audit logs for AI governance.
  • Cause: OAuth client credentials are invalid, expired, or lack the required agentassist:prompt:write scope.
  • Fix: Verify the client ID and secret match a confidential OAuth client in Genesys Cloud. Ensure the scope agentassist:prompt:write is granted. Restart the script to trigger token refresh.
  • Code Fix: The initialize_sdk() function raises a RuntimeError if authentication fails. Check the OAuth client configuration in the Genesys Cloud admin console under Platform > OAuth.
Error: 403 Forbidden
  • Cause: The authenticated user lacks agent assist configuration permissions or the OAuth client is restricted to specific environments.
  • Fix: Assign the user or client the Agent Assist Admin or Agent Assist Prompt Author role. Verify the OAuth client environment matches the target organization.
  • Code Fix: Wrap the update call in a permission check using the SDK’s /api/v2/me endpoint to verify role assignments before proceeding.
Error: 409 Conflict
  • Cause: Optimistic concurrency control detects a version mismatch. Another process modified the prompt configuration between read and write operations.
  • Fix: The update_prompt_with_fallback function automatically fetches the latest version and retries. Ensure your integration does not run concurrent updates on the same prompt ID without synchronization.
  • Code Fix: The existing retry logic handles this. Monitor the attempt field in the result to track concurrency resolution.
  • Cause: Exceeded Genesys Cloud API rate limits. Agent Assist configuration endpoints share rate limit pools with other platform APIs.
  • Fix: Implement exponential backoff. The provided code includes automatic backoff for 429 responses. Reduce update frequency or implement a queue-based dispatcher for bulk modulations.
  • Code Fix: The while attempt < max_retries loop with time.sleep(2 ** attempt) handles rate limiting. Add a global rate limiter if executing multiple prompt updates in parallel.
Error: 400 Bad Request / 422 Unprocessable Entity
  • Cause: Payload violates AI constraints, exceeds maximum randomness thresholds, or contains invalid token budgets.
  • Fix: Review the validate_modulation_payload function. Ensure temperature stays within [0.0, 1.0], token budgets remain within [50, 4096], and hallucination suppression flags align with temperature values.
  • Code Fix: The validation function raises ValueError with explicit constraint violations. Adjust the TemperatureModulationPayload values to match Genesys Cloud’s LLM configuration schema.
