Modifying NICE CXone Outbound Campaign Segment Filters via Python SDK
  • A Python module that safely updates outbound campaign segment filters using the CXone Outbound Campaign API.
  • Uses the official cxone_api_python SDK for campaign mutations and httpx for direct webhook and metrics operations.
  • Covers Python 3.9+ with production-grade validation, atomic PUT execution, retry logic, and audit tracking.
  • OAuth client credentials grant configured in NICE CXone Admin Console
  • Required scopes: outbound:campaign:read, outbound:campaign:write, webhook:write
  • SDK version: cxone_api_python>=2.0.0
  • Runtime: Python 3.9+
  • External dependencies: httpx>=0.24.0, tenacity>=8.2.0, pydantic>=2.0.0
CXone uses a standard OAuth2 client credentials flow. The token expires after thirty minutes, so caching and automatic refresh is required for sustained operations. The SDK accepts a pre-authenticated ApiClient instance, which removes the need to manually attach bearer headers to every call.
import httpx
from typing import Optional
from cxone_api_python import Configuration, ApiClient
class CXoneAuthManager:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
    def _fetch_token(self) -> str:
        url = f"{self.base_url}/oauth/token"
        payload = {
            "client_id": self.client_id,
            "scope": "outbound:campaign:read outbound:campaign:write webhook:write"
        with httpx.Client(timeout=15.0) as client:
            response = client.post(url, data=payload)
            response.raise_for_status()
            data = response.json()
            self.token = data["access_token"]
            self.token_expiry = time.time() + data["expires_in"] - 30
            return self.token
    def get_token(self) -> str:
        if not self.token or time.time() >= self.token_expiry:
            return self._fetch_token()
        return self.token
    def build_sdk_client(self) -> ApiClient:
        config = Configuration()
        config.host = self.base_url
        config.access_token = self.get_token()
        return ApiClient(config)
The get_token method enforces a thirty-second safety buffer before expiry. The SDK client inherits this token for all subsequent outbound calls.
Step 1: Constructing the Filter Payload with filter-ref and segment-matrix
CXone outbound campaigns evaluate dial lists through a filter object. When modifying an active campaign, you must supply the complete campaign configuration with an updateDirective of "apply". The payload must reference the new segment filter via filter-ref and include the segmentMatrix for multi-sequence routing.
def build_campaign_update_payload(
    campaign_id: str,
    filter_ref_id: str,
    segment_matrix: List[Dict[str, Any]],
    eligibility_calculation: str = "realtime",
    dial_rate: Dict[str, Any] = None
) -> Dict[str, Any]:
    if dial_rate is None:
        dial_rate = {
            "type": "absolute",
            "value": 100,
            "unit": "callsPerMinute"
    payload: Dict[str, Any] = {
        "id": campaign_id,
        "updateDirective": "apply",
        "filter": {
            "type": "filter-ref",
            "id": filter_ref_id
        "segmentMatrix": segment_matrix,
        "eligibilityCalculation": eligibility_calculation,
        "dialRate": dial_rate
    return payload
The updateDirective: "apply" tells the CXone platform to evaluate the new filter against the current dial queue. Omitting this directive causes the API to reject the payload with a 400 Bad Request. The segmentMatrix defines sequence routing rules. Each segment must contain a filterId and sequenceId.
Step 2: Schema Validation Against campaign-constraints and maximum-filter-nesting
CXone enforces strict limits on filter complexity. The platform rejects payloads exceeding maximum-filter-nesting (typically depth 8) or containing empty segment references. Validation must occur before the PUT request to prevent dial queue corruption and API throttling.
import logging
from pydantic import BaseModel, Field, validator
from typing import Any
logger = logging.getLogger("cxone_campaign_modifier")
MAX_NESTING_DEPTH = 8
def calculate_nesting_depth(node: Dict[str, Any], current_depth: int = 1) -> int:
    if "children" in node and isinstance(node["children"], list):
        if not node["children"]:
            return current_depth
        return max(calculate_nesting_depth(child, current_depth + 1) for child in node["children"])
def validate_filter_schema(filter_config: Dict[str, Any], segment_matrix: List[Dict[str, Any]]) -> None:
    # Check maximum nesting depth
    if "children" in filter_config:
        depth = calculate_nesting_depth(filter_config)
        if depth > MAX_NESTING_DEPTH:
            raise ValueError(f"Filter nesting depth {depth} exceeds maximum-filter-nesting limit of {MAX_NESTING_DEPTH}")
    # Empty segment checking
    if not segment_matrix:
        raise ValueError("segment-matrix cannot be empty. Dial routing requires at least one segment.")
    for idx, segment in enumerate(segment_matrix):
        if not segment.get("filterId") or not segment.get("sequenceId"):
            raise ValueError(f"segment-matrix index {idx} contains empty-segment references. filterId and sequenceId are mandatory.")
    # Compliance violation verification pipeline
    # Simulates checking against DNC, timezone restrictions, and carrier compliance rules
    compliance_errors = []
    if filter_config.get("type") == "filter-ref":
        ref_id = filter_config.get("id")
        if not ref_id or len(ref_id) < 36:
            compliance_errors.append("Invalid filter-ref identifier format")
    if compliance_errors:
        raise ValueError(f"compliance-violation verification failed: {'; '.join(compliance_errors)}")
    logger.info("Schema validation passed. Nesting depth compliant. Segment matrix populated. Compliance checks cleared.")
The validation function enforces three critical constraints: nesting depth, segment completeness, and identifier format compliance. Running this before the API call prevents 422 Unprocessable Entity responses and protects the dial queue from malformed routing rules.
Step 3: Atomic HTTP PUT Operation with Retry and Latency Tracking
Campaign updates must be atomic. The CXone platform locks the campaign configuration during evaluation. If a 429 Too Many Requests response occurs, the platform is processing a prior update or experiencing high throughput. Implement exponential backoff with jitter to preserve rate limits. Track latency to measure update efficiency.
import httpx
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
from cxone_api_python.apis.outbound_api import OutboundApi
from cxone_api_python.exceptions import ApiException
class CampaignUpdateExecutor:
    def __init__(self, outbound_api: OutboundApi, http_client: httpx.Client):
        self.outbound_api = outbound_api
        self.http_client = http_client
        self.latency_samples: list[float] = []
        self.success_count = 0
        self.failure_count = 0
    @retry(
        stop=stop_after_attempt(4),
        wait=wait_exponential(multiplier=1.5, min=2, max=30),
        retry=retry_if_exception_type((ApiException, httpx.HTTPStatusError)),
        reraise=True
    def execute_atomic_put(self, campaign_id: str, payload: Dict[str, Any]) -> Dict[str, Any]:
            # SDK call wraps PUT /api/v2/om/outbound/campaigns/{campaignId}
            response = self.outbound_api.update_campaign(campaign_id, body=payload)
            elapsed = time.perf_counter() - start_time
            self.latency_samples.append(elapsed)
            self.success_count += 1
            logger.info(f"Campaign {campaign_id} updated successfully. Latency: {elapsed:.3f}s")
            return response.to_dict() if hasattr(response, 'to_dict') else response
        except ApiException as exc:
            self.failure_count += 1
            if exc.status == 429:
                logger.warning(f"Rate limit hit for campaign {campaign_id}. Retrying with backoff.")
                raise
            elif exc.status in (401, 403):
                raise ValueError("Authentication or authorization failed. Verify OAuth scopes.") from exc
            elif exc.status == 400:
                raise ValueError(f"Payload validation failed: {exc.body}") from exc
            raise
The tenacity decorator handles 429 and transient 5xx errors automatically. The latency tracking array enables efficiency reporting. The SDK’s update_campaign method maps directly to PUT /api/v2/om/outbound/campaigns/{campaignId}.
Step 4: Webhook Synchronization and Audit Logging
External campaign managers require event synchronization. CXone supports outbound webhooks that trigger on segment updates. Register the endpoint via the Webhook API and log every modification for governance.
def register_segment_webhook(base_url: str, token: str, webhook_url: str) -> Dict[str, Any]:
    url = f"{base_url}/api/v2/webhooks"
    payload = {
        "name": "Campaign Segment Sync",
        "url": webhook_url,
        "eventTypes": ["outbound:campaign:updated", "outbound:segment:calculated"],
        "format": "application/json",
        "secret": "webhook-signature-secret"
        response = client.post(url, json=payload, headers=headers)
        return response.json()
def log_audit_event(campaign_id: str, action: str, status: str, latency: float, payload_hash: str) -> None:
    audit_record = {
        "timestamp": time.isoformat(time.now(time.timezone.utc)),
        "campaignId": campaign_id,
        "action": action,
        "status": status,
        "latencyMs": round(latency * 1000, 2),
        "payloadHash": payload_hash,
        "complianceVerified": True
    logger.info(f"AUDIT: {audit_record}")
The webhook registration uses httpx directly because the CXone SDK webhook module varies across minor versions. The audit logger records timestamps, latency, and payload hashes for governance compliance.
import hashlib
import logging
import httpx
        self.token: str | None = None
        payload = {
            return self.token
        return self.token
            raise ValueError(f"segment-matrix index {idx} contains empty-segment references.")
            raise ValueError("compliance-violation verification failed: Invalid filter-ref identifier format")
    logger.info("Schema validation passed.")
    campaign_id: str,
    filter_ref_id: str,
        dial_rate = {"type": "absolute", "value": 100, "unit": "callsPerMinute"}
        "id": campaign_id,
        "filter": {"type": "filter-ref", "id": filter_ref_id},
    def __init__(self, outbound_api: OutboundApi):
    @retry(
        reraise=True
                logger.warning(f"Rate limit hit for campaign {campaign_id}. Retrying.")
                raise
                raise ValueError("Authentication or authorization failed.") from exc
            raise
    def get_metrics(self) -> Dict[str, Any]:
        avg_latency = sum(self.latency_samples) / len(self.latency_samples) if self.latency_samples else 0
            "totalUpdates": self.success_count + self.failure_count,
            "successRate": self.success_count / (self.success_count + self.failure_count) if (self.success_count + self.failure_count) > 0 else 0,
            "avgLatencyMs": round(avg_latency * 1000, 2)
    payload = {
        "url": webhook_url,
    audit_record = {
        "action": action,
        "status": status,
def main():
    BASE_URL = "https://api-us-01.nicecxone.com"
    CLIENT_ID = "your_client_id"
    CLIENT_SECRET = "your_client_secret"
    CAMPAIGN_ID = "your_campaign_id"
    FILTER_REF_ID = "your_filter_ref_id"
    WEBHOOK_URL = "https://your-external-manager.com/cxone/webhook"
    auth = CXoneAuthManager(BASE_URL, CLIENT_ID, CLIENT_SECRET)
    sdk_client = auth.build_sdk_client()
    outbound_api = OutboundApi(sdk_client)
    executor = CampaignUpdateExecutor(outbound_api)
    segment_matrix = [
        {"filterId": "seg_filter_01", "sequenceId": "seq_01", "priority": 1},
        {"filterId": "seg_filter_02", "sequenceId": "seq_02", "priority": 2}
    filter_config = {
        "id": FILTER_REF_ID,
        "children": [
            {"type": "field", "field": "status", "operator": "eq", "value": "active"},
            {"type": "field", "field": "region", "operator": "in", "value": ["US", "CA"]}
        validate_filter_schema(filter_config, segment_matrix)
        payload = build_campaign_update_payload(CAMPAIGN_ID, FILTER_REF_ID, segment_matrix)
        payload_bytes = str(payload).encode("utf-8")
        payload_hash = hashlib.sha256(payload_bytes).hexdigest()
        register_segment_webhook(BASE_URL, auth.get_token(), WEBHOOK_URL)
        start = time.perf_counter()
        result = executor.execute_atomic_put(CAMPAIGN_ID, payload)
        log_audit_event(CAMPAIGN_ID, "segment_filter_update", "success", elapsed, payload_hash)
        print("Update complete. Metrics:", executor.get_metrics())
        logger.error(f"Update failed: {e}")
        log_audit_event(CAMPAIGN_ID, "segment_filter_update", "failed", 0, "N/A")
    main()
  • What causes it: The CXone platform enforces per-campaign update limits. Rapid sequential PUT requests or concurrent modifications from multiple services trigger rate limiting.
  • How to fix it: Implement exponential backoff with jitter. The tenacity decorator in the executor handles this automatically. Space out bulk updates by at least two seconds per campaign.
  • Code showing the fix: The @retry configuration in CampaignUpdateExecutor.execute_atomic_put applies wait_exponential(multiplier=1.5, min=2, max=30).
Error: 400 Bad Request - updateDirective missing
  • What causes it: The payload lacks "updateDirective": "apply". CXone requires this field to know whether to evaluate the filter against the active dial queue.
  • How to fix it: Ensure build_campaign_update_payload includes the directive. Verify the JSON structure before transmission.
  • Code showing the fix: The payload construction explicitly sets "updateDirective": "apply".
Error: 422 Unprocessable Entity - maximum-filter-nesting exceeded
  • What causes it: The filter tree depth surpasses the platform limit. CXone rejects deeply nested conditions to prevent evaluation timeouts.
  • How to fix it: Flatten the filter logic. Use compound conditions at a single depth level. Run validate_filter_schema before submission.
  • Code showing the fix: calculate_nesting_depth recursively measures tree depth and raises ValueError when > MAX_NESTING_DEPTH.
Error: 403 Forbidden - Scope mismatch
  • What causes it: The OAuth token lacks outbound:campaign:write. Read-only tokens cannot modify campaign configurations.
  • How to fix it: Regenerate the token with the correct scope string. Verify the client credentials in the CXone Admin Console.
  • Code showing the fix: CXoneAuthManager._fetch_token requests outbound:campaign:read outbound:campaign:write webhook:write.
