Modifying NICE CXone Outbound Campaign Schedules via Python SDK
  • A Python module that programmatically updates outbound campaign schedules using atomic PATCH requests, validates dialer constraints, handles timezone and blackout logic, registers webhook syncs, and generates regulatory audit logs.
  • This implementation uses the NICE CXone Outbound Campaign API surface and the official cxone-sdk-python package for authentication.
  • The code is written in Python 3.9+ using httpx for HTTP transport, pytz for timezone validation, and python-dotenv for credential management.
  • OAuth 2.0 Client Credentials flow with scopes: outbound_campaigns:write, outbound_campaigns:read, outbound_schedules:write, platform:read
  • cxone-sdk-python version 1.60.0 or newer
  • Python 3.9 runtime
  • External dependencies: httpx, pytz, python-dotenv, tenacity
  • A valid NICE CXone tenant environment URL (e.g., https://yourtenant.api.cxone.com)
The NICE CXone platform uses OAuth 2.0 Client Credentials for server-to-server communication. The official Python SDK handles token acquisition, caching, and automatic refresh. You must initialize the CXoneClient with your tenant environment, client ID, and client secret.
import os
from cxone_sdk import CXoneClient
from cxone_sdk.auth import ClientCredentialsAuth
def initialize_cxone_client() -> CXoneClient:
    auth = ClientCredentialsAuth(
        environment=os.getenv("CXONE_ENV", "yourtenant.api.cxone.com"),
        client_id=os.getenv("CXONE_CLIENT_ID"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET"),
        scopes=["outbound_campaigns:write", "outbound_campaigns:read", "outbound_schedules:write"]
    client = CXoneClient(auth=auth)
    return client
The SDK maintains an in-memory token cache. When the access token expires, the next API call automatically triggers a refresh without dropping the connection. You do not need to implement manual token rotation logic.
Step 1: Campaign Retrieval and Constraint Validation
Before modifying a schedule, you must retrieve the existing campaign state to obtain the ETag header and verify concurrent schedule limits. The CXone dialer engine enforces a maximum of five active schedules per campaign. Attempting to exceed this limit returns a 422 Unprocessable Entity response.
import httpx
import json
def fetch_campaign_etag_and_validate_limits(client: CXoneClient, campaign_id: str) -> tuple[str, int]:
    base_url = f"https://{client.auth.environment}"
    headers = client.auth.get_headers()
    response = httpx.get(
        f"{base_url}/api/v2/outbound/campaigns/{campaign_id}",
        headers=headers
    if response.status_code == 401 or response.status_code == 403:
        raise PermissionError(f"Authentication failed with status {response.status_code}. Verify OAuth scopes.")
    if response.status_code != 200:
        raise RuntimeError(f"Campaign retrieval failed: {response.status_code} - {response.text}")
    etag = response.headers.get("ETag", "")
    campaign_data = response.json()
    # Extract existing schedules to enforce concurrent limit
    existing_schedules = campaign_data.get("schedules", [])
    schedule_count = len(existing_schedules)
    if schedule_count >= 5:
        raise ValueError("Maximum concurrent schedule limit (5) reached. Remove an existing schedule before adding a new one.")
    return etag, schedule_count
The ETag value is critical for optimistic locking. CXone uses it to prevent race conditions when multiple processes modify the same campaign simultaneously. You must pass this value in the If-Match header during the PATCH operation.
Step 2: Schedule Payload Construction and Blackout Verification
Schedule payloads require a time window matrix, timezone offset validation, and pause/resume directives. You must verify that the requested dialing windows do not overlap with regulatory blackout periods. The dialer engine rejects schedules that violate timezone offset bounds or conflict with hardcoded blackout rules.
import pytz
BLACKOUT_PERIODS = [
    {"start": "2024-12-25T00:00:00Z", "end": "2024-12-25T23:59:59Z"},
    {"start": "2025-01-01T00:00:00Z", "end": "2025-01-01T23:59:59Z"}
def validate_timezone_and_blackouts(campaign_timezone: str, schedule_windows: List[Dict[str, str]]) -> None:
    tz = pytz.timezone(campaign_timezone)
    now_utc = datetime.now(pytz.utc)
    for window in schedule_windows:
        start_str = window.get("startTime")
        end_str = window.get("endTime")
        if not start_str or not end_str:
            raise ValueError("Schedule windows must contain startTime and endTime in ISO 8601 format.")
        start_dt = datetime.fromisoformat(start_str.replace("Z", "+00:00")).astimezone(tz)
        end_dt = datetime.fromisoformat(end_str.replace("Z", "+00:00")).astimezone(tz)
        # Validate timezone offset constraints (CXone requires offsets between -12 and +14)
        offset_hours = start_dt.utcoffset().total_seconds() / 3600
        if offset_hours < -12 or offset_hours > 14:
            raise ValueError(f"Timezone offset {offset_hours} hours exceeds dialer engine constraints.")
        # Blackout period verification pipeline
        for blackout in BLACKOUT_PERIODS:
            b_start = datetime.fromisoformat(blackout["start"].replace("Z", "+00:00")).astimezone(tz)
            b_end = datetime.fromisoformat(blackout["end"].replace("Z", "+00:00")).astimezone(tz)
            if not (end_dt <= b_start or start_dt >= b_end):
                raise ValueError(f"Schedule window overlaps with regulatory blackout period {blackout['start']} to {blackout['end']}.")
def construct_schedule_payload(campaign_id: str, timezone: str, windows: List[Dict[str, str]], pause_on_full: bool = True) -> Dict[str, Any]:
    validate_timezone_and_blackouts(timezone, windows)
        "campaignId": campaign_id,
        "timeZone": timezone,
        "dialingWindows": windows,
        "pauseConfig": {
            "pauseOnFullQueue": pause_on_full,
            "resumeOnAvailable": True,
            "maxPauseDurationMinutes": 15
        "state": "ACTIVE",
        "priority": 1
The dialingWindows array accepts ISO 8601 timestamps. The pauseConfig object controls dialer state sync triggers. When the queue reaches capacity, the dialer pauses outbound attempts and automatically resumes when agents become available, preventing call abandonment spikes.
Step 3: Atomic PATCH Execution and Dialer State Sync
Schedule modifications must use atomic PATCH operations to preserve existing campaign attributes. You must include the If-Match header with the ETag from Step 1. The CXone API returns 412 Precondition Failed if the ETag does not match, indicating concurrent modification. You must implement retry logic for 429 Too Many Requests responses.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
@retry(
    stop=stop_after_attempt(3),
    wait=wait_exponential(multiplier=1, min=2, max=10),
    retry=retry_if_exception_type(httpx.HTTPStatusError)
def apply_schedule_patch(client: CXoneClient, campaign_id: str, etag: str, payload: Dict[str, Any]) -> Dict[str, Any]:
    headers = {
        **client.auth.get_headers(),
        "If-Match": etag,
    response = httpx.patch(
        f"{base_url}/api/v2/outbound/campaigns/{campaign_id}/schedules",
        headers=headers,
        json=payload
    if response.status_code == 412:
        raise RuntimeError("ETag mismatch. The campaign was modified by another process. Refresh the campaign state and retry.")
    if response.status_code == 422:
        raise ValueError(f"Schema validation failed: {response.json().get('message', 'Unknown validation error')}")
        raise httpx.HTTPStatusError(f"PATCH failed: {response.status_code}", request=response.request, response=response)
    return response.json()
The tenacity decorator handles exponential backoff for rate limits. The dialer engine automatically syncs state changes across all connected media servers within 200 milliseconds. You do not need to trigger manual synchronization.
Step 4: Webhook Registration and Audit Logging
To synchronize modification events with external calendar systems, you must register a webhook callback endpoint. The CXone platform POSTS schedule change events to your endpoint. You must also track modification latency and generate audit logs for regulatory governance.
import logging
from typing import Any
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
logger = logging.getLogger("cxone_schedule_modifier")
def register_webhook(client: CXoneClient, campaign_id: str, callback_url: str) -> Dict[str, Any]:
    headers = {
    payload = {
        "eventTypes": ["SCHEDULE_MODIFIED", "SCHEDULE_PAUSED", "SCHEDULE_RESUMED"],
        "callbackUrl": callback_url,
        "active": True
    response = httpx.post(
        f"{base_url}/api/v2/outbound/webhooks",
        headers=headers,
        json=payload
    if response.status_code == 409:
        logger.warning("Webhook already registered for this campaign.")
    if response.status_code not in (200, 201):
        raise RuntimeError(f"Webhook registration failed: {response.status_code}")
def generate_audit_log(campaign_id: str, payload: Dict[str, Any], latency_ms: float, adherence_rate: float) -> None:
    audit_entry = {
        "timestamp": datetime.now(pytz.utc).isoformat(),
        "action": "SCHEDULE_MODIFIED",
        "payloadHash": hash(json.dumps(payload, sort_keys=True)),
        "latencyMs": latency_ms,
        "scheduleAdherenceRate": adherence_rate,
        "complianceStatus": "VALIDATED",
        "regulatoryFramework": "TCPA_DNC_COMPLIANT"
    logger.info(f"AUDIT_LOG: {json.dumps(audit_entry)}")
The audit log records the payload hash, modification latency, and schedule adherence rate. You can forward this data to a compliance database or SIEM system. The adherence rate represents the percentage of successfully dialed calls within the configured time windows.
import os
import json
import httpx
import pytz
import logging
    return CXoneClient(auth=auth)
    response = httpx.get(f"{base_url}/api/v2/outbound/campaigns/{campaign_id}", headers=headers)
    if response.status_code in (401, 403):
        raise PermissionError(f"Authentication failed with status {response.status_code}.")
    schedule_count = len(campaign_data.get("schedules", []))
        raise ValueError("Maximum concurrent schedule limit (5) reached.")
        start_dt = datetime.fromisoformat(window["startTime"].replace("Z", "+00:00")).astimezone(tz)
        end_dt = datetime.fromisoformat(window["endTime"].replace("Z", "+00:00")).astimezone(tz)
                raise ValueError(f"Schedule window overlaps with regulatory blackout period.")
def construct_schedule_payload(campaign_id: str, timezone: str, windows: List[Dict[str, str]]) -> Dict[str, Any]:
        "pauseConfig": {
            "pauseOnFullQueue": True,
        "state": "ACTIVE",
        "priority": 1
@retry(
    headers = {**client.auth.get_headers(), "If-Match": etag, "Content-Type": "application/json"}
        headers=headers,
        json=payload
        raise RuntimeError("ETag mismatch. Concurrent modification detected.")
        raise ValueError(f"Schema validation failed: {response.json().get('message')}")
    headers = {**client.auth.get_headers(), "Content-Type": "application/json"}
    payload = {
        "active": True
    response = httpx.post(f"{base_url}/api/v2/outbound/webhooks", headers=headers, json=payload)
    audit_entry = {
def main():
    client = initialize_cxone_client()
    campaign_id = os.getenv("CXONE_CAMPAIGN_ID", "default-campaign-id")
    callback_url = os.getenv("WEBHOOK_URL", "https://your-domain.com/webhooks/cxone")
    start_time = time.time()
    etag, _ = fetch_campaign_etag_and_validate_limits(client, campaign_id)
    windows = [
        {"startTime": "2025-01-15T09:00:00Z", "endTime": "2025-01-15T17:00:00Z"}
    payload = construct_schedule_payload(campaign_id, "America/New_York", windows)
    result = apply_schedule_patch(client, campaign_id, etag, payload)
    register_webhook(client, campaign_id, callback_url)
    generate_audit_log(campaign_id, payload, latency_ms, 0.94)
    print(f"Schedule modification complete. Response: {json.dumps(result, indent=2)}")
    main()
Error: 412 Precondition Failed
  • Cause: The If-Match header contains a stale ETag. Another process modified the campaign schedule between your GET and PATCH calls.
  • Fix: Re-fetch the campaign to obtain the latest ETag, merge your changes with the current state, and retry the PATCH operation.
  • Code: The apply_schedule_patch function raises a RuntimeError on 412. Implement a retry loop that calls fetch_campaign_etag_and_validate_limits before the next attempt.
Error: 422 Unprocessable Entity
  • Cause: The payload violates CXone schedule schema constraints. Common triggers include invalid ISO 8601 timestamps, timezone offsets outside the -12 to +14 range, or overlapping dialing windows.
  • Fix: Validate timestamps against pytz before submission. Ensure startTime is strictly less than endTime. Check the dialingWindows array for intersection logic.
  • Code: The validate_timezone_and_blackouts function catches offset violations. Add window intersection checks if your dialing matrix includes multiple overlapping ranges.
  • Cause: The CXone API rate limit for outbound campaign operations has been exceeded. The default limit is 100 requests per minute per tenant.
  • Fix: Implement exponential backoff with jitter. The tenacity decorator in the complete example handles this automatically.
  • Code: The @retry decorator retries up to three times with exponential wait times. Adjust stop_after_attempt and wait_exponential parameters if your workload requires higher throughput.
Error: 401 Unauthorized / 403 Forbidden
  • Cause: Missing or incorrect OAuth scopes. The outbound_campaigns:write scope is mandatory for PATCH operations.
  • Fix: Regenerate your OAuth client credentials with the correct scope assignments. Verify that the client ID and secret match the registered application in the CXone admin console.
  • Code: The initialize_cxone_client function explicitly requests the required scopes. Check your environment variables for typos.
