Modifying Genesys Cloud Outbound Campaign Call Control Configurations via Java SDK
  • A Java module that safely updates outbound campaign dialer settings using atomic PUT operations, validates configurations against system constraints, manages pause/resume workflows, and tracks modification metrics.
  • This tutorial uses the Genesys Cloud Outbound Campaign API (/api/v2/outbound/campaigns/{campaignId}) and the official Java SDK.
  • The code is written in Java 17+ with Maven dependencies and production-grade error handling.
  • OAuth Client Credentials flow with scopes: outbound:campaign:read, outbound:campaign:write, outbound:campaign:pause, outbound:campaign:resume, webhook:write
  • SDK version: com.mypurecloud.api.client:platform-client:162.0.0 (or latest stable)
  • Language/runtime: Java 17+, Maven 3.8+
  • External dependencies: com.google.code.gson:gson:2.10.1, org.slf4j:slf4j-simple:2.0.9, com.fasterxml.jackson.core:jackson-databind:2.15.2
The Genesys Cloud Java SDK manages token lifecycle automatically when configured with client credentials. You must instantiate ApiClient with the correct base URI, client ID, client secret, and required scopes. The SDK caches the access token and handles refresh requests transparently.
import com.mypurecloud.api.client.ApiClient;
import com.mypurecloud.api.client.auth.OAuth;
import java.util.Arrays;
public class GenesysAuth {
    public static ApiClient buildApiClient(String clientId, String clientSecret, String baseUri) throws Exception {
        ApiClient client = new ApiClient();
        client.setBaseUri(baseUri);
        client.setClientId(clientId);
        client.setClientSecret(clientSecret);
        client.setGrantType("client_credentials");
        OAuth oauth = new OAuth();
        oauth.setClientId(clientId);
        oauth.setClientSecret(clientSecret);
        oauth.setGrantType("client_credentials");
        oauth.setScopes(Arrays.asList(
            "outbound:campaign:read",
            "outbound:campaign:write",
            "outbound:campaign:pause",
            "outbound:campaign:resume",
            "webhook:write"
        client.setOAuth(oauth);
        // Force initial token fetch to verify credentials
        client.getAccessToken();
        return client;
Step 1: Initialize SDK and Fetch Baseline Configuration
You must retrieve the current campaign state before modifying it. The GET /api/v2/outbound/campaigns/{campaignId} endpoint returns the full campaign object, including predictive models, dialer configuration, and current status. This baseline is required for schema validation and conflict detection.
import com.mypurecloud.api.client.api.OutboundApi;
import com.mypurecloud.api.client.model.Campaign;
import com.mypurecloud.api.client.model.PredictiveModel;
import com.mypurecloud.api.client.model.DialerConfig;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class CampaignControlModifier {
    private static final Logger log = LoggerFactory.getLogger(CampaignControlModifier.class);
    private final OutboundApi outboundApi;
    private final String campaignId;
    public CampaignControlModifier(ApiClient apiClient, String campaignId) {
        this.outboundApi = new OutboundApi(apiClient);
        this.campaignId = campaignId;
    public Campaign fetchBaseline() throws Exception {
        log.info("Fetching baseline configuration for campaign: {}", campaignId);
            Campaign current = outboundApi.getCampaign(campaignId);
            if (current == null) {
                throw new IllegalArgumentException("Campaign not found. Verify campaignId and environment.");
            log.info("Baseline fetched. Status: {}, PredictiveModel: {}", current.getStatus(), current.getPredictiveModel() != null ? current.getPredictiveModel().getPacingStrategy() : "N/A");
            return current;
        } catch (com.mypurecloud.api.client.ApiException e) {
            handleApiException(e, "fetchBaseline");
            throw e;
Step 2: Validate Schemas Against Dialer Constraints
Genesys Cloud enforces strict limits on dialer configurations. You must validate dropRateThreshold, agentWrapUpTime, settingMatrix complexity, and controlRef references before submission. The validation pipeline checks business rules, JSON depth limits, and resource conflicts.
import com.google.gson.Gson;
import com.google.gson.JsonObject;
import com.google.gson.JsonParser;
import java.util.Map;
import java.util.HashMap;
public class ValidationPipeline {
    private static final int MAX_SETTING_MATRIX_DEPTH = 5;
    private static final double MAX_DROP_RATE = 0.15;
    private static final int MAX_WRAP_UP_SECONDS = 300;
    public static void validateControlPayload(Campaign baseline, Map<String, Object> adjustDirective) throws ValidationException {
        double dropRate = (Double) adjustDirective.getOrDefault("dropRateThreshold", 0.0);
        int wrapUpTime = (Integer) adjustDirective.getOrDefault("agentWrapUpTime", 0);
        String controlRef = (String) adjustDirective.getOrDefault("controlRef", "");
        String settingMatrixJson = (String) adjustDirective.getOrDefault("settingMatrix", "{}");
        // Dialer constraint checks
        if (dropRate < 0.0 || dropRate > MAX_DROP_RATE) {
            throw new ValidationException("dropRateThreshold must be between 0.0 and " + MAX_DROP_RATE + ". Received: " + dropRate);
        if (wrapUpTime < 0 || wrapUpTime > MAX_WRAP_UP_SECONDS) {
            throw new ValidationException("agentWrapUpTime must not exceed " + MAX_WRAP_UP_SECONDS + " seconds. Received: " + wrapUpTime);
        // Setting matrix complexity validation
        JsonObject matrix = JsonParser.parseString(settingMatrixJson).getAsJsonObject();
        if (calculateJsonDepth(matrix) > MAX_SETTING_MATRIX_DEPTH) {
            throw new ValidationException("settingMatrix exceeds maximum nesting depth of " + MAX_SETTING_MATRIX_DEPTH);
        // Control reference verification
        if (controlRef != null && !controlRef.isEmpty() && !controlRef.matches("^[a-zA-Z0-9_-]+$")) {
            throw new ValidationException("controlRef contains invalid characters. Must be alphanumeric, hyphens, or underscores.");
        // Resource limit verification pipeline
        if (baseline.getPredictiveModel() != null && baseline.getPredictiveModel().getMaxConcurrentCalls() != null) {
            int maxCalls = baseline.getPredictiveModel().getMaxConcurrentCalls();
            if (maxCalls > 10000) {
                throw new ValidationException("Predictive model maxConcurrentCalls exceeds tenant limit of 10000.");
        log.info("Validation pipeline passed for campaign: {}", baseline.getId());
    private static int calculateJsonDepth(JsonObject obj) {
        int maxDepth = 0;
        for (var entry : obj.entrySet()) {
            int currentDepth = 1;
            if (entry.getValue().isJsonObject()) {
                currentDepth += calculateJsonDepth(entry.getValue().getAsJsonObject());
            } else if (entry.getValue().isJsonArray()) {
                var arr = entry.getValue().getAsJsonArray();
                if (!arr.isEmpty() && arr.get(0).isJsonObject()) {
                    currentDepth += calculateJsonDepth(arr.get(0).getAsJsonObject());
            maxDepth = Math.max(maxDepth, currentDepth);
        return maxDepth;
    public static class ValidationException extends Exception {
        public ValidationException(String message) {
            super(message);
Step 3: Pause Campaign and Execute Atomic PUT
Modifying predictive dialer settings on an active campaign causes call drops and pacing instability. You must pause the campaign, apply the atomic PUT operation, verify the response, and resume. The PUT /api/v2/outbound/campaigns/{campaignId} endpoint replaces the entire campaign object. You must merge your adjust directive into the existing baseline to preserve unchanged fields.
import com.mypurecloud.api.client.ApiException;
import com.mypurecloud.api.client.model.PauseCampaignRequest;
import java.time.Instant;
    // ... previous constructor and fetchBaseline ...
    public void modifyCallControl(Map<String, Object> adjustDirective) throws Exception {
        long startTime = Instant.now().toEpochMilli();
        Campaign baseline = fetchBaseline();
        // Validate before touching the live campaign
        ValidationPipeline.validateControlPayload(baseline, adjustDirective);
        // Step 3a: Safe pause trigger
        log.info("Pausing campaign for safe modification iteration.");
            outboundApi.pauseCampaign(campaignId, new PauseCampaignRequest());
            Thread.sleep(2000); // Allow dialer to drain active calls
        } catch (ApiException e) {
            if (e.getCode() == 409) {
                log.warn("Campaign already paused. Proceeding with modification.");
            } else {
                throw e;
        // Step 3b: Construct modified payload
        Campaign updatedCampaign = cloneCampaign(baseline);
        applyAdjustDirective(updatedCampaign, adjustDirective);
        // Step 3c: Atomic PUT with retry logic for 429
        Campaign result = executeAtomicPutWithRetry(updatedCampaign);
        // Step 3d: Resume campaign
            outboundApi.resumeCampaign(campaignId, new com.mypurecloud.api.client.model.ResumeCampaignRequest());
            log.info("Campaign resumed successfully.");
            log.error("Failed to resume campaign. Manual intervention required.", e);
            throw e;
        long latency = Instant.now().toEpochMilli() - startTime;
        log.info("Modification complete. Latency: {}ms", latency);
        generateAuditLog(baseline, result, latency, true);
    private Campaign executeAtomicPutWithRetry(Campaign payload) throws Exception {
        int maxRetries = 3;
        Exception lastException = null;
        for (int attempt = 1; attempt <= maxRetries; attempt++) {
                log.info("Executing atomic PUT. Attempt {}/{}", attempt, maxRetries);
                return outboundApi.updateCampaign(campaignId, payload);
                lastException = e;
                if (e.getCode() == 429) {
                    long retryAfter = e.getRetryAfterSeconds() != null ? e.getRetryAfterSeconds() : (long) Math.pow(2, attempt);
                    log.warn("Rate limited (429). Retrying after {} seconds.", retryAfter);
                    Thread.sleep(retryAfter * 1000);
                } else if (e.getCode() == 422 || e.getCode() == 409) {
                    log.error("Validation or conflict error. Aborting retry. Message: {}", e.getMessage());
                    throw e;
                } else {
                    throw e;
        throw lastException;
    private Campaign applyAdjustDirective(Campaign campaign, Map<String, Object> directive) {
        // Map adjust directive to Genesys model fields
        if (directive.containsKey("dropRateThreshold")) {
            Double dropRate = (Double) directive.get("dropRateThreshold");
            PredictiveModel model = campaign.getPredictiveModel() != null ? campaign.getPredictiveModel() : new PredictiveModel();
            model.setDropRateThreshold(dropRate);
            campaign.setPredictiveModel(model);
        if (directive.containsKey("agentWrapUpTime")) {
            Integer wrapUp = (Integer) directive.get("agentWrapUpTime");
            PredictiveModel model = campaign.getPredictiveModel();
            if (model != null) {
                model.setAgentWrapUpTime(wrapUp);
        if (directive.containsKey("controlRef")) {
            campaign.setControlRef((String) directive.get("controlRef"));
        if (directive.containsKey("settingMatrix")) {
            // Store matrix in customAttributes for persistence and webhook sync
            if (campaign.getCustomAttributes() == null) {
                campaign.setCustomAttributes(new HashMap<>());
            campaign.getCustomAttributes().put("settingMatrix", directive.get("settingMatrix").toString());
        return campaign;
    private Campaign cloneCampaign(Campaign source) {
        // SDK does not provide shallow copy. Use Gson for structural clone.
        Gson gson = new Gson();
        String json = gson.toJson(source);
        return gson.fromJson(json, Campaign.class);
Step 4: Process Results, Resume, and Track Metrics
After the atomic PUT succeeds, you must synchronize the modification event with external analytics via webhooks, track latency and success rates, and generate audit logs. Genesys webhooks fire on event:campaign:modified, but you can also register a dedicated webhook programmatically to ensure alignment with your control modifier.
import com.mypurecloud.api.client.api.WebhookApi;
import com.mypurecloud.api.client.model.Webhook;
import com.mypurecloud.api.client.model.WebhookEvent;
import java.io.FileWriter;
import java.io.IOException;
import java.time.format.DateTimeFormatter;
import java.util.Collections;
    private final WebhookApi webhookApi;
    private final String auditLogPath;
    private int successCount = 0;
    private int failureCount = 0;
    public CampaignControlModifier(ApiClient apiClient, String campaignId, String auditLogPath) {
        this.webhookApi = new WebhookApi(apiClient);
        this.auditLogPath = auditLogPath;
    public void registerControlModifiedWebhook(String targetUrl) throws Exception {
        Webhook webhook = new Webhook();
        webhook.setTargetUrl(targetUrl);
        webhook.setDescription("Outbound Campaign Control Modifier Sync");
        webhook.setEvent("event:campaign:modified");
        webhook.setApiVersion("2");
        webhook.setFilterCriteria("resourceId eq '" + campaignId + "'");
        webhook.setHeaders(Collections.singletonMap("X-Modifier-Source", "java-control-modifier"));
            webhookApi.postWebhook(webhook);
            log.info("Webhook registered for campaign modification events.");
                log.warn("Webhook already exists for this campaign. Skipping registration.");
            } else {
                throw e;
    private void generateAuditLog(Campaign before, Campaign after, long latencyMs, boolean success) {
        successCount += success ? 1 : 0;
        failureCount += success ? 0 : 1;
        String timestamp = DateTimeFormatter.ISO_INSTANT.format(Instant.now());
        String logEntry = String.format(
            "%s | Campaign: %s | Action: MODIFY | Latency: %dms | Success: %s | DropRate: %s -> %s | WrapUp: %s -> %s | SuccessRate: %.2f%%\n",
            timestamp,
            campaignId,
            latencyMs,
            success,
            before.getPredictiveModel() != null ? before.getPredictiveModel().getDropRateThreshold() : "null",
            after.getPredictiveModel() != null ? after.getPredictiveModel().getDropRateThreshold() : "null",
            before.getPredictiveModel() != null ? before.getPredictiveModel().getAgentWrapUpTime() : "null",
            after.getPredictiveModel() != null ? after.getPredictiveModel().getAgentWrapUpTime() : "null",
            (double) successCount / (successCount + failureCount) * 100
        try (FileWriter writer = new FileWriter(auditLogPath, true)) {
            writer.write(logEntry);
        } catch (IOException e) {
            log.error("Failed to write audit log.", e);
    private void handleApiException(ApiException e, String operation) {
        switch (e.getCode()) {
            case 401:
                log.error("Authentication failed. Token expired or invalid credentials.");
                break;
            case 403:
                log.error("Forbidden. Missing required scopes: outbound:campaign:write, outbound:campaign:pause.");
                break;
            case 422:
                log.error("Unprocessable Entity. Payload violates Genesys schema constraints.");
                break;
            case 429:
                log.warn("Rate limit exceeded. Implement exponential backoff.");
                break;
            default:
                log.error("API Error [{}]: {} during {}", e.getCode(), e.getMessage(), operation);
The following module combines authentication, validation, atomic modification, webhook synchronization, and audit logging into a single executable class. Replace the placeholder credentials and campaign ID before execution.
public class OutboundControlModifierApp {
        String clientId = "your_client_id";
        String clientSecret = "your_client_secret";
        String baseUri = "https://api.mypurecloud.com";
        String campaignId = "your_campaign_id";
        String auditLogPath = "outbound_audit.log";
        String webhookUrl = "https://your-analytics-endpoint.com/genesys/campaign-modified";
            // 1. Authenticate
            ApiClient apiClient = new ApiClient();
            apiClient.setBaseUri(baseUri);
            apiClient.setClientId(clientId);
            apiClient.setClientSecret(clientSecret);
            apiClient.setGrantType("client_credentials");
            apiClient.getOAuth().setScopes(java.util.Arrays.asList(
                "outbound:campaign:read", "outbound:campaign:write",
                "outbound:campaign:pause", "outbound:campaign:resume",
                "webhook:write"
            apiClient.getAccessToken(); // Verify token
            // 2. Initialize modifier
            CampaignControlModifier modifier = new CampaignControlModifier(apiClient, campaignId, auditLogPath);
            // 3. Register webhook for external analytics sync
            modifier.registerControlModifiedWebhook(webhookUrl);
            // 4. Define adjust directive with control-ref and setting-matrix
            Map<String, Object> adjustDirective = new HashMap<>();
            adjustDirective.put("dropRateThreshold", 0.08);
            adjustDirective.put("agentWrapUpTime", 45);
            adjustDirective.put("controlRef", "ctrl-predictive-v2");
            adjustDirective.put("settingMatrix", "{\"pacing\":{\"strategy\":\"adaptive\",\"maxCalls\":500},\"dialer\":{\"retryAttempts\":3}}");
            // 5. Execute safe modification
            modifier.modifyCallControl(adjustDirective);
            System.out.println("Campaign control modification completed successfully.");
        } catch (Exception e) {
            System.err.println("Modification failed: " + e.getMessage());
            e.printStackTrace();
Error: 409 Conflict during Pause or Update
  • Cause: The campaign is already paused, or another process holds a lock on the campaign resource. Genesys uses optimistic concurrency control on campaign updates.
  • Fix: Check the campaign status before pausing. If already paused, skip the pause step. For 409 on PUT, ensure you are sending the latest version or etag if your SDK version requires it, or fetch the campaign immediately before the PUT to avoid stale state conflicts.
  • Code Fix: Add a status check before pauseCampaign. Handle 409 gracefully by logging and proceeding directly to updateCampaign.
Error: 422 Unprocessable Entity
  • Cause: The payload violates Genesys schema constraints. Common triggers include dropRateThreshold outside 0.0 to 0.15, agentWrapUpTime exceeding 300 seconds, or invalid controlRef characters.
  • Fix: Run the ValidationPipeline before submission. Verify that settingMatrix JSON depth does not exceed 5 levels. Ensure all numeric fields are typed correctly (Double vs Integer).
  • Code Fix: The ValidationPipeline class in Step 2 catches these violations and throws a descriptive ValidationException before the HTTP call.
  • Cause: You exceeded the Genesys Cloud API rate limit (typically 100 requests per second for outbound endpoints). Batch modifications or rapid retry loops trigger this.
  • Fix: Implement exponential backoff with jitter. Read the Retry-After header from the response. Cache tokens to avoid unnecessary OAuth calls.
  • Code Fix: The executeAtomicPutWithRetry method reads e.getRetryAfterSeconds() and applies exponential backoff automatically.
Error: 5xx Server Error
  • Cause: Temporary Genesys platform instability or backend dialer service degradation.
  • Fix: Do not retry immediately. Wait 5 to 10 seconds before the first retry. Log the full response body for support tickets.
  • Code Fix: Wrap the PUT in a try-catch that distinguishes 5xx from client errors. Add a fixed delay before retrying 5xx responses.
