Modifying Genesys Cloud Extension Properties via Telephony APIs with Go
This tutorial builds a production-ready Go service that updates Genesys Cloud extension properties, validates telephony constraints, enforces feature limits, synchronizes codec preferences, and tracks modification metrics. It uses the Genesys Cloud Telephony API endpoint PUT /api/v2/telephony/users/{userId}/extension and mirrors the official Go SDK initialization pattern. The code is written in Go 1.21+ and handles authentication, payload validation, atomic updates, webhook synchronization, and audit logging.
  • OAuth Client Credentials grant configured in Genesys Cloud with telephony:extension:write and telephony:extension:read scopes
  • Genesys Cloud API v2
  • Go 1.21 or later
  • Standard library dependencies: net/http, encoding/json, context, time, sync, log, fmt
  • A valid Genesys Cloud organization subdomain and user ID for testing
Genesys Cloud uses OAuth 2.0 for API authentication. The Client Credentials flow is optimal for server-to-server automation. You must base64 encode the client ID and client secret, then request a token from the /oauth/token endpoint. The token expires after two hours, so your service must cache and refresh it before expiration.
package main
import (
	"bytes"
	"context"
	"encoding/base64"
	"encoding/json"
	"fmt"
	"net/http"
	"time"
type OAuthTokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
	Scope       string `json:"scope"`
func FetchOAuthToken(ctx context.Context, subdomain, clientID, clientSecret string) (string, error) {
	credentials := base64.StdEncoding.EncodeToString([]byte(fmt.Sprintf("%s:%s", clientID, clientSecret)))
	form := []byte("grant_type=client_credentials&scope=telephony%3Aextension%3Awrite+telephony%3Aextension%3Aread")
	req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("https://%s.mypurecloud.com/oauth/token", subdomain), bytes.NewBuffer(form))
	if err != nil {
		return "", fmt.Errorf("failed to create oauth request: %w", err)
	req.Header.Set("Authorization", fmt.Sprintf("Basic %s", credentials))
	resp, err := client.Do(req)
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth failed with status %d", resp.StatusCode)
	var tokenResp OAuthTokenResponse
		return "", fmt.Errorf("failed to decode oauth response: %w", err)
	return tokenResp.AccessToken, nil
Step 1: Initialize the Telephony Client and Handle OAuth
The Genesys Cloud Go SDK exposes platformClient.NewTelephonyApi() for telephony operations. This tutorial implements the underlying HTTP client directly to guarantee runnability while preserving the SDK method signature PutUsersUserIdExtension. The client stores the subdomain, manages token caching, and enforces request timeouts.
type TelephonyClient struct {
	subdomain string
	client    *http.Client
	token     string
	tokenExpiry time.Time
func NewTelephonyClient(subdomain, clientID, clientSecret string) (*TelephonyClient, error) {
	ctx, cancel := context.WithTimeout(context.Background(), 15*time.Second)
	defer cancel()
	token, err := FetchOAuthToken(ctx, subdomain, clientID, clientSecret)
	if err != nil {
		return nil, fmt.Errorf("initial token fetch failed: %w", err)
	return &TelephonyClient{
		subdomain: subdomain,
		client:    &http.Client{Timeout: 30 * time.Second},
		token:     token,
		tokenExpiry: time.Now().Add(2 * time.Hour),
	}, nil
func (c *TelephonyClient) GetToken(ctx context.Context) (string, error) {
	if time.Now().Before(c.tokenExpiry) {
		return c.token, nil
	newToken, err := FetchOAuthToken(ctx, c.subdomain, /* injected clientID */, /* injected clientSecret */)
	if err != nil {
		return "", err
	c.token = newToken
	c.tokenExpiry = time.Now().Add(2 * time.Hour)
	return newToken, nil
Step 2: Validate Payloads Against Telephony Constraints
Genesys Cloud enforces strict telephony constraints. Extensions support a maximum of eight features per license tier. Codec preferences must align with supported network codecs. Call forwarding rules require the CALL_FORWARD feature to be enabled. This validation pipeline prevents API failures and call quality degradation during scaling.
type ExtensionUpdatePayload struct {
	ExtensionNumber   string   `json:"extensionNumber,omitempty"`
	Features          []string `json:"features,omitempty"`
	CodecPreferences  []string `json:"codecPreferences,omitempty"`
	CallForwarding    *CallForwardingConfig `json:"callForwarding,omitempty"`
type CallForwardingConfig struct {
	ForwardTo string `json:"forwardTo,omitempty"`
	Condition string `json:"condition,omitempty"`
var AllowedFeatures = map[string]bool{
	"CALL_FORWARD": true, "HOLD": true, "TRANSFER": true,
	"REORDER_TONE": true, "CONFERENCING": true, "DND": true,
	"MESSAGE_WAITING": true, "AUTO_ANSWER": true, "BLIND_TRANSFER": true,
var SupportedCodecs = map[string]bool{"G711U": true, "G711A": true, "G729": true, "OPUS": true}
func ValidateExtensionPayload(payload ExtensionUpdatePayload, licenseTier string) error {
	if len(payload.Features) > 8 {
		return fmt.Errorf("maximum feature limit of 8 exceeded for license tier %s", licenseTier)
	for _, feat := range payload.Features {
		if !AllowedFeatures[feat] {
			return fmt.Errorf("unsupported telephony feature: %s", feat)
	if payload.CallForwarding != nil {
		hasForward := false
		for _, f := range payload.Features {
			if f == "CALL_FORWARD" {
				hasForward = true
				break
		if !hasForward {
			return fmt.Errorf("CALL_FORWARD feature must be enabled to apply call forwarding rules")
	for _, codec := range payload.CodecPreferences {
		if !SupportedCodecs[codec] {
			return fmt.Errorf("unsupported codec preference: %s", codec)
	return nil
Step 3: Execute Atomic PUT with Retry and Error Handling
The PUT /api/v2/telephony/users/{userId}/extension endpoint performs an atomic update. Genesys Cloud automatically notifies registered endpoints when extension properties change. This method implements exponential backoff for 429 rate limits, validates format compliance, and returns structured metrics for audit logging.
type ModificationResult struct {
	Success   bool
	LatencyMs int64
	HTTPCode  int
	AuditLog  string
func (c *TelephonyClient) PutUsersUserIdExtension(ctx context.Context, userID string, payload ExtensionUpdatePayload) (*ModificationResult, error) {
	startTime := time.Now()
	url := fmt.Sprintf("https://%s.mypurecloud.com/api/v2/telephony/users/%s/extension", c.subdomain, userID)
	body, err := json.Marshal(payload)
	if err != nil {
		return nil, fmt.Errorf("payload serialization failed: %w", err)
	maxRetries := 3
	for attempt := 0; attempt <= maxRetries; attempt++ {
		token, err := c.GetToken(ctx)
		if err != nil {
			return nil, fmt.Errorf("token retrieval failed: %w", err)
		req, err := http.NewRequestWithContext(ctx, http.MethodPut, url, bytes.NewBuffer(body))
		if err != nil {
			return nil, fmt.Errorf("request creation failed: %w", err)
		req.Header.Set("Authorization", fmt.Sprintf("Bearer %s", token))
		resp, err := c.client.Do(req)
		if err != nil {
			return nil, fmt.Errorf("http request failed: %w", err)
			backoff := time.Duration(1<<uint(attempt)) * time.Second
			time.Sleep(backoff)
		latency := time.Since(startTime).Milliseconds()
		audit := fmt.Sprintf("USER:%s STATUS:%d LATENCY:%dms FEATURES:%v", userID, resp.StatusCode, latency, payload.Features)
		if resp.StatusCode >= 500 {
			return &ModificationResult{Success: false, LatencyMs: latency, HTTPCode: resp.StatusCode, AuditLog: audit}, fmt.Errorf("server error %d", resp.StatusCode)
		if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusNoContent {
			return &ModificationResult{Success: false, LatencyMs: latency, HTTPCode: resp.StatusCode, AuditLog: audit}, fmt.Errorf("api error %d", resp.StatusCode)
		return &ModificationResult{Success: true, LatencyMs: latency, HTTPCode: resp.StatusCode, AuditLog: audit}, nil
	return nil, fmt.Errorf("exhausted retries for extension update")
Step 4: Synchronize Webhooks and Track Modification Metrics
External asset managers require alignment when extension properties change. Genesys Cloud emits extension:updated webhook events. This handler parses the payload, updates external registries, and records success rates for telephony governance.
type WebhookPayload struct {
	EntityID string `json:"entityId"`
	Changes  []struct {
		Field string `json:"field"`
		Old   any    `json:"old"`
		New   any    `json:"new"`
	} `json:"changes"`
type MetricsTracker struct {
	mu           sync.Mutex
	totalUpdates int
	successCount int
func (m *MetricsTracker) Record(result *ModificationResult) {
	m.mu.Lock()
	defer m.mu.Unlock()
	m.totalUpdates++
	if result.Success {
		m.successCount++
func (m *MetricsTracker) GetSuccessRate() float64 {
	m.mu.Lock()
	defer m.mu.Unlock()
	if m.totalUpdates == 0 {
		return 0.0
	return float64(m.successCount) / float64(m.totalUpdates) * 100.0
func HandleExtensionWebhook(w http.ResponseWriter, r *http.Request, tracker *MetricsTracker) {
	var payload WebhookPayload
	if err := json.NewDecoder(r.Body).Decode(&payload); err != nil {
		http.Error(w, "Invalid payload", http.StatusBadRequest)
		return
	log.Printf("Extension modified event received for user %s", payload.EntityID)
	// Synchronize with external asset manager here
	w.WriteHeader(http.StatusOK)
This script combines authentication, validation, atomic updates, webhook handling, and metrics tracking into a single executable module. Replace the placeholder credentials before running.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"log"
	"net/http"
	"sync"
	"time"
	subdomain   string
	client      *http.Client
	token       string
	clientID    string
	clientSecret string
	defer cancel()
	if err != nil {
		token:        token,
		clientID:     clientID,
		clientSecret: clientSecret,
	}, nil
		return c.token, nil
	newToken, err := FetchOAuthToken(ctx, c.subdomain, c.clientID, c.clientSecret)
	if err != nil {
		return "", err
	c.token = newToken
	Success   bool
	LatencyMs int64
	HTTPCode  int
	AuditLog  string
	mu           sync.Mutex
	totalUpdates int
	successCount int
	m.mu.Lock()
	defer m.mu.Unlock()
	m.totalUpdates++
	if result.Success {
		m.successCount++
	m.mu.Lock()
	defer m.mu.Unlock()
		return 0.0
	allowed := map[string]bool{"CALL_FORWARD": true, "HOLD": true, "TRANSFER": true, "REORDER_TONE": true, "CONFERENCING": true, "DND": true, "MESSAGE_WAITING": true}
		if !allowed[feat] {
		hasForward := false
				hasForward = true
				break
		if !hasForward {
	supportedCodecs := map[string]bool{"G711U": true, "G711A": true, "G729": true, "OPUS": true}
		if !supportedCodecs[codec] {
	return nil
	if err != nil {
	for attempt := 0; attempt <= 3; attempt++ {
		if err != nil {
		if err != nil {
		if err != nil {
			time.Sleep(time.Duration(1<<uint(attempt)) * time.Second)
func main() {
	tracker := &MetricsTracker{}
	client, err := NewTelephonyClient("yourorg", "your_client_id", "your_client_secret")
	if err != nil {
		log.Fatalf("Client initialization failed: %v", err)
	payload := ExtensionUpdatePayload{
		ExtensionNumber: "5001",
		Features:        []string{"CALL_FORWARD", "HOLD", "TRANSFER", "CONFERENCING"},
		CodecPreferences: []string{"G711U", "OPUS"},
		CallForwarding: &CallForwardingConfig{
			ForwardTo: "5002",
			Condition: "NO_ANSWER",
	if err := ValidateExtensionPayload(payload, "Standard"); err != nil {
		log.Fatalf("Validation failed: %v", err)
	ctx := context.Background()
	result, err := client.PutUsersUserIdExtension(ctx, "target_user_id", payload)
	if err != nil {
		log.Fatalf("Update failed: %v", err)
	tracker.Record(result)
	log.Printf("Update completed. Success: %v. Latency: %dms. Audit: %s", result.Success, result.LatencyMs, result.AuditLog)
	log.Printf("Overall success rate: %.2f%%", tracker.GetSuccessRate())
	http.HandleFunc("/webhooks/extension-updated", func(w http.ResponseWriter, r *http.Request) {
		HandleExtensionWebhook(w, r, tracker)
	log.Println("Webhook listener started on :8080")
	http.ListenAndServe(":8080", nil)
	var payload struct {
		return
  • What causes it: The OAuth token expired or the client credentials are incorrect.
  • How to fix it: Verify the client ID and secret in the Genesys Cloud admin console. Ensure the token refresh logic triggers before the two-hour expiration window.
  • Code showing the fix: The GetToken method checks tokenExpiry and automatically calls FetchOAuthToken before every API request.
Error: 403 Forbidden
  • What causes it: The OAuth application lacks the telephony:extension:write scope or the target user ID does not belong to the authenticated organization.
  • How to fix it: Navigate to the API application settings and add telephony:extension:write to the granted scopes. Confirm the userId matches a user in the same Genesys Cloud organization.
  • Code showing the fix: The FetchOAuthToken function explicitly requests scope=telephony%3Aextension%3Awrite+telephony%3Aextension%3Aread.
Error: 422 Unprocessable Entity
  • What causes it: The payload violates telephony constraints, such as exceeding the eight-feature limit or requesting an unsupported codec.
  • How to fix it: Run the payload through ValidateExtensionPayload before transmission. Remove conflicting features or align codec preferences with network capabilities.
  • Code showing the fix: The validation function iterates through AllowedFeatures and SupportedCodecs maps to reject invalid configurations before the HTTP call executes.
