Mocking NICE CXone External API Calls via Flow API with Python SDK
- A Python module that programmatically creates, validates, and manages external API mocks within a CXone Flow, including latency simulation, schema validation, webhook synchronization, and audit logging.
- This tutorial uses the NICE CXone Flow Mock API (
/api/v2/flows/{flowId}/mocks) and the officialnice-cxone-sdkPython package. - The implementation covers Python 3.9+ with
requests,jsonschema, and structured logging.
- OAuth 2.0 Client Credentials grant type
- Required scopes:
flow:mock:write,flow:mock:read,flow:read - SDK:
nice-cxone-sdk(v2.x) - Runtime: Python 3.9+
- External dependencies:
pip install nice-cxone-sdk requests jsonschema
CXone uses OAuth 2.0 for API authentication. The following code fetches a bearer token, caches it, and handles expiration. The token is then injected into the SDK client configuration.
import requests
from typing import Optional
class CxoneAuthManager:
def __init__(self, environment: str, client_id: str, client_secret: str, scopes: list[str]):
self.environment = environment
self.client_id = client_id
self.scopes = scopes
self.token_url = f"https://{environment}.my.cxone.com/api/v2/oauth/token"
def get_token(self) -> str:
if self.access_token and time.time() < self.token_expiry - 60:
return self.access_token
payload = {
"client_id": self.client_id,
"scope": " ".join(self.scopes)
response = requests.post(self.token_url, data=payload, timeout=10)
response.raise_for_status()
token_data = response.json()
self.token_expiry = time.time() + token_data["expires_in"]
Step 1: Mock Schema Validation and Constraint Checking
CXone enforces strict constraints on mock definitions. The maximum mock payload size is 50KB, and a single flow supports a maximum of 100 concurrent mocks. This step validates the mock structure against a JSON schema before submission.
import json
import jsonschema
from jsonschema import validate, ValidationError
MOCK_SCHEMA = {
"type": "object",
"required": ["request", "response", "enabled"],
"properties": {
"request": {
"type": "object",
"required": ["method", "url"],
"properties": {
"method": {"type": "string", "enum": ["GET", "POST", "PUT", "PATCH", "DELETE"]},
"url": {"type": "string", "format": "uri"},
"headers": {"type": "object"},
"match": {
"type": "object",
"properties": {
"query": {"type": "object"},
"body": {"type": "object"}
"response": {
"type": "object",
"required": ["status", "body"],
"properties": {
"status": {"type": "integer", "minimum": 100, "maximum": 599},
"body": {"type": ["object", "string"]},
"delay": {"type": "integer", "minimum": 0, "maximum": 5000},
"webhookUrl": {"type": "string", "format": "uri"},
"enabled": {"type": "boolean"},
"routeOverride": {"type": "boolean"}
def validate_mock_payload(mock_config: dict) -> None:
payload_bytes = json.dumps(mock_config).encode("utf-8")
if len(payload_bytes) > 50 * 1024:
raise ValueError("Mock payload exceeds 50KB flow engine limit")
validate(instance=mock_config, schema=MOCK_SCHEMA)
except ValidationError as err:
raise ValueError(f"Mock schema validation failed: {err.message}")
Step 2: Atomic PUT Operations with Route Override and Latency
Test environment binding requires atomic updates to prevent concurrent modifications. CXone supports optimistic locking via the If-Match header. The following function constructs a mock with response template matrices, latency directives, and automatic route override triggers.
import logging
from nice_cxone_sdk.client import NiceClient
from nice_cxone_sdk.api.flow_api import FlowApi
from nice_cxone_sdk.rest import ApiException
logger = logging.getLogger("cxone_flow_mocker")
def create_or_update_mock(
client: NiceClient,
flow_id: str,
mock_id: str,
mock_config: dict,
etag: Optional[str] = None
) -> dict:
validate_mock_payload(mock_config)
api_instance = FlowApi(client.api_client)
headers = {}
if etag:
headers["If-Match"] = etag
if mock_id:
response = api_instance.put_flow_mocks(mock_id=mock_id, flow_id=flow_id, body=mock_config, headers=headers)
logger.info("Mock updated atomically with route override and latency directives")
else:
response = api_instance.post_flow_mocks(flow_id=flow_id, body=mock_config, headers=headers)
logger.info("New mock created with endpoint URL reference")
return response.to_dict()
except ApiException as exc:
if exc.status == 409:
raise RuntimeError("Version conflict detected. Fetch latest ETag and retry.")
if exc.status == 429:
raise RuntimeError("Rate limit exceeded. Implement exponential backoff.")
raise
Step 3: Webhook Synchronization and Latency Tracking
Mock events synchronize with external QA orchestration tools via webhook callbacks. The Flow API provides statistics endpoints to track hit counts, latency, and coverage rates.
from datetime import datetime
def sync_mock_stats_and_webhook(
client: NiceClient,
flow_id: str,
mock_id: str,
qa_webhook_url: str
) -> dict:
# Update webhook binding
webhook_config = {"webhookUrl": qa_webhook_url, "enabled": True}
api_instance.patch_flow_mocks(flow_id=flow_id, mock_id=mock_id, body=webhook_config)
# Fetch statistics
stats = api_instance.get_flow_mocks_stats(flow_id=flow_id, mock_id=mock_id)
stats_data = stats.to_dict()
coverage_rate = (stats_data.get("hitCount", 0) / max(stats_data.get("totalFlowExecutions", 1), 1)) * 100
avg_latency_ms = stats_data.get("averageResponseTimeMs", 0)
logger.info(f"Mock {mock_id} coverage: {coverage_rate:.2f}%, avg latency: {avg_latency_ms}ms")
"hitCount": stats_data.get("hitCount", 0),
"coverageRate": round(coverage_rate, 2),
"averageLatencyMs": avg_latency_ms,
"lastHitTime": stats_data.get("lastHitTime")
Step 4: Audit Logging and Governance Pipeline
Testing governance requires structured audit logs for every mock operation. This pipeline records schema validation results, route overrides, and webhook synchronization events.
import json
class MockAuditLogger:
def __init__(self, log_file: str = "mock_audit.log"):
self.log_file = log_file
def log_operation(self, operation: str, mock_id: str, payload_hash: str, success: bool, metadata: dict) -> None:
audit_entry = {
"operation": operation,
"mockId": mock_id,
"payloadHash": payload_hash,
"success": success,
"metadata": metadata,
"governanceTag": "flow_test_mock"
with open(self.log_file, "a", encoding="utf-8") as f:
f.write(json.dumps(audit_entry) + "\n")
logger.info(f"Audit logged: {operation} for {mock_id}")
The following script combines authentication, validation, atomic updates, webhook synchronization, and audit logging into a single automated Flow management module.
import hashlib
import logging
# Configure logging
class CxoneFlowMockManager:
MAX_MOCKS_PER_FLOW = 100
MAX_PAYLOAD_BYTES = 50 * 1024
self.auth = CxoneAuthManager(environment, client_id, client_secret, scopes)
self.client = NiceClient(
client_id=client_id,
client_secret=client_secret,
environment=environment,
oauth_token_url=f"https://{environment}.my.cxone.com/api/v2/oauth/token"
self.flow_api = FlowApi(self.client.api_client)
self.audit = MockAuditLogger()
def _get_etag(self, flow_id: str, mock_id: str) -> Optional[str]:
existing = self.flow_api.get_flow_mocks(flow_id=flow_id, mock_id=mock_id)
return existing.etag
if exc.status == 404:
return None
raise
def deploy_mock(
self,
flow_id: str,
mock_id: str,
mock_config: dict,
qa_webhook_url: str
) -> dict:
# Validate schema and constraints
# Check flow mock limit
existing_mocks = self.flow_api.get_flow_mocks_list(flow_id=flow_id)
if len(existing_mocks) >= self.MAX_MOCKS_PER_FLOW:
raise RuntimeError(f"Flow {flow_id} has reached maximum mock limit ({self.MAX_MOCKS_PER_FLOW})")
# Atomic update with route override and latency
etag = self._get_etag(flow_id, mock_id)
payload_hash = hashlib.sha256(json.dumps(mock_config, sort_keys=True).encode()).hexdigest()
success = False
result = create_or_update_mock(
client=self.client,
flow_id=flow_id,
mock_id=mock_id,
mock_config=mock_config,
etag=etag
success = True
# Synchronize webhook
client=self.client,
flow_id=flow_id,
mock_id=mock_id,
qa_webhook_url=qa_webhook_url
self.audit.log_operation(
operation="deploy_mock",
mock_id=mock_id,
payload_hash=payload_hash,
success=True,
metadata={"routeOverride": mock_config.get("routeOverride"), "delayMs": mock_config.get("response", {}).get("delay")}
return result
except Exception as exc:
mock_id=mock_id,
success=False,
metadata={"error": str(exc)}
raise
# Example usage
MOCK_PAYLOAD = {
"request": {
"method": "POST",
"url": "https://payments.external-api.com/v1/transactions",
"headers": {"Content-Type": "application/json", "X-Trace-Id": "mock-test-001"},
"match": {"body": {"currency": "USD"}}
"response": {
"status": 200,
"body": {"transactionId": "txn_8923", "status": "approved", "amount": 150.00},
"delay": 250,
"headers": {"X-Mock-Source": "cxone-flow-api"}
"enabled": True,
"routeOverride": True,
"webhookUrl": "https://qa-orchestrator.internal.net/webhooks/cxone-mock-hit"
manager = CxoneFlowMockManager(
environment="us",
client_id="your_client_id",
client_secret="your_client_secret",
scopes=["flow:mock:write", "flow:mock:read", "flow:read"]
deployed = manager.deploy_mock(
flow_id="a1b2c3d4-5678-90ab-cdef-1234567890ab",
mock_id="mock_ext_payment_01",
mock_config=MOCK_PAYLOAD,
qa_webhook_url="https://qa-orchestrator.internal.net/webhooks/cxone-mock-hit"
print("Mock deployed successfully:", deployed)
logger.error(f"Deployment failed: {e}")
Error: 400 Bad Request (Schema or Constraint Violation)
- What causes it: The mock payload contains invalid JSON, exceeds the 50KB limit, or violates the Flow engine schema requirements.
- How to fix it: Run the payload through
validate_mock_payload()before API submission. Ensure all required fields (request.method,request.url,response.status,response.body) are present. - Code showing the fix:
except ValueError as verr:
logger.error(f"Schema validation blocked deployment: {verr}")
return
Error: 409 Conflict (Version Mismatch)
- What causes it: Another process modified the mock definition after you fetched it, causing an ETag mismatch on the
PUTrequest. - How to fix it: Fetch the latest resource with
GET, extract the newETagheader, and retry thePUTrequest with the updated value. - Code showing the fix:
etag = manager._get_etag(flow_id, mock_id)
if etag:
headers = {"If-Match": etag}
# Retry PUT with updated etag
- What causes it: CXone enforces rate limits per API client. Rapid mock iteration or bulk deployments trigger throttling.
- How to fix it: Implement exponential backoff with jitter. The following retry decorator handles 429 responses automatically.
import random
def retry_on_rate_limit(max_retries=5, base_delay=1.0):
def decorator(func):
def wrapper(*args, **kwargs):
return func(*args, **kwargs)
if exc.status == 429 and attempt < max_retries - 1:
delay = base_delay * (2 ** attempt) + random.uniform(0, 1)
logger.warning(f"Rate limited. Retrying in {delay:.2f}s (attempt {attempt + 1})")
time.sleep(delay)
else:
raise
return wrapper
return decorator
# Apply to API calls
@retry_on_rate_limit()
def safe_deploy_mock(*args, **kwargs):
# API call here
pass
Error: 403 Forbidden (Missing Scope)
- What causes it: The OAuth token lacks
flow:mock:writeorflow:mock:readscopes. - How to fix it: Regenerate the token with the correct scope string. CXone requires explicit scope matching for mock operations.
environment="us",
client_id="client_id",
client_secret="client_secret",
token = auth.get_token()
