Mocking NICE CXone and Cognigy Webhook Responses with Go
  • A production-grade HTTP mock server in Go that intercepts outbound NICE CXone and Cognigy webhook calls, validates payloads against strict JSON schemas, simulates third-party responses with configurable latency, and tracks spoof success rates.
  • This implementation uses the Go standard library (net/http, crypto/hmac, sync/atomic, log/slog) and the github.com/santhosh-tekuri/jsonschema/v5 package for schema validation.
  • The tutorial covers Go 1.21+ with explicit middleware pipelines, signature verification, payload drift detection, and structured audit logging for offline bot testing.
  • NICE CXone Studio webhook configuration with HMAC secret enabled
  • Cognigy API webhook endpoint configuration
  • Go runtime version 1.21 or higher
  • Required modules: github.com/santhosh-tekuri/jsonschema/v5, github.com/gorilla/mux (optional routing), standard library packages
  • OAuth scope for CXone Studio webhook management: cxone:studio:webhook:read (used only for initial configuration verification; runtime webhook delivery uses HMAC signatures)
NICE CXone outbound webhooks do not transmit OAuth tokens. They secure payloads using HMAC-SHA256 signatures appended to the X-CXONE-SIGNATURE header. Cognigy webhooks follow a similar pattern with X-Cognigy-Signature. The mock server must verify these signatures before processing or spoofing responses. This prevents unauthorized spoof injection and ensures the mock server only responds to legitimate CXone or Cognigy orchestration engines.
The verification pipeline computes the expected signature from the raw request body and compares it against the header value using constant-time comparison to prevent timing attacks.
package auth
import (
	"crypto/hmac"
	"crypto/sha256"
	"encoding/hex"
	"io"
	"net/http"
// VerifyWebhookSignature validates the incoming CXone or Cognigy webhook signature.
// It reads the raw body, computes HMAC-SHA256, and returns a boolean result.
func VerifyWebhookSignature(r *http.Request, secret []byte) bool {
	signature := r.Header.Get("X-CXONE-SIGNATURE")
	if signature == "" {
		signature = r.Header.Get("X-Cognigy-Signature")
		return false
	body, err := io.ReadAll(r.Body)
	if err != nil {
		return false
	r.Body = io.NopCloser(io.NewReadBody(body))
	mac := hmac.New(sha256.New, secret)
	mac.Write(body)
	expected := mac.Sum(nil)
	return hmac.Equal([]byte(signature), hex.EncodeToString(expected))
Step 1: Atomic HTTP Middleware and Latency Constraints
The mock server requires atomic metrics tracking to measure spoof success rates and latency without race conditions. Go sync/atomic types provide lock-free counters. The middleware enforces maximum-spoof-latency-ms limits by measuring request duration and rejecting spoof operations that exceed the threshold. This prevents cascade failures during CXone scaling events.
package middleware
import (
	"log/slog"
	"net/http"
	"sync/atomic"
	"time"
type Metrics struct {
	TotalRequests   atomic.Int64
	SpoofSuccesses  atomic.Int64
	SpoofFailures   atomic.Int64
	TotalLatencyMs  atomic.Int64
var GlobalMetrics Metrics
func AtomicMetricsMiddleware(next http.Handler, maxLatencyMs int) http.Handler {
	return http.HandlerFunc(func(w http.ResponseWriter, r *http.Request) {
		start := time.Now()
		GlobalMetrics.TotalRequests.Add(1)
		next.ServeHTTP(w, r)
		elapsed := time.Since(start).Milliseconds()
		GlobalMetrics.TotalLatencyMs.Add(elapsed)
		if elapsed > int64(maxLatencyMs) {
			slog.Warn("Spoof latency exceeded maximum-spoof-latency-ms limit",
				"elapsed_ms", elapsed, "max_ms", maxLatencyMs)
			GlobalMetrics.SpoofFailures.Add(1)
		} else {
			GlobalMetrics.SpoofSuccesses.Add(1)
Step 2: JSON Schema Validation and Cognigy Matrix Mapping
Webhook payloads must conform to cognigy-constraints before spoofing proceeds. The mock server loads a JSON schema that defines allowed fields, data types, and cardinality limits. The cognigy-matrix is a mapping structure that translates incoming webhook references (webhook-ref) to spoof directives. Schema validation occurs before any response synthesis.
package validator
import (
	"encoding/json"
	"fmt"
	"github.com/santhosh-tekuri/jsonschema/v5"
var (
	compiledSchema *jsonschema.Schema
	compileError   error
func init() {
	// Realistic CXone/Cognigy webhook schema constraints
	schemaJSON := `{
		"type": "object",
		"required": ["webhook-ref", "channel", "direction", "payload"],
		"properties": {
			"webhook-ref": {"type": "string", "pattern": "^WH-[A-Z0-9]{12}$"},
			"channel": {"type": "string", "enum": ["voice", "chat", "sms", "email"]},
			"direction": {"type": "string", "enum": ["inbound", "outbound"]},
			"payload": {"type": "object"},
			"timestamp": {"type": "integer"}
		"additionalProperties": false
	compiledSchema, compileError = jsonschema.CompileString("cxone-webhook.json", schemaJSON)
func ValidatePayload(data []byte) error {
	if compileError != nil {
		return fmt.Errorf("schema compilation failed: %w", compileError)
	var payload interface{}
	if err := json.Unmarshal(data, &payload); err != nil {
		return fmt.Errorf("invalid JSON: %w", err)
	return compiledSchema.Validate(payload)
Step 3: Spoof Response Generation and Payload Drift Detection
The core spoof logic synthesizes HTTP status codes and response bodies based on the spoof directive embedded in the request context or configuration. The server calculates status-code-synthesis by evaluating the webhook-ref against a routing table. Payload drift detection compares the incoming structure against a baseline snapshot. If drift exceeds a threshold, the mock server rejects the spoof to prevent integration coupling during CXone scaling.
package spoof
import (
	"encoding/json"
	"fmt"
	"net/http"
	"time"
type WebhookRequest struct {
	WebhookRef string                 `json:"webhook-ref"`
	Channel    string                 `json:"channel"`
	Direction  string                 `json:"direction"`
	Payload    map[string]interface{} `json:"payload"`
	Timestamp  int64                  `json:"timestamp"`
type SpoofResponse struct {
	StatusCode int                    `json:"status_code"`
	Headers    map[string]string      `json:"headers,omitempty"`
	Body       map[string]interface{} `json:"body"`
	LatencyMs  int                    `json:"latency_ms"`
// BaselineSnapshot stores the expected structure for drift detection
var BaselineSnapshot = map[string]interface{}{
	"webhook-ref": "",
	"channel":     "",
	"direction":   "",
	"payload":     map[string]interface{}{},
func DetectPayloadDrift(incoming, baseline map[string]interface{}) bool {
	for k := range baseline {
		if _, exists := incoming[k]; !exists {
			return true
	return false
func SynthesizeResponse(w http.ResponseWriter, r *http.Request, req WebhookRequest) {
	if DetectPayloadDrift(req.Payload, BaselineSnapshot["payload"].(map[string]interface{})) {
		http.Error(w, "Payload drift detected. Spoof aborted.", http.StatusForbidden)
		return
	// status-code-synthesis evaluation logic
	statusCode := http.StatusOK
	if req.Direction == "outbound" && req.Channel == "voice" {
		statusCode = http.StatusAccepted
	// Simulate automatic spoof trigger delay
	spoofDelay := time.Duration(50) * time.Millisecond
	time.Sleep(spoofDelay)
	response := SpoofResponse{
		StatusCode: statusCode,
		Headers:    map[string]string{"X-Mock-Spoof": "true", "X-Webhook-Ref": req.WebhookRef},
		Body: map[string]interface{}{
			"mock_id":    "MOCK-" + req.WebhookRef,
			"synthesis":  "success",
			"timestamp":  time.Now().UnixMilli(),
			"channel":    req.Channel,
		LatencyMs: int(spoofDelay.Milliseconds()),
	for k, v := range response.Headers {
		w.Header().Set(k, v)
	w.WriteHeader(statusCode)
	json.NewEncoder(w).Encode(response)
Step 4: Audit Logging and External Test Harness Synchronization
The mock server generates structured audit logs for Cognigy governance. Each spoof event records the webhook-ref, latency, success status, and drift check result. The server synchronizes with an external test harness by emitting webhook spoofed webhooks to a configurable callback URL. This enables alignment between offline bot testing and live CXone orchestration.
package audit
import (
	"encoding/json"
	"fmt"
	"io"
	"log/slog"
	"net/http"
	"time"
type AuditRecord struct {
	Timestamp    time.Time `json:"timestamp"`
	SpoofStatus  string    `json:"spoof_status"`
	LatencyMs    int64     `json:"latency_ms"`
	DriftDetected bool     `json:"drift_detected"`
func EmitAuditLog(record AuditRecord, harnessURL string) {
	slog.Info("Audit log emitted", "record", record)
	if harnessURL != "" {
		payload, _ := json.Marshal(record)
		resp, err := http.Post(harnessURL, "application/json", io.NopCloser(io.NewReadBody(payload)))
		if err != nil {
			slog.Error("Failed to sync with external-test-harness", "error", err)
			return
		defer resp.Body.Close()
			slog.Warn("Harness sync returned non-200", "status", resp.StatusCode)
The following Go program integrates all components into a single runnable mock server. It binds to port 8080, enforces signature verification, validates schemas, synthesizes spoof responses, tracks atomic metrics, and emits audit logs.
package main
import (
	"encoding/json"
	"log/slog"
	"net/http"
	"time"
	"mockserver/audit"
	"mockserver/auth"
	"mockserver/middleware"
	"mockserver/spoof"
	"mockserver/validator"
const (
	webhookSecret   = "your-cxone-hmac-secret-key"
	maxLatencyMs    = 500
	harnessSyncURL  = "https://test-harness.example.com/sync"
func webhookHandler(w http.ResponseWriter, r *http.Request) {
	if !auth.VerifyWebhookSignature(r, []byte(webhookSecret)) {
		http.Error(w, "Invalid signature", http.StatusUnauthorized)
		audit.EmitAuditLog(audit.AuditRecord{
			Timestamp:   time.Now(),
			WebhookRef:  "",
			SpoofStatus: "signature_failed",
			StatusCode:  http.StatusUnauthorized,
		}, harnessSyncURL)
		return
	body, _ := io.ReadAll(r.Body)
	if err := validator.ValidatePayload(body); err != nil {
		http.Error(w, fmt.Sprintf("Schema validation failed: %v", err), http.StatusBadRequest)
			SpoofStatus: "schema_failed",
			StatusCode:  http.StatusBadRequest,
		}, harnessSyncURL)
		return
	var req spoof.WebhookRequest
	if err := json.Unmarshal(body, &req); err != nil {
		http.Error(w, "JSON decode error", http.StatusBadRequest)
		return
	spoof.SynthesizeResponse(w, r, req)
		WebhookRef:    req.WebhookRef,
		SpoofStatus:   "success",
		LatencyMs:     middleware.GlobalMetrics.TotalLatencyMs.Load(),
		StatusCode:    http.StatusOK,
		DriftDetected: false,
	}, harnessSyncURL)
func metricsHandler(w http.ResponseWriter, r *http.Request) {
	json.NewEncoder(w).Encode(map[string]int64{
		"total_requests":   middleware.GlobalMetrics.TotalRequests.Load(),
		"spoof_successes":  middleware.GlobalMetrics.SpoofSuccesses.Load(),
		"spoof_failures":   middleware.GlobalMetrics.SpoofFailures.Load(),
		"total_latency_ms": middleware.GlobalMetrics.TotalLatencyMs.Load(),
func main() {
	slog.Info("Starting CXone/Cognigy webhook mocker on :8080")
	mux := http.NewServeMux()
	mux.HandleFunc("/webhook/mock", webhookHandler)
	mux.HandleFunc("/metrics", metricsHandler)
	handler := middleware.AtomicMetricsMiddleware(mux, maxLatencyMs)
	if err := http.ListenAndServe(":8080", handler); err != nil {
		slog.Error("Server failed to start", "error", err)
Error: 401 Unauthorized (Signature Mismatch)
  • Cause: The X-CXONE-SIGNATURE or X-Cognigy-Signature header does not match the computed HMAC-SHA256 digest of the raw body using the configured secret.
  • Fix: Verify that the CXone Studio webhook configuration uses the exact same secret string. Ensure the request body is not modified by reverse proxies or load balancers before reaching the mock server.
  • Code showing the fix: Add a debug log that prints the expected and received signatures during development. Use hex.EncodeToString(mac.Sum(nil)) for comparison.
Error: 400 Bad Request (Schema Validation Failure)
  • Cause: The incoming payload violates cognigy-constraints defined in the JSON schema. Common triggers include missing webhook-ref, invalid channel enum values, or additional properties.
  • Fix: Align the CXone Studio webhook payload template with the schema. Remove dynamic fields that are not explicitly allowed. Use "additionalProperties": false strictly during testing.
  • Code showing the fix: Log the validation error details from jsonschema.Validate() to identify the exact path and rule violation.
Error: 408 Request Timeout (Latency Exceeded)
  • Cause: The spoof delay or downstream processing exceeds maximum-spoof-latency-ms. CXone orchestration engines will drop the request and trigger a retry cascade.
  • Fix: Reduce the artificial time.Sleep duration in the spoof synthesis step. Increase the timeout threshold if the third-party simulation requires heavy computation.
  • Code showing the fix: Adjust maxLatencyMs in the middleware initialization. Monitor /metrics to track total_latency_ms trends.
Error: 429 Too Many Requests (Rate Limit Cascade)
  • Cause: CXone scaling events generate webhook bursts that overwhelm the mock server. The server must simulate 429 responses to test client retry logic.
  • Fix: Implement a token bucket or sliding window rate limiter in the middleware. Return 429 with Retry-After header when the threshold is exceeded.
  • Code showing the fix: Add a sync.Mutex protected counter that increments per second. If count > 100, write w.WriteHeader(http.StatusTooManyRequests) and set w.Header().Set("Retry-After", "5").
