Mitigating Audio Jitter and Packet Loss in Genesys Cloud WebRTC Calls by Implementing Adaptive Forward Error Correction (FEC) and Packet Loss Concealment
This guide details the exact configuration steps to optimize WebRTC audio quality in Genesys Cloud by tuning jitter buffer thresholds, enabling adaptive Forward Error Correction (FEC), and leveraging Packet Loss Concealment (PLC) mechanisms. When complete, your agent browsers and desktop clients will dynamically compensate for network degradation without introducing conversational latency or bandwidth saturation.
  • Licensing Tier: Genesys Cloud CX 1 or higher. WebRTC media path optimization is included in all tiers. Genesys Cloud Observability or WEM Add-on is required for granular packet-level diagnostics and historical jitter trending.
  • Granular Permissions: Site > Edit, Telephony > Settings > Edit, User > Settings > Edit, Architect > Flow > Edit
  • OAuth Scopes: site:edit, telephony:user-settings:edit, user:settings:edit, architect:flow:edit
  • External Dependencies: Unrestricted UDP access to Genesys Cloud media CIDRs on ports 50000-60000, TCP 443 as fallback, stable DNS resolution for *.pure.cloudapps.net, browser hardware acceleration enabled at the OS level.
1. Site-Level Network Constraints and Jitter Buffer Boundaries
The WebRTC media path relies on an adaptive jitter buffer to reorder out-of-sequence RTP packets before decoding. Genesys Cloud exposes buffer bounds at the site level to prevent the underlying libwebrtc stack from oscillating between extreme values during network fluctuation.
Configure the site network settings via the Admin API to establish strict minimum and maximum buffer thresholds. We set the minimum to 30 milliseconds to absorb micro-bursts from enterprise Wi-Fi handoffs, and the maximum to 120 milliseconds to prevent conversational lag. Values above 150 milliseconds trigger natural interruption patterns in human dialogue, degrading agent-customer rapport.
API Configuration:
PATCH /api/v2/sites/{siteId}
Request Body:
  "networkSettings": {
    "jitterBufferMinMs": 30,
    "jitterBufferMaxMs": 120,
    "jitterBufferAdaptiveEnabled": true,
    "preferredTransportProtocol": "UDP",
    "turnServerFallbackEnabled": true
The Trap: Setting jitterBufferMaxMs to 200 milliseconds or higher to combat perceived packet loss. A large static buffer masks loss initially but introduces severe talker-listener delay. When the buffer exceeds the WebRTC congestion control algorithm’s tolerance, the stack forcibly drains the buffer, causing immediate audio clipping and silence gaps. The downstream effect is a 40 percent increase in call abandonment and agent-reported audio quality tickets.
Architectural Reasoning: We constrain the adaptive window because unbounded jitter buffers interact poorly with WebRTC’s Generic Congestion Control (GCC). GCC reduces bitrate when it detects high RTT or buffer expansion. By capping the maximum at 120 milliseconds, we force GCC to react to actual network congestion rather than buffer inflation, maintaining a stable bitrate profile during cellular degradation.
2. WebRTC Codec Selection and Adaptive FEC Activation
OPUS is the mandatory codec for Genesys Cloud WebRTC audio. OPUS natively supports both Forward Error Correction and Packet Loss Concealment. The platform does not toggle PLC independently; PLC activates automatically when the decoder detects missing sequence numbers in the OPUS stream. We control FEC aggressiveness through site telephony settings.
FEC works by transmitting redundant payload blocks alongside primary audio frames. When packet loss occurs, the decoder reconstructs missing frames from the redundant data. Adaptive FEC scales redundancy based on real-time loss percentage. We enable this scaling to prevent bandwidth waste on clean networks while protecting against burst loss on congested links.
API Configuration:
Request Body:
  "telephonySettings": {
    "audioCodecs": ["OPUS", "G722", "G711U", "G711A"],
    "preferredAudioCodec": "OPUS",
    "fecEnabled": true,
    "fecAdaptiveEnabled": true,
    "fecRedundancyMaxPercent": 25,
    "plcEnabled": true,
    "audioSampleRateHz": 48000,
    "audioChannels": 1
The Trap: Disabling fecAdaptiveEnabled and setting fecRedundancyMaxPercent to a fixed high value. Fixed FEC transmits redundant data regardless of network conditions. On a stable corporate LAN, this consumes an additional 15 to 20 percent of available bandwidth. The downstream effect triggers QoS policing on enterprise firewalls, causing intentional packet drops that defeat the purpose of FEC. Adaptive scaling remains mandatory for heterogeneous agent environments.
Architectural Reasoning: We prioritize OPUS in the codec negotiation list because G.711 and G.722 lack native FEC and PLC capabilities. If the WebRTC offer/answer exchange falls back to G.711 due to misconfigured site preferences, packet loss becomes immediately audible as clipping or dropout. By locking preferredAudioCodec to OPUS and enabling adaptive FEC, we ensure the media path utilizes the codec’s built-in error resilience before network conditions degrade beyond recovery.
3. User-Level Audio Overrides and Browser Environment Hardening
Site settings establish the baseline, but user-level configurations can override network and audio parameters. Inconsistent user settings create unpredictable media paths that complicate troubleshooting. We enforce uniform audio profiles via the User Settings API, particularly for remote agents operating on variable internet connections.
User settings control device sampling rates, echo cancellation profiles, and local jitter buffer overrides. We lock the audio sample rate to 48000 Hz to match the WebRTC native processing pipeline. Deviating from 48000 Hz forces the browser to perform real-time sample rate conversion, increasing CPU utilization and introducing processing jitter.
API Configuration:
PUT /api/v2/users/{userId}/settings
Request Body:
  "audioSettings": {
    "echoCancellationEnabled": true,
    "noiseSuppressionEnabled": true,
    "autoGainControlEnabled": true,
    "sampleRateHz": 48000,
    "channelCount": 1,
    "deviceOverrideEnabled": false
The Trap: Allowing deviceOverrideEnabled to remain true while agents connect via consumer-grade headsets with variable sampling rates. Consumer USB audio devices frequently report 44100 Hz or 96000 Hz capabilities. The browser selects the highest supported rate, triggering internal resampling. The downstream effect is CPU starvation on older laptops, causing WebRTC thread starvation and periodic audio freezing during high-concurrency call handling.
Architectural Reasoning: We disable device overrides to force the WebRTC stack to use the platform-native 48000 Hz pipeline. This eliminates resampling overhead and ensures consistent packetization intervals. Consistent packetization allows the jitter buffer to predict arrival times accurately, reducing buffer expansion events. When combined with site-level FEC, this creates a deterministic audio path that scales predictably across diverse hardware.
4. Architect Flow Media Optimization and Transcoding Elimination
WebRTC audio quality degrades when Architect flows process unoptimized media files. The Play block in Architect streams audio to the agent or customer. If the uploaded media file does not match the WebRTC codec profile, Genesys Cloud performs real-time transcoding on the media server. Transcoding increases server CPU load and introduces packetization delay into the RTP stream.
We enforce OPUS or MP3 media uploads at 48000 Hz stereo. The media server caches these files and streams them directly to the WebRTC leg without format conversion. This preserves the jitter buffer timing and prevents transcoding-induced latency spikes.
Configuration Steps:
  1. Navigate to Architect > Media Files.
  2. Upload audio files encoded as opus or mp3 with a bitrate of 128 kbps or higher.
  3. Verify sample rate matches 48000 Hz using a media inspection tool.
  4. In the Architect flow, configure Play blocks to reference the optimized media file ID.
  5. Enable Optimize for WebRTC in the flow block properties where available.
The Trap: Uploading uncompressed WAV files or low-bitrate MP3s (64 kbps) to Architect flows. WAV files force the media server to transcode to OPUS in real time. Low-bitrate MP3s introduce compression artifacts that compound with FEC redundancy, creating audible robotic distortion during packet loss recovery. The downstream effect is a 200 percent increase in media server CPU utilization during peak hours, causing cascade latency across all concurrent WebRTC sessions.
Architectural Reasoning: We align media file encoding with the WebRTC codec chain to eliminate server-side transcoding. When the Play block streams pre-encoded OPUS, the media server performs zero-copy packetization into RTP frames. This preserves the original timing stamps, allowing the client jitter buffer to process packets without reordering delays. The result is a flat latency profile regardless of IVR complexity or media playback duration.
Edge Case 1: Browser Hardware Acceleration Interference
The Failure Condition: Agents report intermittent audio crackling and complete audio dropouts despite optimal network metrics and correctly configured FEC settings. PCAP analysis shows healthy UDP flow with no packet loss.
The Root Cause: Modern browsers utilize GPU hardware acceleration for WebRTC media rendering. Certain GPU drivers conflict with the WebRTC audio thread scheduler, causing frame dropping during high CPU utilization. The hardware-accelerated audio pipeline bypasses the software jitter buffer, rendering FEC and PLC ineffective.
The Solution: Disable hardware acceleration for media processing via browser group policy. Deploy the HardwareAccelerationMode policy to disabled or gpu_compositor_only for Chrome/Edge. Verify the browser flag #disable-gpu is not globally enforced, as this breaks video capabilities. Monitor browser console for WebRTC audio processing failed warnings. Cross-reference with WEM Audio Quality dashboards to isolate browser-specific degradation patterns.
Edge Case 2: Asymmetric Routing and NAT Traversal Failure
The Failure Condition: One-way audio or intermittent dropouts exclusively on cellular networks. WebRTC ICE logs show relay candidates selected instead of host or srflx.
The Root Cause: Asymmetric routing occurs when upload and download paths traverse different network gateways. WebRTC UDP packets arrive at the media server out of order or with mismatched sequence numbers. The jitter buffer discards packets waiting for missing predecessors, triggering aggressive FEC scaling. If the NAT device blocks STUN binding updates, the connection falls back to TCP relay, introducing serialization latency that breaks conversational pacing.
The Solution: Force STUN server alignment by configuring turnServerFallbackEnabled to true at the site level. Verify Genesys Cloud regional endpoint routing matches the agent’s geographic location. Implement network-level pinhole firewall rules for UDP 50000-60000. Use the Genesys Cloud WebRTC diagnostics tool to force ICE candidate refresh. If TCP relay remains active, adjust QoS policies to prioritize Genesys Cloud CIDRs over general internet traffic.
Edge Case 3: High-Loss Network Saturation and FEC Bandwidth Bloat
The Failure Condition: Agents on congested Wi-Fi networks experience increasing audio quality degradation as call duration extends. Network monitoring shows UDP traffic approaching interface saturation.
The Root Cause: Adaptive FEC scales redundancy based on observed packet loss. On lossy links with 5 percent or higher loss, FEC redundancy can increase to 25 percent of total payload. Without QoS enforcement, the combined traffic exceeds available bandwidth, triggering additional packet drops. This creates a feedback loop where higher loss triggers higher FEC, which triggers more bandwidth consumption, resulting in network saturation.
The Solution: Cap fecRedundancyMaxPercent at 15 percent for known lossy environments. Implement DiffServ QoS marking for Genesys Cloud UDP traffic at the network edge. Configure router policies to prioritize DSCP EF (Expedited Forwarding) for WebRTC media streams. Monitor packet loss thresholds using Genesys Cloud Observability network analytics. If loss exceeds 3 percent consistently, route agents through Genesys Cloud Softphone (SIP) or provide wired network alternatives, as FEC cannot compensate for structural bandwidth deficits.
