Migrating NICE CXone IVR Legacy Prompts via IVR Flow API with Python
  • A production-grade Python module that extracts legacy prompt references, reconstructs them with format conversion directives, validates against CXone storage and version limits, and atomically updates IVR flows.
  • Uses the NICE CXone REST API endpoints /api/v2/prompts, /api/v2/ivr/flows/{id}, and /oauth/token with direct HTTP calls.
  • Covers Python 3.9+ with type hints, retry logic, audit logging, and webhook synchronization.
  • OAuth 2.0 Client Credentials flow with scopes: prompts:read, prompts:write, ivr:flows:read, ivr:flows:write, storage:read, webhooks:write
  • CXone API v2
  • Python 3.9+ runtime
  • External dependencies: requests, httpx, pydantic, tenacity, python-dotenv, structlog
CXone uses standard OAuth 2.0 Client Credentials for server-to-server integrations. The token endpoint requires your organization domain, client ID, and client secret. The following class handles token acquisition, caching, and automatic refresh logic.
import os
import requests
from typing import Optional
@dataclass
class CXoneAuthClient:
    org_domain: str
    client_id: str
    client_secret: str
    token_url: str = ""
    _token: Optional[str] = field(default=None, init=False, repr=False)
    _expires_at: float = field(default=0.0, init=False, repr=False)
    def __post_init__(self) -> None:
        self.token_url = f"https://{self.org_domain}/oauth/token"
    def get_token(self) -> str:
        if self._token and time.time() < self._expires_at:
            return self._token
        payload = {
            "client_id": self.client_id,
            "scope": "prompts:read prompts:write ivr:flows:read ivr:flows:write storage:read webhooks:write"
        response = requests.post(self.token_url, data=payload, timeout=15)
        response.raise_for_status()
        data = response.json()
        self._token = data["access_token"]
        self._expires_at = time.time() + data["expires_in"] - 30  # 30s buffer
        return self._token
    def headers(self) -> dict:
            "Authorization": f"Bearer {self.get_token()}",
            "Accept": "application/json"
The get_token method caches the token and subtracts thirty seconds from the expiration window to prevent boundary failures. The headers method returns the complete authentication header set required for all subsequent CXone API calls.
Step 1: Construct Migration Payloads with prompt-ref, asset-matrix, and convert directive
CXone IVR flows reference prompts using a promptRef object. Legacy systems often store media paths without standardized codec metadata. The migration payload must reconstruct this reference, map the media assets, and apply a conversion directive for format normalization.
class AssetMatrix(BaseModel):
    url: str
    original_codec: str
    target_codec: str
    sample_rate: int = 8000
    bit_rate: int = 128
    size_bytes: int
class ConvertDirective(BaseModel):
    convert_to: str = Field(..., pattern="^(mp3|wav|ogg)$")
    preserve_metadata: bool = True
    validate_format: bool = True
class PromptMigrationPayload(BaseModel):
    prompt_ref: str
    language: str
    asset_matrix: AssetMatrix
    convert_directive: ConvertDirective
    version: int = 1
    def to_cxone_prompt_body(self) -> dict:
        """Transforms internal migration structure to CXone Prompt API schema."""
            "name": self.name,
            "language": self.language,
            "media": {
                "url": self.asset_matrix.url,
                "codec": self.convert_directive.convert_to,
                "sampleRate": self.asset_matrix.sample_rate,
                "bitRate": self.asset_matrix.bit_rate
            "version": self.version
The to_cxone_prompt_body method strips migration-specific fields and outputs the exact JSON structure expected by POST /api/v2/prompts. The asset_matrix tracks original and target codecs for transcode calculation, while the convert_directive enforces format boundaries.
Step 2: Validate Schemas Against Storage Constraints and Maximum Format Version Limits
CXone enforces strict storage constraints and version limits. Prompts must not exceed fifty megabytes, and the format version must align with the platform maximum. The validation pipeline rejects payloads that violate these constraints before network transmission.
import structlog
CXONE_MAX_PROMPT_SIZE_BYTES = 50 * 1024 * 1024  # 50MB
CXONE_MAX_FORMAT_VERSION = 3
SUPPORTED_LOCALES = ["en-US", "en-GB", "es-ES", "fr-FR", "de-DE", "pt-BR", "ja-JP"]
def validate_migration_schema(payload: PromptMigrationPayload) -> None:
    if payload.asset_matrix.size_bytes > CXONE_MAX_PROMPT_SIZE_BYTES:
        raise ValueError(
            f"Storage constraint violation: payload size {payload.asset_matrix.size_bytes} exceeds {CXONE_MAX_PROMPT_SIZE_BYTES} bytes"
    if payload.version > CXONE_MAX_FORMAT_VERSION:
        raise ValueError(
            f"Format version limit exceeded: requested {payload.version}, maximum allowed {CXONE_MAX_FORMAT_VERSION}"
    if payload.language not in SUPPORTED_LOCALES:
        raise ValueError(
            f"Language pack verification failed: {payload.language} is not in supported CXone locales"
    logger.info(
        "schema_validation_passed",
        prompt_ref=payload.prompt_ref,
        size_bytes=payload.asset_matrix.size_bytes,
        version=payload.version
This function executes before any HTTP request. It prevents storage quota exhaustion and rejects unsupported language packs. The SUPPORTED_LOCALES list acts as a verification pipeline to ensure seamless audio playback across CXone regions.
Step 3: Handle Codec Transcode Calculation and Metadata Preservation via Atomic HTTP POST
The prompt creation operation must be atomic. CXone uses ETags for optimistic concurrency control. The following function performs the transcode calculation, preserves metadata, and triggers automatic version locks via ETag comparison.
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import httpx
class CXonePromptMigrator:
    def __init__(self, org_domain: str, client_id: str, client_secret: str):
        self.auth = CXoneAuthClient(org_domain, client_id, client_secret)
        self.base_url = f"https://{org_domain}/api/v2"
        self.client = httpx.Client(
            timeout=30.0,
            headers=self.auth.headers(),
            verify=True
    @retry(
        stop=stop_after_attempt(3),
        wait=wait_exponential(multiplier=1, min=2, max=10),
        retry=retry_if_exception_type(httpx.HTTPStatusError)
    def migrate_prompt(self, payload: PromptMigrationPayload) -> dict:
        validate_migration_schema(payload)
        body = payload.to_cxone_prompt_body()
        endpoint = f"{self.base_url}/prompts"
        start_time = time.time()
            response = self.client.post(endpoint, json=body)
            if e.response.status_code == 409:
                logger.warning("version_lock_conflict", prompt_ref=payload.prompt_ref, detail="ETag mismatch detected during atomic post")
                raise
            raise
        finally:
            logger.info("prompt_post_completed", prompt_ref=payload.prompt_ref, latency_ms=latency_ms)
        result = response.json()
        etag = response.headers.get("ETag", "")
        # Format verification step
        if payload.convert_directive.validate_format and result.get("media", {}).get("codec") != payload.convert_directive.convert_to:
            raise RuntimeError(f"Format verification failed: expected {payload.convert_directive.convert_to}, received {result['media']['codec']}")
            "id": result["id"],
            "name": result["name"],
            "etag": etag,
            "version": result.get("version"),
            "latency_ms": latency_ms
The tenacity decorator handles 429 rate-limit cascades and transient 5xx errors with exponential backoff. The ETag header captures the automatic version lock trigger. Format verification compares the response codec against the directive to ensure transcode calculation succeeded.
Step 4: Broken Link Checking and Language Pack Verification Pipelines
Before updating IVR flows, the system must verify that media URLs are accessible and language packs are resolved. This step prevents missing media during CXone scaling events.
def verify_asset_links(payload: PromptMigrationPayload) -> bool:
    """Performs broken link checking via HTTP HEAD requests."""
        head_resp = httpx.head(payload.asset_matrix.url, timeout=10.0, follow_redirects=True)
        if head_resp.status_code != 200:
            logger.error("broken_link_detected", url=payload.asset_matrix.url, status=head_resp.status_code)
            return False
        return True
        logger.error("cdn_reachability_failure", url=payload.asset_matrix.url, error=str(e))
        return False
def update_ivr_flow_reference(flow_id: str, new_prompt_id: str, org_domain: str, client_id: str, client_secret: str) -> dict:
    """Synchronizes IVR flow with the newly migrated prompt."""
    client = httpx.Client(timeout=30.0, headers=auth.headers())
    endpoint = f"https://{org_domain}/api/v2/ivr/flows/{flow_id}"
    # Fetch current flow to preserve ETag and structure
    get_resp = client.get(endpoint)
    get_resp.raise_for_status()
    flow_data = get_resp.json()
    current_etag = get_resp.headers.get("ETag", "")
    # Locate and replace prompt-ref in flow definition
    flow_data["promptRef"] = {"id": new_prompt_id}
    put_headers = {**auth.headers(), "If-Match": current_etag}
    put_resp = client.put(endpoint, json=flow_data, headers=put_headers)
    put_resp.raise_for_status()
    return {"flow_id": flow_id, "new_prompt_id": new_prompt_id, "status": "updated"}
The verify_asset_links function executes a HEAD request to the CDN URL. If the status is not 200, the pipeline halts. The update_ivr_flow_reference function fetches the IVR flow, injects the new promptRef, and uses the If-Match header with the ETag to enforce atomic updates and prevent concurrent migration collisions.
Step 5: Synchronize Events, Track Latency, Generate Audit Logs, and Trigger Webhooks
The final step aggregates migration metrics, writes governance audit logs, and synchronizes with external CDN webhooks.
import json
class MigrationAuditor:
    def __init__(self, log_file: str = "migration_audit.log"):
        self.log_file = log_file
        self.success_count = 0
        self.failure_count = 0
        self.total_latency = 0.0
    def record_event(self, prompt_ref: str, result: dict, status: str) -> None:
        self.total_latency += result.get("latency_ms", 0)
        if status == "success":
            self.success_count += 1
        else:
            self.failure_count += 1
        audit_entry = {
            "prompt_ref": prompt_ref,
            "status": status,
            "result": result,
            "success_rate": self.success_count / (self.success_count + self.failure_count) if (self.success_count + self.failure_count) > 0 else 0.0,
            "avg_latency_ms": self.total_latency / (self.success_count + self.failure_count) if (self.success_count + self.failure_count) > 0 else 0.0
        with open(self.log_file, "a") as f:
            f.write(json.dumps(audit_entry) + "\n")
        logger.info("audit_log_written", prompt_ref=prompt_ref, status=status)
    def trigger_cdn_sync_webhook(self, webhook_url: str, prompt_id: str, etag: str) -> None:
        payload = {
            "event": "prompt_migrated",
            "prompt_id": prompt_id,
            "etag": etag,
            "sync_required": True
            httpx.post(webhook_url, json=payload, timeout=10.0)
            logger.info("cdn_sync_webhook_triggered", prompt_id=prompt_id)
            logger.warning("cdn_sync_webhook_failed", error=str(e))
The MigrationAuditor class tracks convert success rates and average latency. It appends JSON-lines audit logs for media governance compliance. The trigger_cdn_sync_webhook method sends a POST to an external endpoint to align CDN caches after migration completion.
The following script combines all components into a runnable migration orchestrator. Replace the environment variables with your CXone credentials before execution.
import os
import sys
import json
import httpx
import structlog
# Load previous definitions (CXoneAuthClient, AssetMatrix, ConvertDirective, PromptMigrationPayload,
# validate_migration_schema, CXonePromptMigrator, verify_asset_links, update_ivr_flow_reference, MigrationAuditor)
# In a real environment, import these from separate modules.
load_dotenv()
structlog.configure(
    processors=[
        structlog.processors.JSONRenderer()
    logger_factory=structlog.PrintLoggerFactory()
def run_migration_pipeline():
    org = os.getenv("CXONE_ORG_DOMAIN")
    client_id = os.getenv("CXONE_CLIENT_ID")
    client_secret = os.getenv("CXONE_CLIENT_SECRET")
    webhook_url = os.getenv("EXTERNAL_CDN_WEBHOOK_URL")
    if not all([org, client_id, client_secret]):
        logger.critical("missing_credentials", detail="Set CXONE_ORG_DOMAIN, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET")
        sys.exit(1)
    migrator = CXonePromptMigrator(org, client_id, client_secret)
    auditor = MigrationAuditor("cxone_prompt_migration_audit.log")
    # Simulated legacy prompt inventory
    legacy_prompts = [
            "prompt_ref": "legacy_prom_001",
            "name": "Welcome Message v1",
            "language": "en-US",
            "asset_matrix": {
                "url": "https://cdn.legacy.example.com/prompts/welcome_v1.wav",
                "original_codec": "wav",
                "target_codec": "mp3",
                "sample_rate": 8000,
                "bit_rate": 128,
                "size_bytes": 2400000
            "convert_directive": {
                "convert_to": "mp3",
                "preserve_metadata": True,
                "validate_format": True
            "flow_id": "flow_abc123"
    for item in legacy_prompts:
        payload = PromptMigrationPayload(
            prompt_ref=item["prompt_ref"],
            name=item["name"],
            language=item["language"],
            asset_matrix=AssetMatrix(**item["asset_matrix"]),
            convert_directive=ConvertDirective(**item["convert_directive"])
            if not verify_asset_links(payload):
                auditor.record_event(payload.prompt_ref, {}, "failure_link_check")
            migration_result = migrator.migrate_prompt(payload)
            new_prompt_id = migration_result["id"]
            etag = migration_result["etag"]
            update_ivr_flow_reference(item["flow_id"], new_prompt_id, org, client_id, client_secret)
            auditor.record_event(payload.prompt_ref, migration_result, "success")
            auditor.trigger_cdn_sync_webhook(webhook_url or "https://hooks.example.com/cdn-sync", new_prompt_id, etag)
            logger.info("migration_completed", prompt_ref=payload.prompt_ref, new_id=new_prompt_id)
            auditor.record_event(payload.prompt_ref, {"error": str(e)}, "failure")
            logger.error("migration_step_failed", prompt_ref=payload.prompt_ref, error=str(e))
This script loads environment variables, initializes the migrator and auditor, iterates through a legacy prompt inventory, validates links, executes the atomic POST, updates the IVR flow reference, logs audit entries, and triggers CDN synchronization. It requires only credential injection to run in production.
Error: 400 Bad Request
  • Cause: The payload violates CXone schema validation, typically due to unsupported codec values, invalid language codes, or missing required fields like media.url.
  • Fix: Verify that convert_to matches mp3, wav, or ogg. Ensure language matches CXone supported locales. Add print debugging before the POST to inspect the final JSON body.
  • Code Fix: Wrap the POST in a try-except block that logs response.text for schema error details.
Error: 409 Conflict
  • Cause: Automatic version lock trigger fired due to ETag mismatch. Another process modified the IVR flow or prompt between fetch and update.
  • Fix: Implement retry logic with a fresh GET request to retrieve the current ETag before retrying the PUT. The tenacity decorator handles this if configured for 409 status codes.
  • Code Fix: Add retry=retry_if_exception_type(lambda e: isinstance(e, httpx.HTTPStatusError) and e.response.status_code == 409) to the retry decorator.
  • Cause: Rate limit cascade across CXone microservices. The migration pipeline exceeds the allowed requests per minute.
  • Fix: The provided tenacity configuration applies exponential backoff. Reduce batch sizes or introduce time.sleep() between iterations if processing thousands of prompts.
  • Code Fix: Monitor the Retry-After header in 429 responses and adjust the backoff multiplier accordingly.
Error: 415 Unsupported Media Type
  • Cause: The CDN URL returns a content type that CXone cannot transcode, or the asset_matrix size exceeds platform limits.
  • Fix: Verify the HEAD request returns 200 and a valid audio content type. Ensure size_bytes remains under fifty megabytes.
  • Code Fix: Add MIME type validation in verify_asset_links by checking head_resp.headers.get("content-type").
