Media Control platform Problem
Hi everyone!
I have a problem GVP 8.1 Medai Control Platform.
I have simple composer application - Entry->Prompt block (with single word Hi)->Exit.
When i starting outbound campaign, GVP playing the “unknown tts engine” answer, and that what i can see in MCP log:
20:07:20.163 Trc 20001 INFO 006F00C7-100047E1-20000022-tts-2-REALSPEAK?MRCPv1 2680 06100000 Warning: Cannot get the Attributes for opensession using engine: REALSPEAK
20:07:20.163 Std 20003 WARN 006F00C7-100047E1-20000022-tts-2-REALSPEAK?MRCPv1 2680 061007DC Unable to open a session using engine REALSPEAK?MRCPv1 in MRCPv1 module. Please check speech resource provision and application to make sure the right engine name and protocol version are specified -(return code: -3)
In MCP, in sections ASR and TTS there are defaultengine options, what should i type here?
Hi Kirill
Did You created MRCPv1 application and setup options and did You then connected this app to all MCP servers?
Pawel
Hi Pawel
I found the answer, there was some mistakes in my MCP configuration.
If you share what kind of config issue you had, many people would potentially benefit from it in the future :slight_smile:
Fra
