Hi all, hope everything’s fine around there.
When creating/configuring an Alarm Condition in SCI, may I use the same code for both Detect Event and Cancel Event parameters on a single condition? or is mandatory to use two distinct codes?
Best regards,
Gef.
Hey Gef! How are you doing? Hope everything fine in Italy which has been more heavy impacted…Stay safe
About the ID, no, need to be a different one or a timer
Hi Cav. Here in Italy the situation is quite bad ad the moment, especially in the north of the country; Since 7 of March I’m stuck at home due to the risk of contagion moving outside. My luck I can work from home and I live in a “low precence” area. Hope everything will get better soon for everyone, but I fear thhis will need still 1 or 2 more months if people will respect the rules. In your country is everything allright?
Going back to the question, I mean in SCI I have a predefined number of codes of a specific type I can use from URS (015-22001~22020), but if I have to assign 2 codes, in fact I can create only 10 conditions (2 codes start/clean each). My target is to have all 20 codes to create 20 different reactions. I already assign a 1hour cooldown time for the alarm.
Well no, because when SCS receives the event, how can it know which to trigger?
Also, custom codes are usually to signal a problem or a specific event… Like a DB problem for each call… How can a different call clean the previous error?
Here in Brazil things are quite slow… Which worries me. At Peru I was there two weeks ago and was able to leave just before the borders were closed. There the action plan is much faster and hope will help to prevent. I also see a month task, will not be fast… Stay safe there.
Hi Cav. Cancel Code can be blank, leaving the cancelation only on timeout? (the goal is still to have as many different available conditions as possible).
I agree… readiness is fundamental in the management of this problem, but sadly in most cases everithing seems to move really slowly on both sides, management and people. Stay safe too.
Yes, that is what I do, and store them at DB so I can check later
Be safe and hope everything is ok
Ok, got it; thank you very much.
Good luck for everything.
I’ve written Kafka Producers which uses the PDSK so that I can publish events (such as Log Server messages) onto topics and then consume them for analysis purposes in microservices.
Regards
Craig
