Master Flow Reuse: Calling Shared Flows from Multiple Inbound Call Flows
- One sentence: The code constructs a Genesys Cloud CX configuration where a single “Common” flow is invoked by multiple distinct inbound call flows using the
Subflownode. - One sentence: This tutorial uses the Genesys Cloud CX REST API v2 via the Python SDK (
purecloud-platform-client-v2). - One sentence: The programming language covered is Python 3.9+.
- OAuth Client Type: Service Account with
offline_accessscope. - Required Scopes:
flow:flow:read(to read existing flows for reference, if needed)flow:flow:write(to create or update flows)flow:flow:admin(optional, but recommended for managing flow versions)
- SDK Version:
purecloud-platform-client-v2>= 149.0.0 (Ensure you are on a recent version to support the latestSubflownode properties). - Language/Runtime: Python 3.9 or higher.
- External Dependencies:
pip install purecloud-platform-client-v2
Genesys Cloud uses OAuth 2.0. For server-to-server integrations, you must use the Service Account flow. The following code demonstrates how to initialize the SDK client with a valid access token.
Note: In production, implement token caching. The AccessToken object returned by the SDK handles refresh tokens automatically if the offline_access scope is granted during client creation.
import os
from purecloud_platform_client import Configuration, ApiClient, FlowApi, AuthenticationApi
from purecloud_platform_client.rest import ApiException
def get_api_client() -> ApiClient:
Initializes and returns a configured ApiClient instance.
Assumes environment variables are set:
- GENESYS_CLOUD_ENVIRONMENT (e.g., 'mypurecloud.com')
- GENESYS_CLOUD_CLIENT_ID
- GENESYS_CLOUD_CLIENT_SECRET
environment = os.getenv("GENESYS_CLOUD_ENVIRONMENT")
client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
if not all([environment, client_id, client_secret]):
raise ValueError("Missing required environment variables for Genesys Cloud authentication.")
# Configure the SDK
configuration = Configuration(
base_url=f"https://{environment}",
client_id=client_id,
client_secret=client_secret,
scopes=["flow:flow:write", "flow:flow:read"]
api_client = ApiClient(configuration)
# Validate connection by fetching current user info (optional but good for debugging)
auth_api = AuthenticationApi(api_client)
# This forces a token fetch if none exists
auth_api.post_oauth2token()
except ApiException as e:
print(f"Authentication failed: {e.status} {e.reason}")
raise
return api_client
Step 1: Create the “Common” Shared Flow
Before you can call a shared flow, it must exist. We will create a simple flow named “Common Error Handler” that plays an error message and disconnects. This flow will serve as the target for our Subflow calls.
Key Concept: A shared flow is just a standard flow with the type set to generic or call. The distinction lies in how it is invoked. We will use type: generic for this example as it is agnostic of interaction type.
from purecloud_platform_client import (
FlowApi,
Flow,
FlowType,
FlowNode,
PlayMessageNode,
DisconnectNode,
FlowNodeOut,
FlowNodeIn
def create_common_flow(api_client: ApiClient, org_id: str) -> str:
Creates a generic flow that plays an error message and disconnects.
Returns the Flow ID.
flow_api = FlowApi(api_client)
# 1. Define the Play Message Node
play_node = PlayMessageNode(
name="Play Error Message",
message_type="text",
message_text="An error has occurred. Please try again later.",
# In production, use 'media' and reference a valid Media ID
# message_type="media",
# message_id="VALID_MEDIA_ID"
# 2. Define the Disconnect Node
disconnect_node = DisconnectNode(
name="Disconnect",
disposition="busy"
# 3. Define the Start Node (Implicit in flow creation, but we define connections)
# The start node is always "Start". We need to connect it to our first node.
# 4. Assemble the Flow Object
flow = Flow(
name="Common Error Handler",
description="Shared flow for handling generic errors.",
type="generic",
version=1,
nodes={
"Start": FlowNode(
name="Start",
node_type="Start",
out={
"default": FlowNodeOut(
node_id="PlayError",
transition_type="conditional"
"PlayError": FlowNode(
node_type="PlayMessage",
node_data=play_node,
out={
"completed": FlowNodeOut(
node_id="Disconnect",
"error": FlowNodeOut(
"Disconnect": FlowNode(
name="Disconnect",
node_type="Disconnect",
node_data=disconnect_node
# Create the flow
# Note: post_flow requires the body to be a Flow object
response = flow_api.post_flow(body=flow)
print(f"Created Common Flow with ID: {response.id}")
return response.id
print(f"Failed to create flow: {e.status} {e.reason}")
raise
Step 2: Create the “Subflow” Node Configuration
The core of module reuse is the Subflow node. This node pauses the current flow, executes the target flow, and then resumes the current flow.
Critical Parameters:
flow_id: The ID of the target flow (created in Step 1).input_mapping: A dictionary mapping variables from the calling flow to the target flow.output_mapping: A dictionary mapping variables from the target flow back to the calling flow.on_error: Defines behavior if the subflow fails (e.g.,disconnect,return, orfallback).
SubflowNode,
FlowNodeOut,
FlowNodeIn
def create_subflow_node(target_flow_id: str) -> dict:
Returns the node configuration for a Subflow node.
subflow_node_data = SubflowNode(
flow_id=target_flow_id,
# Example: Pass the caller's phone number to the subflow as 'caller_number'
input_mapping={
"caller_number": "${interaction.customer.phone}"
# Example: Capture the result status from the subflow
output_mapping={
"subflow_result": "${subflow.output.result}"
on_error="return" # Return to the calling flow on error, do not disconnect
"node_type": "Subflow",
"node_data": subflow_node_data,
"out": {
node_id="End",
node_id="End",
Step 3: Create Multiple Inbound Call Flows Using the Shared Module
Now we create two distinct inbound call flows (InboundFlowA and InboundFlowB). Both will include a Subflow node pointing to the Common Error Handler created in Step 1.
Scenario:
- InboundFlowA: Plays “Welcome to Service A”, then calls the Common Error Handler, then disconnects.
- InboundFlowB: Plays “Welcome to Service B”, then calls the Common Error Handler, then disconnects.
This demonstrates how to reuse the same logic without duplicating the error handling code.
FlowApi,
Flow,
PlayMessageNode,
DisconnectNode,
FlowNode
def create_inbound_flow(api_client: ApiClient, flow_name: str, welcome_message: str, common_flow_id: str) -> str:
Creates an inbound call flow that plays a welcome message and then invokes the common subflow.
# 1. Welcome Node
welcome_node = PlayMessageNode(
name="Welcome",
message_text=welcome_message
# 2. Subflow Node (Reusing the logic from Step 2)
subflow_config = create_subflow_node(common_flow_id)
# 3. Disconnect Node
name="Disconnect",
disposition="normal"
flow = Flow(
name=flow_name,
description=f"Inbound flow for {flow_name} using common subflow.",
type="call",
version=1,
nodes={
"Start": FlowNode(
name="Start",
node_type="Start",
out={
node_id="Welcome",
"Welcome": FlowNode(
name="Welcome",
node_data=welcome_node,
out={
node_id="CallCommon",
"CallCommon": FlowNode(
name="Invoke Common Error Handler",
**subflow_config
"End": FlowNode(
name="Disconnect",
print(f"Created Inbound Flow '{flow_name}' with ID: {response.id}")
return response.id
print(f"Failed to create flow '{flow_name}': {e.status} {e.reason}")
raise
Step 4: Execute the Orchestration
This function ties everything together. It creates the common flow first, then creates two distinct inbound flows that reference the common flow ID.
def main():
# Initialize API Client
api_client = get_api_client()
# Get Organization ID (usually required for some contexts, though flow creation is tenant-scoped)
# For simplicity, we assume the default tenant context.
# Step 1: Create the Common Shared Flow
common_flow_id = create_common_flow(api_client, org_id="default")
# Step 2: Create Inbound Flow A
flow_a_id = create_inbound_flow(
api_client=api_client,
flow_name="Inbound Service A",
welcome_message="Welcome to Service A. You are being transferred to the common handler.",
common_flow_id=common_flow_id
# Step 3: Create Inbound Flow B
flow_b_id = create_inbound_flow(
flow_name="Inbound Service B",
welcome_message="Welcome to Service B. You are being transferred to the common handler.",
print(f"\n--- Summary ---")
print(f"Common Flow ID: {common_flow_id}")
print(f"Inbound Flow A ID: {flow_a_id}")
print(f"Inbound Flow B ID: {flow_b_id}")
print(f"Fatal error: {e}")
raise
import os
import sys
Configuration, ApiClient, FlowApi, AuthenticationApi,
Flow, FlowNode, PlayMessageNode, DisconnectNode, FlowNodeOut,
SubflowNode, ApiException
raise ValueError("Missing required environment variables.")
raise Exception(f"Authentication failed: {e.status} {e.reason}")
return api_client
def create_common_flow(api_client: ApiClient) -> str:
name="Play Error",
message_text="System error. Please retry."
name="Disconnect",
disposition="busy"
flow = Flow(
type="generic",
version=1,
nodes={
"Start": FlowNode(
name="Start",
node_type="Start",
out={"default": FlowNodeOut(node_id="PlayError", transition_type="conditional")}
name="Play Error",
out={
"completed": FlowNodeOut(node_id="Disconnect", transition_type="conditional"),
"error": FlowNodeOut(node_id="Disconnect", transition_type="conditional")
name="Disconnect",
return response.id
raise Exception(f"Create common flow failed: {e.reason}")
input_mapping={},
output_mapping={},
on_error="return"
"out": {
"completed": FlowNodeOut(node_id="End", transition_type="conditional"),
"error": FlowNodeOut(node_id="End", transition_type="conditional")
def create_inbound_flow(api_client: ApiClient, flow_name: str, welcome_msg: str, common_id: str) -> str:
name="Welcome",
message_text=welcome_msg
subflow_config = create_subflow_node(common_id)
name="Disconnect",
flow = Flow(
name=flow_name,
type="call",
version=1,
nodes={
"Start": FlowNode(
name="Start",
node_type="Start",
out={"default": FlowNodeOut(node_id="Welcome", transition_type="conditional")}
name="Welcome",
out={
"completed": FlowNodeOut(node_id="CallCommon", transition_type="conditional"),
"error": FlowNodeOut(node_id="CallCommon", transition_type="conditional")
name="Call Common",
**subflow_config
"End": FlowNode(
name="End",
return response.id
raise Exception(f"Create inbound flow failed: {e.reason}")
common_id = create_common_flow(api_client)
print(f"Common Flow ID: {common_id}")
id_a = create_inbound_flow(api_client, "Flow A", "Welcome to A", common_id)
print(f"Flow A ID: {id_a}")
id_b = create_inbound_flow(api_client, "Flow B", "Welcome to B", common_id)
print(f"Flow B ID: {id_b}")
print(f"Error: {e}")
sys.exit(1)
Error: 400 Bad Request - Invalid Node Structure
Cause: The Subflow node requires a valid flow_id that exists in the same organization. Additionally, the out object must define transitions for completed and error. If you omit error in the out object, the flow validation will fail.
Fix: Ensure the SubflowNode is initialized with a valid ID and that the parent FlowNode includes the out dictionary with both completed and error keys.
# Correct structure
"out": {
"completed": FlowNodeOut(node_id="NextNode", transition_type="conditional"),
"error": FlowNodeOut(node_id="ErrorNode", transition_type="conditional")
Error: 403 Forbidden - Insufficient Scope
Cause: The OAuth token does not include flow:flow:write.
Fix: Update your Service Account configuration in the Genesys Cloud Admin Portal. Navigate to Security > OAuth 2.0 > Service Accounts. Edit your client and ensure flow:flow:write is checked in the Scopes section. Regenerate the client secret if necessary.
Error: 422 Unprocessable Entity - Flow Validation Error
Cause: The flow contains circular references or disconnected nodes. For example, if the Start node does not have an out definition, the flow is invalid.
Fix: Verify that every node (except terminal nodes like Disconnect) has an out object. Ensure that the node_id references in FlowNodeOut match the keys in the nodes dictionary exactly.
# Check this mapping
nodes={
"Start": FlowNode(..., out={"default": FlowNodeOut(node_id="Welcome", ...)}),
"Welcome": FlowNode(...), # Key "Welcome" must exist
