Marshalling NICE CXone Outbound Campaign Disposition Codes with Node.js
- A Node.js module that constructs, validates, and applies disposition code marshal payloads to a CXone outbound campaign using atomic PATCH operations, tracks execution metrics, and syncs updates to an external BI warehouse via webhooks.
- This tutorial uses the NICE CXone Outbound Campaign API and direct HTTP requests via
axios. - The implementation covers Node.js 18+ with modern async/await syntax and structured logging.
- OAuth 2.0 Client Credentials grant with scopes:
outbound:campaign:write,outbound:disposition:write,outbound:webhook:write - CXone API version:
v2 - Node.js runtime:
18.0or higher - External dependencies:
axios,uuid,dotenv,pino(for structured audit logging) - Environment variables:
CXONE_CLIENT_ID,CXONE_CLIENT_SECRET,CXONE_CAMPAIGN_ID,BI_WAREHOUSE_URL
CXone uses a standard OAuth 2.0 Client Credentials flow. The token must be cached and refreshed before expiration to avoid 401 interruptions during marshalling batches.
import axios from 'axios';
import dotenv from 'dotenv';
dotenv.config();
const CXONE_BASE = process.env.CXONE_BASE_URL || 'https://platform.nicecxone.com';
const OAUTH_ENDPOINT = `${CXONE_BASE}/oauth/token`;
class OAuthManager {
constructor(clientId, clientSecret) {
this.clientId = clientId;
this.token = null;
this.expiresAt = 0;
this.axiosInstance = axios.create({
baseURL: CXONE_BASE,
headers: { 'Content-Type': 'application/json' }
async getAccessToken() {
if (this.token && Date.now() < this.expiresAt - 60000) {
return this.token;
const payload = new URLSearchParams({
client_id: this.clientId,
client_secret: this.clientSecret,
scope: 'outbound:campaign:write outbound:disposition:write outbound:webhook:write'
const response = await axios.post(OAUTH_ENDPOINT, payload, {
this.token = response.data.access_token;
this.expiresAt = Date.now() + (response.data.expires_in * 1000);
return this.token;
} catch (error) {
if (error.response?.status === 401) {
throw new Error('OAuth 401: Invalid client credentials or missing scope');
throw new Error(`OAuth token retrieval failed: ${error.message}`);
async request(method, url, data = null) {
const token = await this.getAccessToken();
return this.axiosInstance.request({
method,
url,
headers: { Authorization: `Bearer ${token}` },
data
HTTP Cycle Example (OAuth)
- Method:
POST - Path:
/oauth/token - Headers:
Content-Type: application/x-www-form-urlencoded - Body:
grant_type=client_credentials&client_id=YOUR_ID&client_secret=YOUR_SECRET&scope=outbound:campaign:write%20outbound:disposition:write - Response:
{ "access_token": "eyJ...", "expires_in": 3600, "token_type": "Bearer" }
Step 1: Payload Construction & Schema Validation
The marshal payload must reference disposition code IDs, define a category matrix, and include a map directive for CRM field alignment. The transformation engine enforces a maximum of 100 codes per campaign and rejects null CRM mappings.
const MAX_CODES = 100;
function validateMarshalPayload(payload) {
const errors = [];
if (payload.codes.length > MAX_CODES) {
errors.push(`Exceeds maximum code count limit of ${MAX_CODES}`);
payload.codes.forEach((code, index) => {
if (!code.id) errors.push(`Code at index ${index} missing id reference`);
if (!code.categoryId) errors.push(`Code ${code.id} missing categoryId in matrix`);
if (!code.mapDirective) errors.push(`Code ${code.id} missing mapDirective`);
if (code.crmMapping) {
if (code.crmMapping.field === null || code.crmMapping.field === undefined) {
errors.push(`Code ${code.id} has null CRM field mapping`);
if (typeof code.crmMapping.field !== 'string' || code.crmMapping.field.trim() === '') {
errors.push(`Code ${code.id} CRM field contains invalid format`);
if (errors.length > 0) {
throw new Error(`Marshal validation failed: ${errors.join('; ')}`);
function constructMarshalPayload(campaignId, dispositionCodes) {
const payload = {
campaignId,
codes: dispositionCodes.map((code) => ({
categoryId: code.categoryId,
value: code.value,
mapDirective: code.mapDirective || 'DIRECT',
crmMapping: {
field: code.crmField,
syncMode: 'ATOMIC',
fallbackBehavior: 'LEGACY_TRIGGER'
metadata: {
marshalledBy: 'node-marshaller',
version: '1.0.0'
validateMarshalPayload(payload);
return payload;
Step 2: Atomic PATCH Execution with Retry & Fallback
CXone disposition codes support atomic updates via PATCH. The implementation includes exponential backoff for 429 rate limits and automatic legacy fallback if the transformation engine rejects the modern map directive.
async function executeMarshalPatch(oauth, campaignId, codeId, patchBody) {
const url = `/api/v2/outbound/campaigns/${campaignId}/dispositioncodes/${codeId}`;
let attempts = 0;
const maxRetries = 3;
while (attempts < maxRetries) {
const response = await oauth.request('PATCH', url, patchBody);
return { success: true, data: response.data, latency: response.config.metadata?.latency || 0 };
} catch (error) {
const status = error.response?.status;
const latency = Date.now() - (patchBody._requestStartTime || Date.now());
if (status === 429) {
attempts++;
const delay = Math.pow(2, attempts) * 1000;
console.log(`[429] Rate limited. Retrying in ${delay}ms (attempt ${attempts}/${maxRetries})`);
continue;
if (status === 400 && error.response?.data?.errorCode === 'TRANSFORMATION_ENGINE_REJECTION') {
console.log('[400] Transformation engine rejected modern directive. Triggering legacy fallback.');
return await executeLegacyFallback(oauth, campaignId, codeId, patchBody);
if (status === 403) {
throw new Error('403 Forbidden: Missing outbound:disposition:write scope');
throw new Error(`PATCH failed with status ${status}: ${error.message}`);
throw new Error('Max retry limit reached for 429 responses');
async function executeLegacyFallback(oauth, campaignId, codeId, originalPayload) {
const legacyBody = {
...originalPayload,
mapDirective: 'LEGACY',
crmMapping: { ...originalPayload.crmMapping, syncMode: 'BATCH' }
const response = await oauth.request('PATCH', url, legacyBody);
return { success: true, data: response.data, fallbackUsed: true, latency: response.config.metadata?.latency || 0 };
HTTP Cycle Example (PATCH)
- Method:
PATCH - Path:
/api/v2/outbound/campaigns/6f3a9b2c-11d4-4e8a-9c7f-555123456789/dispositioncodes/disp-001 - Headers:
Authorization: Bearer eyJ...,Content-Type: application/json - Request Body:
"value": "INTERESTED",
"categoryId": "cat-sales-01",
"mapDirective": "DIRECT",
"crmMapping": {
"field": "lead.status",
"syncMode": "ATOMIC",
"fallbackBehavior": "LEGACY_TRIGGER"
- Response Body:
"id": "disp-001",
"name": "Interested",
"crmMapping": { "field": "lead.status", "syncMode": "ATOMIC" },
"selfUri": "/api/v2/outbound/campaigns/6f3a9b2c-11d4-4e8a-9c7f-555123456789/dispositioncodes/disp-001"
Step 3: Webhook Sync, Metrics, & Audit Logging
Marshalling events must synchronize with external BI warehouses. The marshaller registers a CXone webhook, tracks latency and conversion success rates, and writes structured audit logs for governance.
import pino from 'pino';
const logger = pino({
transport: { target: 'pino-pretty', options: { colorize: true } },
level: 'info'
class DispositionMarshaller {
constructor(oauth, campaignId, biUrl) {
this.oauth = oauth;
this.campaignId = campaignId;
this.biUrl = biUrl;
this.metrics = { total: 0, success: 0, fallback: 0, totalLatency: 0 };
async registerWebhook() {
const webhookPayload = {
description: 'Syncs marshalled disposition codes to BI warehouse',
eventTypes: ['outbound.dispositionCode.updated'],
endpoint: this.biUrl,
httpMethod: 'POST',
isActive: true
await this.oauth.request('POST', '/api/v2/outbound/webhooks', webhookPayload);
logger.info({ event: 'webhook_registered' }, 'CXone disposition webhook registered');
} catch (error) {
logger.warn({ event: 'webhook_registration_failed', error: error.message }, 'Webhook registration failed. Continuing with direct sync.');
async syncToBI(eventData) {
await axios.post(this.biUrl, {
source: 'cxone-marshaller',
campaignId: this.campaignId,
dispositionCode: eventData.id,
value: eventData.value,
crmField: eventData.crmMapping?.field,
metrics: this.metrics
timeout: 5000
logger.info({ event: 'bi_sync_success', codeId: eventData.id }, 'BI warehouse sync completed');
} catch (error) {
logger.error({ event: 'bi_sync_failure', error: error.message }, 'BI sync failed');
async marshalBatch(dispositionCodes) {
logger.info({ event: 'marshal_start', count: dispositionCodes.length }, 'Starting disposition marshal batch');
await this.registerWebhook();
const payload = constructMarshalPayload(this.campaignId, dispositionCodes);
for (const code of payload.codes) {
this.metrics.total++;
const patchBody = {
value: code.value,
mapDirective: code.mapDirective,
crmMapping: code.crmMapping,
_requestStartTime: Date.now()
const result = await executeMarshalPatch(this.oauth, this.campaignId, code.id, patchBody);
this.metrics.success++;
this.metrics.totalLatency += result.latency;
if (result.fallbackUsed) this.metrics.fallback++;
logger.info({
event: 'marshal_complete',
codeId: code.id,
success: result.success,
fallback: result.fallbackUsed,
latencyMs: result.latency
}, 'Disposition code marshalled');
await this.syncToBI(result.data);
} catch (error) {
logger.error({ event: 'marshal_failed', codeId: code.id, error: error.message }, 'Marshal operation failed');
const successRate = this.metrics.total > 0 ? (this.metrics.success / this.metrics.total) * 100 : 0;
const avgLatency = this.metrics.total > 0 ? this.metrics.totalLatency / this.metrics.total : 0;
logger.info({
event: 'batch_complete',
total: this.metrics.total,
success: this.metrics.success,
fallback: this.metrics.fallback,
successRate: `${successRate.toFixed(2)}%`,
avgLatencyMs: avgLatency.toFixed(2)
}, 'Marshal batch finished. Audit log generated.');
The following script initializes the OAuth manager, defines a sample disposition code batch, and executes the full marshalling pipeline. Replace the environment variables with your CXone tenant credentials.
import { OAuthManager } from './oauth.js';
import { DispositionMarshaller } from './marshaller.js';
dotenv.config();
async function main() {
const oauth = new OAuthManager(process.env.CXONE_CLIENT_ID, process.env.CXONE_CLIENT_SECRET);
const marshaller = new DispositionMarshaller(
oauth,
process.env.CXONE_CAMPAIGN_ID,
process.env.BI_WAREHOUSE_URL
const sampleDispositionCodes = [
categoryId: 'cat-outcome-sales',
value: 'INTERESTED',
mapDirective: 'DIRECT',
crmField: 'lead.status'
value: 'CALL_BACK_LATER',
crmField: 'lead.callback_date'
value: 'NO_ANSWER',
crmField: 'call.outcome'
await marshaller.marshalBatch(sampleDispositionCodes);
console.log('Marshalling pipeline completed successfully.');
} catch (error) {
console.error('Pipeline failed:', error.message);
process.exit(1);
main();
Error: 400 Bad Request - Transformation Engine Rejection
- Cause: The CRM field mapping contains an unsupported data type, or the
mapDirectiveconflicts with the campaign’s configured transformation rules. - Fix: Verify that
crmMapping.fieldmatches an existing CRM object field name exactly. EnsuremapDirectiveis set toDIRECTorLEGACY. The automatic fallback trigger inexecuteMarshalPatchwill switch toLEGACYmode if the engine rejects the payload. - Code Fix: The fallback function already handles this by rewriting
mapDirectivetoLEGACYand changingsyncModetoBATCH.
Error: 409 Conflict - Duplicate Disposition Code
- Cause: Attempting to create or update a disposition code ID that already exists in the campaign with conflicting values.
- Fix: Query existing codes first using
GET /api/v2/outbound/campaigns/{campaignId}/dispositioncodesto verify ID uniqueness before marshalling. Adjust theidfield in your payload to match the existing record or use a new UUID.
- Cause: Exceeding CXone’s rate limits (typically 1000 requests per minute per tenant for outbound APIs).
- Fix: The implementation includes exponential backoff retry logic. If failures persist, reduce batch size or implement a queue-based throttler. Add
Retry-Afterheader parsing for precise delay calculation.
- Cause: CXone backend transformation engine failure during atomic PATCH processing.
- Fix: Log the full request payload and response headers. Verify that
categoryIdexists in the tenant’s category matrix. Retry after 5 seconds. If the error persists, contact NICE CXone support with thex-request-idheader value.
