Managing Token Refresh for Genesys Cloud Web Messaging Mobile Clients in Java
  • A Java background service that continuously monitors Genesys Cloud access token expiration and automatically issues new tokens before session interruption occurs.
  • Direct integration with the Genesys Cloud /api/v2/oauth/token endpoint using the refresh_token grant type and secure keystore credential management.
  • Implementation in Java 17 using the built-in java.net.http module for HTTP and WebSocket communication, with zero external framework dependencies.
  • Genesys Cloud OAuth 2.0 client configured with refresh_token and client_credentials grant types enabled.
  • Required OAuth scopes: webmessaging:guest:read, webmessaging:guest:write, openid.
  • Java Development Kit 17 or higher.
  • External dependency: com.fasterxml.jackson.core:jackson-databind:2.15.2 for JSON serialization and deserialization.
Genesys Cloud OAuth 2.0 requires Basic authentication in the request header for token requests. The credentials consist of the client ID and client secret concatenated with a colon, then Base64 encoded. The refresh flow does not use the SDK authentication manager because mobile clients require explicit control over token lifecycle events and background thread scheduling.
The following code demonstrates how to construct the initial authentication header and establish a secure connection to the Genesys Cloud organization domain.
import java.net.URI;
import java.nio.charset.StandardCharsets;
import java.util.Base64;
public class GenesysAuthConfig {
    private final String organizationDomain;
    private final String clientId;
    private final String clientSecret;
    private final String authorizationHeader;
    public GenesysAuthConfig(String organizationDomain, String clientId, String clientSecret) {
        this.organizationDomain = organizationDomain.replace("https://", "").replace("/api", "");
        this.clientId = clientId;
        String credentials = clientId + ":" + clientSecret;
        this.authorizationHeader = "Basic " + Base64.getEncoder().encodeToString(credentials.getBytes(StandardCharsets.UTF_8));
    public URI getOAuthEndpoint() {
        return URI.create("https://" + organizationDomain + "/api/v2/oauth/token");
    public String getAuthorizationHeader() {
        return authorizationHeader;
    public String getOrganizationDomain() {
        return organizationDomain;
Step 1: Secure Keystore Integration for Refresh Credentials
Mobile applications must never store refresh tokens in plain text or shared preferences. Java provides the java.security.KeyStore API to wrap credential storage with platform-native security providers. The following implementation loads a PKCS12 keystore, retrieves the refresh token under a defined alias, and securely updates it after each successful OAuth response.
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.security.KeyStore;
public class SecureTokenVault {
    private final String keystorePath;
    private final char[] keystorePassword;
    private final String tokenAlias;
    private KeyStore keyStore;
    public SecureTokenVault(String keystorePath, String keystorePassword, String tokenAlias) {
        this.keystorePath = keystorePath;
        this.keystorePassword = keystorePassword.toCharArray();
        this.tokenAlias = tokenAlias;
        loadKeystore();
    private void loadKeystore() {
        try (FileInputStream fis = new FileInputStream(keystorePath)) {
            keyStore = KeyStore.getInstance("PKCS12");
            keyStore.load(fis, keystorePassword);
        } catch (Exception e) {
            throw new RuntimeException("Failed to load secure keystore at " + keystorePath, e);
    public String getRefreshToken() throws Exception {
        String encoded = keyStore.getCertificateChain(tokenAlias) != null
            ? Base64.getEncoder().encodeToString(keyStore.getCertificate(tokenAlias).getEncoded())
            : keyStore.getEntry(tokenAlias, new KeyStore.PasswordProtection(keystorePassword))
                .toString();
        return keyStore.isKeyEntry(tokenAlias) ? null : extractSecretAlias(tokenAlias);
    private String extractSecretAlias(String alias) throws Exception {
        KeyStore.ProtectionParameter protParam = new KeyStore.PasswordProtection(keystorePassword);
        Object entry = keyStore.getEntry(alias, protParam);
        if (entry instanceof KeyStore.SecretKeyEntry) {
            return new String(((KeyStore.SecretKeyEntry) entry).getSecretKey().getEncoded(), StandardCharsets.UTF_8);
        return null;
    public void updateRefreshToken(String newToken) throws Exception {
        byte[] tokenBytes = newToken.getBytes(StandardCharsets.UTF_8);
        javax.crypto.SecretKey secretKey = new javax.crypto.spec.SecretKeySpec(tokenBytes, "AES");
        KeyStore.SecretKeyEntry entry = new KeyStore.SecretKeyEntry(secretKey);
        keyStore.setEntry(tokenAlias, entry, protParam);
        try (FileOutputStream fos = new FileOutputStream(keystorePath)) {
            keyStore.store(fos, keystorePassword);
Step 2: Background Token Expiration Monitor and Refresh Logic
The background service uses ScheduledExecutorService to evaluate token expiration at fixed intervals. When the remaining validity drops below a thirty-second threshold, the service triggers a POST request to the Genesys Cloud OAuth endpoint. The implementation includes exponential backoff retry logic for HTTP 429 rate-limit responses and explicit error mapping for session invalidation.
Full HTTP request/response cycle for the refresh grant:
Request
POST /api/v2/oauth/token HTTP/1.1
Host: {organization}.mygen.com
Authorization: Basic {base64(client_id:client_secret)}
Accept: application/json
grant_type=refresh_token&refresh_token={stored_refresh_token}
Response
  "refresh_token": "dGhpcyBpcyBhIHJlZnJlc2ggdG9rZW4gZm9yIGdlbmVzeXN...",
  "expires_in": 3600,
  "token_type": "Bearer",
  "scope": "webmessaging:guest:read webmessaging:guest:write openid"
The Java implementation translates this cycle into a thread-safe refresh routine:
import java.time.Instant;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.atomic.AtomicReference;
public class TokenRefreshManager {
    private final GenesysAuthConfig authConfig;
    private final SecureTokenVault tokenVault;
    private final HttpClient httpClient;
    private final ObjectMapper mapper;
    private final AtomicReference<String> currentAccessToken = new AtomicReference<>();
    private final AtomicReference<String> currentRefreshToken = new AtomicReference<>();
    private Instant tokenExpiryTime;
    public TokenRefreshManager(GenesysAuthConfig authConfig, SecureTokenVault tokenVault) {
        this.authConfig = authConfig;
        this.tokenVault = tokenVault;
        this.httpClient = HttpClient.newBuilder()
                .followRedirects(HttpClient.Redirect.NEVER)
                .build();
        this.mapper = new ObjectMapper();
    public void startBackgroundMonitor(ScheduledExecutorService executor) {
        executor.scheduleAtFixedRate(this::checkAndRefreshToken, 0, 30, TimeUnit.SECONDS);
    private void checkAndRefreshToken() {
            long remainingSeconds = tokenExpiryTime.getEpochSecond() - Instant.now().getEpochSecond();
            if (remainingSeconds > 30) return;
            String refreshToken = currentRefreshToken.get();
            if (refreshToken == null) {
                refreshToken = tokenVault.extractSecretAlias("refresh_token_alias");
            String requestBody = "grant_type=refresh_token&refresh_token=" + java.net.URLEncoder.encode(refreshToken, "UTF-8");
                    .uri(authConfig.getOAuthEndpoint())
                    .header("Authorization", authConfig.getAuthorizationHeader())
                    .header("Content-Type", "application/x-www-form-urlencoded")
                    .header("Accept", "application/json")
                    .POST(HttpRequest.BodyPublishers.ofString(requestBody))
                    .build();
            handleOAuthResponse(response);
            handleRefreshFailure(e);
    private void handleOAuthResponse(HttpResponse<String> response) throws Exception {
        if (response.statusCode() == 200) {
            JsonNode json = mapper.readTree(response.body());
            String newAccessToken = json.get("access_token").asText();
            String newRefreshToken = json.get("refresh_token").asText();
            int expiresIn = json.get("expires_in").asInt();
            currentAccessToken.set(newAccessToken);
            currentRefreshToken.set(newRefreshToken);
            tokenExpiryTime = Instant.now().plusSeconds(expiresIn);
            tokenVault.updateRefreshToken(newRefreshToken);
        } else if (response.statusCode() == 429) {
            executeRateLimitBackoff(response);
        } else if (response.statusCode() >= 400) {
            throw new AuthenticationException(mapErrorCode(response.statusCode(), response.body()));
    private void executeRateLimitBackoff(HttpResponse<String> response) throws Exception {
        int retryAfter = 5;
        String header = response.headers().firstValue("Retry-After").orElse(null);
        if (header != null) retryAfter = Integer.parseInt(header);
        long backoffMs = (long) (retryAfter * 1000 * (1 + Math.random()));
        Thread.sleep(backoffMs);
        // Re-attempt once with same request builder pattern
        // In production, wrap in a recursive retry wrapper with max attempts
Step 3: WebSocket Control Frame State Synchronization
Genesys Cloud Web Messaging maintains persistent state over a WebSocket connection. When a token refresh completes, the mobile client must notify the WebSocket layer to update the authorization context without dropping the connection. Genesys accepts JSON control frames that update session metadata. The following code establishes the WebSocket connection and injects the new token via a structured control message.
import java.net.http.WebSocket;
import java.util.concurrent.CompletionStage;
public class WebSocketStateManager {
    private WebSocket webSocket;
    public WebSocketStateManager(GenesysAuthConfig authConfig) {
    public void establishConnection(WebSocket.Listener listener) {
        String wsUrl = "wss://" + authConfig.getOrganizationDomain() + "/api/v2/engagements/messages/conversations/websocket";
        webSocket = HttpClient.newHttpClient().newWebSocketBuilder()
                .uri(java.net.URI.create(wsUrl))
                .buildAsync(listener, new WebSocket.Listener() {
                    @Override
                    public CompletionStage<?> onText(WebSocket webSocket, CharSequence data, boolean more) {
                        return listener.onText(webSocket, data, more);
                }).join();
    public void broadcastTokenUpdate(String newAccessToken) {
        if (webSocket == null) return;
        String controlFrame = """
                "type": "AUTH_REFRESH",
                "payload": {
                    "access_token": "%s",
                    "timestamp": "%d"
            """.formatted(newAccessToken, System.currentTimeMillis());
        webSocket.sendText(controlFrame, true);
Step 4: Session Invalidation Handling and Error Code Mapping
OAuth refresh tokens eventually expire or become revoked due to security policies, credential rotation, or explicit logout. When the /api/v2/oauth/token endpoint returns a failure, the application must translate the HTTP status into a deterministic error code and trigger a full re-authentication flow. The mapping below handles the four primary failure states.
public class AuthenticationException extends Exception {
    private final int errorCode;
    private final String errorMessage;
    public AuthenticationException(int errorCode, String errorMessage) {
        super("Genesys Auth Error: " + errorCode + " - " + errorMessage);
        this.errorCode = errorCode;
        this.errorMessage = errorMessage;
    public int getErrorCode() { return errorCode; }
    public String getErrorMessage() { return errorMessage; }
public class ErrorMapper {
    public static AuthenticationException mapErrorCode(int httpStatus, String responseBody) {
        return switch (httpStatus) {
            case 400 -> new AuthenticationException(1001, "Invalid refresh token or malformed request body.");
            case 401 -> new AuthenticationException(1002, "Client credentials rejected. Verify client ID and secret.");
            case 403 -> new AuthenticationException(1003, "Refresh token revoked or OAuth client lacks required scopes.");
            case 404 -> new AuthenticationException(1004, "OAuth endpoint unreachable. Verify organization domain.");
            case 500 -> new AuthenticationException(2001, "Genesys Cloud internal server error. Retry after backoff.");
            case 503 -> new AuthenticationException(2002, "Service unavailable. Throttle refresh attempts.");
            default -> new AuthenticationException(9999, "Unexpected HTTP status: " + httpStatus);
The following file combines all components into a single executable class. Save the file as GenesysMessagingTokenManager.java, compile with javac, and run with java GenesysMessagingTokenManager. Replace the placeholder credentials and keystore path before execution.
import java.util.concurrent.Executors;
public class GenesysMessagingTokenManager {
    public GenesysMessagingTokenManager(String organizationDomain, String clientId, String clientSecret, String keystorePath, String keystorePassword) {
        this.tokenVault = new SecureTokenVault(keystorePath, keystorePassword);
        this.httpClient = HttpClient.newBuilder().followRedirects(HttpClient.Redirect.NEVER).build();
        this.tokenExpiryTime = Instant.now();
    public void initialize() throws Exception {
        ScheduledExecutorService executor = Executors.newSingleThreadScheduledExecutor();
        startBackgroundMonitor(executor);
        establishWebSocketConnection();
    private void startBackgroundMonitor(ScheduledExecutorService executor) {
                    .uri(URI.create("https://" + organizationDomain + "/api/v2/oauth/token"))
                    .header("Authorization", authorizationHeader)
                    .build();
            System.err.println("Token refresh failed: " + e.getMessage());
            triggerReAuthenticationFlow(e);
            if (webSocket != null) {
                String controlFrame = String.format("{\"type\":\"AUTH_REFRESH\",\"payload\":{\"token_type\":\"Bearer\",\"access_token\":\"%s\",\"timestamp\":%d}}", newAccessToken, System.currentTimeMillis());
            int retryAfter = 5;
            Thread.sleep(retryAfter * 1000L);
            checkAndRefreshToken();
        } else {
            triggerReAuthenticationFlow(ErrorMapper.mapErrorCode(response.statusCode(), response.body()));
    private void establishWebSocketConnection() {
        String wsUrl = "wss://" + organizationDomain + "/api/v2/engagements/messages/conversations/websocket";
                .uri(URI.create(wsUrl))
                .buildAsync(new WebSocket.Listener() {
                    @Override
                    public CompletionStage<?> onText(WebSocket ws, CharSequence data, boolean more) {
                        System.out.println("WebSocket message received: " + data);
                        return CompletionStage.completedFuture(null);
                    @Override
                    public void onError(WebSocket ws, Throwable error) {
                        System.err.println("WebSocket error: " + error.getMessage());
                }).join();
    private void triggerReAuthenticationFlow(Throwable cause) {
        System.out.println("Session invalidation detected. Initiating full re-authentication flow.");
        // In production, emit an event to the UI layer to redirect to the login screen
        // and clear local session state.
    public static void main(String[] args) throws Exception {
        // Replace with actual Genesys Cloud credentials and keystore path
        String orgDomain = "myorganization.mygen.com";
        String clientId = "your_client_id";
        String clientSecret = "your_client_secret";
        String keystorePath = "secure_tokens.p12";
        String keystorePassword = "keystore_password";
        GenesysMessagingTokenManager manager = new GenesysMessagingTokenManager(orgDomain, clientId, clientSecret, keystorePath, keystorePassword);
        manager.initialize();
        System.out.println("Background token monitor and WebSocket bridge initialized.");
    private static class SecureTokenVault {
        public SecureTokenVault(String keystorePath, String keystorePassword) {
            this.tokenAlias = "refresh_token_alias";
            loadKeystore();
                throw new RuntimeException("Failed to load secure keystore", e);
        public String extractSecretAlias(String alias) throws Exception {
            return null;
    private static class ErrorMapper {
                case 401 -> new AuthenticationException(1002, "Client credentials rejected.");
                case 403 -> new AuthenticationException(1003, "Refresh token revoked or missing scopes.");
                case 404 -> new AuthenticationException(1004, "OAuth endpoint unreachable.");
                case 500 -> new AuthenticationException(2001, "Genesys Cloud internal server error.");
                case 503 -> new AuthenticationException(2002, "Service unavailable.");
    private static class AuthenticationException extends Exception {
  • Cause: The Base64 encoded client credentials are incorrect, or the OAuth client has been disabled in the Genesys Cloud admin console.
  • Fix: Verify the client ID and client secret match the OAuth 2.0 client configuration. Ensure the refresh_token grant type is explicitly enabled for the client.
  • Code showing the fix: Regenerate the authorization header by concatenating the exact client ID and secret string before Base64 encoding.
Error: 403 Forbidden
  • Cause: The refresh token has been revoked, expired beyond the maximum lifetime, or the OAuth client lacks the webmessaging:guest:read scope.
  • Fix: Invalidate the local keystore entry for the refresh token and force a full re-authentication flow. Verify that the OAuth client scope assignment includes webmessaging:guest:*.
  • Code showing the fix: Catch AuthenticationException with error code 1003, clear currentRefreshToken, and call triggerReAuthenticationFlow().
  • Cause: The background scheduler triggered refresh requests too frequently, or multiple application instances are competing for the same resource.
  • Fix: Parse the Retry-After header from the response and apply exponential backoff. Never poll faster than the token expiration window minus thirty seconds.
  • Code showing the fix: The executeRateLimitBackoff logic reads the Retry-After header, multiplies it by a random jitter factor, and sleeps the background thread before re-attempting.
Error: 5xx Server Errors
  • Cause: Genesys Cloud platform maintenance, routing failures, or temporary backend degradation.
  • Fix: Implement a circuit breaker pattern that pauses refresh attempts for sixty seconds after three consecutive 5xx responses. Log the incident and notify the telemetry pipeline.
  • Code showing the fix: Wrap the httpClient.send() call in a retry counter. If the counter exceeds three, suspend the scheduled task using executor.shutdown() and restart it after a fixed delay.
