Managing NICE CXone Outbound Campaign Dialer Settings with Go
This tutorial delivers a production-ready Go module that constructs, validates, and applies atomic PATCH operations to NICE CXone outbound campaign dialer settings. It implements the CXone Outbound Campaign API to manage dialer profile references, strategy matrices, and optimization directives while enforcing engine constraints and retry limits. The code handles OAuth 2.0 authentication, executes carrier capacity and compliance verification pipelines, registers settings-applied webhooks for gateway synchronization, and tracks configuration latency with structured audit logging. The implementation uses Go 1.21+ and standard library HTTP clients.
  • OAuth 2.0 Client Credentials grant configured in CXone Admin Console
  • Required scopes: outbound:campaign:write, outbound:campaign:read, outbound:carrier:read
  • CXone API v2 endpoint pattern: https://api-{region}.niceincontact.com
  • Go 1.21 or higher
  • Standard library packages: net/http, encoding/json, time, sync, context, log/slog, fmt, errors, math
  • Network access to CXone API and webhook listener endpoint
CXone uses standard OAuth 2.0 Client Credentials flow. The token endpoint returns a bearer token valid for sixty minutes. You must cache the token and refresh it before expiration to prevent authentication failures during batch updates.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"io"
	"net/http"
	"sync"
	"time"
type TokenResponse struct {
	TokenType   string `json:"token_type"`
	ExpiresIn   int    `json:"expires_in"`
type OAuthConfig struct {
	Region      string
	ClientID    string
	ClientSecret string
	APIBaseURL  string
func (c *OAuthConfig) GetToken(ctx context.Context) (*TokenResponse, error) {
	reqBody := fmt.Sprintf(
		"grant_type=client_credentials&client_id=%s&client_secret=%s",
		c.ClientID, c.ClientSecret,
	req, err := http.NewRequestWithContext(ctx, http.MethodPost,
		fmt.Sprintf("https://api-%s.niceincontact.com/oauth/token", c.Region),
		io.NopReader(reqBody),
	if err != nil {
		return nil, fmt.Errorf("failed to create token request: %w", err)
	resp, err := client.Do(req)
	if err != nil {
		return nil, fmt.Errorf("token request failed: %w", err)
	defer resp.Body.Close()
		return nil, fmt.Errorf("token request returned %d: %s", resp.StatusCode, string(body))
	var token TokenResponse
	if err := json.NewDecoder(resp.Body).Decode(&token); err != nil {
		return nil, fmt.Errorf("failed to decode token response: %w", err)
	return &token, nil
type TokenCache struct {
	mu      sync.Mutex
	token   *TokenResponse
	expires time.Time
	config  *OAuthConfig
func NewTokenCache(cfg *OAuthConfig) *TokenCache {
	return &TokenCache{config: cfg}
func (tc *TokenCache) GetBearerToken(ctx context.Context) (string, error) {
	tc.mu.Lock()
	defer tc.mu.Unlock()
	if tc.token != nil && time.Now().Before(tc.expires.Add(-5*time.Minute)) {
		return tc.token.AccessToken, nil
	token, err := tc.config.GetToken(ctx)
	if err != nil {
		return "", err
	tc.token = token
	tc.expires = time.Now().Add(time.Duration(token.ExpiresIn) * time.Second)
	return token.AccessToken, nil
The TokenCache struct implements thread-safe token retrieval with a five-minute early refresh window. This prevents race conditions when multiple goroutines trigger concurrent PATCH operations.
CXone dialer configurations require strict adherence to engine constraints. The strategy matrix defines call pacing, while the optimization directive controls routing behavior. You must validate maximum retry attempts against the dialer engine limit of ten. The validation pipeline rejects malformed payloads before network transmission.
type DialerStrategy struct {
	Type              string  `json:"type"`
	MaxCallsPerSecond float64 `json:"maxCallsPerSecond,omitempty"`
	AbandonRate       float64 `json:"abandonRate,omitempty"`
type OptimizationDirective struct {
type DialerPayload struct {
	DialerProfileID   string                 `json:"dialerProfileId"`
	Strategy          *DialerStrategy        `json:"strategy"`
	Optimization      *OptimizationDirective `json:"optimization"`
	MaxRetryAttempts  int                    `json:"maxRetryAttempts"`
	CarrierID         string                 `json:"carrierId"`
	ComplianceFlags   []string               `json:"complianceFlags,omitempty"`
	WebhookURL        string                 `json:"webhookUrl,omitempty"`
func (p *DialerPayload) Validate() error {
	if p.DialerProfileID == "" {
		return fmt.Errorf("dialerProfileId is required")
	if p.Strategy == nil || p.Strategy.Type == "" {
		return fmt.Errorf("strategy type is required")
	validStrategies := map[string]bool{
		"progressive": true,
		"predictive":  true,
		"power":       true,
		"preview":     true,
	if !validStrategies[p.Strategy.Type] {
		return fmt.Errorf("invalid strategy type: %s", p.Strategy.Type)
	if p.Optimization == nil || p.Optimization.Type == "" {
		return fmt.Errorf("optimization directive is required")
	validOptimizations := map[string]bool{
		"agentEfficiency": true,
		"answerRate":      true,
		"costOptimization": true,
	if !validOptimizations[p.Optimization.Type] {
		return fmt.Errorf("invalid optimization type: %s", p.Optimization.Type)
	if p.MaxRetryAttempts < 0 || p.MaxRetryAttempts > 10 {
		return fmt.Errorf("maxRetryAttempts must be between 0 and 10, got %d", p.MaxRetryAttempts)
	if p.CarrierID == "" {
		return fmt.Errorf("carrierId is required for capacity verification")
	return nil
The Validate method enforces CXone dialer engine constraints. It rejects invalid strategy types, blocks optimization directives outside the supported set, and caps retry attempts at ten. This prevents 400 Bad Request responses from the dialer engine.
Step 2: Carrier Capacity and Compliance Verification Pipeline
Before applying dialer changes, you must verify carrier capacity and compliance flags. The pipeline queries the CXone carrier endpoint to check available capacity against the requested maxCallsPerSecond. It also validates compliance flags against regional telephony requirements.
type CarrierStatus struct {
	Capacity    int     `json:"capacity"`
	CurrentLoad int     `json:"currentLoad"`
	Compliance  struct {
		Flags []string `json:"allowedFlags"`
	} `json:"compliance"`
type APIHttpClient struct {
	baseURL   string
	tokenCache *TokenCache
	httpClient *http.Client
func NewAPIHttpClient(cfg *OAuthConfig) *APIHttpClient {
	return &APIHttpClient{
		baseURL:    fmt.Sprintf("https://api-%s.niceincontact.com", cfg.Region),
		tokenCache: NewTokenCache(cfg),
		httpClient: &http.Client{Timeout: 15 * time.Second},
func (c *APIHttpClient) VerifyCarrierCapacity(ctx context.Context, payload *DialerPayload) error {
	token, err := c.tokenCache.GetBearerToken(ctx)
	if err != nil {
		return fmt.Errorf("token retrieval failed: %w", err)
	req, err := http.NewRequestWithContext(ctx, http.MethodGet,
		fmt.Sprintf("%s/api/v2/outbound/carriers/%s", c.baseURL, payload.CarrierID), nil)
	if err != nil {
		return fmt.Errorf("carrier request creation failed: %w", err)
	resp, err := c.httpClient.Do(req)
	if err != nil {
		return fmt.Errorf("carrier capacity check failed: %w", err)
	if resp.StatusCode == http.StatusNotFound {
		return fmt.Errorf("carrier %s not found", payload.CarrierID)
		return fmt.Errorf("carrier check returned %d", resp.StatusCode)
	var status CarrierStatus
	if err := json.NewDecoder(resp.Body).Decode(&status); err != nil {
		return fmt.Errorf("carrier response decode failed: %w", err)
	availableCapacity := status.Capacity - status.CurrentLoad
	requestedCapacity := int(payload.Strategy.MaxCallsPerSecond)
	if requestedCapacity > availableCapacity {
		return fmt.Errorf("insufficient carrier capacity: requested %d, available %d",
			requestedCapacity, availableCapacity)
	for _, flag := range payload.ComplianceFlags {
		found := false
		for _, allowed := range status.Compliance.Flags {
			if flag == allowed {
				found = true
				break
		if !found {
			return fmt.Errorf("compliance flag %s not permitted for carrier %s", flag, payload.CarrierID)
	return nil
The verification pipeline fetches real-time carrier metrics and cross-references compliance flags. It blocks configuration updates when capacity is insufficient or compliance flags violate carrier agreements. This prevents network throttling during campaign scaling.
Step 3: Atomic PATCH Execution and Traffic Redistribution
CXone supports atomic configuration updates via JSON Merge Patch. You must use the application/merge-patch+json content type to ensure partial updates do not overwrite unrelated dialer settings. The client implements exponential backoff for 429 Too Many Requests responses to handle rate-limit cascades.
type PatchResult struct {
	CampaignID string
	Status     int
	Latency    time.Duration
	Timestamp  time.Time
func (c *APIHttpClient) ApplyDialerConfig(ctx context.Context, campaignID string, payload *DialerPayload) (*PatchResult, error) {
	payBytes, err := json.Marshal(payload)
	if err != nil {
		return nil, fmt.Errorf("payload serialization failed: %w", err)
	startTime := time.Now()
	var lastErr error
	for attempt := 0; attempt < 4; attempt++ {
		token, tokenErr := c.tokenCache.GetBearerToken(ctx)
		if tokenErr != nil {
			return nil, fmt.Errorf("token retrieval failed: %w", tokenErr)
		req, reqErr := http.NewRequestWithContext(ctx, http.MethodPatch,
			fmt.Sprintf("%s/api/v2/outbound/campaigns/%s", c.baseURL, campaignID),
			io.NopReader(string(payBytes)),
		if reqErr != nil {
			return nil, fmt.Errorf("patch request creation failed: %w", reqErr)
		req.Header.Set("Content-Type", "application/merge-patch+json")
		resp, doErr := c.httpClient.Do(req)
		if doErr != nil {
			lastErr = fmt.Errorf("patch execution failed: %w", doErr)
			time.Sleep(time.Duration(math.Pow(2, float64(attempt))) * time.Second)
		respBody, _ := io.ReadAll(resp.Body)
		resp.Body.Close()
			lastErr = fmt.Errorf("rate limited (429): %s", string(respBody))
			backoff := time.Duration(math.Pow(2, float64(attempt+1))) * time.Second
			time.Sleep(backoff)
		if resp.StatusCode >= 500 {
			lastErr = fmt.Errorf("server error %d: %s", resp.StatusCode, string(respBody))
		if resp.StatusCode != http.StatusOK && resp.StatusCode != http.StatusAccepted {
			return nil, fmt.Errorf("patch failed with %d: %s", resp.StatusCode, string(respBody))
		return &PatchResult{
			CampaignID: campaignID,
			Status:     resp.StatusCode,
			Latency:    time.Since(startTime),
			Timestamp:  time.Now(),
		}, nil
	return nil, fmt.Errorf("patch failed after retries: %w", lastErr)
The retry loop implements exponential backoff with a four-attempt limit. It distinguishes between client errors, server errors, and rate limits. The application/merge-patch+json header ensures CXone applies only the specified fields, triggering automatic traffic redistribution without disrupting active call legs.
Step 4: Webhook Synchronization and Metrics Tracking
External telephony gateways require alignment with CXone dialer state changes. You register a webhook URL within the dialer payload to receive settingsApplied events. The manager tracks configuration latency and success rates using a thread-safe metrics collector and structured audit logs.
type AuditEntry struct {
	Action      string    `json:"action"`
	CampaignID  string    `json:"campaignId"`
	Status      string    `json:"status"`
	LatencyMs   float64   `json:"latency_ms"`
	Timestamp   time.Time `json:"timestamp"`
	PayloadHash string    `json:"payload_hash"`
type DialerManager struct {
	client  *APIHttpClient
	logger  *slog.Logger
	metrics sync.Map
func NewDialerManager(cfg *OAuthConfig, logger *slog.Logger) *DialerManager {
	return &DialerManager{
		client: NewAPIHttpClient(cfg),
		logger: logger,
func (m *DialerManager) GeneratePayloadHash(payload *DialerPayload) string {
	data, _ := json.Marshal(payload)
	return fmt.Sprintf("%x", data[:8])
func (m *DialerManager) UpdateCampaignDialer(ctx context.Context, campaignID string, payload *DialerPayload) error {
	m.logger.Info("starting dialer update", "campaign", campaignID)
	if err := payload.Validate(); err != nil {
		m.logger.Error("payload validation failed", "error", err)
		return fmt.Errorf("validation failed: %w", err)
	if err := m.client.VerifyCarrierCapacity(ctx, payload); err != nil {
		m.logger.Error("carrier verification failed", "error", err)
		return fmt.Errorf("carrier check failed: %w", err)
	result, err := m.client.ApplyDialerConfig(ctx, campaignID, payload)
	if err != nil {
		m.logger.Error("patch application failed", "error", err)
		m.recordMetric(campaignID, "failure", 0)
		return fmt.Errorf("update failed: %w", err)
	m.logger.Info("dialer update applied", "campaign", campaignID, "latency", result.Latency, "status", result.Status)
	m.recordMetric(campaignID, "success", result.Latency.Milliseconds())
	audit := AuditEntry{
		Action:      "dialer_config_update",
		Status:      fmt.Sprintf("%d", result.Status),
		LatencyMs:   result.Latency.Milliseconds(),
		Timestamp:   result.Timestamp,
		PayloadHash: m.GeneratePayloadHash(payload),
	auditJSON, _ := json.Marshal(audit)
	m.logger.Info("audit log", "entry", string(auditJSON))
	return nil
func (m *DialerManager) recordMetric(campaignID, status string, latencyMs int64) {
	key := campaignID + ":" + status
	m.metrics.Store(key, latencyMs)
func (m *DialerManager) GetSuccessRate(campaignID string) float64 {
	var success, total int64
	m.metrics.Range(func(k, v interface{}) bool {
		key := k.(string)
		if len(key) > len(campaignID)+1 && key[:len(campaignID)] == campaignID {
			total++
			if key[len(campaignID)+1:] == "success" {
				success++
		return true
	if total == 0 {
		return 0
	return float64(success) / float64(total) * 100
The DialerManager orchestrates validation, capacity checks, PATCH execution, and audit logging. It stores latency metrics in a concurrent map and calculates success rates per campaign. The webhook URL embedded in the payload triggers CXone to push settingsApplied events to your external gateway endpoint, ensuring telephony routing tables synchronize with dialer state changes.
The following module integrates all components into a runnable script. Replace the placeholder credentials and identifiers with your CXone environment values.
package main
import (
	"context"
	"encoding/json"
	"fmt"
	"log/slog"
	"os"
	"time"
func main() {
	logger := slog.New(slog.NewJSONHandler(os.Stdout, &slog.HandlerOptions{
		Level: slog.LevelInfo,
	cfg := &OAuthConfig{
		Region:       "us-east-1",
		ClientID:     os.Getenv("CXONE_CLIENT_ID"),
		ClientSecret: os.Getenv("CXONE_CLIENT_SECRET"),
	manager := NewDialerManager(cfg, logger)
	payload := &DialerPayload{
		DialerProfileID:  "dialer-profile-88291",
		CarrierID:        "carrier-44102",
		MaxRetryAttempts: 3,
		Strategy: &DialerStrategy{
			Type:              "progressive",
			MaxCallsPerSecond: 150,
			AbandonRate:       0.03,
		Optimization: &OptimizationDirective{
			Type: "agentEfficiency",
		ComplianceFlags: []string{"tcpa_compliant", "stir_shaken_verified"},
		WebhookURL:      "https://gateway.yourdomain.com/cxone/webhooks/settings-applied",
	ctx, cancel := context.WithTimeout(context.Background(), 30*time.Second)
	defer cancel()
	if err := manager.UpdateCampaignDialer(ctx, "campaign-77391", payload); err != nil {
		logger.Error("campaign update failed", "error", err)
		os.Exit(1)
	rate := manager.GetSuccessRate("campaign-77391")
	logger.Info("configuration success rate", "campaign", "campaign-77391", "rate_percent", rate)
Run the script with CXONE_CLIENT_ID and CXONE_CLIENT_SECRET environment variables set. The program validates the payload, verifies carrier capacity, applies the atomic PATCH, logs audit entries, and reports the success rate.
Error: 400 Bad Request
  • Cause: Payload violates CXone schema constraints, retry attempts exceed ten, or strategy/optimization types are invalid.
  • Fix: Review the Validate method output. Ensure maxRetryAttempts falls within 0-10. Verify strategy.type matches progressive, predictive, power, or preview. Confirm optimization.type matches agentEfficiency, answerRate, or costOptimization.
  • Code Fix: Add explicit field checks before serialization. Use the validation pipeline to catch schema violations locally.
  • Cause: Expired OAuth token or invalid client credentials.
  • Fix: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET. Ensure the token cache refreshes before expiration. Check that the OAuth client has outbound:campaign:write scope granted.
  • Code Fix: The TokenCache automatically refreshes tokens five minutes before expiration. Log token retrieval failures to diagnose credential mismatches.
Error: 403 Forbidden
  • Cause: OAuth client lacks required scopes or the campaign belongs to a different tenant.
  • Fix: Grant outbound:campaign:write and outbound:carrier:read scopes to the OAuth client in CXone Admin. Verify the campaignId matches your tenant.
  • Code Fix: Inspect the HTTP response body for scope denial messages. Rotate credentials if scope assignments were recently updated.
Error: 409 Conflict
  • Cause: Concurrent modification of the same campaign resource or incompatible webhook URL format.
  • Fix: Serialize campaign updates. Ensure the webhook URL uses HTTPS and accepts POST requests. Retry after a brief delay if another process modified the campaign.
  • Code Fix: Implement optimistic locking by reading the current campaign revision before PATCH, though CXone merge-patch handles most concurrent writes safely.
  • Cause: Rate limit cascade from rapid sequential PATCH operations or carrier capacity polling.
  • Fix: The retry loop implements exponential backoff. Reduce batch update frequency. Distribute requests across multiple campaigns with staggered intervals.
  • Code Fix: The ApplyDialerConfig method automatically retries with backoff up to four attempts. Increase the attempt limit if your workload requires higher throughput.
