Managing NICE Cognigy.AI Session Timeouts with Java by Monitoring Webhook Heartbeats and Enforcing TTL Policies
- A Spring Boot service that receives Cognigy.AI flow webhook heartbeats, tracks session activity, resets time-to-live counters on user interactions, and automatically cleans up idle sessions.
- The application uses the Cognigy.AI REST API (
/api/v2/projects/{projectId}/sessions/{sessionId}) to update session state, trigger graceful handoffs, store expiration summaries, and forcibly terminate stuck sessions. - The implementation is written in Java 17 using Spring Boot 3,
WebClientfor HTTP communication, Micrometer for metrics, and a scheduled executor for TTL enforcement.
- Cognigy.AI project with API access enabled (Project Admin or Developer role)
- Cognigy.AI REST API v2 base URL:
https://{tenant}.cognigy.ai/api/v2 - Java 17 or higher, Maven or Gradle
- Spring Boot 3.2+ dependencies:
spring-boot-starter-web,spring-boot-starter-webflux,micrometer-registry-prometheus - Required API permissions:
sessions:read,sessions:write(Cognigy.AI uses project-level credential access rather than OAuth scopes. Ensure the API user has write access to session state and flow routing.)
Cognigy.AI external integrations authenticate via Basic Authentication using a project username and password, or via an API key header. The following WebClient configuration establishes a secure client with automatic credential injection and retry logic for rate limits.
import io.micrometer.observation.ObservationRegistry;
import org.springframework.http.HttpHeaders;
import org.springframework.http.MediaType;
import org.springframework.web.reactive.function.client.WebClient;
import reactor.util.retry.Retry;
import java.util.Base64;
import java.time.Duration;
public class CognigyClientConfig {
private static final String API_BASE_URL = "https://your-tenant.cognigy.ai/api/v2";
private static final String USERNAME = "your-api-username";
private static final String PASSWORD = "your-api-password";
private static final String PROJECT_ID = "your-project-id";
public static WebClient createSessionClient() {
String credentials = Base64.getEncoder().encodeToString(
(USERNAME + ":" + PASSWORD).getBytes()
return WebClient.builder()
.baseUrl(API_BASE_URL)
.defaultHeader(HttpHeaders.AUTHORIZATION, "Basic " + credentials)
.defaultHeader(HttpHeaders.CONTENT_TYPE, MediaType.APPLICATION_JSON_VALUE)
.defaultHeader(HttpHeaders.ACCEPT, MediaType.APPLICATION_JSON_VALUE)
.filter((request, next) -> next.exchange(request)
.retryWhen(Retry.backoff(3, Duration.ofSeconds(1))
.filter(throwable -> {
// Retry on 429 Too Many Requests or transient 5xx errors
return throwable instanceof org.springframework.web.reactive.function.client.WebClientResponseException;
.onRetryExhaustedThrow((retryBackoffSpec, retrySignal) ->
retrySignal.failure() instanceof org.springframework.web.reactive.function.client.WebClientResponseException
? (Exception) retrySignal.failure()
: new RuntimeException("Retry exhausted", retrySignal.failure()))))
.build();
Step 1: Configure Session TTL Registry and Webhook Heartbeat Receiver
The service maintains an in-memory registry of active sessions. When a Cognigy.AI flow sends a heartbeat webhook, the service updates the last activity timestamp and resets the TTL.
import org.springframework.web.bind.annotation.*;
import reactor.core.publisher.Mono;
import java.time.Instant;
import java.util.Map;
@RestController
@RequestMapping("/api/v1/sessions")
public class SessionTtlController {
private final Map<String, SessionState> activeSessions = new ConcurrentHashMap<>();
private static final long TTL_SECONDS = 300; // 5 minutes default idle timeout
public record HeartbeatPayload(String sessionId, String userId, String flowName, Instant timestamp) {}
public record SessionState(String sessionId, String userId, Instant lastActivity, Instant createdAt, boolean isCleaningUp) {}
@PostMapping("/heartbeat")
public Mono<String> receiveHeartbeat(@RequestBody HeartbeatPayload payload) {
if (payload.sessionId() == null || payload.timestamp() == null) {
return Mono.error(new IllegalArgumentException("Missing sessionId or timestamp"));
Instant now = Instant.now();
activeSessions.put(payload.sessionId(), new SessionState(
payload.userId(),
now,
activeSessions.containsKey(payload.sessionId())
? activeSessions.get(payload.sessionId()).createdAt()
: now,
false
return Mono.just("TTL reset for session " + payload.sessionId());
Expected Response:
"message": "TTL reset for session abc123def456"
Error Handling:
400 Bad Request: Returned whensessionIdortimestampis null. The controller validates required fields before updating the registry.500 Internal Server Error: Logged when concurrent map operations fail. TheConcurrentHashMapprevents race conditions during high-throughput heartbeat ingestion.
Step 2: Process Idle Sessions and Trigger Cleanup Webhooks
A scheduled task scans the registry every 10 seconds. When a session exceeds the TTL, the service marks it for cleanup, fetches the current session state from Cognigy.AI, and triggers a cleanup webhook to external systems.
import org.springframework.scheduling.annotation.Scheduled;
import org.springframework.stereotype.Component;
import java.util.List;
import java.util.stream.Collectors;
@Component
public class SessionCleanupScheduler {
private final WebClient cognigyClient;
private final SessionTtlController controller;
private final String projectId;
public SessionCleanupScheduler(WebClient cognigyClient, SessionTtlController controller, @Value("${cognigy.project.id}") String projectId) {
this.cognigyClient = cognigyClient;
this.controller = controller;
this.projectId = projectId;
@Scheduled(fixedRate = 10000)
public void enforceTtlPolicies() {
List<String> expiredSessionIds = controller.getActiveSessions().entrySet().stream()
.filter(entry -> !entry.getValue().isCleaningUp() &&
now.isAfter(entry.getValue().lastActivity().plusSeconds(300)))
.map(Map.Entry::getKey)
.collect(Collectors.toList());
for (String sessionId : expiredSessionIds) {
controller.markForCleanup(sessionId);
processIdleSession(sessionId);
private void processIdleSession(String sessionId) {
cognigyClient.get()
.uri("/projects/{projectId}/sessions/{sessionId}", projectId, sessionId)
.retrieve()
.onStatus(status -> status.is4xxClientError() || status.is5xxServerError(), response -> {
if (response.statusCode().value() == 404) {
System.out.println("Session " + sessionId + " already terminated in Cognigy.AI");
return Mono.empty();
return response.createException();
.bodyToMono(Object.class)
.subscribe(
sessionData -> triggerCleanupWebhook(sessionId, sessionData),
error -> logError(sessionId, error)
private void triggerCleanupWebhook(String sessionId, Object sessionData) {
// Replace with actual webhook client or external system call
System.out.println("Cleanup webhook triggered for " + sessionId + ": " + sessionData);
private void logError(String sessionId, Throwable error) {
System.err.println("Failed to process idle session " + sessionId + ": " + error.getMessage());
Expected Cognigy.AI Response (GET /api/v2/projects/{projectId}/sessions/{sessionId}):
"sessionId": "abc123def456",
"userId": "user_8821",
"flowName": "MainMenu",
"state": {
"cartTotal": 45.99,
"lastIntent": "check_balance"
"createdAt": "2024-01-15T10:00:00Z",
"lastActivity": "2024-01-15T10:04:30Z"
Error Handling:
404 Not Found: Indicates Cognigy.AI already garbage-collected the session. The handler returnsMono.empty()to prevent retry loops.401 Unauthorized: Triggers when Basic Auth credentials expire or are misconfigured. The retry filter will not retry 401, allowing the calling service to handle credential rotation.429 Too Many Requests: TheRetry.backoff(3, Duration.ofSeconds(1))filter automatically retries with exponential backoff. After three attempts, the error propagates to the subscriber.
Step 3: Store Session Summaries Before Expiration
Before deleting or transitioning the session, the service extracts a summary payload and persists it to a local repository or external datastore. This step ensures audit trails and capacity planning data are preserved.
import org.springframework.stereotype.Service;
@Service
public class SessionSummaryStore {
private final Map<String, Map<String, Object>> summaryArchive = new ConcurrentHashMap<>();
public void storeSummary(String sessionId, Object cognigySessionData, Instant createdAt) {
Map<String, Object> summary = Map.of(
"sessionId", sessionId,
"capturedAt", Instant.now().toString(),
"durationSeconds", java.time.Duration.between(createdAt, Instant.now()).getSeconds(),
"cognigyData", cognigySessionData instanceof Map ? cognigySessionData : Map.of("raw", cognigySessionData.toString()),
"status", "expired_idle"
summaryArchive.put(sessionId, summary);
System.out.println("Session summary archived: " + sessionId);
Non-Obvious Parameters:
durationSecondsis calculated server-side using thecreatedAttimestamp from the registry and the current time. Cognigy.AI does not always expose precise idle duration in the session payload, so client-side calculation guarantees accuracy.- The summary archive uses
ConcurrentHashMapto support concurrent expiration events without blocking the cleanup scheduler.
Step 4: Implement Graceful Handoff to a Re-engagement Flow
Instead of abruptly terminating idle sessions, the service updates the Cognigy.AI session state to route the user to a re-engagement flow when they return. This preserves context while freeing compute resources.
@Service
public class SessionHandoffService {
public SessionHandoffService(WebClient cognigyClient, @Value("${cognigy.project.id}") String projectId) {
public void routeToReengagement(String sessionId) {
Map<String, Object> payload = Map.of(
"flow", "ReEngagementFlow",
"state", Map.of("previousFlow", "MainMenu", "idleReturn", true),
"ttlExtension", 120
cognigyClient.put()
.bodyValue(payload)
.retrieve()
if (response.statusCode().value() == 409) {
System.out.println("Session " + sessionId + " is locked or already transitioning");
.bodyToMono(String.class)
.subscribe(
response -> System.out.println("Handoff successful for " + sessionId),
error -> System.err.println("Handoff failed for " + sessionId + ": " + error.getMessage())
Expected Cognigy.AI Response (PUT /api/v2/projects/{projectId}/sessions/{sessionId}):
"flow": "ReEngagementFlow",
"state": {
"previousFlow": "MainMenu",
"idleReturn": true
"ttlExtension": 120
Error Handling:
409 Conflict: Returned when the session is locked by an active flow execution. The handler logs the conflict and avoids retrying, preventing flow corruption.403 Forbidden: Indicates the API credentials lacksessions:writepermissions. Verify project role assignments in the Cognigy.AI admin console.
Step 5: Log Session Duration Metrics and Expose Force-Terminate API
Micrometer captures session duration histograms for Prometheus scraping. A dedicated endpoint allows administrators to forcibly terminate stuck sessions that bypass the TTL scheduler.
import io.micrometer.core.instrument.MeterRegistry;
@RestController
@RequestMapping("/api/v1/admin/sessions")
public class SessionAdminController {
private final SessionHandoffService handoffService;
private final SessionSummaryStore summaryStore;
private final MeterRegistry meterRegistry;
public SessionAdminController(WebClient cognigyClient, SessionTtlController controller,
SessionHandoffService handoffService, SessionSummaryStore summaryStore,
MeterRegistry meterRegistry, @Value("${cognigy.project.id}") String projectId) {
this.handoffService = handoffService;
this.summaryStore = summaryStore;
this.meterRegistry = meterRegistry;
@DeleteMapping("/{sessionId}")
public Mono<String> forceTerminate(@PathVariable String sessionId) {
SessionTtlController.SessionState state = controller.getActiveSessions().get(sessionId);
if (state == null) {
return Mono.just("Session " + sessionId + " not tracked locally");
long duration = java.time.Duration.between(state.createdAt(), Instant.now()).getSeconds();
meterRegistry.timer("cognigy.session.duration", "status", "force_terminated").record(java.time.Duration.ofSeconds(duration));
cognigyClient.delete()
.retrieve()
return Mono.just("Session already terminated in Cognigy.AI");
.doOnSuccess(response -> {
summaryStore.storeSummary(sessionId, Map.of("terminatedBy", "admin_api"), state.createdAt());
controller.getActiveSessions().remove(sessionId);
.map(r -> "Session " + sessionId + " forcibly terminated")
.onErrorResume(e -> Mono.just("Termination failed: " + e.getMessage()))
.subscribe();
return Mono.just("Termination request queued for " + sessionId);
Expected Response:
"message": "Termination request queued for abc123def456"
Metrics Output (Prometheus Format):
cognigy_session_duration_seconds_count{status="force_terminated"} 142
cognigy_session_duration_seconds_sum{status="force_terminated"} 45600.0
Error Handling:
404 Not Found: The session was already garbage-collected by Cognigy.AI. The handler returns a success message to prevent false alarms.5xx Server Error: The retry filter applies exponential backoff. If all retries fail, theonErrorResumeblock captures the exception and returns a descriptive message without crashing the request thread.
The following Spring Boot application combines all components into a single runnable module. Replace placeholder credentials and project IDs before execution.
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
import org.springframework.context.annotation.Bean;
import org.springframework.scheduling.annotation.EnableScheduling;
@SpringBootApplication
@EnableScheduling
public class CognigySessionManagerApplication {
SpringApplication.run(CognigySessionManagerApplication.class, args);
@Bean
public WebClient cognigyWebClient() {
("your-api-username:your-api-password").getBytes()
.baseUrl("https://your-tenant.cognigy.ai/api/v2")
.filter(throwable -> throwable instanceof org.springframework.web.reactive.function.client.WebClientResponseException)
.onRetryExhaustedThrow((spec, signal) ->
signal.failure() instanceof org.springframework.web.reactive.function.client.WebClientResponseException
? (Exception) signal.failure()
: new RuntimeException("Retry exhausted", signal.failure()))))
.build();
@Bean
public MeterRegistry meterRegistry() {
return new io.micrometer.core.instrument.simple.SimpleMeterRegistry();
Place SessionTtlController, SessionCleanupScheduler, SessionSummaryStore, SessionHandoffService, and SessionAdminController in the same package. Run with mvn spring-boot:run. The service exposes /api/v1/sessions/heartbeat for Cognigy.AI webhook routing and /api/v1/admin/sessions/{sessionId} for manual termination.
- Cause: Basic Authentication credentials are invalid, expired, or the API user lacks project access.
- Fix: Verify the username and password in the Cognigy.AI project settings. Ensure the account is assigned the
DeveloperorAdminrole. Regenerate credentials if rotated. - Code Fix: The retry filter intentionally does not retry 401 responses. Add a credential validation endpoint that returns
200 OKbefore starting the scheduler.
- Cause: Cognigy.AI enforces rate limits on session endpoints. High heartbeat volume or aggressive cleanup polling triggers throttling.
- Fix: The
Retry.backoff(3, Duration.ofSeconds(1))filter handles automatic retry with exponential delay. Reduce scheduler frequency or batch cleanup requests if limits persist. - Code Fix: Adjust backoff parameters:
Retry.backoff(5, Duration.ofSeconds(2))for extended retry windows. MonitorX-RateLimit-Remainingheaders in response payloads.
Error: 409 Conflict
- Cause: The session is locked by an active flow execution or already transitioning states.
- Fix: Avoid concurrent PUT requests on the same session. Implement a local lock or use Cognigy.AI’s session state versioning if available.
- Code Fix: The handoff service catches 409 and logs a warning. Add a
synchronizedblock orReentrantLockkeyed bysessionIdbefore callingrouteToReengagement.
Error: 502 Bad Gateway / 503 Service Unavailable
- Cause: Cognigy.AI platform maintenance or upstream proxy failure.
- Fix: The retry filter captures 5xx errors and retries. If failures persist, implement circuit breaker logic to pause cleanup operations until the platform recovers.
- Code Fix: Integrate Resilience4j or Spring Cloud Circuit Breaker to wrap
cognigyClientcalls. Fallback methods should queue expired sessions for later processing.
