Managing NICE Cognigy.AI Model Versions with Node.js
A Node.js service that exports Cognigy.AI bot model definitions, stores versioned snapshots with semantic versioning metadata, computes intent and entity deltas, automates rollbacks upon deployment failures, tracks model lineage for audit compliance, and exposes a REST API for version comparison and deployment status.
This tutorial uses the Cognigy.AI REST API v2 and standard Node.js HTTP/Express patterns.
The implementation uses JavaScript with axios, express, semver, jsondiffpatch, and crypto.
- Cognigy.AI service account with
model:readandmodel:writeOAuth scopes - Cognigy.AI API v2 endpoint (e.g.,
https://your-tenant.cognigy.ai/api/v2) - Node.js 18 or higher
- npm dependencies:
axios,express,semver,jsondiffpatch,uuid,cors - Local directory structure for snapshots:
./model-snapshots/
Cognigy.AI uses OAuth 2.0 client credentials flow. The service account must possess model:read and model:write scopes. The following token manager handles initial acquisition, caching, and automatic refresh when the access token expires.
const crypto = require('crypto');
class CognigyAuthClient {
constructor(host, clientId, clientSecret) {
this.host = host.replace(/\/$/, '');
this.clientId = clientId;
this.accessToken = null;
this.tokenExpiry = 0;
async getToken() {
if (this.accessToken && Date.now() < this.tokenExpiry) {
return this.accessToken;
const authString = Buffer.from(`${this.clientId}:${this.clientSecret}`).toString('base64');
const response = await axios.post(`${this.host}/oauth/token`, 'grant_type=client_credentials', {
headers: {
'Authorization': `Basic ${authString}`,
'Content-Type': 'application/x-www-form-urlencoded',
'Accept': 'application/json'
if (response.status !== 200) {
throw new Error(`Authentication failed with status ${response.status}: ${response.data?.error_description || response.statusText}`);
this.accessToken = response.data.access_token;
this.tokenExpiry = Date.now() + (response.data.expires_in * 1000) - 5000;
async apiRequest(method, path, data = null, params = null) {
const token = await this.getToken();
const config = {
method,
url: `${this.host}${path}`,
headers: {
params,
timeout: 15000
if (data) config.data = data;
const response = await axios(config);
if (response.status >= 500) {
throw new Error(`Server error ${response.status}: ${response.statusText}`);
if (response.status === 429) {
const retryAfter = response.headers['retry-after'] ? parseInt(response.headers['retry-after'], 10) : 2;
console.log(`Rate limited. Retrying after ${retryAfter} seconds...`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
return this.apiRequest(method, path, data, params);
return response;
Step 1: Export Model Definition and Enforce Semantic Versioning
The Cognigy.AI Model API returns the complete bot definition when querying a specific model. You must validate the version string against semantic versioning rules before persisting the snapshot. The GET /api/v2/models/{modelId} endpoint requires the model:read scope.
const fs = require('fs').promises;
const path = require('path');
const semver = require('semver');
const SNAPSHOTS_DIR = './model-snapshots';
async function exportAndStoreModel(authClient, modelId, version, author) {
if (!semver.valid(version)) {
throw new Error(`Invalid semantic version: ${version}. Must follow MAJOR.MINOR.PATCH format.`);
const response = await authClient.apiRequest('GET', `/api/v2/models/${modelId}`);
const modelDefinition = response.data;
const snapshotPath = path.join(SNAPSHOTS_DIR, `${version}.json`);
const metadataPath = path.join(SNAPSHOTS_DIR, `${version}-metadata.json`);
await fs.mkdir(SNAPSHOTS_DIR, { recursive: true });
await fs.writeFile(snapshotPath, JSON.stringify(modelDefinition, null, 2));
const lineage = {
version,
modelId,
author,
createdAt: new Date().toISOString(),
status: 'stored',
checksum: crypto.createHash('sha256').update(JSON.stringify(modelDefinition)).digest('hex'),
previousVersion: await getLatestVersion()
await fs.writeFile(metadataPath, JSON.stringify(lineage, null, 2));
return lineage;
async function getLatestVersion() {
const files = await fs.readdir(SNAPSHOTS_DIR);
const versions = files
.filter(f => f.endsWith('.json') && !f.includes('-metadata'))
.map(f => f.replace('.json', ''))
.filter(v => semver.valid(v));
return versions.length ? versions.sort(semver.compare).pop() : null;
} catch {
return null;
Step 2: Compare Model Deltas for Intents and Entities
Model drift occurs when intents or entities change between versions. The jsondiffpatch library computes structured differences. You filter the delta to isolate cognitive model components and ignore UI or configuration noise.
const jsondiffpatch = require('jsondiffpatch');
async function compareModelDeltas(baseVersion, targetVersion) {
const basePath = path.join(SNAPSHOTS_DIR, `${baseVersion}.json`);
const targetPath = path.join(SNAPSHOTS_DIR, `${targetVersion}.json`);
const baseModel = JSON.parse(await fs.readFile(basePath, 'utf8'));
const targetModel = JSON.parse(await fs.readFile(targetPath, 'utf8'));
const delta = jsondiffpatch.diff(baseModel, targetModel);
const changes = {
intents: [],
entities: [],
other: []
const traverseDelta = (obj, prefix = '') => {
if (!obj) return;
Object.entries(obj).forEach(([key, value]) => {
const fullPath = prefix ? `${prefix}.${key}` : key;
if (fullPath.includes('intents') || fullPath.includes('entities')) {
if (Array.isArray(value) && value[0] !== undefined) {
if (value[0] === undefined) changes[fullPath.includes('intents') ? 'intents' : 'entities'].push({ path: fullPath, action: 'deleted' });
else if (value[2] === undefined) changes[fullPath.includes('intents') ? 'intents' : 'entities'].push({ path: fullPath, action: 'added' });
else changes[fullPath.includes('intents') ? 'intents' : 'entities'].push({ path: fullPath, action: 'modified', base: value[0], target: value[2] });
} else {
} else {
changes.other.push({ path: fullPath });
if (typeof value === 'object' && value !== null && !Array.isArray(value)) {
traverseDelta(value, fullPath);
traverseDelta(delta);
return changes;
Step 3: Automate Rollback and Track Deployment Status
When a deployment fails, you restore the previous stable version using PUT /api/v2/models/{modelId}. The model:write scope is required. The lineage metadata updates to reflect the rollback event and deployment status.
const { v4: uuidv4 } = require('uuid');
async function rollbackToVersion(authClient, modelId, targetVersion) {
const snapshotPath = path.join(SNAPSHOTS_DIR, `${targetVersion}.json`);
const modelDefinition = JSON.parse(await fs.readFile(snapshotPath, 'utf8'));
const response = await authClient.apiRequest('PUT', `/api/v2/models/${modelId}`, modelDefinition);
if (response.status !== 200 && response.status !== 204) {
throw new Error(`Rollback failed with status ${response.status}`);
const metadataPath = path.join(SNAPSHOTS_DIR, `${targetVersion}-metadata.json`);
const metadata = JSON.parse(await fs.readFile(metadataPath, 'utf8'));
metadata.status = 'active';
metadata.rollbackId = uuidv4();
metadata.rollbackTimestamp = new Date().toISOString();
await fs.writeFile(metadataPath, JSON.stringify(metadata, null, 2));
return { success: true, version: targetVersion, responseStatus: response.status };
} catch (error) {
console.error(`Rollback failed: ${error.message}`);
return { success: false, version: targetVersion, error: error.message };
async function triggerDeployment(authClient, modelId) {
await authClient.apiRequest('POST', `/api/v2/deployments`, { modelId });
return { status: 'deployed', timestamp: new Date().toISOString() };
} catch (error) {
return { status: 'failed', timestamp: new Date().toISOString(), error: error.message };
The following Express application integrates all components. It exposes endpoints for version management, delta comparison, rollback automation, and deployment status tracking.
const express = require('express');
const cors = require('cors');
const CognigyAuthClient = require('./auth'); // Assume auth module from Step 0
const app = express();
app.use(cors());
app.use(express.json());
const AUTH_CLIENT = new CognigyAuthClient(
process.env.COGNIGY_HOST,
process.env.COGNIGY_CLIENT_ID,
process.env.COGNIGY_CLIENT_SECRET
app.get('/api/versions', async (req, res) => {
const response = await AUTH_CLIENT.apiRequest('GET', '/api/v2/models', { page: 1, pageSize: 25 });
res.json(response.data);
} catch (error) {
res.status(500).json({ error: error.message });
app.post('/api/export', async (req, res) => {
const { modelId, version, author } = req.body;
if (!modelId || !version || !author) {
return res.status(400).json({ error: 'Missing required fields: modelId, version, author' });
const lineage = await exportAndStoreModel(AUTH_CLIENT, modelId, version, author);
res.status(201).json(lineage);
} catch (error) {
app.get('/api/compare/:base/:target', async (req, res) => {
const { base, target } = req.params;
const delta = await compareModelDeltas(base, target);
res.json({ base, target, delta });
} catch (error) {
res.status(404).json({ error: error.message });
app.post('/api/rollback/:version', async (req, res) => {
const { version } = req.params;
const { modelId } = req.body;
if (!modelId) return res.status(400).json({ error: 'modelId is required' });
const result = await rollbackToVersion(AUTH_CLIENT, modelId, version);
res.json(result);
} catch (error) {
app.post('/api/deploy', async (req, res) => {
const deployment = await triggerDeployment(AUTH_CLIENT, modelId);
if (deployment.status === 'failed') {
const latest = await getLatestVersion();
if (latest) {
const rollback = await rollbackToVersion(AUTH_CLIENT, modelId, latest);
return res.status(502).json({ deployment, rollback, message: 'Deployment failed. Automatic rollback initiated.' });
res.json({ deployment });
} catch (error) {
app.get('/api/status', async (req, res) => {
const files = await fs.readdir('./model-snapshots');
const metadataFiles = files.filter(f => f.endsWith('-metadata.json'));
const statuses = await Promise.all(metadataFiles.map(async f => {
const data = JSON.parse(await fs.readFile(`./model-snapshots/${f}`, 'utf8'));
return { version: data.version, status: data.status, lastModified: data.rollbackTimestamp || data.createdAt };
res.json({ modelStatuses: statuses });
} catch (error) {
app.listen(3000, () => console.log('Model versioning service running on port 3000'));
- Cause: The OAuth token has expired, the client credentials are incorrect, or the service account lacks the required
model:readormodel:writescope. - Fix: Verify the Cognigy.AI service account configuration in the admin console. Ensure the
CognigyAuthClientreceives the correctclientIdandclientSecret. The token manager automatically refreshes tokens before expiry, but initial credential mismatches will fail immediately.
Error: 403 Forbidden
- Cause: The service account has authentication but lacks permission to access the specific model or perform write operations.
- Fix: Assign the service account to a role with
Model ManagerorSystem Adminprivileges. Confirm the OAuth grant includesmodel:writeif callingPUT /api/v2/models/{id}.
Error: 422 Unprocessable Entity
- Cause: Invalid semantic version format, malformed JSON payload, or missing required fields in the Cognigy.AI model definition during import.
- Fix: Validate version strings using
semver.valid()before storage. When rolling back, ensure the exported JSON structure matches the exact schema expected byPUT /api/v2/models/{id}. Cognigy.AI rejects payloads with missingid,name, or structural mismatches.
Error: 500 Internal Server Error on Export
- Cause: The Cognigy.AI backend fails to serialize the model, or the model contains circular references or unsupported custom properties.
- Fix: Implement a retry mechanism with exponential backoff for transient 5xx errors. The provided
apiRequestmethod already handles 429 retries. For 500 errors, log themodelIdand verify the model builds successfully in the Cognigy.AI console before exporting.
