Managing Multi-Turn NICE Cognigy Conversation State via DynamoDB Serialization in Node.js
- This tutorial builds a Node.js webhook handler that receives inbound conversation payloads from NICE Cognigy, serializes the multi-turn dialogue context to AWS DynamoDB, and automatically expires stale sessions using native Time To Live (TTL) attributes.
- The implementation uses the AWS SDK for JavaScript v3 (
@aws-sdk/client-dynamodband@aws-sdk/lib-dynamodb) alongside Express.js to process HTTP POST requests. - The code demonstrates production-grade state management, including payload validation, exponential backoff retry logic for throttling, and explicit error boundaries for 4xx and 5xx responses.
- An active AWS account with permissions to create DynamoDB tables and IAM roles
- Node.js 18 or higher installed locally
- NICE Cognigy.AI project with a configured Webhook node
- Required npm packages:
express,@aws-sdk/client-dynamodb,@aws-sdk/lib-dynamodb,@aws-sdk/util-dynamodb,uuid,cors - Environment variables for AWS credentials and webhook secret
NICE Cognigy webhooks operate as inbound HTTP POST requests. Cognigy does not attach OAuth tokens to webhook payloads. Instead, you secure the endpoint using a shared secret header or IP allowlisting. DynamoDB operations require IAM authentication via environment variables.
The following code demonstrates how to validate the shared secret and initialize the DynamoDB client with explicit region configuration.
import express from 'express';
import { DynamoDBClient } from '@aws-sdk/client-dynamodb';
import { DynamoDBDocumentClient } from '@aws-sdk/lib-dynamodb';
import crypto from 'crypto';
const app = express();
app.use(express.json());
// Cognigy sends this header when configured in the Webhook node security settings
const WEBHOOK_SECRET = process.env.COGNIGY_WEBHOOK_SECRET || 'default-secret';
// AWS SDK v3 initialization
const ddbClient = new DynamoDBClient({
region: process.env.AWS_REGION || 'us-east-1',
credentials: {
accessKeyId: process.env.AWS_ACCESS_KEY_ID,
secretAccessKey: process.env.AWS_SECRET_ACCESS_KEY
const ddbDocClient = DynamoDBDocumentClient.from(ddbClient);
Cognigy webhooks do not require OAuth scopes for inbound delivery. If you later query the Cognigy Platform API to update user profiles or log interactions, you must use a service account with the cognigy:write and cognigy:read scopes. This tutorial focuses exclusively on the inbound webhook state serialization pattern.
Step 1: Configure DynamoDB Table Schema with TTL
DynamoDB TTL is a server-side feature that automatically deletes items when a specified epoch timestamp expires. This eliminates the need for cron jobs or manual cleanup scripts. You must enable TTL on the expiryTime attribute during table creation.
The table uses conversationId as the partition key and timestamp as the sort key. This design supports querying all state snapshots for a single conversation in chronological order.
# Create the table via AWS CLI
aws dynamodb create-table \
--table-name CognigyConversationState \
--attribute-definitions AttributeName=conversationId,AttributeType=S AttributeName=timestamp,AttributeType=N \
--key-schema AttributeName=conversationId,KeyType=HASH AttributeName=timestamp,KeyType=RANGE \
--billing-mode PAY_PER_REQUEST \
--region us-east-1
Enable TTL on the expiryTime attribute:
aws dynamodb update-time-to-live \
--time-to-live-specification Enabled=true,AttributeName=expiryTime \
--region us-east-1
Step 2: Build the Inbound Webhook Handler
Cognigy sends a structured JSON payload containing the session context, user input, and flow variables. The handler must validate the request signature, extract the conversation identifier, and prepare the state object for serialization.
The following Express route defines the exact HTTP request cycle. Cognigy expects a 200 OK response within 15 seconds. Any other status code triggers a retry or fails the webhook node.
// Expected Cognigy Webhook Request
// POST /webhook/cognigy-state
// Content-Type: application/json
// X-Cognigy-Secret: <your-secret>
// Body:
// "session": { "sessionId": "abc-123", "userId": "user-456" },
// "input": { "text": "I need to update my order" },
// "context": { "variables": { "orderNumber": "ORD-998", "turnCount": 3 } },
// "flow": { "name": "OrderManagement" }
app.post('/webhook/cognigy-state', async (req, res) => {
const providedSecret = req.headers['x-cognigy-secret'];
if (!providedSecret || !crypto.timingSafeEqual(Buffer.from(providedSecret), Buffer.from(WEBHOOK_SECRET))) {
return res.status(401).json({ error: 'Invalid webhook signature' });
const { session, input, context, flow } = req.body;
if (!session?.sessionId) {
return res.status(400).json({ error: 'Missing session identifier' });
const stateRecord = await serializeConversationState(session, input, context, flow);
res.status(200).json({ status: 'acknowledged', conversationId: stateRecord.conversationId });
} catch (error) {
console.error('Webhook processing failed:', error);
res.status(500).json({ error: 'Failed to persist conversation state' });
Step 3: Serialize Dialogue Context and Apply TTL
The serialization function transforms the Cognigy payload into a flat DynamoDB item. You must compute the TTL expiry time in Unix epoch seconds. The example uses a 24-hour retention window, which aligns with standard conversation cooling periods.
DynamoDB strongly types all attributes. The @aws-sdk/lib-dynamodb serializer handles type conversion automatically. You must structure the item with explicit partition and sort keys.
const RETENTION_HOURS = 24;
const TABLE_NAME = 'CognigyConversationState';
export async function serializeConversationState(session, input, context, flow) {
const conversationId = session.sessionId;
const timestamp = Date.now();
const expiryTime = Math.floor((Date.now() + (RETENTION_HOURS * 60 * 60 * 1000)) / 1000);
const item = {
conversationId,
timestamp,
expiryTime,
userId: session.userId || 'anonymous',
flowName: flow?.name || 'unknown',
userInput: input?.text || '',
turnCount: context?.variables?.turnCount || 1,
dialogueContext: {
variables: context?.variables || {},
entities: context?.entities || [],
lastUtterance: input?.text || ''
metadata: {
serializedAt: new Date().toISOString(),
platform: 'cognigy',
version: '1.0'
// PutItem operation with explicit request configuration
const putCommand = {
TableName: TABLE_NAME,
Item: item,
// ConditionExpression prevents overwriting concurrent turns if strict ordering is required
// ConditionExpression: 'attribute_not_exists(conversationId) OR attribute_not_exists(timestamp)'
await ddbDocClient.put(putCommand);
return item;
Step 4: Implement Retry Logic and Error Boundaries
DynamoDB returns 429 ThrottlingException when write capacity limits are exceeded or when the service experiences transient load. AWS SDK v3 includes automatic retries, but production systems require explicit control over retry windows and jitter to prevent thundering herd scenarios.
The following utility wraps DynamoDB calls with exponential backoff. It captures ThrottlingException and ProvisionedThroughputExceededException, retries up to five times, and surfaces 403 AccessDeniedException immediately.
import { ThrottlingException, ProvisionedThroughputExceededException, DynamoDBServiceException } from '@aws-sdk/client-dynamodb';
const MAX_RETRIES = 5;
const BASE_DELAY_MS = 100;
async function withRetry(operation, attempt = 1) {
return await operation();
} catch (error) {
if (error instanceof DynamoDBServiceException) {
const isRetryable =
error.name === 'ThrottlingException' ||
error.name === 'ProvisionedThroughputExceededException';
if (!isRetryable) {
// Surface 403, 404, or validation errors immediately
throw error;
if (attempt >= MAX_RETRIES) {
throw new Error(`DynamoDB retry limit exceeded after ${MAX_RETRIES} attempts: ${error.message}`);
// Exponential backoff with jitter
const delay = Math.min(BASE_DELAY_MS * Math.pow(2, attempt - 1) + Math.random() * 50, 2000);
console.warn(`DynamoDB throttled. Retrying in ${Math.round(delay)}ms (attempt ${attempt}/${MAX_RETRIES})`);
return withRetry(operation, attempt + 1);
throw error;
Integrate the retry wrapper into the serialization function by replacing the direct put call with await withRetry(() => ddbDocClient.put(putCommand)). This guarantees graceful degradation during traffic spikes while preserving data integrity.
The following module combines authentication, serialization, retry logic, and a pagination-enabled query endpoint. Copy the file to server.js, install dependencies, and run with node server.js.
import { DynamoDBDocumentClient, QueryCommand } from '@aws-sdk/lib-dynamodb';
const WEBHOOK_SECRET = process.env.COGNIGY_WEBHOOK_SECRET || 'cognigy-secret-key';
credentials: {
} catch (error) {
const isRetryable = error.name === 'ThrottlingException' || error.name === 'ProvisionedThroughputExceededException';
if (!isRetryable) throw error;
if (attempt >= MAX_RETRIES) throw new Error(`Retry limit exceeded: ${error.message}`);
throw error;
const item = {
conversationId,
timestamp,
expiryTime,
dialogueContext: { variables: context?.variables || {}, entities: context?.entities || [] },
metadata: { serializedAt: new Date().toISOString(), platform: 'cognigy' }
await withRetry(() => ddbDocClient.put({ TableName: TABLE_NAME, Item: item }));
return item;
if (!session?.sessionId) return res.status(400).json({ error: 'Missing session identifier' });
const record = await serializeConversationState(session, input, context, flow);
res.status(200).json({ status: 'acknowledged', conversationId: record.conversationId });
} catch (error) {
app.get('/query/state', async (req, res) => {
const { conversationId, lastEvaluatedKey } = req.query;
if (!conversationId) return res.status(400).json({ error: 'conversationId is required' });
const queryParams = {
KeyConditionExpression: 'conversationId = :cid',
ExpressionAttributeValues: { ':cid': conversationId },
ScanIndexForward: false,
Limit: 50
if (lastEvaluatedKey) queryParams.ExclusiveStartKey = JSON.parse(lastEvaluatedKey);
const command = new QueryCommand(queryParams);
const result = await withRetry(() => ddbDocClient.send(command));
res.json({
items: result.Items,
paginationToken: result.LastEvaluatedKey ? JSON.stringify(result.LastEvaluatedKey) : null
} catch (error) {
res.status(500).json({ error: 'Query failed', details: error.message });
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => console.log(`Cognigy state webhook handler running on port ${PORT}`));
- Cause: The
X-Cognigy-Secretheader is missing, malformed, or does not match theCOGNIGY_WEBHOOK_SECRETenvironment variable. - Fix: Verify the webhook node configuration in Cognigy matches the server secret exactly. Use
crypto.timingSafeEqualto prevent timing attacks during comparison. - Code Fix: Ensure the header extraction uses lowercase
req.headers['x-cognigy-secret']because HTTP headers are case-insensitive and Node.js normalizes them to lowercase.
Error: 403 AccessDeniedException
- Cause: The IAM role or access keys lack
dynamodb:PutItemordynamodb:Querypermissions on theCognigyConversationStatetable. - Fix: Attach the following policy to the execution role:
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": ["dynamodb:PutItem", "dynamodb:Query", "dynamodb:GetItem"],
"Resource": "arn:aws:dynamodb:us-east-1:ACCOUNT_ID:table/CognigyConversationState"
Error: 429 ThrottlingException
- Cause: Write throughput exceeds provisioned capacity or the service experiences regional load.
- Fix: The
withRetrywrapper implements exponential backoff with jitter. If throttling persists, switch the table toPAY_PER_REQUESTbilling mode or implement a message queue (SQS) to buffer inbound webhooks during peak traffic. - Code Fix: Verify
MAX_RETRIESandBASE_DELAY_MSvalues match your traffic pattern. IncreaseBASE_DELAY_MSto200if retries cascade.
Error: 500 Internal Server Error (Serialization Failure)
- Cause: DynamoDB rejects items exceeding 400 KB, or the payload contains unsupported types like functions or undefined values.
- Fix: Sanitize the
contextobject before serialization. Remove circular references and cap string lengths. Add a payload size check before callingput. - Code Fix: Insert
if (JSON.stringify(item).length > 380000) return res.status(413).json({ error: 'Payload exceeds DynamoDB 400KB limit' });before thewithRetrycall.
