Managing Genesys Cloud WebSocket Keep-Alive Heartbeats in Python
A production-ready heartbeat manager that maintains persistent Genesys Cloud WebSocket connections, calculates jitter, enforces timeout thresholds, tracks latency, and synchronizes connection health via webhooks. The solution uses the Genesys Cloud Python SDK for authentication and the websockets library for transport-level frame management. This tutorial covers Python 3.10+.
- OAuth2 client credentials with
view:platformscope - Genesys Cloud Python SDK (
genesyscloud>=2.0.0) websockets>=12.0for async WebSocket operationshttpx>=0.25.0for webhook synchronization- Python 3.10+ runtime
pip install genesyscloud websockets httpx
Genesys Cloud WebSocket endpoints require a valid Bearer token in the Authorization header. The token must be refreshed before expiration to prevent 401 Unauthorized disconnects. The following code demonstrates the client credentials flow using the SDK, then caches the token for WebSocket initialization.
import os
import asyncio
import logging
import uuid
import random
from typing import Optional, Dict, Any, Tuple
import httpx
import websockets
from websockets.exceptions import ConnectionClosed, WebSocketException
from genesyscloud.auth import OAuthClientCredentialsConfig, OAuthClientCredentialsClient
logging.basicConfig(
level=logging.INFO,
format="%(asctime)s | %(levelname)s | %(name)s | %(message)s",
datefmt="%Y-%m-%dT%H:%M:%S%z"
logger = logging.getLogger("genesys_ws_heartbeat")
class GenesysOAuthManager:
"""Handles token acquisition and refresh for WebSocket authentication."""
def __init__(self, region: str, client_id: str, client_secret: str):
self.region = region
self.config = OAuthClientCredentialsConfig(
region=region,
client_id=client_id,
client_secret=client_secret,
scope="view:platform"
self.oauth_client = OAuthClientCredentialsClient(self.config)
self._expires_at: Optional[float] = None
async def get_access_token(self) -> str:
if self._token and self._expires_at and time.time() < self._expires_at - 60:
return self._token
logger.info("Acquiring or refreshing OAuth token")
self.oauth_client.login()
self._token = self.oauth_client.get_access_token()
# SDK stores expiration; we approximate refresh threshold
self._expires_at = time.time() + 3500 # 1 hour token, refresh 60s early
return self._token
except Exception as exc:
logger.error("OAuth token acquisition failed: %s", exc)
raise
def build_ws_url(self) -> str:
return f"wss://api.{self.region}.genesyscloud.com/api/v2/platform/websockets"
Step 1: Establish WebSocket Connection with Bearer Token
The Genesys Cloud WebSocket endpoint expects the Authorization header on the initial handshake. The websockets library accepts custom headers via the extra_headers parameter. We pass the socket reference explicitly to enable atomic frame operations later.
class WebSocketConnector:
"""Manages the initial handshake and socket reference lifecycle."""
def __init__(self, ws_url: str, token: str):
self.ws_url = ws_url
self.token = token
self.socket_ref: Optional[websockets.WebSocketClientProtocol] = None
async def connect(self) -> websockets.WebSocketClientProtocol:
headers = {"Authorization": f"Bearer {self.token}"}
logger.info("Initiating WebSocket handshake to %s", self.ws_url)
self.socket_ref = await websockets.connect(
self.ws_url,
extra_headers=headers,
ping_interval=0, # Disabled; we manage heartbeat manually
ping_timeout=10,
max_size=10485760 # 10MB frame limit
logger.info("WebSocket connection established. Socket ref: %s", id(self.socket_ref))
return self.socket_ref
except websockets.InvalidStatusCode as exc:
logger.error("Handshake failed with status %s: %s", exc.status_code, exc.reason)
raise
logger.error("WebSocket connection failed: %s", exc)
raise
Step 2: Interval Matrix, Jitter Calculation, and Ping Directive
Network constraints require randomized intervals to prevent thundering herd effects during scaling events. The interval matrix defines a base interval and a jitter range. The ping directive sends a control frame and validates the server response format.
class HeartbeatEngine:
"""Executes ping directives with jitter and validates server responses."""
def __init__(self, base_interval: float = 20.0, jitter_range: float = 5.0):
self.base_interval = base_interval
self.jitter_range = jitter_range
self.last_pong_time: Optional[float] = None
self.ping_success_count = 0
self.ping_failure_count = 0
self.total_latency_ms = 0.0
def calculate_next_interval(self) -> float:
"""Returns base interval plus uniform jitter to distribute load."""
jitter = random.uniform(0, self.jitter_range)
return self.base_interval + jitter
async def send_ping_directive(self, socket_ref: websockets.WebSocketClientProtocol) -> Tuple[bool, float]:
Sends a ping control frame and measures round-trip time.
Returns (success: bool, latency_ms: float)
if not socket_ref or socket_ref.closed:
return False, 0.0
# websockets handles RFC 6455 ping/pong automatically when ping_timeout is set.
# We trigger a manual ping to enforce our interval matrix.
await socket_ref.ping()
self.last_pong_time = time.time()
self.ping_success_count += 1
self.total_latency_ms += latency_ms
logger.debug("Ping directive successful. Latency: %.2fms", latency_ms)
return True, latency_ms
except TimeoutError:
logger.warning("Ping directive timed out. Connection may be stale.")
self.ping_failure_count += 1
return False, 0.0
logger.error("Ping directive failed: %s", exc)
return False, 0.0
Step 3: Stale Connection Checking, Retry Logic, and Audit Logging
Stale connections occur when the server drops the socket without sending a close frame. We evaluate the time delta between the last pong and the current timestamp. If the delta exceeds the timeout threshold, we trigger a reconnect. The retry logic enforces maximum attempt limits and exponential backoff. Audit logs capture every state transition for governance.
class HeartbeatManager:
"""Orchestrates keep-alive, retry, latency tracking, and webhook sync."""
def __init__(
self,
oauth_manager: GenesysOAuthManager,
jitter_range: float = 5.0,
stale_threshold: float = 45.0,
max_retries: int = 5,
webhook_url: Optional[str] = None
self.oauth_manager = oauth_manager
self.connector = WebSocketConnector("", "")
self.engine = HeartbeatEngine(base_interval, jitter_range)
self.stale_threshold = stale_threshold
self.max_retries = max_retries
self.retry_count = 0
self.is_running = False
self.audit_log: list[Dict[str, Any]] = []
def _log_audit(self, event: str, details: Dict[str, Any]):
entry = {
"event": event,
"details": details,
"trace_id": str(uuid.uuid4())
self.audit_log.append(entry)
logger.info("AUDIT | %s | %s", event, details)
def _check_stale_connection(self) -> bool:
if not self.engine.last_pong_time:
return True
delta = time.time() - self.engine.last_pong_time
is_stale = delta > self.stale_threshold
if is_stale:
logger.warning("Stale connection detected. Pong delta: %.2fs", delta)
return is_stale
async def _emit_webhook(self, payload: Dict[str, Any]):
if not self.webhook_url:
return
async with httpx.AsyncClient(timeout=5.0) as client:
await client.post(self.webhook_url, json=payload)
logger.info("Heartbeat webhook synchronized successfully")
logger.error("Webhook sync failed: %s", exc)
async def _handle_reconnect(self):
self.retry_count += 1
if self.retry_count > self.max_retries:
logger.error("Maximum reconnection attempts (%d) exceeded. Shutting down.", self.max_retries)
return False
backoff = min(2 ** self.retry_count * 0.5, 30.0)
logger.info("Reconnecting in %.1fs (attempt %d/%d)", backoff, self.retry_count, self.max_retries)
await asyncio.sleep(backoff)
token = await self.oauth_manager.get_access_token()
self.connector = WebSocketConnector(self.oauth_manager.build_ws_url(), token)
return True
async def run(self):
self.is_running = True
self._log_audit("HEARTBEAT_MANAGER_START", {"max_retries": self.max_retries, "base_interval": self.engine.base_interval})
while self.is_running:
if not self.connector.socket_ref or self.connector.socket_ref.closed:
self.connector.socket_ref = await self.connector.connect()
self._log_audit("CONNECTION_ESTABLISHED", {"socket_ref": id(self.connector.socket_ref)})
await self._emit_webhook({"status": "connected", "timestamp": datetime.now(timezone.utc).isoformat()})
interval = self.engine.calculate_next_interval()
success, latency = await self.engine.send_ping_directive(self.connector.socket_ref)
if not success or self._check_stale_connection():
logger.warning("Heartbeat validation failed. Triggering reconnect pipeline.")
self._log_audit("HEARTBEAT_FAILURE", {"latency_ms": latency, "retry_count": self.retry_count})
await self._emit_webhook({"status": "heartbeat_failed", "latency_ms": latency, "timestamp": datetime.now(timezone.utc).isoformat()})
should_reconnect = await self._handle_reconnect()
if not should_reconnect:
break
# Format verification: ensure socket is still open after ping
if self.connector.socket_ref and not self.connector.socket_ref.closed:
self._log_audit("HEARTBEAT_SUCCESS", {"latency_ms": latency, "interval_used": interval})
await asyncio.sleep(interval)
except ConnectionClosed as exc:
logger.warning("Connection closed by remote: code=%s, reason=%s", exc.code, exc.reason)
self._log_audit("CONNECTION_CLOSED", {"code": exc.code, "reason": exc.reason})
await self._emit_webhook({"status": "closed", "code": exc.code, "timestamp": datetime.now(timezone.utc).isoformat()})
except WebSocketException as exc:
logger.error("WebSocket transport error: %s", exc)
self._log_audit("TRANSPORT_ERROR", {"error": str(exc)})
logger.critical("Unhandled exception in heartbeat loop: %s", exc)
break
self._log_audit("HEARTBEAT_MANAGER_STOP", {"final_retries": self.retry_count})
logger.info("Heartbeat manager stopped.")
The following script initializes the authentication layer, configures the heartbeat manager with production thresholds, and runs the async event loop. Replace the placeholder credentials with your Genesys Cloud client configuration.
import asyncio
import os
async def main():
# Configuration
REGION = os.getenv("GENESYS_REGION", "mypurecloud.ie")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "your_client_id")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "your_client_secret")
WEBHOOK_URL = os.getenv("NETWORK_MONITOR_WEBHOOK", "https://your-monitor.internal/heartbeat")
# Initialize OAuth manager
oauth_mgr = GenesysOAuthManager(
region=REGION,
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET
# Initialize heartbeat manager with network constraints
manager = HeartbeatManager(
oauth_manager=oauth_mgr,
base_interval=20.0,
jitter_range=5.0,
stale_threshold=45.0,
max_retries=5,
webhook_url=WEBHOOK_URL
await manager.run()
except KeyboardInterrupt:
logger.info("Interrupt received. Gracefully stopping heartbeat manager.")
manager.is_running = False
logger.error("Fatal error in main loop: %s", exc)
raise
asyncio.run(main())
Error: 1006 Abnormal Closure
- What causes it: The network layer drops the connection without sending a WebSocket close frame. This frequently occurs during Genesys Cloud scaling events or intermediate proxy timeouts.
- How to fix it: The stale connection check evaluates the pong timestamp delta. If the delta exceeds
stale_threshold, the manager triggers the reconnect pipeline automatically. Ensure your firewall allows persistent TCP connections on port 443 for at least 60 seconds. - Code showing the fix: The
_check_stale_connectionmethod returnsTruewhendelta > self.stale_threshold, which forces the retry loop to execute_handle_reconnect.
Error: 401 Unauthorized Handshake Failure
- What causes it: The Bearer token expired during the WebSocket lifecycle or the client credentials lack the
view:platformscope. - How to fix it: The
GenesysOAuthManagerchecks token expiration before every connection attempt. If the token is within 60 seconds of expiry, it forces a refresh. Verify that your OAuth client is granted the correct scopes in the Genesys Cloud admin console. - Code showing the fix:
oauth_client.login()is called insideget_access_token()whentime.time() >= self._expires_at - 60. The fresh token is passed directly toWebSocketConnector.
Error: TimeoutError During Ping Directive
- What causes it: The server did not respond to the RFC 6455 ping frame within the
ping_timeoutwindow. This indicates high network latency or a frozen transport. - How to fix it: The
send_ping_directivemethod catchesTimeoutErrorand marks the ping as failed. The main loop detects the failure and initiates the reconnect sequence. Adjustping_timeoutinwebsockets.connect()if your infrastructure requires longer round-trip times, but do not exceed 15 seconds to maintain fast failure detection. - Code showing the fix: The
except TimeoutErrorblock inHeartbeatEngine.send_ping_directiveincrementsping_failure_countand returns(False, 0.0), which triggers the stale connection pipeline.
Error: Maximum Reconnection Attempts Exceeded
- What causes it: Persistent authentication failures, region outages, or misconfigured network policies prevent successful handshakes.
- How to fix it: The manager enforces
max_retriesto prevent infinite loops. When the limit is reached,is_runningflips toFalseand the loop terminates. Implement an external alerting system that monitors the webhook payload forstatus: heartbeat_failedpatterns. Rotate credentials or verify region availability before restarting. - Code showing the fix:
if self.retry_count > self.max_retries:setsself.is_running = Falseand breaks the loop, ensuring controlled shutdown.
