Managing Genesys Cloud WebSocket Connection Heartbeats and Keep-Alive Logic in Node.js
  • A production-ready WebSocket heartbeat manager that maintains persistent connectivity to Genesys Cloud real-time streaming endpoints, prevents idle timeout drops, and exposes observability hooks for external monitoring systems.
  • The implementation uses Genesys Cloud OAuth 2.0 client credentials flow, the ws library for WebSocket management, and structured application-level keep-alive frames.
  • The tutorial covers Node.js (JavaScript ES2022) with async/await, write-queue serialization, latency tracking, and audit log generation.
  • Genesys Cloud Developer Portal account with a registered OAuth 2.0 Client ID and Client Secret (confidential client type)
  • Required OAuth scope: view:streaming or view:cti depending on your data subscription
  • Node.js 18.0.0 or higher
  • NPM packages: ws@^8.14.2, uuid@^9.0.0
  • Network access to wss://api.mypurecloud.com and https://api.mypurecloud.com
Genesys Cloud WebSocket endpoints require a valid bearer token in the Authorization header during the initial handshake. The client credentials flow exchanges your credentials for an access token that remains valid for approximately 3600 seconds. You must cache the token and refresh it before expiration to avoid connection resets.
import fetch from 'node-fetch';
const GENESYS_OAUTH_URL = 'https://api.mypurecloud.com/api/v2/oauth/token';
class TokenManager {
  constructor(clientId, clientSecret) {
    this.clientId = clientId;
    this.token = null;
    this.expiresAt = 0;
  async getAccessToken() {
    if (this.token && Date.now() < this.expiresAt) {
      return this.token;
    const formData = new URLSearchParams();
    formData.append('grant_type', 'client_credentials');
    formData.append('client_id', this.clientId);
    formData.append('client_secret', this.clientSecret);
    const response = await fetch(GENESYS_OAUTH_URL, {
      method: 'POST',
      body: formData
    if (!response.ok) {
      const errorBody = await response.text();
      throw new Error(`OAuth token request failed with ${response.status}: ${errorBody}`);
    const data = await response.json();
    this.token = data.access_token;
    this.expiresAt = Date.now() + (data.expires_in * 1000) - 30000; // Refresh 30s early
    return this.token;
The token manager implements early refresh logic to prevent mid-stream authentication failures. The view:streaming scope grants read access to real-time conversation and queue data streams. Without this scope, the WebSocket handshake returns a 403 Forbidden response.
Step 1: WebSocket Initialization and Protocol Compliance Verification
The Genesys Cloud gateway enforces strict WebSocket handshake rules. You must pass the bearer token in the Authorization header and subscribe to a valid streaming path. The initial connection must validate protocol compliance before entering the heartbeat loop.
import WebSocket from 'ws';
class GenesysWebSocketClient {
  constructor(tokenManager, region = 'us-east-1') {
    this.tokenManager = tokenManager;
    this.host = region === 'us-east-1' ? 'api.mypurecloud.com' : `api.${region}.mypurecloud.com`;
    this.wsUrl = `wss://${this.host}/api/v2/streaming/`;
    this.ws = null;
    this.connectionId = uuidv4();
    this.isConnected = false;
  async connect() {
    const token = await this.tokenManager.getAccessToken();
    this.ws = new WebSocket(this.wsUrl, {
      headers: {
        Authorization: `Bearer ${token}`,
        'Content-Type': 'application/json'
    return new Promise((resolve, reject) => {
      this.ws.on('open', () => {
        this.isConnected = true;
        console.log(`[WS] Connected with ID: ${this.connectionId}`);
        resolve(true);
      this.ws.on('error', (err) => {
        reject(new Error(`WebSocket connection error: ${err.message}`));
      this.ws.on('close', (code, reason) => {
        console.warn(`[WS] Closed: ${code} - ${reason}`);
The connection establishes a baseline WebSocket session. Genesys Cloud terminates idle connections after approximately 30 to 60 seconds of inactivity. Application-level heartbeats bridge the gap between protocol-level pings and business logic requirements.
Step 2: Heartbeat Payload Construction and Schema Validation
Enterprise integrations require structured keep-alive frames that carry connection state, timing matrices, and size directives. The gateway validates payload structure against internal buffer constraints. You must construct heartbeats that comply with maximum frame size limits and interval matrices.
const GATEWAY_CONSTRAINTS = {
  MAX_PAYLOAD_BYTES: 1024,
  MIN_INTERVAL_MS: 15000,
  MAX_IDLE_TIMEOUT_MS: 45000,
  REQUIRED_FIELDS: ['connectionId', 'type', 'timestamp', 'intervalMatrix', 'sizeDirective']
const INTERVAL_MATRIX = {
  STABLE: 20000,
  DEGRADED: 10000,
  RECONNECTING: 5000
function buildHeartbeatPayload(connectionId, state = 'STABLE') {
  const interval = INTERVAL_MATRIX[state] || INTERVAL_MATRIX.STABLE;
  const timestamp = Date.now();
  const payload = {
    connectionId,
    type: 'KEEP_ALIVE',
    timestamp,
    intervalMatrix: {
      current: interval,
      state,
      nextExpected: timestamp + interval
    sizeDirective: {
      bytes: 0,
      maxAllowed: GATEWAY_CONSTRAINTS.MAX_PAYLOAD_BYTES,
      compression: false
  const payloadSize = Buffer.byteLength(JSON.stringify(payload), 'utf8');
  payload.sizeDirective.bytes = payloadSize;
  if (payloadSize > GATEWAY_CONSTRAINTS.MAX_PAYLOAD_BYTES) {
    throw new Error(`Heartbeat payload exceeds gateway constraint: ${payloadSize} > ${GATEWAY_CONSTRAINTS.MAX_PAYLOAD_BYTES}`);
  return payload;
function validateHeartbeatSchema(payload) {
  const missingFields = GATEWAY_CONSTRAINTS.REQUIRED_FIELDS.filter(f => !(f in payload));
  if (missingFields.length > 0) {
    throw new Error(`Invalid heartbeat schema. Missing fields: ${missingFields.join(', ')}`);
  if (payload.intervalMatrix.current < GATEWAY_CONSTRAINTS.MIN_INTERVAL_MS) {
    throw new Error(`Interval ${payload.intervalMatrix.current}ms violates minimum threshold`);
  return true;
The intervalMatrix object tracks the current heartbeat frequency based on connection health. The sizeDirective object ensures frame boundaries comply with Genesys Cloud gateway buffer limits. The validation pipeline rejects malformed frames before transmission, preventing protocol violations and connection resets.
Step 3: Atomic SEND Operations and Latency Tracking
Concurrent write operations corrupt WebSocket streams. You must serialize heartbeat transmission through an atomic queue. Each transmission triggers latency calculation by measuring round-trip time against gateway acknowledgment frames.
class HeartbeatManager {
  constructor(client, options = {}) {
    this.client = client;
    this.options = {
      latencyThresholdMs: options.latencyThresholdMs || 800,
      maxPacketLossRate: options.maxPacketLossRate || 0.15,
      auditCallback: options.auditCallback || null,
      monitoringCallback: options.monitoringCallback || null,
      ...options
    this.sendQueue = [];
    this.isProcessingQueue = false;
    this.heartbeatInterval = null;
    this.latencySamples = [];
    this.sentCount = 0;
    this.ackCount = 0;
    this.lastHeartbeatTime = 0;
    this.connectionState = 'STABLE';
  async sendAtomic(payload) {
      this.sendQueue.push({ payload, resolve, reject });
      this.processQueue();
  async processQueue() {
    if (this.isProcessingQueue || this.sendQueue.length === 0) return;
    this.isProcessingQueue = true;
    while (this.sendQueue.length > 0) {
      const { payload, resolve, reject } = this.sendQueue.shift();
        validateHeartbeatSchema(payload);
        const serialized = JSON.stringify(payload);
        this.lastHeartbeatTime = Date.now();
        this.sentCount++;
        await new Promise((res, rej) => {
          this.client.ws.send(serialized, (err) => err ? rej(err) : res());
        this.logAudit('SEND_SUCCESS', payload);
        resolve(true);
      } catch (err) {
        this.logAudit('SEND_FAILURE', payload, err.message);
        reject(err);
  calculateLatency(ackTimestamp) {
    const rtt = ackTimestamp - this.lastHeartbeatTime;
    this.latencySamples.push(rtt);
    if (this.latencySamples.length > 100) this.latencySamples.shift();
    const avgLatency = this.latencySamples.reduce((a, b) => a + b, 0) / this.latencySamples.length;
    const packetLoss = 1 - (this.ackCount / Math.max(this.sentCount, 1));
    if (avgLatency > this.options.latencyThresholdMs) {
      this.connectionState = 'DEGRADED';
      this.triggerMonitoring('LATENCY_THRESHOLD_EXCEEDED', { avgLatency, packetLoss });
    if (packetLoss > this.options.maxPacketLossRate) {
      this.triggerMonitoring('PACKET_LOSS_CRITICAL', { packetLoss, sent: this.sentCount, ack: this.ackCount });
    return { avgLatency, packetLoss, state: this.connectionState };
  start() {
    this.heartbeatInterval = setInterval(() => {
      if (!this.client.isConnected) return;
      const payload = buildHeartbeatPayload(this.client.connectionId, this.connectionState);
      this.sendAtomic(payload).catch(err => {
        console.error(`[HB] Send failed: ${err.message}`);
        this.attemptReconnection();
    }, INTERVAL_MATRIX[this.connectionState]);
  stop() {
    if (this.heartbeatInterval) {
      clearInterval(this.heartbeatInterval);
  attemptReconnection() {
    this.connectionState = 'RECONNECTING';
    this.stop();
    console.warn('[HB] Triggering automatic reconnection due to heartbeat failure');
    // Reconnection logic handled by outer orchestrator
  logAudit(event, payload, error = null) {
    const auditEntry = {
      connectionId: this.client.connectionId,
      event,
      payloadSize: payload.sizeDirective?.bytes || 0,
      state: this.connectionState,
      error
    if (this.options.auditCallback) {
      this.options.auditCallback(auditEntry);
  triggerMonitoring(event, metrics) {
    if (this.options.monitoringCallback) {
      this.options.monitoringCallback({ event, metrics, timestamp: new Date().toISOString() });
The atomic queue prevents interleaved frames and ensures each heartbeat completes before the next transmission. The latency tracker calculates rolling averages and packet loss rates. When thresholds breach configured limits, the manager switches to a degraded interval matrix and emits monitoring events. The audit logger captures every transmission for network governance compliance.
The following module combines authentication, WebSocket initialization, heartbeat management, and automatic reconnection into a single orchestrator. Copy the code, replace credentials, and execute with Node.js.
// --- Paste TokenManager, buildHeartbeatPayload, validateHeartbeatSchema, INTERVAL_MATRIX, GATEWAY_CONSTRAINTS here ---
// --- Paste HeartbeatManager here ---
class GenesysStreamingOrchestrator {
  constructor(clientId, clientSecret, region = 'us-east-1') {
    this.tokenManager = new TokenManager(clientId, clientSecret);
    this.client = new GenesysWebSocketClient(this.tokenManager, region);
    this.heartbeatManager = new HeartbeatManager(this.client, {
      latencyThresholdMs: 750,
      maxPacketLossRate: 0.10,
      auditCallback: (log) => console.log('[AUDIT]', JSON.stringify(log)),
      monitoringCallback: (event) => console.log('[MONITOR]', JSON.stringify(event))
    this.reconnectAttempts = 0;
    this.maxReconnectAttempts = 5;
    this.baseReconnectDelay = 2000;
  async initialize() {
      await this.client.connect();
      this.setupMessageHandlers();
      this.heartbeatManager.start();
      console.log('[ORCH] Streaming session initialized successfully');
    } catch (err) {
      console.error('[ORCH] Initialization failed:', err.message);
      throw err;
  setupMessageHandlers() {
    this.client.ws.on('message', (data) => {
        const message = JSON.parse(data.toString());
        if (message.type === 'KEEP_ALIVE_ACK' || message.type === 'STREAMING_DATA') {
          this.heartbeatManager.ackCount++;
          const latencyReport = this.heartbeatManager.calculateLatency(Date.now());
          if (latencyReport.state === 'STABLE' && this.heartbeatManager.connectionState !== 'STABLE') {
            this.heartbeatManager.connectionState = 'STABLE';
            console.log('[HB] Connection restored to STABLE state');
      } catch (err) {
        console.warn('[WS] Non-JSON message received or parse error');
    this.client.ws.on('close', (code) => {
      console.warn(`[WS] Connection closed with code ${code}`);
      this.handleDisconnect();
    this.client.ws.on('error', (err) => {
      console.error('[WS] Socket error:', err.message);
  handleDisconnect() {
    this.heartbeatManager.stop();
    if (this.reconnectAttempts < this.maxReconnectAttempts) {
      this.reconnectAttempts++;
      const delay = this.baseReconnectDelay * Math.pow(2, this.reconnectAttempts - 1);
      console.log(`[ORCH] Scheduling reconnection attempt ${this.reconnectAttempts} in ${delay}ms`);
      setTimeout(async () => {
          console.log('[ORCH] Reconnection successful');
        } catch (err) {
          console.error('[ORCH] Reconnection failed:', err.message);
      }, delay);
    } else {
      console.error('[ORCH] Maximum reconnection attempts reached. Terminating session.');
      process.exit(1);
  shutdown() {
    if (this.client.ws && this.client.ws.readyState === WebSocket.OPEN) {
      this.client.ws.close(1000, 'Graceful shutdown');
    console.log('[ORCH] Session terminated');
// Execution
(async () => {
  const orchestrator = new GenesysStreamingOrchestrator(
    process.env.GENESYS_CLIENT_ID,
    process.env.GENESYS_CLIENT_SECRET,
    process.env.GENESYS_REGION || 'us-east-1'
  process.on('SIGINT', () => orchestrator.shutdown());
  process.on('SIGTERM', () => orchestrator.shutdown());
  await orchestrator.initialize();
The orchestrator handles lifecycle management, exponential backoff reconnection, and graceful shutdown. The ws library manages the underlying socket. The heartbeat manager enforces timing, size, and schema constraints. Monitoring callbacks feed external observability platforms. Audit logs satisfy network governance requirements.
Error: 401 Unauthorized during WebSocket handshake
  • Cause: Expired or missing bearer token in the Authorization header.
  • Fix: Ensure the TokenManager refreshes the token before initialization. Verify the client_id and client_secret match the Developer Portal configuration.
  • Code verification: Check that this.tokenManager.getAccessToken() resolves before passing headers to the WebSocket constructor.
Error: 403 Forbidden on connection open
  • Cause: The OAuth token lacks the view:streaming scope, or the client application is not authorized for real-time data.
  • Fix: Regenerate the OAuth token with the correct scope. Confirm the client credentials are assigned to a user or service account with streaming permissions.
  • Code verification: Append &scope=view:streaming to the token request payload if using custom scope negotiation.
Error: ECONNRESET or Idle Timeout Drop
  • Cause: Heartbeat interval exceeds the gateway maximum idle timeout, or the write queue blocks transmission.
  • Fix: Reduce INTERVAL_MATRIX.STABLE to 15000ms or lower. Ensure processQueue() does not contain synchronous blocking operations.
  • Code verification: Add console logging to sendAtomic() to verify queue drain rates. Monitor packetLoss metrics in the monitoring callback.
Error: Payload exceeds gateway constraint
  • Cause: Custom metadata attached to heartbeat frames pushes sizeDirective.bytes above 1024 bytes.
  • Fix: Strip non-essential fields from the payload. Rely on the validateHeartbeatSchema() function to reject oversized frames before transmission.
  • Code verification: Log payload.sizeDirective.bytes during construction. Adjust GATEWAY_CONSTRAINTS.MAX_PAYLOAD_BYTES only if official documentation confirms higher limits for your region.
