Managing Genesys Cloud Web Messaging WebSocket Connection Pools with Python
  • A production-ready WebSocket connection pool manager that dynamically scales connections to the Genesys Cloud Web Messaging Guest API.
  • A scaling controller that validates capacity matrices against infrastructure limits, enforces heartbeat tuning, and executes atomic failover operations.
  • Python code using the genesyscloud SDK, websockets, httpx, and pydantic to handle authentication, pool management, metric tracking, audit logging, and webhook synchronization.
  • Genesys Cloud OAuth client type: Confidential (Client Credentials Grant)
  • Required OAuth scopes: webmessaging:guest, webhook:read_write, analytics:reports:read
  • SDK/API version: Genesys Cloud Python SDK v133.0.0+, REST API v2
  • Runtime: Python 3.9 or higher
  • External dependencies: genesyscloud, websockets, httpx, pydantic, aiohttp
Genesys Cloud requires a bearer token for all REST API calls and WebSocket handshake validation. The Python SDK handles token caching and automatic refresh, but you must initialize the client with your OAuth credentials before invoking any API surface.
import os
import httpx
from genesyscloud.platform_client_v2.client_configuration import ClientConfiguration
from genesyscloud.platform_client_v2.api.oauth_api import OAuthApi
def initialize_genesys_client(
    client_id: str,
    client_secret: str,
    base_url: str
) -> ClientConfiguration:
    Configures the Genesys Cloud platform client with OAuth credentials.
    Returns a shared ClientConfiguration instance for SDK usage.
    config = ClientConfiguration()
    config.client_id = client_id
    config.client_secret = client_secret
    config.base_url = base_url
    # Explicitly request required scopes
    config.scopes = [
        "webmessaging:guest",
        "webhook:read_write",
        "analytics:reports:read"
    # Verify connectivity and token acquisition
    oauth_api = OAuthApi(config)
        token_response = oauth_api.post_oauth_token(
            grant_type="client_credentials",
            scope=" ".join(config.scopes)
        if token_response.access_token is None:
            raise RuntimeError("OAuth token acquisition failed.")
    except ApiException as e:
        raise RuntimeError(f"Authentication failed with status {e.status}: {e.body}") from e
    return config
The SDK caches the token in memory and refreshes it automatically before expiration. You will reuse this ClientConfiguration object for webhook registration and any subsequent REST calls.
Step 1: Define Scaling Directives and Capacity Validation
Genesys Cloud does not expose REST endpoints to scale WebSocket pools. The client application must manage connection scaling. You will define a ScalingDirective model that contains pool references, capacity matrices, and expansion rules. The scaler validates these directives against operating system socket limits and application memory constraints before opening new connections.
import asyncio
import logging
import resource
import psutil
from pydantic import BaseModel, Field, validator
from typing import Dict, List, Optional
logger = logging.getLogger("genesys_pool_scaler")
class CapacityMatrix(BaseModel):
    min_connections: int = Field(default=2, ge=1)
    max_connections: int = Field(default=50, ge=1)
    scale_step: int = Field(default=5, ge=1)
    heartbeat_interval_seconds: float = Field(default=15.0, gt=0)
    latency_threshold_ms: float = Field(default=200.0, gt=0)
    max_memory_percent: float = Field(default=85.0, le=100, ge=50)
class ScalingDirective(BaseModel):
    pool_reference: str
    capacity: CapacityMatrix
    expand_trigger: str = Field(default="queue_depth")
    @validator("capacity")
    def validate_capacity_bounds(cls, v, values):
        if v.min_connections > v.max_connections:
            raise ValueError("min_connections cannot exceed max_connections")
        return v
class InfrastructureValidator:
    """Validates scaling requests against OS and memory constraints."""
    @staticmethod
    def check_socket_limits(requested_count: int) -> bool:
        soft_limit, hard_limit = resource.getrlimit(resource.RLIMIT_NOFILE)
        return requested_count < soft_limit
    @staticmethod
    def check_memory_footprint(max_percent: float) -> bool:
        memory = psutil.virtual_memory()
        return memory.percent < max_percent
    @classmethod
    def validate_scaling_request(cls, directive: ScalingDirective, current_count: int) -> bool:
        target = min(current_count + directive.capacity.scale_step, directive.capacity.max_connections)
        if not cls.check_socket_limits(target):
            logger.warning("Scaling blocked: OS socket limit reached.")
            return False
        if not cls.check_memory_footprint(directive.capacity.max_memory_percent):
            logger.warning("Scaling blocked: Memory footprint exceeds threshold.")
            return False
        return True
Step 2: Build the WebSocket Connection Pool with Heartbeat and Failover
The Genesys Cloud Web Messaging Guest API uses a WebSocket endpoint at wss://{region}.mypurecloud.com/webmessaging/guest/v1. You will implement an async pool that manages connection reuse, sends periodic pings to satisfy the heartbeat interval, and executes atomic failover on connection drops.
import websockets
import json
from asyncio import Queue
from typing import Any
class GuestWebSocketConnection:
    """Manages a single WebSocket connection to the Genesys Cloud Guest API."""
    def __init__(self, region: str, connection_id: str, heartbeat_seconds: float):
        self.region = region
        self.connection_id = connection_id
        self.heartbeat_seconds = heartbeat_seconds
        self.ws: Optional[websockets.WebSocketClientProtocol] = None
        self.is_connected = False
        self.last_pong_time: float = 0.0
        self.reuse_count = 0
    async def connect(self) -> bool:
        uri = f"wss://{self.region}.mypurecloud.com/webmessaging/guest/v1"
            self.ws = await websockets.connect(
                uri,
                ping_interval=self.heartbeat_seconds,
                ping_timeout=10.0,
                close_timeout=5.0
            self.is_connected = True
            self.last_pong_time = time.time()
            logger.info(f"Connection {self.connection_id} established to {uri}")
            return True
            logger.error(f"Failed to connect {self.connection_id}: {e}")
            return False
    async def send_message(self, payload: Dict[str, Any]) -> bool:
        if not self.is_connected or self.ws is None:
            return False
            await self.ws.send(json.dumps(payload))
            self.reuse_count += 1
            return True
        except websockets.exceptions.ConnectionClosed as e:
            logger.warning(f"Connection {self.connection_id} closed: {e.code} {e.reason}")
            return False
            logger.error(f"Send error on {self.connection_id}: {e}")
            return False
    async def close(self) -> None:
        if self.ws and not self.ws.closed:
            await self.ws.close()
    def check_latency(self, threshold_ms: float) -> bool:
        """Returns True if latency is within acceptable bounds."""
        if self.ws is None or self.ws.last_pong is None:
            return False
        latency_seconds = time.time() - self.last_pong_time
        latency_ms = latency_seconds * 1000
        return latency_ms <= threshold_ms
class WebSocketPool:
    """Thread-safe async pool for Genesys Cloud Web Messaging connections."""
    def __init__(self, region: str, directive: ScalingDirective):
        self.directive = directive
        self.connections: List[GuestWebSocketConnection] = []
        self.available_queue: Queue[GuestWebSocketConnection] = Queue()
        self._lock = asyncio.Lock()
    async def initialize(self) -> int:
        """Creates the minimum required connections."""
        tasks = [self._create_connection(f"pool-{i}") for i in range(self.directive.capacity.min_connections)]
        results = await asyncio.gather(*tasks)
        success_count = sum(1 for r in results if r)
        logger.info(f"Pool initialized with {success_count}/{self.directive.capacity.min_connections} connections.")
        return success_count
    async def _create_connection(self, conn_id: str) -> bool:
        conn = GuestWebSocketConnection(
            self.region,
            conn_id,
            self.directive.capacity.heartbeat_interval_seconds
        success = await conn.connect()
        if success:
            self.connections.append(conn)
            await self.available_queue.put(conn)
        return success
    async def scale_up(self) -> int:
        """Expands the pool by the defined scale_step if validation passes."""
        async with self._lock:
            current = len(self.connections)
            if not InfrastructureValidator.validate_scaling_request(self.directive, current):
                logger.info("Scale-up blocked by infrastructure constraints.")
                return 0
            target = min(current + self.directive.capacity.scale_step, self.directive.capacity.max_connections)
            new_count = target - current
            tasks = [self._create_connection(f"pool-{current+i}") for i in range(new_count)]
            success = sum(1 for r in results if r)
            logger.info(f"Scale-up complete: added {success}/{new_count} connections.")
            return success
    async def get_connection(self) -> Optional[GuestWebSocketConnection]:
        """Returns a healthy connection from the pool."""
        while not self.available_queue.empty():
            conn = await self.available_queue.get()
            if conn.is_connected and conn.check_latency(self.directive.capacity.latency_threshold_ms):
                return conn
            else:
                await conn.close()
                self.connections.remove(conn)
        return None
    async def release_connection(self, conn: GuestWebSocketConnection) -> None:
        """Returns a connection to the pool for reuse."""
        if conn.is_connected:
        else:
            await conn.close()
            if conn in self.connections:
Step 3: Implement Metric Tracking, Audit Logging, and Webhook Synchronization
You will track scaling latency, expansion success rates, and generate structured audit logs. The scaler will register a Genesys Cloud webhook to notify external auto-scaling groups of pool state changes.
from genesyscloud.platform_client_v2.api.webhook_api import WebhookApi
from genesyscloud.platform_client_v2.model import Webhook, WebhookEntityFilter, WebhookHttpTarget
@dataclass
class ScalingMetrics:
    total_scale_attempts: int = 0
    successful_expansions: int = 0
    average_scaling_latency_ms: float = 0.0
    connection_exhaustion_count: int = 0
    audit_log: List[Dict[str, Any]] = field(default_factory=list)
    def record_scale_attempt(self, success: bool, latency_ms: float) -> None:
        self.total_scale_attempts += 1
        if success:
            self.successful_expansions += 1
            self.average_scaling_latency_ms = (
                (self.average_scaling_latency_ms * (self.total_scale_attempts - 1) + latency_ms) / self.total_scale_attempts
        self.audit_log.append({
            "event": "scale_attempt",
            "success": success,
            "latency_ms": latency_ms,
            "pool_size": self.total_scale_attempts  # Simplified tracking
        logger.info(f"Audit: Scale attempt {'succeeded' if success else 'failed'} in {latency_ms:.2f}ms")
class PoolScaler:
    """Orchestrates scaling, metrics, webhook sync, and failover."""
    def __init__(self, config: ClientConfiguration, region: str, directive: ScalingDirective):
        self.config = config
        self.pool = WebSocketPool(region, directive)
        self.metrics = ScalingMetrics()
        self.webhook_api = WebhookApi(config)
    async def register_scale_webhook(self, target_url: str) -> Optional[str]:
        """Registers a webhook to notify external systems of scaling events."""
            webhook = Webhook(
                name="Genesys Web Messaging Pool Scaler",
                description="Triggers on pool scale events",
                enabled=True,
                target=WebhookHttpTarget(
                    url=target_url,
                    http_method="POST",
                    headers={"Content-Type": "application/json"}
                entity_filter=WebhookEntityFilter(
                    entity="webmessaging",
                    event="conversation.created"
            response = self.webhook_api.post_webhooks(webhook=webhook)
            logger.info(f"Webhook registered: {response.id}")
            return response.id
            logger.error(f"Webhook registration failed: {e.body}")
            return None
    async def execute_scale_iteration(self) -> bool:
        """Runs a single scaling cycle with latency tracking and failover logic."""
        start_time = time.time()
        success = False
        if self.pool.available_queue.empty() and len(self.pool.connections) < self.directive.capacity.max_connections:
            added = await self.pool.scale_up()
            success = added > 0
        else:
            success = True  # No scaling needed
        self.metrics.record_scale_attempt(success, latency_ms)
        if not success:
            self.metrics.connection_exhaustion_count += 1
            logger.warning("Scaling iteration failed. Initiating failover cleanup.")
            await self._failover_cleanup()
        return success
    async def _failover_cleanup(self) -> None:
        """Closes stale connections and attempts graceful recovery."""
        stale = [c for c in self.pool.connections if not c.is_connected]
        for conn in stale:
            await conn.close()
            self.pool.connections.remove(conn)
        logger.info(f"Failover cleanup: removed {len(stale)} stale connections.")
    def get_metrics_snapshot(self) -> Dict[str, Any]:
            "total_attempts": self.metrics.total_scale_attempts,
            "successful_expansions": self.metrics.successful_expansions,
            "success_rate_percent": (
                (self.metrics.successful_expansions / self.metrics.total_scale_attempts * 100)
                if self.metrics.total_scale_attempts > 0 else 0.0
            "avg_latency_ms": self.metrics.average_scaling_latency_ms,
            "exhaustion_count": self.metrics.connection_exhaustion_count,
            "audit_trail": self.metrics.audit_log[-10:]  # Last 10 entries
The following script combines authentication, pool initialization, scaling execution, metric tracking, and webhook registration into a single runnable module. Replace the placeholder credentials and webhook URL before execution.
import asyncio
import os
import sys
async def main():
    # Configuration
    CLIENT_ID = os.getenv("GENESYS_CLIENT_ID", "your-client-id")
    CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET", "your-client-secret")
    BASE_URL = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
    REGION = os.getenv("GENESYS_REGION", "mypurecloud")
    WEBHOOK_URL = os.getenv("EXTERNAL_WEBHOOK_URL", "https://example.com/scale-events")
    # Initialize SDK client
    config = initialize_genesys_client(CLIENT_ID, CLIENT_SECRET, BASE_URL)
    # Define scaling parameters
    directive = ScalingDirective(
        pool_reference="webmsg-prod-pool-01",
        capacity=CapacityMatrix(
            min_connections=3,
            max_connections=20,
            scale_step=4,
            heartbeat_interval_seconds=12.0,
            latency_threshold_ms=150.0,
            max_memory_percent=80.0
        expand_trigger="queue_depth"
    # Initialize scaler
    scaler = PoolScaler(config, REGION, directive)
    # Register external webhook
    webhook_id = await scaler.register_scale_webhook(WEBHOOK_URL)
    if not webhook_id:
        logger.warning("Continuing without webhook registration.")
    # Initialize base pool
    await scaler.pool.initialize()
    # Run scaling iterations
    logger.info("Starting scaling evaluation loop...")
    for i in range(3):
        await asyncio.sleep(2)
        await scaler.execute_scale_iteration()
    # Output final metrics and audit log
    snapshot = scaler.get_metrics_snapshot()
    logger.info("Scaling metrics snapshot:")
    logger.info(json.dumps(snapshot, indent=2))
    # Graceful shutdown
    for conn in scaler.pool.connections:
        await conn.close()
    logger.info("Pool scaler shutdown complete.")
    asyncio.run(main())
  • What causes it: Invalid OAuth credentials, expired token, or missing scopes.
  • How to fix it: Verify the client ID and secret match a Confidential client in Genesys Cloud. Ensure the webmessaging:guest and webhook:read_write scopes are attached to the client. The SDK automatically refreshes tokens, but initial handshake failures indicate credential mismatch.
  • Code showing the fix: The initialize_genesys_client function explicitly requests scopes and raises a clear exception on failure.
  • What causes it: Exceeding Genesys Cloud REST API rate limits during webhook registration or token refresh.
  • How to fix it: Implement exponential backoff for REST calls. The Python SDK does not include built-in retry logic for all endpoints, so wrap httpx or SDK calls in a retry decorator.
import httpx
def retry_with_backoff(func, max_retries=3):
            return func()
            if e.response.status_code == 429:
                wait_time = 2 ** attempt
                logger.warning(f"Rate limited. Retrying in {wait_time}s...")
                time.sleep(wait_time)
            else:
                raise
    raise RuntimeError("Max retries exceeded for 429 response.")
Error: WebSocket Connection Refused or Close Code 1006
  • What causes it: Network restrictions, incorrect region subdomain, or Genesys Cloud terminating idle connections.
  • How to fix it: Verify the region matches your org (e.g., mypurecloud.com for US, mypurecloud.ie for EU). Ensure your outbound firewall allows wss:// traffic on port 443. The pool manager includes heartbeat tuning and latency checks to prevent idle termination.
  • Code showing the fix: The GuestWebSocketConnection class configures ping_interval and validates last_pong timestamps. Stale connections are removed during failover cleanup.
Error: Memory Footprint or Socket Limit Exceeded
  • What causes it: Aggressive scaling directives exceed OS RLIMIT_NOFILE or application memory thresholds.
  • How to fix it: Adjust CapacityMatrix.max_connections and max_memory_percent. Run ulimit -n to check OS limits. The InfrastructureValidator blocks scaling when constraints are violated, preventing exhaustion.
