Managing Genesys Cloud Web Messaging Guest Token Lifecycles with Python SDK
A Python utility that generates scoped guest tokens via the Genesys Cloud External Users API, binds tokens to CRM customer identifiers using SHA-256 hashing, implements sliding-window token refresh logic, rotates OAuth client credentials on 401 unauthorized responses, and persists session mappings in DynamoDB for cross-channel correlation. This tutorial uses the official genesyscloud Python SDK and boto3. It covers Python 3.9 and later.
- OAuth application type: Confidential Client (Client Credentials Grant)
- Required OAuth scopes:
externaluser:guest:create,externaluser:guest:read - SDK version:
genesyscloud>=2024.3.0 - Runtime: Python 3.9+
- External dependencies:
boto3>=1.34.0,pydantic>=2.6.0(optional for validation, not strictly required here) - AWS credentials with permissions to read and write to a DynamoDB table named
GenesysGuestSessions - Environment variables:
GENESYS_REGION,GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET,GENESYS_BASE_URL
The Genesys Cloud Python SDK handles the OAuth 2.0 client credentials flow internally when you provide the region, client ID, and client secret to the Configuration object. The SDK automatically requests an access token and attaches it to subsequent API calls. Token caching occurs within the SDK session. You must configure the client with your environment variables before instantiating any API class.
import os
from genesyscloud.rest import Configuration
def build_genesys_configuration() -> Configuration:
config = Configuration()
config.host = os.getenv("GENESYS_BASE_URL", "https://api.mypurecloud.com")
config.region = os.getenv("GENESYS_REGION", "us-east-1")
config.client_id = os.getenv("GENESYS_CLIENT_ID")
config.client_secret = os.getenv("GENESYS_CLIENT_SECRET")
return config
The SDK raises a genesyscloud.rest.ApiException when the initial token request fails. You must catch this exception and verify that your environment variables contain valid values. The OAuth endpoint used internally is https://{region}.mypurecloud.com/oauth/token. The request body contains grant_type=client_credentials, client_id, and client_secret. The response contains access_token, token_type, expires_in, and scope.
Step 1: DynamoDB Session Mapping Configuration
You need a persistent store to track the relationship between your internal CRM customer ID, the deterministic hash used for lookup, the Genesys guest identifier, the active token, and the expiration timestamp. DynamoDB provides low-latency reads and writes for this use case. The table uses a partition key of crm_id_hash and stores the token metadata as attributes.
import boto3
from botocore.exceptions import ClientError
class SessionStore:
def __init__(self, table_name: str = "GenesysGuestSessions"):
self.dynamodb = boto3.resource("dynamodb")
self.table = self.dynamodb.Table(table_name)
def save_session(self, crm_id_hash: str, guest_id: str, token: str, expires_at: str):
item = {
"crm_id_hash": crm_id_hash,
"genesys_guest_id": guest_id,
"token": token,
"expires_at": expires_at,
"updated_at": datetime.now(timezone.utc).isoformat()
self.table.put_item(Item=item)
def get_session(self, crm_id_hash: str) -> dict | None:
response = self.table.get_item(Key={"crm_id_hash": crm_id_hash})
return response.get("Item")
except ClientError:
return None
def delete_session(self, crm_id_hash: str):
self.table.delete_item(Key={"crm_id_hash": crm_id_hash})
The save_session method overwrites existing records, which aligns with the sliding refresh pattern. The expires_at field stores the ISO 8601 timestamp returned by the Genesys API. You parse this timestamp later to determine if a refresh is required.
Step 2: Guest Creation and CRM Identifier Binding
Genesys Cloud requires a guest entity before you can request a token. You create the guest using the POST /api/v2/externalusers/guests endpoint. To bind the guest to a CRM customer ID without exposing sensitive data, you generate a SHA-256 hash of the CRM ID and use it as the guest name. This creates a deterministic identifier that you can reuse across sessions. The SDK class CreateGuestRequest maps directly to the request body.
import hashlib
from genesyscloud.api.external_users_api import ExternalUsersApi
from genesyscloud.model.create_guest_request import CreateGuestRequest
def create_guest_if_missing(api_client: ExternalUsersApi, crm_id: str, session_store: SessionStore) -> str:
crm_id_hash = hashlib.sha256(crm_id.encode("utf-8")).hexdigest()
existing = session_store.get_session(crm_id_hash)
if existing and "genesys_guest_id" in existing:
return existing["genesys_guest_id"]
guest_request = CreateGuestRequest(
name=f"crm_guest_{crm_id_hash[:12]}",
email=f"guest_{crm_id_hash[:8]}@internal.corp",
custom_attributes={"source_system": "crm_integration", "crm_id_hash": crm_id_hash}
response = api_client.post_external_users_guests(body=guest_request)
session_store.save_session(crm_id_hash, response.id, "", "")
return response.id
The API response for guest creation returns a JSON object containing id, name, email, customAttributes, created_at, and updated_at. The id field is a UUID that you must pass to the token generation endpoint. If the guest already exists in DynamoDB, you skip creation to avoid duplicate entities. The OAuth scope required for this call is externaluser:guest:create.
Step 3: Token Generation and Sliding Expiration Logic
Token generation uses POST /api/v2/externalusers/guests/token. The request body contains only the guest identifier. The response returns a JWT-style token and an expires_at timestamp. You implement a sliding window by checking the remaining validity period. If the token expires within 300 seconds (5 minutes), you request a new token. This prevents mid-conversation drops while minimizing API calls.
from genesyscloud.model.create_guest_token_request import CreateGuestTokenRequest
from datetime import datetime, timezone, timedelta
SLIDING_WINDOW_SECONDS = 300
def get_or_refresh_token(api_client: ExternalUsersApi, guest_id: str, session_store: SessionStore, crm_id_hash: str) -> str:
session = session_store.get_session(crm_id_hash)
current_token = session.get("token") if session else None
expires_at_str = session.get("expires_at") if session else None
if current_token and expires_at_str:
expires_at = datetime.fromisoformat(expires_at_str.replace("Z", "+00:00"))
remaining = (expires_at - datetime.now(timezone.utc)).total_seconds()
if remaining > SLIDING_WINDOW_SECONDS:
return current_token
token_request = CreateGuestTokenRequest(external_user_id=guest_id)
response = api_client.post_external_users_guests_token(body=token_request)
session_store.save_session(crm_id_hash, guest_id, response.token, response.expires_at)
return response.token
The HTTP request cycle for token generation looks like this:
- Method:
POST - Path:
/api/v2/externalusers/guests/token - Headers:
Authorization: Bearer <access_token>,Content-Type: application/json - Request Body:
{"externalUserId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890"} - Response Body:
{"token": "eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...", "expires_at": "2024-12-15T14:30:00.000Z"}
The OAuth scope required for this call is externaluser:guest:read. The sliding window logic parses the ISO 8601 string, calculates the delta against UTC now, and triggers a refresh only when necessary. This pattern reduces API load and keeps web messaging sessions alive.
Step 4: 401 Credential Rotation and Retry Handling
Production integrations often use multiple OAuth clients for high availability or tenant isolation. When the Genesys API returns a 401 Unauthorized response, the SDK raises an ApiException with status code 401. You catch this exception, rotate to the next client credential pair, reinitialize the API client, and retry the operation. This prevents permanent failures during credential rotation windows or expired tokens.
from typing import List, Callable, Any
class CredentialRotator:
def __init__(self, credentials: List[dict]):
self.credentials = credentials
self.current_index = 0
def rotate(self):
self.current_index = (self.current_index + 1) % len(self.credentials)
creds = self.credentials[self.current_index]
return creds["client_id"], creds["client_secret"]
def safe_api_call(api_call_fn: Callable, rotator: CredentialRotator, max_retries: int = 3) -> Any:
return api_call_fn()
except ApiException as e:
if e.status == 401 and attempt < max_retries - 1:
print(f"401 Unauthorized on attempt {attempt + 1}. Rotating credentials.")
new_client_id, new_secret = rotator.rotate()
# Reinitialize configuration and API client with new credentials
config = build_genesys_configuration()
config.client_id = new_client_id
config.client_secret = new_secret
# Update the API client instance or recreate it in the caller
raise # Caller handles reinitialization
else:
raise
except Exception:
raise
The safe_api_call wrapper catches ApiException, checks the status code, and triggers rotation. In a production module, you would update the Configuration object and recreate the ExternalUsersApi instance inside the caller loop. The 401 response typically indicates an expired or invalid OAuth token, but credential rotation handles cases where the client secret was rotated externally. You must ensure your retry loop does not mask 403 Forbidden or 429 Too Many Requests errors.
The following script combines all components into a runnable module. You must set the environment variables before execution. The script creates or retrieves a guest, manages token expiration with a sliding window, handles credential rotation on 401, and persists mappings in DynamoDB.
import os
import hashlib
import boto3
from genesyscloud.rest import Configuration, ApiException
DYNAMODB_TABLE = "GenesysGuestSessions"
def build_configuration(client_id: str, client_secret: str) -> Configuration:
config.client_id = client_id
config.client_secret = client_secret
return config
class SessionStore:
def __init__(self, table_name: str = DYNAMODB_TABLE):
item = {
"token": token,
except ClientError:
return None
def rotate(self) -> tuple[str, str]:
class GuestTokenManager:
self.rotator = CredentialRotator(credentials)
self.config = build_configuration(*self.rotator.rotate())
self.api_client = ExternalUsersApi(configuration=self.config)
self.store = SessionStore()
def _reinitialize_api(self):
new_id, new_secret = self.rotator.rotate()
self.config = build_configuration(new_id, new_secret)
def ensure_guest(self, crm_id: str) -> str:
existing = self.store.get_session(crm_id_hash)
for attempt in range(3):
response = self.api_client.post_external_users_guests(body=guest_request)
self.store.save_session(crm_id_hash, response.id, "", "")
return response.id
if e.status == 401 and attempt < 2:
self._reinitialize_api()
else:
raise
def get_guest_token(self, crm_id: str) -> str:
guest_id = self.ensure_guest(crm_id)
session = self.store.get_session(crm_id_hash)
response = self.api_client.post_external_users_guests_token(body=token_request)
self.store.save_session(crm_id_hash, guest_id, response.token, response.expires_at)
else:
raise
credentials = [
{"client_id": os.getenv("GENESYS_CLIENT_ID"), "client_secret": os.getenv("GENESYS_CLIENT_SECRET")},
{"client_id": os.getenv("GENESYS_CLIENT_ID_2"), "client_secret": os.getenv("GENESYS_CLIENT_SECRET_2")}
manager = GuestTokenManager(credentials)
token = manager.get_guest_token("CRM-987654")
print(f"Active token: {token[:20]}...")
The module initializes the credential rotator, builds the configuration, and creates the API client. The ensure_guest method handles guest creation with retry logic. The get_guest_token method checks the sliding window, generates a token if necessary, and handles 401 rotations. You run the script with valid environment variables. The DynamoDB table must exist before execution.
- What causes it: The OAuth access token has expired, the client secret was rotated, or the OAuth application lacks the required scopes.
- How to fix it: Verify that your OAuth application has
externaluser:guest:createandexternaluser:guest:readscopes. Ensure the client secret matches the client ID. Implement credential rotation as shown in the complete example. The SDK caches tokens, so restarting the process or reinitializing the configuration forces a new token request. - Code showing the fix: The
_reinitialize_apimethod swaps credentials and recreates theExternalUsersApiinstance. The retry loop catchesApiExceptionwithstatus == 401and triggers rotation.
Error: 403 Forbidden
- What causes it: The OAuth application lacks the required scopes, or the calling user/role does not have permission to create external users.
- How to fix it: Navigate to the Genesys Cloud admin console, open the OAuth application, and add
externaluser:guest:createandexternaluser:guest:readto the allowed scopes. Save the application. Verify that the associated role has External User permissions. - Code showing the fix: No code change is required. Update the OAuth application configuration in the Genesys Cloud portal.
- What causes it: You exceeded the API rate limit for external user operations. Genesys Cloud enforces per-client and per-tenant limits.
- How to fix it: Implement exponential backoff. Cache guest identifiers aggressively. Avoid recreating guests for the same CRM ID. Use the sliding window logic to prevent unnecessary token refresh calls.
- Code showing the fix: Wrap API calls in a retry loop with
time.sleep(2 ** attempt)on 429 responses. The complete example focuses on 401 rotation, but you can extend theexcept ApiExceptionblock to handle 429 similarly.
Error: DynamoDB ConditionalCheckFailedException or ResourceNotFoundException
- What causes it: The DynamoDB table does not exist, or IAM permissions are insufficient.
- How to fix it: Create the table with
crm_id_hashas the partition key. Attach an IAM policy allowingdynamodb:GetItem,dynamodb:PutItem, anddynamodb:DeleteItemto the execution role. Verify that theAWS_REGIONenvironment variable matches the table location.
