Managing Genesys Cloud Web Messaging Guest Connection Lifecycles in TypeScript
- A TypeScript client that establishes a persistent WebSocket connection to Genesys Cloud Web Messaging, automatically recovers from network partitions using exponential backoff with jitter, rotates expired guest tokens via the REST API, and restores conversation state by fetching and replaying message history.
- This implementation interacts directly with the Genesys Cloud v2 Conversational Messaging REST endpoints and the platform WebSocket gateway.
- The tutorial provides a complete, production-ready TypeScript module using native
fetchandWebSocketAPIs with explicit error handling, retry logic, and pagination support.
- OAuth 2.0 client configuration with the following scopes:
webmessaging:guest:send,webmessaging:guest:read,webmessaging:conversation:read - Genesys Cloud API version: v2 (Conversational Messaging surface)
- Runtime: Node.js 18+ or modern browser environment supporting ES2020+
- Dependencies:
uuid(for correlation IDs),@types/node(if running in Node), TypeScript 5.0+ - A provisioned Genesys Cloud environment with Web Messaging enabled and a target queue ID configured
Genesys Cloud Web Messaging guest flows do not require client-side OAuth token exchange. The guest session is initialized through a public REST endpoint that returns a guestToken. This token authenticates all subsequent WebSocket frames and REST requests for the duration of the session. The token expires after a platform-defined window (typically 30 to 60 minutes). The client must cache this token and rotate it before expiration or upon receiving authentication failure signals.
The following helper establishes a base API client that handles headers, environment routing, and explicit 429 retry logic:
const API_BASE = 'https://{environment}.mygen.com/api/v2';
interface ApiClientConfig {
environment: string;
guestToken: string;
class ApiClient {
private baseUrl: string;
private token: string;
constructor(config: ApiClientConfig) {
this.baseUrl = `https://${config.environment}.mygen.com/api/v2`;
this.token = config.guestToken;
async request<T>(endpoint: string, options: RequestInit = {}): Promise<T> {
const url = `${this.baseUrl}${endpoint}`;
const headers = {
'Authorization': `Bearer ${this.token}`,
...options.headers,
let retries = 0;
const maxRetries = 3;
while (retries <= maxRetries) {
const response = await fetch(url, { ...options, headers });
if (response.status === 429) {
const retryAfter = parseInt(response.headers.get('Retry-After') || '1', 10);
console.warn(`Rate limited. Retrying after ${retryAfter}s (attempt ${retries + 1}/${maxRetries})`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
retries++;
continue;
if (!response.ok) {
const errorBody = await response.text();
throw new Error(`API Error ${response.status}: ${errorBody}`);
return response.json() as Promise<T>;
throw new Error('Max retries exceeded for 429 response');
Step 1: Initialize Guest Session and Establish WebSocket Connection
The guest session begins with a POST request to /api/v2/messaging/conversations. The response contains the conversationId and initial guestToken. These values are required to register on the WebSocket gateway.
interface CreateConversationResponse {
guestToken: string;
routing: { selectedQueueId: string };
async function initializeGuestSession(apiClient: ApiClient, queueId: string): Promise<CreateConversationResponse> {
const payload = {
conversationName: 'Web Guest Session',
routing: { selectedQueueId: queueId },
attributes: {
custom: { source: 'typescript-client' }
return apiClient.request<CreateConversationResponse>('/messaging/conversations', {
method: 'POST',
body: JSON.stringify(payload)
function connectWebSocket(environment: string, conversationId: string, guestToken: string): WebSocket {
const wsUrl = `wss://${environment}.mygen.com/ws`;
const socket = new WebSocket(wsUrl);
socket.onopen = () => {
console.log('WebSocket connected. Sending registration frame.');
socket.send(JSON.stringify({
type: 'register',
conversationId,
guestToken
socket.onmessage = (event: MessageEvent) => {
const data = JSON.parse(event.data);
handleWebSocketMessage(data);
socket.onerror = (error) => {
console.error('WebSocket error:', error);
socket.onclose = (event: CloseEvent) => {
console.log(`WebSocket closed with code ${event.code}. Reason: ${event.reason}`);
return socket;
function handleWebSocketMessage(data: Record<string, unknown>) {
const type = data.type as string;
switch (type) {
case 'registered':
console.log('Successfully registered with Web Messaging gateway.');
break;
case 'message':
console.log('Incoming message:', data);
break;
case 'error':
console.error('Gateway error:', data);
break;
default:
console.log('Unhandled message type:', type);
Step 2: Implement Jitter-Based Reconnection Strategy
Network instability requires a deterministic reconnection loop. Pure exponential backoff causes thundering herd problems when many clients reconnect simultaneously. Adding randomized jitter distributes reconnection attempts across time windows.
function calculateBackoffWithJitter(attempt: number, baseDelay: number = 1000): number {
const exponential = Math.min(baseDelay * Math.pow(2, attempt), 30000);
const jitter = Math.random() * exponential;
return exponential + jitter;
async function reconnectWithJitter(
attempt: number,
maxAttempts: number,
onReconnect: () => Promise<void>
): Promise<void> {
if (attempt >= maxAttempts) {
console.error('Max reconnection attempts reached. Aborting.');
return;
const delay = calculateBackoffWithJitter(attempt);
console.log(`Reconnection attempt ${attempt + 1}/${maxAttempts} in ${Math.round(delay)}ms`);
await onReconnect();
} catch (error) {
console.error('Reconnection failed:', error);
reconnectWithJitter(attempt + 1, maxAttempts, onReconnect);
Step 3: Refresh Guest Tokens and Handle Session Expiration
Genesys Cloud invalidates guest tokens after a fixed window. The WebSocket gateway returns a 1008 or 1009 close code, or REST calls return 401. The client must rotate the token via POST /api/v2/messaging/conversations/{id}/guest-tokens and re-register on the active socket.
interface RefreshTokenResponse {
guestToken: string;
async function refreshGuestToken(apiClient: ApiClient, conversationId: string): Promise<string> {
const response = await apiClient.request<RefreshTokenResponse>(
`/messaging/conversations/${conversationId}/guest-tokens`,
{ method: 'POST' }
return response.guestToken;
function reRegisterWebSocket(socket: WebSocket, conversationId: string, newToken: string): void {
if (socket.readyState === WebSocket.OPEN) {
type: 'register',
conversationId,
guestToken: newToken
console.log('Re-registered with refreshed guest token.');
Step 4: Fetch Conversation History and Replay Interrupted State
When a connection drops, messages sent during the outage are not buffered indefinitely on the gateway. The client must retrieve the full message history to restore UI state and acknowledge processed messages. The history endpoint supports pagination via nextPageToken.
interface Message {
type: string;
to: { id: string; name: string };
text: string;
timestamp: string;
interface MessageHistoryResponse {
messages: Message[];
nextPageToken?: string;
async function fetchConversationHistory(apiClient: ApiClient, conversationId: string): Promise<Message[]> {
const allMessages: Message[] = [];
let nextPageToken: string | undefined;
let page = 1;
const limit = 50;
do {
const params = new URLSearchParams({
limit: limit.toString(),
conversationId,
...(nextPageToken ? { nextPageToken } : {})
const response = await apiClient.request<MessageHistoryResponse>(
`/messaging/conversations/${conversationId}/messages?${params.toString()}`
allMessages.push(...response.messages);
nextPageToken = response.nextPageToken;
console.log(`Fetched page ${page} of conversation history (${response.messages.length} messages)`);
page++;
} while (nextPageToken);
return allMessages.sort((a, b) => new Date(a.timestamp).getTime() - new Date(b.timestamp).getTime());
function replayMessageHistory(messages: Message[]): void {
console.log(`Replaying ${messages.length} historical messages to restore state.`);
messages.forEach((msg, index) => {
setTimeout(() => {
console.log(`[History Replay ${index + 1}/${messages.length}] ${msg.from.name}: ${msg.text}`);
}, index * 100);
The following module combines all components into a single, runnable class. It manages connection state, token rotation, history synchronization, and graceful shutdown.
export interface WebMessagingConfig {
queueId: string;
maxReconnectAttempts?: number;
export class GenesysWebMessagingClient {
private apiClient: ApiClient | null = null;
private ws: WebSocket | null = null;
private guestToken: string | null = null;
private conversationId: string | null = null;
private reconnectAttempts = 0;
private maxReconnectAttempts: number;
private isRunning = false;
private tokenExpiryTimer: ReturnType<typeof setTimeout> | null = null;
constructor(private config: WebMessagingConfig) {
this.maxReconnectAttempts = config.maxReconnectAttempts || 10;
async start(): Promise<void> {
this.isRunning = true;
console.log('Initializing Web Messaging guest session...');
const session = await initializeGuestSession(
new ApiClient({ environment: this.config.environment, guestToken: 'placeholder' }),
this.config.queueId
this.conversationId = session.id;
this.guestToken = session.guestToken;
this.apiClient = new ApiClient({
guestToken: this.guestToken
this.setupWebSocket();
this.scheduleTokenRefresh();
console.log(`Session started. Conversation ID: ${this.conversationId}`);
private setupWebSocket(): void {
if (!this.guestToken || !this.conversationId) return;
this.ws = connectWebSocket(this.config.environment, this.conversationId, this.guestToken);
this.ws.onclose = (event) => {
if (!this.isRunning) return;
if (event.code === 1008 || event.code === 1009 || event.code === 4001) {
console.warn('Session expired or invalid. Refreshing token before reconnect.');
this.refreshTokenAndReconnect();
} else {
console.log('Connection dropped. Initiating reconnection strategy.');
reconnectWithJitter(this.reconnectAttempts, this.maxReconnectAttempts, () => this.reconnect());
private async reconnect(): Promise<void> {
this.reconnectAttempts++;
console.log(`Reconnecting (attempt ${this.reconnectAttempts})...`);
if (this.ws?.readyState === WebSocket.OPEN) {
this.ws.close();
if (!this.historySynced) {
await this.syncHistory();
this.historySynced = true;
private async refreshTokenAndReconnect(): Promise<void> {
if (!this.conversationId || !this.apiClient) return;
const newToken = await refreshGuestToken(this.apiClient, this.conversationId);
this.guestToken = newToken;
this.apiClient = new ApiClient({ environment: this.config.environment, guestToken: newToken });
reRegisterWebSocket(this.ws, this.conversationId, newToken);
} catch (error) {
console.error('Token refresh failed:', error);
private async syncHistory(): Promise<void> {
if (!this.apiClient || !this.conversationId) return;
const messages = await fetchConversationHistory(this.apiClient, this.conversationId);
replayMessageHistory(messages);
} catch (error) {
console.error('History sync failed:', error);
private scheduleTokenRefresh(): void {
if (this.tokenExpiryTimer) clearTimeout(this.tokenExpiryTimer);
this.tokenExpiryTimer = setTimeout(() => {
}, 25 * 60 * 1000);
async stop(): Promise<void> {
this.isRunning = false;
this.ws.close(1000, 'Client shutting down');
console.log('Web Messaging client stopped.');
async sendGuestMessage(text: string): Promise<void> {
if (this.ws?.readyState !== WebSocket.OPEN) {
throw new Error('WebSocket is not connected');
this.ws.send(JSON.stringify({
type: 'send',
message: {
text,
attributes: { correlationId: uuidv4() }
console.log('Message queued for delivery.');
private historySynced = false;
Error: HTTP 401 Unauthorized on REST or WebSocket
- Cause: The
guestTokenhas expired or was never properly initialized. Genesys Cloud invalidates tokens after a platform-defined window. - Fix: Intercept
401responses or WebSocket close codes1008/1009. CallPOST /api/v2/messaging/conversations/{id}/guest-tokensto rotate the credential. Update the localApiClientinstance and send a newregisterframe over the active WebSocket. - Code Fix: The
refreshTokenAndReconnect()method in the complete example handles this automatically by catching expiration signals and rotating the token before re-registering.
Error: HTTP 403 Forbidden
- Cause: The OAuth client lacks the required scopes (
webmessaging:guest:send,webmessaging:conversation:read) or the target queue is not provisioned for Web Messaging. - Fix: Verify the application integration in Genesys Cloud Admin > Security > OAuth Clients. Ensure the scopes match the REST endpoints being called. Confirm the queue has Web Messaging enabled and routing rules configured.
- Code Fix: Log the full response body from
fetchto capture the exact scope violation message. Validate queue ID provisioning before session initialization.
- Cause: Excessive REST calls (history fetch, token refresh) or WebSocket registration attempts exceed Genesys Cloud rate limits.
- Fix: Implement exponential backoff with jitter. Parse the
Retry-Afterheader from the response. TheApiClient.request()method already includes a retry loop that respectsRetry-Afterand caps at three attempts. - Code Fix: Ensure pagination requests are spaced appropriately. Avoid polling the history endpoint on every reconnect; cache results and only fetch when state divergence is detected.
Error: WebSocket Close Code 1006 (Abnormal Closure)
- Cause: Network partition, proxy interference, or TLS termination failure. The gateway did not send a proper close frame.
- Fix: Treat this as a transient network error. Trigger the jitter-based reconnection loop immediately. Verify firewall rules allow outbound connections to
*.mygen.com:443. - Code Fix: The
ws.onclosehandler distinguishes between authentication failures and network drops, routing1006directly toreconnectWithJitter().
Error: Missing nextPageToken in History Response
- Cause: The conversation contains fewer messages than the requested
limit, or the API version does not support pagination for that specific query. - Fix: Always check for the presence of
nextPageTokenbefore continuing the pagination loop. ThefetchConversationHistoryfunction uses ado...whileloop that terminates when the token is undefined. - Code Fix: Add defensive null checks on
response.nextPageToken. Log pagination boundaries to verify complete history retrieval.
