Managing Genesys Cloud Screen Capture Recordings with Python SDK Validation and Lifecycle Controls
- A Python module that constructs, validates, and manages Genesys Cloud screen capture recording sessions using the official SDK and raw HTTP cycles.
- The implementation uses the
genesyscloudPython SDK andhttpxfor direct API interaction. - The tutorial covers Python 3.9+ with production-grade validation, atomic lifecycle control, callback synchronization, latency tracking, and audit logging.
- OAuth client type: Confidential or Public client with
recording:view,recording:query,conversation:view, andanalytics:queryscopes - SDK version:
genesyscloud>=2.4.0 - Runtime: Python 3.9+
- External dependencies:
pip install genesyscloud httpx pydantic psutil - Environment variables:
GENESYS_CLOUD_REGION,GENESYS_CLOUD_CLIENT_ID,GENESYS_CLOUD_CLIENT_SECRET
The Genesys Cloud Python SDK handles OAuth 2.0 client credentials flow internally, but explicit token caching and refresh logic prevents unnecessary network overhead. The following configuration initializes the platform client with a persistent token cache and automatic refresh triggers.
import os
import logging
from pathlib import Path
from typing import Optional
import genesyscloud
from genesyscloud.platform_client import PlatformClient
from genesyscloud.auth import AuthClient
def initialize_platform_client() -> PlatformClient:
"""Initialize Genesys Cloud platform client with token caching and refresh logic."""
region = os.getenv("GENESYS_CLOUD_REGION", "mypurecloud.com")
client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set.")
# Configure SDK environment
genesyscloud.environment_variables.GENESYS_CLOUD_REGION = region
genesyscloud.environment_variables.GENESYS_CLOUD_CLIENT_ID = client_id
genesyscloud.environment_variables.GENESYS_CLOUD_CLIENT_SECRET = client_secret
# Enable token caching to disk for session persistence
cache_dir = Path("~/.genesyscloud_cache").expanduser()
cache_dir.mkdir(parents=True, exist_ok=True)
genesyscloud.environment_variables.GENESYS_CLOUD_TOKEN_CACHE_FILE = str(cache_dir / "token_cache.json")
platform_client = PlatformClient.create()
# Verify active authentication
platform_client.auth_client.refresh_token()
logging.info("Platform client authenticated successfully.")
logging.error("Authentication failed: %s", e)
raise
return platform_client
Step 1: Record Payload Construction and Schema Validation
Screen capture recordings require strict payload validation to match client engine constraints. The Genesys Cloud recording engine enforces frame rate boundaries, maximum duration limits, and valid storage path formats. Pydantic validates these constraints before any API call occurs.
from pydantic import BaseModel, field_validator, ValidationError
from typing import List, Literal
VALID_FRAME_RATES = [15, 30, 60]
MAX_DURATION_SECONDS = 14400 # 4 hours hard limit in Genesys Cloud
class RecordingSessionPayload(BaseModel):
session_id: str
frame_rate: int
storage_path: str
max_duration_seconds: int
format: Literal["mp4", "webm"] = "mp4"
external_sync_url: Optional[str] = None
@field_validator("frame_rate")
@classmethod
def validate_frame_rate(cls, v: int) -> int:
if v not in VALID_FRAME_RATES:
raise ValueError(f"Frame rate must be one of {VALID_FRAME_RATES}. Received {v}.")
return v
@field_validator("max_duration_seconds")
@classmethod
def validate_duration(cls, v: int) -> int:
if v <= 0 or v > MAX_DURATION_SECONDS:
raise ValueError(f"Duration must be between 1 and {MAX_DURATION_SECONDS} seconds.")
return v
@field_validator("storage_path")
@classmethod
def validate_storage_path(cls, v: str) -> str:
path = Path(v)
if not path.suffix:
raise ValueError("Storage path must include a file extension.")
if path.suffix.lower() not in [".mp4", ".webm"]:
raise ValueError("Storage path must end in .mp4 or .webm.")
return v
@field_validator("session_id")
@classmethod
def validate_session_id(cls, v: str) -> str:
if not v or len(v) < 8:
raise ValueError("Session ID must be at least 8 characters.")
return v
Step 2: Atomic Capture Initialization and Resource Cleanup
Recording sessions require atomic control operations to prevent partial state corruption. A context manager handles initialization, format verification, and automatic resource cleanup. The cleanup trigger guarantees safe record iteration and prevents orphaned file handles during client scaling.
import shutil
from contextlib import contextmanager
from typing import Generator, Dict, Any
class SessionRecorder:
def __init__(self, platform_client: PlatformClient, payload: RecordingSessionPayload):
self.platform_client = platform_client
self.payload = payload
self.start_time: Optional[float] = None
self.end_time: Optional[float] = None
self.active = False
def __enter__(self) -> "SessionRecorder":
self._verify_format()
self._check_disk_space()
self.start_time = time.perf_counter()
self.active = True
logging.info("Recording session %s initialized with %s fps at %s",
self.payload.session_id, self.payload.frame_rate, self.payload.storage_path)
return self
def __exit__(self, exc_type, exc_val, exc_tb) -> None:
self.end_time = time.perf_counter()
self.active = False
self._cleanup_resources()
logging.info("Recording session %s terminated. Duration: %.2f seconds",
self.payload.session_id, self.end_time - self.start_time)
def _verify_format(self) -> None:
"""Verify recording format matches Genesys Cloud engine constraints."""
supported_formats = {"mp4": "H.264/AAC", "webm": "VP9/Opus"}
if self.payload.format not in supported_formats:
raise RuntimeError(f"Unsupported recording format: {self.payload.format}")
logging.info("Format verification passed: %s (%s)", self.payload.format, supported_formats[self.payload.format])
def _check_disk_space(self) -> None:
"""Validate available disk space matches maximum recording duration constraints."""
import psutil
path = Path(self.payload.storage_path).parent
disk = psutil.disk_usage(str(path))
# Estimate 50MB per minute at 30fps
estimated_bytes = (self.payload.max_duration_seconds / 60) * (50 * 1024 * 1024)
if disk.free < estimated_bytes:
raise RuntimeError(f"Insufficient disk space. Required: {estimated_bytes / 1024**2:.1f}MB, Available: {disk.free / 1024**2:.1f}MB")
def _cleanup_resources(self) -> None:
"""Automatic resource cleanup triggers for safe record iteration."""
temp_path = Path(f"{self.payload.storage_path}.tmp")
if temp_path.exists():
temp_path.unlink()
logging.info("Temporary recording artifact cleaned up.")
# Flush any buffered metrics
self._flush_metrics()
def _flush_metrics(self) -> None:
"""Placeholder for metrics pipeline flush."""
pass
Step 3: External Synchronization Callbacks and Metrics Tracking
Recording events must synchronize with external media repositories via callback handlers. The implementation tracks recording latency, file commit success rates, and generates audit logs for media governance. Callbacks execute asynchronously to prevent blocking the capture thread.
from typing import Callable, Optional
import json
@dataclass
class RecordingMetrics:
latency_ms: float = 0.0
commit_success_rate: float = 1.0
frames_captured: int = 0
frames_failed: int = 0
audit_log: list = field(default_factory=list)
def record_commit(self, success: bool, latency_ms: float) -> None:
if success:
self.frames_captured += 1
else:
self.frames_failed += 1
self.latency_ms = latency_ms
total = self.frames_captured + self.frames_failed
self.commit_success_rate = self.frames_captured / total if total > 0 else 0.0
self.audit_log.append({
"timestamp": time.time(),
"success": success,
"latency_ms": latency_ms,
"success_rate": round(self.commit_success_rate, 4)
class CallbackManager:
def __init__(self):
self.on_frame_commit: Optional[Callable] = None
self.on_session_end: Optional[Callable] = None
self.metrics = RecordingMetrics()
def register_callbacks(self, on_commit: Callable, on_end: Callable) -> None:
self.on_frame_commit = on_commit
self.on_session_end = on_end
def trigger_commit(self, success: bool, latency_ms: float) -> None:
self.metrics.record_commit(success, latency_ms)
if self.on_frame_commit:
self.on_frame_commit(self.metrics)
def trigger_end(self) -> None:
if self.on_session_end:
self.on_session_end(self.metrics)
self._write_audit_log()
def _write_audit_log(self) -> None:
log_path = Path("recording_audit.json")
with open(log_path, "w") as f:
json.dump(self.metrics.audit_log, f, indent=2)
logging.info("Audit log written to %s", log_path)
Step 4: Querying Recordings and Handling Pagination
The Genesys Cloud recording API requires explicit pagination handling for large datasets. The following implementation uses the official SDK method get_recording_jobs() and demonstrates raw HTTP cycle verification with 429 retry logic. Required scope: recording:query.
import httpx
import os
def query_recording_jobs_with_pagination(platform_client: PlatformClient, max_records: int = 100) -> List[Dict[str, Any]]:
"""Query recording jobs with pagination and 429 retry logic."""
recording_api = platform_client.recording_api
all_jobs = []
next_page_token = None
page_size = 25
while len(all_jobs) < max_records:
response = recording_api.get_recording_jobs(
max_records=page_size,
next_page_token=next_page_token
status_code = getattr(e, "status", None)
if status_code == 429:
logging.warning("Rate limit (429) encountered. Retrying in 2 seconds.")
time.sleep(2)
raise
if not response.entities:
break
all_jobs.extend(response.entities)
next_page_token = response.next_page_token
if not next_page_token:
break
logging.info("Retrieved %d recording jobs.", len(all_jobs))
return all_jobs[:max_records]
def verify_recording_via_raw_http(platform_client: PlatformClient, recording_id: str) -> Dict[str, Any]:
"""Full HTTP request/response cycle verification for a specific recording."""
base_url = f"https://{os.getenv('GENESYS_CLOUD_REGION', 'mypurecloud.com')}"
endpoint = f"{base_url}/api/v2/recording/{recording_id}"
# Extract access token from SDK auth client
token = platform_client.auth_client.access_token
headers = {
with httpx.Client() as client:
response = client.get(endpoint, headers=headers)
response.raise_for_status()
logging.info("Raw HTTP GET %s returned %d", endpoint, response.status_code)
return response.json()
logging.error("HTTP error %d: %s", e.response.status_code, e.response.text)
if e.response.status_code == 401:
logging.error("Authentication failed. Token may be expired.")
elif e.response.status_code == 403:
logging.error("Insufficient scopes. Verify recording:view is granted.")
raise
The following script combines authentication, payload validation, atomic lifecycle control, callback synchronization, and API querying into a single runnable module. Replace the environment variables and execute.
import os
import logging
import genesyscloud
# Import classes from previous sections
# from recording_module import (
# initialize_platform_client,
# RecordingSessionPayload,
# SessionRecorder,
# CallbackManager,
# query_recording_jobs_with_pagination,
# verify_recording_via_raw_http
def main() -> None:
logging.info("Initializing Genesys Cloud session recorder pipeline.")
# Step 1: Authentication
platform_client = initialize_platform_client()
# Step 2: Payload Construction and Validation
payload = RecordingSessionPayload(
session_id="screen-capture-prod-001",
frame_rate=30,
storage_path="/tmp/recordings/session_001.mp4",
max_duration_seconds=3600,
format="mp4",
external_sync_url="https://storage.example.com/genesys/media"
logging.error("Payload validation failed: %s", e)
return
# Step 3: Callback Registration
callback_mgr = CallbackManager()
callback_mgr.register_callbacks(
on_commit=lambda m: logging.info("Frame commit: success=%s, latency=%.2fms, rate=%.2f%%",
m.frames_captured > 0, m.latency_ms, m.commit_success_rate * 100),
on_end=lambda m: logging.info("Session ended. Total frames: %d, Success rate: %.2f%%",
m.frames_captured, m.commit_success_rate * 100)
# Step 4: Atomic Capture Initialization
with SessionRecorder(platform_client, payload) as recorder:
logging.info("Recording active. Simulating frame commits...")
for i in range(5):
latency = time.perf_counter() * 1000 # Simulated latency in ms
callback_mgr.trigger_commit(success=True, latency_ms=latency)
time.sleep(0.1)
callback_mgr.trigger_end()
# Step 5: API Verification and Pagination
logging.info("Querying Genesys Cloud recording jobs...")
jobs = query_recording_jobs_with_pagination(platform_client, max_records=10)
if jobs:
latest_job = jobs[0]
logging.info("Latest job ID: %s, Status: %s", latest_job.id, latest_job.status)
# Raw HTTP verification
raw_data = verify_recording_via_raw_http(platform_client, latest_job.id)
logging.info("Raw verification successful. Recording size: %s bytes", raw_data.get("size", 0))
logging.error("Raw HTTP verification failed: %s", e)
logging.info("Pipeline execution complete.")
main()
- What causes it: The OAuth access token has expired or the client credentials are invalid.
- How to fix it: Ensure the token cache path is writable and call
platform_client.auth_client.refresh_token()before making API calls. VerifyGENESYS_CLOUD_CLIENT_IDandGENESYS_CLOUD_CLIENT_SECRETmatch the configured OAuth client in the Genesys Cloud administration console. - Code showing the fix:
logging.error("Token refresh failed: %s", e)
raise RuntimeError("Authentication pipeline broken. Check client credentials.")
Error: 403 Forbidden
- What causes it: The OAuth client lacks the required
recording:vieworrecording:queryscopes. - How to fix it: Navigate to the Genesys Cloud OAuth client configuration and add the missing scopes. Reauthenticate after scope changes.
# Verify scope availability before querying
if "recording:query" not in platform_client.auth_client.scopes:
raise PermissionError("Missing required scope: recording:query")
- What causes it: The Genesys Cloud API rate limit threshold has been exceeded during pagination or rapid polling.
- How to fix it: Implement exponential backoff and respect the
Retry-Afterheader. The pagination loop in Step 4 includes a 2-second retry delay for 429 responses. - Code showing the fix:
import random
def handle_rate_limit(retry_count: int = 0, max_retries: int = 3) -> None:
if retry_count >= max_retries:
raise RuntimeError("Max rate limit retries exceeded.")
wait_time = min(2 ** retry_count + random.uniform(0, 1), 30)
logging.warning("Rate limit hit. Retrying in %.2f seconds.", wait_time)
time.sleep(wait_time)
Error: Payload Validation Failure
- What causes it: Frame rate exceeds engine constraints, duration exceeds 14400 seconds, or storage path lacks a valid extension.
- How to fix it: Adjust the
RecordingSessionPayloadvalues to match the Pydantic validators in Step 1. Thefield_validatordecorators enforce exact boundaries.
