Managing Genesys Cloud phone number assignments via Routing API with Go by constructing assignment payloads with phone number ID references, feature type matrices, and routing destination directives, validating assignment schemas against telephony infrastructure constraints and maximum feature count limits to prevent assignment failure, handling assignment update via atomic PUT operations with format verification and automatic carrier provisioning triggers for safe assignment iteration, implementing assignment validation logic using number format checking and feature compatibility verification pipelines to ensure reliable connectivity and prevent service disruption during Routing scaling, synchronizing assignment events with external telecom management platforms via webhook callbacks for alignment, tracking assignment latency and feature activation rates for telephony efficiency, generating assignment audit logs for infrastructure governance, and exposing a number manager for automated Routing management
A production-grade Go module that constructs, validates, and atomically updates phone number assignment payloads in Genesys Cloud, tracks activation latency, generates structured audit logs, and synchronizes state with external telecom platforms via webhook callbacks. This tutorial uses the Genesys Cloud Telephony Numbers API (/api/v2/telephony/providers/edges/{edgeId}/numbers/{numberId}/assignments) through the official Go SDK. The implementation is written in Go 1.21+.
- OAuth Client Credentials flow configured in Genesys Cloud Admin Console
- Required scopes:
telephony:edge:write,telephony:edge:read - Go runtime version 1.21 or higher
- SDK dependency:
github.com/myapps/go-platform-client/platformclientv2 - Standard library packages:
encoding/json,fmt,log,net/http,regexp,sync,time,github.com/google/uuid
Genesys Cloud requires a bearer token for all API calls. The Go SDK provides an authclient package that handles the OAuth 2.0 client credentials flow, token caching, and automatic refresh. You must initialize the authentication client before creating the API client.
package main
import (
"context"
"fmt"
"log"
"github.com/myapps/go-platform-client/platformclientv2"
"github.com/myapps/go-platform-client/platformclientv2/authclient"
func initializeGenesysClient(envURL, clientId, clientSecret string) (*platformclientv2.ApiClient, error) {
auth, err := authclient.NewClient(context.Background(), envURL, clientId, clientSecret)
if err != nil {
return nil, fmt.Errorf("failed to initialize auth client: %w", err)
apiClient := platformclientv2.NewApiClient()
apiClient.SetAuthClient(auth)
return apiClient, nil
The authclient manages token expiration silently. If the underlying OAuth endpoint returns a 401 Unauthorized, the SDK automatically requests a new token before retrying the original call. You do not need to implement manual token caching.
Step 1: Initialize the Genesys Cloud Client & Validate Infrastructure Constraints
Before constructing assignment payloads, you must validate the phone number format and verify feature compatibility against Genesys telephony infrastructure rules. Genesys restricts certain feature combinations. For example, sms and fax cannot be assigned to the same number in most regions. The maximum number of active features per assignment is four.
import (
"fmt"
"regexp"
"strings"
type AssignmentValidation struct {
PhoneNumber string
Features []string
EdgeID string
NumberID string
var e164Regex = regexp.MustCompile(`^\+[1-9]\d{1,14}$`)
func validateAssignmentSchema(schema AssignmentValidation) error {
if !e164Regex.MatchString(schema.PhoneNumber) {
return fmt.Errorf("phone number %q does not match E.164 format", schema.PhoneNumber)
if len(schema.Features) == 0 {
return fmt.Errorf("assignment requires at least one feature type")
if len(schema.Features) > 4 {
return fmt.Errorf("maximum feature count exceeded: %d (limit is 4)", len(schema.Features))
featureSet := make(map[string]bool)
for _, f := range schema.Features {
featureSet[strings.ToLower(f)] = true
if featureSet["sms"] && featureSet["fax"] {
return fmt.Errorf("feature conflict: sms and fax cannot be assigned to the same number")
if featureSet["sms"] && featureSet["voice"] && featureSet["fax"] {
return fmt.Errorf("feature conflict: triple feature assignment (voice, sms, fax) is unsupported")
return nil
This validation pipeline prevents 400 Bad Request responses caused by carrier provisioning rules. The SDK will reject malformed payloads before they reach the Genesys edge servers.
Step 2: Construct Assignment Payloads with Feature Matrices & Routing Directives
Assignments require a routing destination that dictates where inbound traffic flows. You must reference the destination type (queue, agent, user, or ivr) and provide the corresponding entity ID. The SDK struct platformclientv2.Telephonyedgeassignment maps directly to the API schema.
import (
func buildAssignmentPayload(schema AssignmentValidation, destinationType, destinationID string) (*platformclientv2.Telephonyedgeassignment, error) {
if err := validateAssignmentSchema(schema); err != nil {
return nil, err
routingDest := &platformclientv2.Telephonyedgeassignmentroutingdestination{
Type: platformclientv2.PtrString(destinationType),
assignment := &platformclientv2.Telephonyedgeassignment{
EdgeId: platformclientv2.PtrString(schema.EdgeID),
NumberId: platformclientv2.PtrString(schema.NumberID),
Features: &schema.Features,
RoutingDestination: routingDest,
return assignment, nil
The routing destination must exist in your Genesys environment before assignment. If you reference a non-existent queue or agent ID, the API returns a 404 Not Found. Always verify destination IDs via the Routing API (/api/v2/routing/queues/{id} or /api/v2/users/{id}) before constructing the payload.
Step 3: Execute Atomic PUT Operations with Retry & Latency Tracking
Assignment updates are atomic. Genesys Cloud processes the entire payload in a single transaction. If any feature fails carrier provisioning, the entire assignment rolls back. You must implement exponential backoff for 429 Too Many Requests responses and track latency for telephony efficiency metrics.
import (
"fmt"
"net/http"
"time"
type AssignmentResult struct {
Success bool
LatencyMs float64
AuditPayload map[string]interface{}
func updateAssignment(client *platformclientv2.ApiClient, assignment *platformclientv2.Telephonyedgeassignment, assignmentID string) (*AssignmentResult, error) {
telephonyAPI := platformclientv2.NewTelephonyedgeassignmentApi(client)
startTime := time.Now()
var lastErr error
var resp *http.Response
// Exponential backoff for 429 rate limits
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
result, httpResp, err := telephonyAPI.UpdateTelephonyedgeassignment(
assignment.GetEdgeId(),
assignment.GetNumberId(),
assignmentID,
*assignment,
resp = httpResp
if err != nil {
lastErr = err
if httpResp != nil && httpResp.StatusCode == http.StatusTooManyRequests {
waitTime := time.Duration(1<<uint(attempt)) * time.Second
time.Sleep(waitTime)
return &AssignmentResult{Success: false, LatencyMs: float64(time.Since(startTime).Milliseconds()), AuditPayload: nil}, fmt.Errorf("assignment update failed: %w", err)
latency := time.Since(startTime).Milliseconds()
Success: true,
LatencyMs: float64(latency),
AuditPayload: map[string]interface{}{
"assignment_id": assignmentID,
"number_id": assignment.GetNumberId(),
"features": assignment.GetFeatures(),
"destination": assignment.GetRoutingDestination().GetType(),
"latency_ms": latency,
"status": "activated",
}, nil
return &AssignmentResult{Success: false, LatencyMs: float64(time.Since(startTime).Milliseconds())}, fmt.Errorf("max retries exceeded: %v", lastErr)
The UpdateTelephonyedgeassignment method executes a PUT request to /api/v2/telephony/providers/edges/{edgeId}/numbers/{numberId}/assignments/{assignmentId}. The SDK automatically serializes the struct to JSON. The retry loop handles rate-limit cascades without blocking your main goroutine pool.
Full HTTP Request/Response Cycle
The SDK abstracts the HTTP layer, but understanding the raw cycle is critical for debugging. Below is the exact request and response structure.
Request:
PUT /api/v2/telephony/providers/edges/5f8a2b1c-4d3e-4a1b-9c7d-8e6f5a4b3c2d/numbers/14155552671/assignments/7a9b8c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d HTTP/1.1
Host: myorg.mygen.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
"edgeId": "5f8a2b1c-4d3e-4a1b-9c7d-8e6f5a4b3c2d",
"numberId": "14155552671",
"features": ["voice", "sms"],
"routingDestination": {
"type": "queue",
"id": "2c3d4e5f-6a7b-8c9d-0e1f-2a3b4c5d6e7f"
Response (200 OK):
HTTP/1.1 200 OK
X-Request-Id: req_8f7e6d5c4b3a2910
"id": "7a9b8c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d",
"type": "queue",
"selfUri": "/api/v2/telephony/providers/edges/5f8a2b1c-4d3e-4a1b-9c7d-8e6f5a4b3c2d/numbers/14155552671/assignments/7a9b8c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d"
Step 4: Synchronize Events, Track Activation Rates & Generate Audit Logs
After successful assignment, you must notify external telecom management platforms and record infrastructure governance data. The webhook callback payload must include feature activation metrics and latency benchmarks.
import (
"bytes"
"encoding/json"
"fmt"
"net/http"
"sync"
type NumberManager struct {
webhookURL string
activationCounter int64
mu sync.Mutex
func NewNumberManager(apiClient *platformclientv2.ApiClient, webhookURL string) *NumberManager {
return &NumberManager{
client: apiClient,
webhookURL: webhookURL,
func (nm *NumberManager) ProcessAssignment(schema AssignmentValidation, assignmentID, destType, destID string) error {
payload, err := buildAssignmentPayload(schema, destType, destID)
if err != nil {
return fmt.Errorf("payload construction failed: %w", err)
result, err := updateAssignment(nm.client, payload, assignmentID)
if err != nil {
return fmt.Errorf("atomic update failed: %w", err)
nm.mu.Lock()
nm.activationCounter++
currentRate := float64(nm.activationCounter) / float64(time.Now().Unix())
nm.mu.Unlock()
auditLog := map[string]interface{}{
"timestamp": time.Now().UTC().Format(time.RFC3339),
"number": schema.PhoneNumber,
"latency_ms": result.LatencyMs,
"activation_rate": currentRate,
"features_activated": len(*payload.Features),
"governance_status": "compliant",
if err := nm.syncWebhook(auditLog); err != nil {
log.Printf("warning: webhook sync failed: %v", err)
log.Printf("audit: %s", toJSON(auditLog))
return nil
func (nm *NumberManager) syncWebhook(payload map[string]interface{}) error {
jsonBody, err := json.Marshal(payload)
if err != nil {
return err
req, err := http.NewRequest(http.MethodPost, nm.webhookURL, bytes.NewBuffer(jsonBody))
if err != nil {
return err
req.Header.Set("X-Genesys-Event", "assignment.activated")
resp, err := client.Do(req)
if err != nil {
return err
defer resp.Body.Close()
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook returned status %d", resp.StatusCode)
return nil
func toJSON(v interface{}) string {
b, _ := json.Marshal(v)
return string(b)
The NumberManager encapsulates assignment lifecycle management. It tracks feature activation rates per second, calculates latency, and pushes structured audit logs to your external webhook endpoint. The sync.Mutex prevents race conditions during concurrent assignment processing.
The following script demonstrates the full workflow from authentication to webhook synchronization. Replace the placeholder credentials with your OAuth client details.
package main
import (
"log"
"os"
func main() {
envURL := os.Getenv("GENESYS_ENV_URL")
clientID := os.Getenv("GENESYS_CLIENT_ID")
clientSecret := os.Getenv("GENESYS_CLIENT_SECRET")
webhookURL := os.Getenv("TELECOM_WEBHOOK_URL")
if envURL == "" || clientID == "" || clientSecret == "" {
log.Fatal("GENESYS_ENV_URL, GENESYS_CLIENT_ID, and GENESYS_CLIENT_SECRET must be set")
auth, err := authclient.NewClient(context.Background(), envURL, clientID, clientSecret)
if err != nil {
log.Fatalf("auth initialization failed: %v", err)
manager := NewNumberManager(apiClient, webhookURL)
schema := AssignmentValidation{
PhoneNumber: "+14155552671",
Features: []string{"voice", "sms"},
EdgeID: "5f8a2b1c-4d3e-4a1b-9c7d-8e6f5a4b3c2d",
NumberID: "14155552671",
err = manager.ProcessAssignment(schema, "7a9b8c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d", "queue", "2c3d4e5f-6a7b-8c9d-0e1f-2a3b4c5d6e7f")
if err != nil {
log.Fatalf("assignment processing failed: %v", err)
log.Println("assignment synchronized and audited successfully")
Run the script with go run main.go. The program validates the payload, executes the atomic PUT, tracks latency, increments the activation counter, and POSTs the audit record to your webhook endpoint.
Error: 400 Bad Request - Feature Matrix Conflict
What causes it: The payload contains incompatible features (e.g., sms and fax on the same number) or exceeds the maximum feature count of four.
How to fix it: Review the validateAssignmentSchema function output. Remove conflicting features or split the assignment across multiple numbers.
Code showing the fix:
log.Printf("schema validation failed: %v", err)
// Adjust features before retry
schema.Features = []string{"voice"}
Error: 403 Forbidden - Insufficient Scopes
What causes it: The OAuth token lacks telephony:edge:write or telephony:edge:read permissions.
How to fix it: Update the OAuth client configuration in Genesys Admin Console under Security > OAuth > Clients. Regenerate the token.
if err != nil {
log.Fatalf("scope mismatch or invalid credentials: %v", err)
Error: 429 Too Many Requests - Rate Limit Cascade
What causes it: The assignment endpoint enforces a strict request quota per edge. Burst traffic triggers throttling.
How to fix it: The updateAssignment function implements exponential backoff. Ensure your goroutine pool does not exceed 10 concurrent assignment requests per second.
Error: 404 Not Found - Invalid Routing Destination
What causes it: The routingDestination.id references a queue, agent, or IVR that does not exist in the Genesys environment.
How to fix it: Query the Routing API first to verify the destination ID exists.
queueAPI := platformclientv2.NewQueueApi(client)
_, resp, err := queueAPI.GetQueue(destinationID)
if err != nil || resp.StatusCode == http.StatusNotFound {
return fmt.Errorf("routing destination %s does not exist", destinationID)
