Managing Dynamic Do-Not-Call Lists in NICE CXone Outbound with Node.js
  • A Node.js service that receives internal opt-out webhooks, normalizes phone numbers to E.164, deduplicates them in a Redis sorted set, and pushes batched updates to the CXone Outbound DNC API with automatic conflict resolution.
  • This tutorial uses the CXone Event Subscription API, the CXone Outbound DNC API, and the Redis client library.
  • The implementation covers JavaScript (Node.js) with async/await, Redis, axios, and libphonenumber-js.
  • CXone OAuth client credentials with scopes: outbound:dnc:write, event-subscriptions:read, event-subscriptions:write
  • CXone API version: v2
  • Node.js 18+ and npm
  • External dependencies: axios, redis, libphonenumber-js, express
  • Redis instance (local or managed) accessible on port 6379
  • A CXone Outbound DNC List ID to receive the contacts
CXone uses OAuth 2.0 client credentials flow. You must cache the access token and refresh it before expiration to avoid 401 errors during batch operations. The token endpoint requires the client_id, client_secret, and grant_type=client_credentials.
const CXONE_BASE_URL = process.env.CXONE_BASE_URL; // e.g., https://org123.my.cxone.com
const CLIENT_ID = process.env.CXONE_CLIENT_ID;
const CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET;
let cachedToken = null;
let tokenExpiry = 0;
async function getCXoneToken() {
  const now = Date.now();
  if (cachedToken && now < tokenExpiry - 60000) {
    return cachedToken;
    const response = await axios.post(`${CXONE_BASE_URL}/api/v2/oauth/token`, null, {
      params: {
        client_id: CLIENT_ID,
        client_secret: CLIENT_SECRET
    cachedToken = response.data.access_token;
    tokenExpiry = now + (response.data.expires_in * 1000);
    return cachedToken;
  } catch (error) {
    if (error.response && error.response.status === 401) {
      throw new Error('OAuth authentication failed. Verify client_id and client_secret.');
    throw error;
// Required OAuth scope for all subsequent DNC operations: outbound:dnc:write
The token caching logic checks the expiration timestamp and subtracts a sixty second buffer. This prevents race conditions where multiple batch workers request tokens simultaneously. The function throws a descriptive error on 401 responses instead of bubbling raw axios errors.
Step 1: Webhook Listener & Event Subscription Registration
CXone delivers opt-out events via HTTP POST to a registered callback URL. You must first register the subscription using the Event Subscription API, then expose an Express endpoint to receive payloads.
const express = require('express');
const app = express();
app.use(express.json());
// Register subscription via CXone API (run once during setup or via CLI)
async function registerWebhookSubscription(callbackUrl) {
  const token = await getCXoneToken();
  const response = await axios.post(`${CXONE_BASE_URL}/api/v2/event-subscriptions`, {
    eventTypes: ['contact.opt_out', 'contact.do_not_call.add'],
    callbackUrl: callbackUrl,
    enabled: true,
    retryPolicy: { maxRetries: 3, interval: 60 }
    headers: {
      'Content-Type': 'application/json'
  console.log('Subscription registered:', response.data.id);
// Webhook receiver
app.post('/webhook/opt-out', async (req, res) => {
    const payload = req.body;
    // CXone event payload structure varies by event type
    const phoneNumber = payload.data?.phoneNumber || payload.data?.contact?.phoneNumber;
    if (!phoneNumber) {
      return res.status(400).json({ error: 'Missing phoneNumber in event payload' });
    await processOptOutEvent(phoneNumber);
    res.status(200).json({ status: 'accepted' });
  } catch (error) {
    console.error('Webhook processing failed:', error.message);
    res.status(500).json({ error: 'Internal processing error' });
// Required OAuth scope for subscription registration: event-subscriptions:write
The endpoint returns a 200 response immediately to prevent CXone from retrying the delivery. The actual DNC processing happens asynchronously to avoid blocking the webhook thread. The processOptOutEvent function bridges the webhook payload to the normalization and deduplication pipeline.
Step 2: E.164 Formatting & Redis Sorted Set Deduplication
Phone numbers arrive in inconsistent formats. The libphonenumber-js library normalizes them to E.164. Redis sorted sets provide O(log N) deduplication and batch retrieval using timestamps as scores.
const { parsePhoneNumberFromString } = require('libphonenumber-js');
const { createClient } = require('redis');
const redisClient = createClient({ url: process.env.REDIS_URL || 'redis://localhost:6379' });
redisClient.on('error', (err) => console.error('Redis Client Error:', err));
await redisClient.connect();
const DNC_REDIS_KEY = 'dnc:pending:batch';
const BATCH_SIZE = 50;
async function processOptOutEvent(rawPhone) {
  let e164Number;
    // Assumes US region by default. Adjust region parameter based on your data source.
    const parsed = parsePhoneNumberFromString(rawPhone, 'US');
    if (!parsed || !parsed.isValid()) {
      console.warn('Invalid phone number skipped:', rawPhone);
      return;
    e164Number = parsed.format('E.164');
  } catch (error) {
    console.error('Phone parsing failed:', error.message);
    return;
  // ZADD with current timestamp as score. Redis automatically overwrites duplicates with the new score.
  const timestamp = Date.now();
  await redisClient.zAdd(DNC_REDIS_KEY, { score: timestamp, value: e164Number });
  console.log(`Number ${e164Number} added to deduplication queue with score ${timestamp}`);
The sorted set uses the current millisecond timestamp as the score. When a duplicate number arrives, ZADD updates the score to the latest timestamp. This ensures the most recent opt-out event dictates the processing order. The batch processor will always fetch the oldest entries first, maintaining FIFO semantics while guaranteeing deduplication.
Step 3: Batched DNC API Push with Conflict Resolution
CXone Outbound DNC API accepts batch updates via POST /api/v2/outbound/dnc-lists/{listId}/contacts. The endpoint returns 201 for new records, 200 for updates, and 409 for conflicts. You must implement retry logic for 429 rate limits and explicit conflict resolution for 409 responses.
const DNC_LIST_ID = process.env.CXONE_DNC_LIST_ID;
async function pushBatchToCXone(batchNumbers) {
  if (batchNumbers.length === 0) return;
  const payload = {
    contacts: batchNumbers.map(num => ({
      phoneNumber: num,
      reason: 'webhook_opt_out',
      source: 'internal_system'
      `${CXONE_BASE_URL}/api/v2/outbound/dnc-lists/${DNC_LIST_ID}/contacts`,
      payload,
        headers: {
          'X-CXone-Version': '2023-10-01'
        timeout: 15000
    console.log(`Successfully processed ${response.data.count} contacts`);
    return response.data;
  } catch (error) {
    if (error.response && error.response.status === 429) {
      const retryAfter = error.response.headers['retry-after'] || 5;
      console.warn(`Rate limited. Retrying in ${retryAfter} seconds...`);
      await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
      return pushBatchToCXone(batchNumbers);
    if (error.response && error.response.status === 409) {
      return resolveConflicts(token, batchNumbers, error.response.data);
    throw error;
async function resolveConflicts(token, batchNumbers, conflictResponse) {
  // CXone returns conflicting contact IDs in the error payload
  const conflictingIds = conflictResponse?.conflicts?.map(c => c.contactId) || [];
  const nonConflicting = batchNumbers.filter(num => !conflictingIds.includes(num));
  if (nonConflicting.length > 0) {
    await pushBatchToCXone(nonConflicting);
  // For conflicts, attempt targeted upsert using PUT endpoint
  for (const num of conflictingIds) {
      await axios.put(
        `${CXONE_BASE_URL}/api/v2/outbound/dnc-lists/${DNC_LIST_ID}/contacts/${num}`,
        { phoneNumber: num, reason: 'webhook_opt_out' },
          headers: {
      console.log(`Conflict resolved via upsert for ${num}`);
    } catch (upsertError) {
      console.error(`Upsert failed for ${num}:`, upsertError.message);
// Required OAuth scope for DNC operations: outbound:dnc:write
The batch push function handles 429 responses by reading the Retry-After header and recursively retrying the exact same payload. For 409 conflicts, the function splits the batch into conflicting and non-conflicting numbers. Non-conflicting numbers retry immediately. Conflicting numbers trigger a targeted PUT request to upsert the record with the latest timestamp. This prevents batch failures from blocking valid records.
Step 4: Batch Scheduler & Queue Drainage
The service requires a scheduler to periodically drain the Redis sorted set and push batches to CXone. The scheduler fetches the oldest entries using ZRANGEBYSCORE, processes them, and removes them from the queue.
async function batchProcessor() {
  while (true) {
      // Fetch oldest BATCH_SIZE entries
      const pending = await redisClient.zRangeByScore(DNC_REDIS_KEY, '-inf', '+inf', { BY: 'SCORE', COUNT: BATCH_SIZE });
      if (pending.length === 0) {
        await new Promise(resolve => setTimeout(resolve, 5000));
        continue;
      console.log(`Processing batch of ${pending.length} numbers`);
      await pushBatchToCXone(pending);
      // Remove successfully processed entries
      await redisClient.zRem(DNC_REDIS_KEY, ...pending);
      // Brief pause before next batch
      await new Promise(resolve => setTimeout(resolve, 2000));
    } catch (error) {
      console.error('Batch processor error:', error.message);
      await new Promise(resolve => setTimeout(resolve, 10000));
// Start scheduler
batchProcessor();
// Start HTTP server
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => {
  console.log(`DNC webhook listener running on port ${PORT}`);
The scheduler runs an infinite loop with a five second idle check. When entries exist, it fetches the oldest batch, pushes to CXone, and removes them from Redis. The ZREM call ensures processed numbers do not reappear in subsequent cycles. The two second pause between batches respects CXone API throughput limits.
redisClient.connect().catch(console.error);
  if (cachedToken && now < tokenExpiry - 60000) return cachedToken;
      params: { grant_type: 'client_credentials', client_id: CLIENT_ID, client_secret: CLIENT_SECRET },
    return cachedToken;
  } catch (error) {
    if (error.response?.status === 401) throw new Error('OAuth authentication failed.');
    throw error;
  let e164Number;
    if (!parsed || !parsed.isValid()) return;
  } catch { return; }
  await redisClient.zAdd(DNC_REDIS_KEY, { score: Date.now(), value: e164Number });
  const payload = { contacts: batchNumbers.map(num => ({ phoneNumber: num, reason: 'webhook_opt_out', source: 'internal_system' })) };
    const response = await axios.post(`${CXONE_BASE_URL}/api/v2/outbound/dnc-lists/${DNC_LIST_ID}/contacts`, payload, {
      headers: { 'Authorization': `Bearer ${token}`, 'Content-Type': 'application/json', 'X-CXone-Version': '2023-10-01' },
      timeout: 15000
  } catch (error) {
    if (error.response?.status === 409) return resolveConflicts(token, batchNumbers, error.response.data);
    throw error;
  if (nonConflicting.length > 0) await pushBatchToCXone(nonConflicting);
      await axios.put(`${CXONE_BASE_URL}/api/v2/outbound/dnc-lists/${DNC_LIST_ID}/contacts/${num}`, { phoneNumber: num, reason: 'webhook_opt_out' }, {
        headers: { 'Authorization': `Bearer ${token}`, 'Content-Type': 'application/json' }
    } catch (upsertError) { console.error(`Upsert failed for ${num}:`, upsertError.message); }
    const phoneNumber = req.body.data?.phoneNumber || req.body.data?.contact?.phoneNumber;
    if (!phoneNumber) return res.status(400).json({ error: 'Missing phoneNumber' });
  } catch (error) {
  while (true) {
      if (pending.length === 0) { await new Promise(resolve => setTimeout(resolve, 5000)); continue; }
    } catch (error) {
batchProcessor();
app.listen(PORT, () => console.log(`DNC webhook listener running on port ${PORT}`));
  • Cause: The OAuth token has expired or the client credentials are incorrect. The token caching buffer may have been exceeded during a long batch operation.
  • Fix: Ensure the getCXoneToken function runs before every API call. Verify the client_id and client_secret match a CXone API client with the outbound:dnc:write scope assigned.
  • Code showing the fix: The token refresh logic subtracts 60000 milliseconds from the expiry timestamp. This guarantees a fresh token is fetched before the server rejects the request.
Error: 409 Conflict
  • Cause: The phone number already exists in the DNC list with a different reason or source. CXone prevents duplicate inserts via the batch endpoint.
  • Fix: Implement the resolveConflicts function to split the batch and retry non-conflicting numbers. Use a targeted PUT request for conflicting numbers to update the reason field.
  • Code showing the fix: The conflict resolver extracts conflicts[].contactId from the error payload, filters them out of the retry batch, and issues individual upsert calls.
  • Cause: The batch processor exceeds CXone API rate limits. Outbound DNC endpoints typically cap at 100 requests per minute per organization.
  • Fix: Read the Retry-After header and implement exponential backoff. Reduce BATCH_SIZE if 429 responses persist.
  • Code showing the fix: The pushBatchToCXone function catches 429 status codes, pauses execution using setTimeout, and recursively retries the identical payload.
Error: Redis Connection Refused
  • Cause: The Redis instance is unreachable or the URL contains an incorrect port/authentication string.
  • Fix: Verify the REDIS_URL environment variable matches your deployment environment. Add connection retry logic with redisClient.connect().catch() and monitor network policies.
  • Code showing the fix: The redisClient.on('error') listener logs connection drops. The batch processor wraps Redis calls in try-catch blocks and pauses for ten seconds before retrying.
Error: Phone Number Parsing Failure
  • Cause: The incoming webhook payload contains malformed strings, leading characters, or unsupported country codes.
  • Fix: Adjust the default region parameter in parsePhoneNumberFromString. Log invalid numbers to a dead letter queue instead of crashing the batch.
  • Code showing the fix: The processOptOutEvent function validates parsed.isValid() before writing to Redis. Invalid numbers trigger a warning log and skip queue insertion.
