Managing Do-Not-Call List Exceptions Programmatically Using the CXone Outbound DNC API in Java with Transactional Integrity Checks and Conflict Resolution
  • A Java utility that creates and updates CXone DNC exceptions with idempotent request handling, optimistic locking, and automated conflict resolution.
  • This tutorial uses the CXone Outbound DNC API v2 and the official CXone Java SDK.
  • The implementation covers Java 17 with production-grade retry logic, state verification, and error handling.
  • CXone OAuth2 client configured with dnc:read and dnc:write scopes
  • CXone Java SDK v2.10+ (com.nice.cxp:cxp-api)
  • Java 17 runtime
  • Maven dependencies: com.nice.cxp:cxp-api:2.10.0, com.fasterxml.jackson.core:jackson-databind:2.15.2, org.slf4j:slf4j-api:2.0.9
CXone uses standard OAuth2 client credentials flow for server-to-server integrations. You must cache the access token and refresh it before expiration. The token endpoint is https://api-us.nice.incontact.com/oauth/token.
import java.net.URI;
import java.time.Instant;
import java.util.Map;
public class CxoneTokenManager {
    private static final HttpClient HTTP_CLIENT = HttpClient.newHttpClient();
    private static final ObjectMapper MAPPER = new ObjectMapper();
    private String accessToken;
    private Instant expiresAt;
    public String getAccessToken(String clientId, String clientSecret, String basePath) throws Exception {
        if (accessToken != null && Instant.now().isBefore(expiresAt.minusSeconds(60))) {
            return accessToken;
        String tokenUrl = basePath.replace("/api/v2", "") + "/oauth/token";
        String payload = Map.of(
            "grant_type", "client_credentials",
            "client_id", clientId,
            "client_secret", clientSecret,
            "scope", "dnc:read dnc:write"
        ).entrySet().stream()
            .map(e -> e.getKey() + "=" + e.getValue())
            .reduce((a, b) -> a + "&" + b)
            .orElse("");
            .uri(URI.create(tokenUrl))
            .header("Content-Type", "application/x-www-form-urlencoded")
            .POST(HttpRequest.BodyPublishers.ofString(payload))
            .build();
        HttpResponse<String> response = HTTP_CLIENT.send(request, HttpResponse.BodyHandlers.ofString());
            throw new RuntimeException("OAuth token request failed with status " + response.statusCode());
        Map<String, Object> tokenData = MAPPER.readValue(response.body(), Map.class);
        accessToken = (String) tokenData.get("access_token");
        expiresAt = Instant.now().plusSeconds((long) tokenData.get("expires_in"));
        return accessToken;
HTTP Request Cycle
POST /oauth/token HTTP/1.1
Host: api-us.nice.incontact.com
grant_type=client_credentials&client_id=your_client_id&client_secret=your_client_secret&scope=dnc:read%20dnc:write
HTTP Response
  "token_type": "Bearer",
  "expires_in": 3600,
  "scope": "dnc:read dnc:write"
Step 1: SDK Initialization and Idempotency Header Configuration
CXone APIs support the X-Idempotency-Key header to prevent duplicate creations during network retries. You must attach this header to every DNC exception request. The CXone Java SDK allows custom headers through the ApiClient configuration.
import com.nice.cxp.api.client.ApiClient;
import com.nice.cxp.api.client.Configuration;
import java.util.UUID;
public class CxoneDncClient {
    private final ApiClient apiClient;
    private final String basePath;
    public CxoneDncClient(String basePath, String accessToken) {
        this.basePath = basePath;
        Configuration configuration = new Configuration();
        configuration.setBasePath(basePath);
        configuration.setApiKey("Authorization", "Bearer " + accessToken);
        this.apiClient = new ApiClient(configuration);
    public ApiClient getApiClient() {
        return apiClient;
    public String generateIdempotencyKey(String phone, String campaignId) {
        return String.format("dnc-exc-%s-%s-%s",
            phone.replace(" ", "").replace("-", ""),
            campaignId,
            UUID.randomUUID().toString().substring(0, 8));
Required OAuth Scope: dnc:write
Step 2: Pre-flight Search and Transactional State Verification
CXone does not support database-level transactions across API calls. You must implement a local transaction manager that verifies state before mutation. The DNC search endpoint supports pagination and returns existing exceptions for a given number and campaign.
import com.nice.cxp.api.v2.outbound.dnc.DncApi;
import com.nice.cxp.api.v2.outbound.dnc.model.SearchDncExceptionsRequest;
import com.nice.cxp.api.v2.outbound.dnc.model.DncException;
import com.nice.cxp.api.ApiException;
import java.util.List;
import java.util.ArrayList;
import java.util.HashMap;
public class DncTransactionManager {
    private final DncApi dncApi;
    private final Map<String, DncException> pendingState = new HashMap<>();
    public DncTransactionManager(DncApi dncApi) {
        this.dncApi = dncApi;
    public DncException findExistingException(String number, String campaignId) throws ApiException {
        SearchDncExceptionsRequest searchRequest = new SearchDncExceptionsRequest();
        searchRequest.setNumber(number);
        searchRequest.setCampaignId(campaignId);
        searchRequest.setPageSize(20);
        searchRequest.setPage(1);
        var response = dncApi.searchDncExceptions(searchRequest);
        if (response.getResults() != null && !response.getResults().isEmpty()) {
            return response.getResults().get(0);
        return null;
    public void recordPendingState(String idempotencyKey, DncException exception) {
        pendingState.put(idempotencyKey, exception);
    public boolean verifyState(String idempotencyKey, DncException expected) throws ApiException {
        DncException current = dncApi.getDncException(expected.getId());
        if (!current.getVersion().equals(expected.getVersion())) {
            return false;
        return true;
HTTP Request Cycle
POST /api/v2/outbound/dnc/exceptions/search HTTP/1.1
Authorization: Bearer eyJhbGciOiJSUzI1NiIs...
  "number": "+18005551234",
  "campaignId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
  "pageSize": 20,
  "page": 1
HTTP Response
  "results": [
      "id": "exc-9876543210",
      "validFrom": "2024-01-01T00:00:00.000Z",
      "validTo": "2025-01-01T00:00:00.000Z",
      "reason": "Customer requested removal",
      "source": "API",
      "version": 1
  "page": 1,
  "pageSize": 20,
  "totalResults": 1
Step 3: Conflict Resolution and Optimistic Concurrency
When a 409 Conflict occurs, CXone indicates that a duplicate exception exists or that the resource version has changed. You must implement optimistic locking using the If-Match header and resolve conflicts by either updating the existing record or skipping duplicate operations.
import com.nice.cxp.api.v2.outbound.dnc.model.CreateDncExceptionRequest;
import com.nice.cxp.api.v2.outbound.dnc.model.UpdateDncExceptionRequest;
import com.nice.cxp.api.client.RequestContext;
import java.time.OffsetDateTime;
public class DncConflictResolver {
    private static final int MAX_RETRIES = 3;
    private static final long INITIAL_BACKOFF_MS = 500;
    public DncConflictResolver(DncApi dncApi) {
    public DncException createOrUpdateWithConflictResolution(
            CreateDncExceptionRequest createReq,
            String existingId) throws Exception {
        int attempt = 0;
        long backoff = INITIAL_BACKOFF_MS;
        while (attempt < MAX_RETRIES) {
                DncException created = dncApi.createDncException(createReq);
                created.setVersion(created.getVersion());
                return created;
            } catch (ApiException ex) {
                if (ex.getCode() == 409) {
                    return resolveConflict(createReq, existingId, idempotencyKey);
                } else if (ex.getCode() == 429) {
                    attempt++;
                    if (attempt >= MAX_RETRIES) throw ex;
                    TimeUnit.MILLISECONDS.sleep(backoff);
                    backoff *= 2;
                } else {
                    throw ex;
        throw new RuntimeException("Max retries exceeded for DNC exception creation");
    private DncException resolveConflict(
            String existingId,
            String idempotencyKey) throws ApiException {
        if (existingId == null) {
            throw new RuntimeException("Conflict resolution failed: no existing ID provided");
        DncException existing = dncApi.getDncException(existingId);
        UpdateDncExceptionRequest updateReq = new UpdateDncExceptionRequest();
        updateReq.setReason(createReq.getReason());
        updateReq.setValidFrom(createReq.getValidFrom());
        updateReq.setValidTo(createReq.getValidTo());
        updateReq.setSource(createReq.getSource());
        DncException updated = dncApi.updateDncException(existingId, existing.getVersion(), updateReq);
        return updated;
HTTP Request Cycle with Optimistic Locking
PUT /api/v2/outbound/dnc/exceptions/exc-9876543210 HTTP/1.1
If-Match: 1
  "reason": "Updated via automated reconciliation",
  "source": "API"
HTTP Response
  "source": "API",
  "version": 2
Step 4: Batch Processing with Transactional Rollback Simulation
CXone does not provide native rollback across multiple API calls. You must track successful operations in memory and compensate for failures by reversing state or logging discrepancies for manual review. This pattern ensures auditability and prevents partial corruption.
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class DncBatchProcessor {
    private static final Logger LOG = LoggerFactory.getLogger(DncBatchProcessor.class);
    private final DncTransactionManager txManager;
    private final DncConflictResolver conflictResolver;
    private final List<DncExceptionResult> transactionLog = new ArrayList<>();
    public DncBatchProcessor(DncTransactionManager txManager, DncConflictResolver conflictResolver) {
        this.txManager = txManager;
        this.conflictResolver = conflictResolver;
    public Map<String, Object> processBatch(List<CreateDncExceptionRequest> requests, String campaignId) throws Exception {
        int successCount = 0;
        int conflictCount = 0;
        List<String> failedNumbers = new ArrayList<>();
        for (CreateDncExceptionRequest req : requests) {
            String idempotencyKey = generateKey(req.getNumber(), campaignId);
                DncException existing = txManager.findExistingException(req.getNumber(), campaignId);
                String existingId = existing != null ? existing.getId() : null;
                DncException result = conflictResolver.createOrUpdateWithConflictResolution(
                    req, idempotencyKey, existingId);
                txManager.recordPendingState(idempotencyKey, result);
                transactionLog.add(new DncExceptionResult(req.getNumber(), "SUCCESS", result.getId(), null));
                successCount++;
                    conflictCount++;
                    transactionLog.add(new DncExceptionResult(req.getNumber(), "CONFLICT_RESOLVED", null, ex.getMessage()));
                } else {
                    failedNumbers.add(req.getNumber());
                    transactionLog.add(new DncExceptionResult(req.getNumber(), "FAILED", null, ex.getMessage()));
        Map<String, Object> summary = new HashMap<>();
        summary.put("successCount", successCount);
        summary.put("conflictCount", conflictCount);
        summary.put("failedNumbers", failedNumbers);
        summary.put("transactionLog", transactionLog);
        return summary;
    private String generateKey(String phone, String campaignId) {
        return String.format("batch-%s-%s-%d", phone, campaignId, System.currentTimeMillis());
    public List<DncExceptionResult> getTransactionLog() {
        return transactionLog;
    public static class DncExceptionResult {
        public final String number;
        public final String status;
        public final String exceptionId;
        public final String errorMessage;
        public DncExceptionResult(String number, String status, String exceptionId, String errorMessage) {
            this.number = number;
            this.status = status;
            this.exceptionId = exceptionId;
            this.errorMessage = errorMessage;
public class DncExceptionManager {
        String clientId = System.getenv("CXONE_CLIENT_ID");
        String clientSecret = System.getenv("CXONE_CLIENT_SECRET");
        String basePath = "https://api-us.nice.incontact.com/api/v2";
            CxoneTokenManager tokenManager = new CxoneTokenManager();
            String token = tokenManager.getAccessToken(clientId, clientSecret, basePath);
            configuration.setApiKey("Authorization", "Bearer " + token);
            ApiClient apiClient = new ApiClient(configuration);
            DncApi dncApi = new DncApi(apiClient);
            DncTransactionManager txManager = new DncTransactionManager(dncApi);
            DncConflictResolver conflictResolver = new DncConflictResolver(dncApi);
            DncBatchProcessor batchProcessor = new DncBatchProcessor(txManager, conflictResolver);
            List<CreateDncExceptionRequest> batch = List.of(
                buildRequest("+18005551234", "a1b2c3d4-e5f6-7890-abcd-ef1234567890", "Opt-out requested"),
                buildRequest("+18005555678", "a1b2c3d4-e5f6-7890-abcd-ef1234567890", "Regulatory compliance")
            Map<String, Object> result = batchProcessor.processBatch(batch, "a1b2c3d4-e5f6-7890-abcd-ef1234567890");
            System.out.println("Batch completed: " + result);
        } catch (Exception e) {
            e.printStackTrace();
    private static CreateDncExceptionRequest buildRequest(String number, String campaignId, String reason) {
        CreateDncExceptionRequest req = new CreateDncExceptionRequest();
        req.setNumber(number);
        req.setCampaignId(campaignId);
        req.setValidFrom(OffsetDateTime.now());
        req.setValidTo(OffsetDateTime.now().plusYears(1));
        req.setReason(reason);
        req.setSource("EXTERNAL_SYSTEM");
        return req;
  • What causes it: The OAuth token has expired, contains incorrect scopes, or was generated with mismatched client credentials.
  • How to fix it: Refresh the token using the CxoneTokenManager before retrying. Verify that the client credentials match the CXone application settings.
  • Code showing the fix:
if (ex.getCode() == 401) {
    String newToken = tokenManager.getAccessToken(clientId, clientSecret, basePath);
    configuration.setApiKey("Authorization", "Bearer " + newToken);
    // Retry the original request
Error: 403 Forbidden
  • What causes it: The OAuth token lacks the required dnc:read or dnc:write scope, or the client ID is restricted to specific environments.
  • How to fix it: Update the OAuth client configuration in CXone to include both DNC scopes. Ensure the token request payload explicitly requests scope=dnc:read dnc:write.
String payload = "grant_type=client_credentials&client_id=" + clientId +
    "&client_secret=" + clientSecret +
    "&scope=dnc:read%20dnc:write";
Error: 409 Conflict
  • What causes it: A DNC exception already exists for the same number and campaign, or the version number provided in If-Match does not match the server state.
  • How to fix it: Implement the conflict resolution pattern shown in Step 3. Fetch the existing record, compare versions, and perform an update instead of a creation.
  • What causes it: The CXone API rate limit has been exceeded. DNC endpoints typically enforce 100 requests per minute per tenant.
  • How to fix it: Implement exponential backoff. Read the Retry-After header if present. Pause execution before retrying.
    long retryAfter = Long.parseLong(ex.getResponseHeaders().getOrDefault("Retry-After", "1"));
    TimeUnit.SECONDS.sleep(retryAfter);
    continue;
  • What causes it: CXone backend processing failure, often related to malformed phone number formatting or campaign ID validation.
  • How to fix it: Validate phone numbers in E.164 format before submission. Verify campaign IDs exist in the target environment. Retry with a longer backoff period.
if (!number.matches("^\\+?[1-9]\\d{1,14}$")) {
    throw new IllegalArgumentException("Phone number must be in E.164 format");
