Manage Failover Routing for NICE Cognigy Webhooks in Node.js
  • A Node.js endpoint failover manager that intercepts outbound webhook payloads, evaluates health matrices, and routes traffic to primary or secondary Cognigy endpoints.
  • The module uses NICE CXone Webhook API endpoints to synchronize routing state and enforces circuit breaker logic against latency spikes and capacity constraints.
  • The implementation covers Node.js 18+ with modern async/await syntax, axios for HTTP operations, and built-in dns/tls modules for infrastructure validation.
  • NICE CXone OAuth 2.0 client credentials with webhooks:read and webhooks:write scopes
  • Node.js 18.0 or higher
  • Dependencies: axios, uuid (run npm install axios uuid)
  • Access to a CXone organization with webhook configuration permissions
  • Target Cognigy webhook endpoints (primary and secondary URLs)
NICE CXone uses OAuth 2.0 client credentials flow for programmatic access. The following code fetches an access token, caches it, and implements automatic refresh when the token expires.
const CXONE_OAUTH_URL = 'https://api.mypurecloud.com/oauth/token';
const CXONE_API_BASE = 'https://api.mypurecloud.com/api/v2';
class CxoneAuthManager {
  constructor(clientId, clientSecret, environment = 'us-east-1') {
    this.clientId = clientId;
    this.baseUrl = `https://api.${environment}.mypurecloud.com`;
    this.token = null;
    this.tokenExpiry = 0;
  async getAccessToken() {
    const now = Date.now();
    if (this.token && now < this.tokenExpiry - 60000) {
      return this.token;
    const auth = Buffer.from(`${this.clientId}:${this.clientSecret}`).toString('base64');
    const response = await axios.post(`${this.baseUrl}/oauth/token`, {
      scope: 'webhooks:read webhooks:write'
      headers: {
        'Authorization': `Basic ${auth}`,
        'Content-Type': 'application/x-www-form-urlencoded'
    this.token = response.data.access_token;
    this.tokenExpiry = now + (response.data.expires_in * 1000);
    return this.token;
  async request(endpoint, method = 'GET', body = null) {
    const token = await this.getAccessToken();
    const url = `${this.baseUrl}${endpoint}`;
    const config = {
      method,
      url,
      headers: {
        'Content-Type': 'application/json'
      timeout: 10000
    if (body) config.data = body;
      const res = await axios(config);
      return res.data;
    } catch (err) {
      if (err.response?.status === 429) {
        const retryAfter = parseInt(err.response.headers['retry-after'] || '5', 10);
        console.warn(`CXone rate limited. Retrying after ${retryAfter}s...`);
        await new Promise(r => setTimeout(r, retryAfter * 1000));
        return this.request(endpoint, method, body);
      throw err;
Step 1: Health Matrix and Infrastructure Validation
The failover manager requires a deterministic health matrix before routing traffic. This step validates DNS resolution, TLS certificate validity, and capacity constraints against maximum failover frequency limits.
const dns = require('dns').promises;
const tls = require('tls');
const http = require('http');
const https = require('https');
const { URL } = require('url');
class HealthValidator {
  constructor(maxFailoverFrequency = 5, windowMs = 300000) {
    this.maxFailoverFrequency = maxFailoverFrequency;
    this.windowMs = windowMs;
    this.failoverTimestamps = [];
  async validateEndpoint(endpointUrl) {
    const parsed = new URL(endpointUrl);
    const healthMatrix = {
      dns: false,
      ssl: false,
      capacity: false,
      latency: 0,
      await dns.lookup(parsed.hostname);
      healthMatrix.dns = true;
    } catch (err) {
      console.error(`DNS resolution failed for ${parsed.hostname}: ${err.message}`);
      return healthMatrix;
      const socket = tls.connect({
        host: parsed.hostname,
        port: parsed.port || 443,
        servername: parsed.hostname,
        rejectUnauthorized: true
      await new Promise((resolve, reject) => {
        socket.on('secure', () => {
          socket.destroy();
          resolve();
        socket.on('error', (e) => {
          socket.destroy();
          reject(e);
        socket.setTimeout(5000, () => {
          socket.destroy();
          reject(new Error('SSL handshake timeout'));
      healthMatrix.ssl = true;
    } catch (err) {
      console.error(`SSL verification failed for ${parsed.hostname}: ${err.message}`);
    const isUnderCapacity = this.checkFailoverFrequency();
    healthMatrix.capacity = isUnderCapacity;
    if (!isUnderCapacity) {
      console.warn('Maximum failover frequency exceeded. Blocking switch.');
  checkFailoverFrequency() {
    this.failoverTimestamps = this.failoverTimestamps.filter(ts => now - ts < this.windowMs);
    if (this.failoverTimestamps.length >= this.maxFailoverFrequency) {
      return false;
    this.failoverTimestamps.push(now);
    return true;
Step 2: Circuit Breaker Evaluation and Latency Spike Detection
The circuit breaker prevents cascading failures during latency spikes. This step calculates sliding window latency, evaluates circuit state, and triggers atomic POST operations only when the circuit is closed or half-open.
class CircuitBreaker {
  constructor(failureThreshold = 3, recoveryTimeoutMs = 30000, latencyThresholdMs = 2000) {
    this.failureThreshold = failureThreshold;
    this.recoveryTimeoutMs = recoveryTimeoutMs;
    this.latencyThresholdMs = latencyThresholdMs;
    this.state = 'closed';
    this.failureCount = 0;
    this.lastFailureTime = 0;
    this.latencyWindow = [];
  recordLatency(ms) {
    this.latencyWindow.push({ time: now, ms });
    this.latencyWindow = this.latencyWindow.filter(entry => now - entry.time < 60000);
    const avgLatency = this.latencyWindow.reduce((sum, e) => sum + e.ms, 0) / this.latencyWindow.length;
    return avgLatency;
  shouldAllowRequest() {
    if (this.state === 'closed') return true;
    if (this.state === 'open') {
      if (Date.now() - this.lastFailureTime > this.recoveryTimeoutMs) {
        this.state = 'half-open';
        console.log('Circuit breaker transitioning to half-open state.');
        return true;
      return false;
    return true;
  recordSuccess() {
    if (this.state === 'half-open') {
      console.log('Circuit breaker closed after successful recovery.');
  recordFailure() {
    this.failureCount++;
    this.lastFailureTime = Date.now();
    if (this.failureCount >= this.failureThreshold) {
      this.state = 'open';
      console.warn(`Circuit breaker opened after ${this.failureCount} failures.`);
Step 3: Failover Payload Construction and Atomic POST Operations
This step constructs the failover payload with endpoint-ref, health-matrix, and switch-directive fields. It validates the schema, performs format verification, and executes atomic POST operations to the target Cognigy endpoint.
const { v4: uuidv4 } = require('uuid');
class FailoverRouter {
  constructor(validator, circuitBreaker, auditLogger) {
    this.validator = validator;
    this.circuitBreaker = circuitBreaker;
    this.auditLogger = auditLogger;
    this.successCount = 0;
    this.failCount = 0;
  validateFailoverPayload(payload) {
    const requiredFields = ['endpoint-ref', 'health-matrix', 'switch-directive', 'payload-data'];
    const missing = requiredFields.filter(f => !payload[f]);
    if (missing.length > 0) {
      throw new Error(`Invalid failover schema. Missing fields: ${missing.join(', ')}`);
    if (typeof payload['health-matrix'] !== 'object' ||
        typeof payload['switch-directive'] !== 'string') {
      throw new Error('Format verification failed: health-matrix must be object, switch-directive must be string.');
    return true;
  async routeWebhook(primaryUrl, secondaryUrl, cognigyPayload) {
    const requestId = uuidv4();
    let targetUrl = primaryUrl;
    let fallbackUsed = false;
    const healthMatrix = await this.validator.validateEndpoint(primaryUrl);
    if (!healthMatrix.dns || !healthMatrix.ssl || !healthMatrix.capacity) {
      console.log(`Primary endpoint unhealthy. Evaluating secondary: ${secondaryUrl}`);
      const secondaryHealth = await this.validator.validateEndpoint(secondaryUrl);
      if (secondaryHealth.dns && secondaryHealth.ssl && secondaryHealth.capacity) {
        targetUrl = secondaryUrl;
        fallbackUsed = true;
      } else {
        throw new Error('Both primary and secondary endpoints failed health validation.');
    if (!this.circuitBreaker.shouldAllowRequest()) {
      throw new Error('Circuit breaker open. Request rejected to prevent cascade failure.');
    const failoverPayload = {
      'endpoint-ref': {
        primary: primaryUrl,
        active: targetUrl,
        fallback_used: fallbackUsed,
        request_id: requestId
      'health-matrix': healthMatrix,
      'switch-directive': fallbackUsed ? 'FAILOVER_TRIGGERED' : 'PRIMARY_ROUTED',
      'payload-data': cognigyPayload,
      'audit-timestamp': new Date().toISOString()
    this.validateFailoverPayload(failoverPayload);
    const startTime = Date.now();
      const response = await axios.post(targetUrl, failoverPayload, {
        headers: { 'Content-Type': 'application/json', 'X-Request-ID': requestId },
        timeout: 5000
      const latency = Date.now() - startTime;
      this.circuitBreaker.recordLatency(latency);
      const avgLatency = this.circuitBreaker.recordLatency(latency);
      if (avgLatency > this.circuitBreaker.latencyThresholdMs) {
        console.warn(`Latency spike detected: ${avgLatency}ms exceeds threshold.`);
      this.circuitBreaker.recordSuccess();
      this.successCount++;
      this.auditLogger.log({
        action: 'webhook_routed',
        target: targetUrl,
        status: response.status,
        latency_ms: latency,
      return { success: true, latency, targetUrl };
    } catch (err) {
      this.circuitBreaker.recordFailure();
      this.failCount++;
        action: 'webhook_failed',
        target: targetUrl,
        error: err.message,
      throw err;
  getMetrics() {
    const total = this.successCount + this.failCount;
      total_requests: total,
      success_rate: total ? (this.successCount / total) * 100 : 0,
      circuit_state: this.circuitBreaker.state,
      avg_latency_window: this.circuitBreaker.latencyWindow.length
Step 4: CXone Synchronization and External Load Balancer Alignment
This step synchronizes failover events with NICE CXone via the Webhook API and triggers alignment webhooks to external load balancers. It ensures configuration parity across infrastructure layers.
class CxoneFailoverManager {
  constructor(authManager, validator, circuitBreaker, auditLogger, lbWebhookUrl) {
    this.cxone = authManager;
    this.router = new FailoverRouter(validator, circuitBreaker, auditLogger);
    this.lbWebhookUrl = lbWebhookUrl;
  async syncWebhookConfiguration(cxoneWebhookId, primaryUrl, secondaryUrl) {
    const payload = {
      name: 'Cognigy Failover Webhook',
      url: primaryUrl,
      method: 'POST',
      custom_properties: {
        failover_secondary: secondaryUrl,
        managed_by: 'endpoint_failover_manager',
        last_sync: new Date().toISOString()
      const result = await this.cxone.request(`/webhooks/${cxoneWebhookId}`, 'PUT', payload);
        action: 'cxone_config_sync',
        webhook_id: cxoneWebhookId,
        status: 'success'
      return result;
    } catch (err) {
        error: err.message,
        status: 'failed'
      throw err;
  async notifyLoadBalancer(eventType, targetUrl, metrics) {
    const lbPayload = {
      event: eventType,
      target_endpoint: targetUrl,
      metrics: metrics,
      source: 'cxone_failover_manager'
      await axios.post(this.lbWebhookUrl, lbPayload, {
        timeout: 3000
        action: 'lb_alignment',
        event: eventType,
        target: targetUrl,
        status: 'synced'
    } catch (err) {
      console.error(`Load balancer sync failed: ${err.message}`);
        event: eventType,
        error: err.message,
        status: 'failed'
  async processOutboundWebhook(cxoneWebhookId, primaryUrl, secondaryUrl, cognigyData) {
    await this.syncWebhookConfiguration(cxoneWebhookId, primaryUrl, secondaryUrl);
    const result = await this.router.routeWebhook(primaryUrl, secondaryUrl, cognigyData);
    const metrics = this.router.getMetrics();
    await this.notifyLoadBalancer(result.fallback_used ? 'FAILOVER' : 'PRIMARY', result.targetUrl, metrics);
    return result;
class AuditLogger {
  constructor(logFile = 'failover_audit.log') {
    this.logFile = logFile;
    this.fs = require('fs');
  log(entry) {
    const line = JSON.stringify({ ...entry, logged_at: new Date().toISOString() }) + '\n';
    this.fs.appendFileSync(this.logFile, line, 'utf8');
The following script initializes the failover manager, configures health validation, circuit breaker thresholds, and processes a simulated outbound webhook to a Cognigy endpoint. Replace the placeholder credentials and URLs with your environment values.
const CxoneAuthManager = require('./auth');
const HealthValidator = require('./validator');
const CircuitBreaker = require('./breaker');
const CxoneFailoverManager = require('./manager');
const AuditLogger = require('./logger');
async function main() {
  const CXONE_CLIENT_ID = process.env.CXONE_CLIENT_ID || 'your_client_id';
  const CXONE_CLIENT_SECRET = process.env.CXONE_CLIENT_SECRET || 'your_client_secret';
  const CXONE_ENV = process.env.CXONE_ENV || 'us-east-1';
  const PRIMARY_COGNIGY_URL = process.env.PRIMARY_URL || 'https://primary.cognigy.webhook.example.com/inbound';
  const SECONDARY_COGNIGY_URL = process.env.SECONDARY_URL || 'https://secondary.cognigy.webhook.example.com/inbound';
  const LB_WEBHOOK_URL = process.env.LB_WEBHOOK_URL || 'https://internal.lb.example.com/align';
  const CXONE_WEBHOOK_ID = process.env.CXONE_WEBHOOK_ID || 'webhook-123456';
  const auth = new CxoneAuthManager(CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_ENV);
  const validator = new HealthValidator(5, 300000);
  const breaker = new CircuitBreaker(3, 30000, 2000);
  const logger = new AuditLogger('cognigy_failover_audit.log');
  const manager = new CxoneFailoverManager(auth, validator, breaker, logger, LB_WEBHOOK_URL);
  const cognigyPayload = {
    conversation_id: 'conv-8f7d6e5c',
    intent: 'transfer_to_agent',
    channel: 'web',
    metadata: {
      priority: 'high',
      language: 'en-US'
    console.log('Initiating failover routing pipeline...');
    const result = await manager.processOutboundWebhook(
      CXONE_WEBHOOK_ID,
      PRIMARY_COGNIGY_URL,
      SECONDARY_COGNIGY_URL,
      cognigyPayload
    console.log('Routing complete:', result);
    console.log('Metrics:', manager.router.getMetrics());
  } catch (err) {
    console.error('Pipeline failed:', err.message);
    process.exit(1);
main();
  • Cause: Expired OAuth token, missing webhooks:write scope, or incorrect client credentials.
  • Fix: Verify the grant_type: client_credentials request returns a valid token. Ensure the CXone security profile attached to the client includes webhook management permissions.
  • Code Fix: The CxoneAuthManager automatically refreshes tokens before expiry. Log err.response.data to identify scope mismatches.
  • Cause: CXone API rate limits or Cognigy endpoint throttling.
  • Fix: The CxoneAuthManager.request method parses the retry-after header and retries automatically. For Cognigy endpoints, implement exponential backoff in the FailoverRouter catch block.
  • Code Fix: Add await new Promise(r => setTimeout(r, 1000 * Math.pow(2, retryCount))) before retrying POST operations.
Error: SSL Verification Failed or DNS Lookup Timeout
  • Cause: Invalid certificate chain, hostname mismatch, or network isolation blocking port 53/443.
  • Fix: Run openssl s_client -connect hostname:443 to validate certificates. Ensure the execution environment has outbound DNS access. The HealthValidator uses rejectUnauthorized: true by design. Do not disable it in production.
  • Code Fix: Check err.code for UNABLE_TO_VERIFY_LEAF_SIGNATURE or ENOTFOUND. Route to secondary endpoint or trigger load balancer realignment.
Error: Circuit Breaker Open State
  • Cause: Consecutive failures or latency exceeding the configured threshold.
  • Fix: Wait for the recoveryTimeoutMs window. The breaker transitions to half-open and allows a probe request. If successful, it closes. If it fails, it reopens.
  • Code Fix: Monitor circuit_state in metrics. Adjust failureThreshold or recoveryTimeoutMs if transient network blips trigger false positives.
Error: Maximum Failover Frequency Exceeded
  • Cause: The system attempts to switch endpoints more than maxFailoverFrequency times within the sliding window.
  • Fix: Reduce webhook dispatch rate or increase the windowMs parameter. The HealthValidator blocks switches to prevent routing oscillation.
  • Code Fix: Review failoverTimestamps array length. Implement queueing or batch processing for high-volume webhook streams.
