Major difference between SIP server 7.6.0.62 and 7.6.0.73
Does anybody on this forum know the major differences between these two versions? What happens if we don’t upgrade?
If u have access to genesys support site u can read about all changes from 7.6.0.62 to 7.6.0.73 (and latest one 7.6.0.76) in release notes.
Genereal, most differenses what only in latest version Genesys fix same ugly bags and provide same hones futures. And don’t forget about first sysadmins rule - It’s work? Well don’t touch it! =)))
WBR Timur
The release notes should show the differences, but realistically if you don’t upgrade, it will keep working as it does now.
Generally… no need to upgrade unless there is something specific in the release notes that you need.
