has anyone been playing with the latest version of Genesys PBX Simulator? I have found that there are quite a few differences and that with effort, you can even connect to it without using Genesys T-Server. (Previous versions would prevent you connecting to it directly with JTAPI or TSAPI… now this is no longer a case, it seems)
Has anyone actually put together a feature comparison list?
Also, how does it compare to using IPCODE from Avaya (Their PBX Simulator)
Best regards,
