How does one configure SIP server 8.1 to write specific sip headers to ICON? I have a customer that is sending data in something other than the conventional UUI header and need to include it in some reporting.
On the Framework 8.1 SIP Server Deployment Guide - Chapter 5: SIP Server Feature Support, there is a section called āMapping SIP Headers and SDP Messagesā. Take a look if that helps you. It explains how to copy data from SIP messages to T-Lib UserData (which can ben later configured on ICON to write to the database on the adata_spec.xml file)
so, if you want to tap the header from INVITE - for example -
on the SIP SERVER - Options Tab - create a new section called āINVITEā - Inside that define the KVP -
something like this -
Key = Value
userdata-1 =Call-ID(matching the Call-ID Parameter in Header)
userdata-2 =User-to-User
you would get something like this in the output - once you have set it up correctly :
User-to-Userā ā00DE08199206515E980ED2;encoding=hexā
āCall-IDā āBW1414579900103181867563641@ā
and now this will get attached as user data in the logs, you can manipulate it -
if this is what you are looking out for.
Water,
Sorry for the delayed response, thank you for your kind assistance! Much appreciated.
