Hi
I am currently installing LFMT . I am able to see all the applications in GAX LFM tool menu like manage log collection, setup indec…
But I am unable to start indexer and rsync, i am getting below error in
ERROR: com.genesyslab.lfm.config.Cfg2FileList - Incorrect number of arguments.The program requires the lfm application, host, port, username, password and the default application (in that order) for the LFM application to generate LST files for all configuration servers. In addition, you can provide a configuration
servername and the list of log files for which the LST files are to be generated.
[IndexerMain] ERROR Incorrect number of arguments. The program requires the lfm application, host, port, username, password and the default application (in that order) for the LFM application to generate LST files for all configuration servers. In addition, you can provide a configuration servername and the list of log files for which the LST files are to be generated.
I am not able to find any above configaration details in LFMT deployment guide.
