JS SDK PKCE auth flow: code_verifier mismatch in token exchange
Stuck on the token exchange step for a SPA auth flow using PKCE. Generating the code_verifier and code_challenge correctly on the frontend, but the POST to /api/v2/oauth/token returns a 401 with “invalid_grant”. The SDK’s authenticate method seems to expect the verifier in the body, but I’m unsure if the base64 encoding needs to be URL-safe or raw. Here’s the payload structure I’m sending. Any idea what’s off?
