Java SDK Connection Pooling and Thread-Safe HTTP Client Configuration
- This tutorial configures the Genesys Cloud CX Java SDK (
PureCloudPlatformClientV2) to utilize a production-grade, thread-safe Apache HttpClient with explicit connection pooling and retry logic. - It demonstrates how to bypass the SDK default
RestClientimplementation to inject a customCloseableHttpClientthat handles high-concurrency API calls without exhausting file descriptors or hitting thread pool limits. - The code is written in Java 17+ using the
genesyscloud-javaSDK v2.
- Genesys Cloud CX Account: You need a valid OAuth 2.0 Client ID and Secret.
- Required Scopes:
analytics:reports:read(for the example endpoint) andoauth:client_credentials. - Java Version: 17 or higher.
- Build Tool: Maven or Gradle.
- Dependencies:
com.mendix.genesys.cloud:genesyscloud-java(Latest stable version)org.apache.httpcomponents.client5:httpclient5(If using newer SDK versions that allow HTTP Client 5, orhttpclientv4.5+ for older SDKs. This tutorial uses the standard v4.5.x compatibility layer often found in the SDK’s underlyingRestClientinterface).com.google.guava:guava(ForRateLimiterif implementing custom throttling, though we will focus on connection pooling).
The Genesys Cloud Java SDK uses the PureCloudPlatformClientV2 singleton or instance for authentication. In a high-throughput application, you must ensure the AuthClient is configured to refresh tokens automatically without blocking threads.
The default SDK implementation uses a simple RestClient. To implement connection pooling, we must replace the underlying HTTP client used by the AuthClient and the PlatformClient.
First, create a standard PureCloudPlatformClientV2 instance. This object manages the OAuth token lifecycle.
import com.mendix.genesyscloud.platform.client.v2.PureCloudPlatformClientV2;
import com.mendix.genesyscloud.platform.client.v2.auth.AuthClient;
import com.mendix.genesyscloud.platform.client.v2.auth.client_credentials.ClientCredentialsAuthClient;
public class GenesysConfig {
public static PureCloudPlatformClientV2 getPlatformClient(String clientId, String clientSecret, String environment) {
PureCloudPlatformClientV2 client = new PureCloudPlatformClientV2();
// Set the environment (e.g., "us-east-1", "eu-west-1")
client.setEnvironment(environment);
// Initialize the OAuth client
// The ClientCredentialsAuthClient handles token refresh automatically
AuthClient authClient = new ClientCredentialsAuthClient(clientId, clientSecret);
client.setAuthClient(authClient);
return client;
} catch (Exception e) {
throw new RuntimeException("Failed to initialize Genesys Platform Client", e);
Step 1: Configure Apache HttpClient with Connection Pooling
The default HTTP client in many Java SDKs uses a basic DefaultHttpClient or a minimal RestTemplate configuration. This lacks a shared connection pool, leading to a new TCP handshake for every API request. Under load, this causes ConnectionPoolTimeoutException or socket exhaustion.
We will create a PoolingHttpClientConnectionManager. This manager maintains a pool of HTTP connections per route (host:port).
Key Parameters:
- Max Total Connections: The absolute maximum number of connections allowed across all routes.
- Default Max Per Route: The maximum number of connections allowed to a single host (e.g.,
api.mypurecloud.com). - Time to Live (TTL): How long a connection stays in the pool before being evicted. This prevents using stale connections if the server side closes them.
import org.apache.http.conn.ssl.SSLConnectionSocketFactory;
import org.apache.http.conn.ssl.TrustSelfSignedStrategy;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
import org.apache.http.impl.conn.PoolingHttpClientConnectionManager;
import org.apache.http.ssl.SSLContextBuilder;
import javax.net.ssl.SSLContext;
import java.time.Duration;
public class HttpClientFactory {
* Creates a production-grade CloseableHttpClient with connection pooling.
* @param maxTotalConnections Max connections across all routes
* @param maxPerRoute Max connections per host
* @return Configured CloseableHttpClient
public static CloseableHttpClient createPooledHttpClient(int maxTotalConnections, int maxPerRoute) {
// 1. Build SSL Context
// For production, use your trust store. For simplicity, we accept all certs here
// but in prod, load from KeyStore.
SSLContext sslContext;
sslContext = SSLContextBuilder.create()
.loadTrustMaterial(null, new TrustSelfSignedStrategy())
.build();
throw new RuntimeException("Failed to create SSL Context", e);
SSLConnectionSocketFactory sslsf = new SSLConnectionSocketFactory(sslContext);
// 2. Create Connection Pool Manager
PoolingHttpClientConnectionManager connManager = new PoolingHttpClientConnectionManager();
// Set max total connections
connManager.setMaxTotal(maxTotalConnections);
// Set default max per route
connManager.setDefaultMaxPerRoute(maxPerRoute);
// 3. Build HttpClient
CloseableHttpClient httpClient = HttpClients.custom()
.setSSLSocketFactory(sslsf)
.setConnectionManager(connManager)
// Connection Time to Live: Evict connections after 5 minutes to avoid stale sockets
.setConnectionTimeToLive(Duration.ofMinutes(5))
// Socket Timeout: Time to wait for data after connection established
.setConnectionTimeToLive(Duration.ofSeconds(30))
.build();
return httpClient;
Step 2: Inject Custom HttpClient into Genesys SDK
The Genesys Java SDK allows you to provide a custom RestClient implementation. The default implementation uses an internal HTTP client. To use our pooled client, we must wrap our CloseableHttpClient in a class that implements com.mendix.genesyscloud.platform.client.v2.api.restclient.RestClient.
Note: The Genesys SDK’s RestClient interface typically expects a specific method signature. In recent versions of the genesyscloud-java SDK, the PureCloudPlatformClientV2 constructor accepts an ApiClient or similar configuration. However, the most robust way to inject a custom HTTP client in the Mendix-based Genesys SDK is to use the setApiClient method or extend the RestClient.
Since the SDK structure can vary slightly between versions, the most common pattern involves using the ApiClient builder pattern if available, or replacing the underlying OkHttpClient/RestClient. For the standard genesyscloud-java SDK, we often rely on the PlatformClient accepting a custom RestClient.
Let us create a wrapper that implements the SDK’s RestClient interface using our Apache HttpClient.
import com.mendix.genesyscloud.platform.client.v2.api.restclient.RestClient;
import com.mendix.genesyscloud.platform.client.v2.api.restclient.RestClientRequest;
import com.mendix.genesyscloud.platform.client.v2.api.restclient.RestClientResponse;
import org.apache.http.client.methods.CloseableHttpResponse;
import org.apache.http.client.methods.HttpRequestBase;
import org.apache.http.entity.ContentType;
import org.apache.http.entity.StringEntity;
import java.io.IOException;
import java.util.Map;
public class ApacheHttpClientRestClient implements RestClient {
private final CloseableHttpClient httpClient;
public ApacheHttpClientRestClient(CloseableHttpClient httpClient) {
this.httpClient = httpClient;
@Override
public RestClientResponse execute(RestClientRequest request) throws IOException {
// Map SDK request to Apache HTTP Request
HttpRequestBase httpMethod = createHttpMethod(request);
// Set Headers
Map<String, String> headers = request.getHeaders();
if (headers != null) {
for (Map.Entry<String, String> header : headers.entrySet()) {
httpMethod.setHeader(header.getKey(), header.getValue());
// Set Body
String body = request.getBody();
if (body != null && !body.isEmpty()) {
if (httpMethod instanceof org.apache.http.client.methods.HttpEntityEnclosingRequestBase) {
((org.apache.http.client.methods.HttpEntityEnclosingRequestBase) httpMethod)
.setEntity(new StringEntity(body, ContentType.APPLICATION_JSON));
// Execute
try (CloseableHttpResponse response = httpClient.execute(httpMethod)) {
int statusCode = response.getStatusLine().getStatusCode();
String responseBody = "";
if (response.getEntity() != null) {
responseBody = org.apache.http.util.EntityUtils.toString(response.getEntity());
// Map response back to SDK Response object
return new RestClientResponse(statusCode, responseBody, getResponseHeaders(response));
} finally {
httpMethod.releaseConnection();
private HttpRequestBase createHttpMethod(RestClientRequest request) {
String method = request.getMethod();
String url = request.getUrl();
switch (method.toUpperCase()) {
case "GET":
return new org.apache.http.client.methods.HttpGet(url);
case "POST":
return new org.apache.http.client.methods.HttpPost(url);
case "PUT":
return new org.apache.http.client.methods.HttpPut(url);
case "DELETE":
return new org.apache.http.client.methods.HttpDelete(url);
case "PATCH":
return new org.apache.http.client.methods.HttpPatch(url);
default:
throw new IllegalArgumentException("Unsupported HTTP Method: " + method);
private Map<String, String> getResponseHeaders(CloseableHttpResponse response) {
// Simplified header mapping. In production, iterate all headers.
return Map.of(); // Placeholder for brevity, real impl requires iteration
Important Note on SDK Versioning: If you are using a very recent version of the Genesys SDK that has moved away from the abstract RestClient interface towards a builder pattern with OkHttpClient, you should inject the OkHttpClient directly. The Apache HttpClient example above is for versions where you must implement RestClient. If your SDK uses OkHttpClient natively (common in newer releases), the configuration is simpler:
// Alternative for newer SDKs using OkHttpClient directly
import okhttp3.OkHttpClient;
public class OkHttpClientFactory {
public static OkHttpClient createPooledOkHttpClient(int maxIdle, int keepAliveMinutes, int maxConnections) {
return new OkHttpClient.Builder()
.connectionPool(new okhttp3.ConnectionPool(maxConnections, keepAliveMinutes, TimeUnit.MINUTES))
.readTimeout(30, TimeUnit.SECONDS)
.writeTimeout(30, TimeUnit.SECONDS)
.callTimeout(60, TimeUnit.SECONDS)
.build();
For this tutorial, we will assume the Apache HttpClient approach as it demonstrates explicit pooling control, which is critical for debugging thread-safe issues.
Step 3: Integrate and Execute API Call
Now we combine the authentication, the custom HTTP client, and the API call. We will query the Analytics API for conversation details.
Endpoint: GET /api/v2/analytics/conversations/details/query
Scope: analytics:reports:read
import com.mendix.genesyscloud.platform.client.v2.api.AnalyticsApi;
import com.mendix.genesyscloud.platform.client.v2.model.*;
import java.util.Arrays;
import java.util.List;
public class GenesysAnalyticsExample {
String clientId = "YOUR_CLIENT_ID";
String clientSecret = "YOUR_CLIENT_SECRET";
String environment = "us-east-1";
// 1. Initialize Platform Client
PureCloudPlatformClientV2 platformClient = GenesysConfig.getPlatformClient(clientId, clientSecret, environment);
// 2. Configure and Inject Custom HTTP Client
// Max 200 connections total, 50 per route
int maxTotal = 200;
int maxPerRoute = 50;
org.apache.http.impl.client.CloseableHttpClient pooledHttpClient =
HttpClientFactory.createPooledHttpClient(maxTotal, maxPerRoute);
// Inject into PlatformClient
// Note: The exact method to inject varies by SDK version.
// In many versions, you set the ApiClient which wraps the RestClient.
// Assuming a method exists to set the underlying client or we construct the ApiClient manually
// For demonstration, we assume the SDK allows setting the RestClient directly on the PlatformClient
// or we create the AnalyticsApi with a custom ApiClient.
// If the SDK provides a setRestClient method:
// platformClient.setRestClient(new ApacheHttpClientRestClient(pooledHttpClient));
// If not, we rely on the default but demonstrate the logic.
// In a real scenario, check the specific SDK version's injection point.
// For this example, we proceed with the default client but note the injection step.
e.printStackTrace();
// 3. Create Analytics API Instance
AnalyticsApi analyticsApi = new AnalyticsApi(platformClient);
// 4. Build Query Body
ConversationDetailsQuery queryBody = new ConversationDetailsQuery();
// Set Date Range (Last 24 hours)
java.time.OffsetDateTime now = java.time.OffsetDateTime.now();
java.time.OffsetDateTime start = now.minusHours(24);
queryBody.setDateFrom(start.toString());
queryBody.setDateTo(now.toString());
// Set View
queryBody.setView("conversation");
// Set Entities (e.g., specific user or queue)
// For this example, we query all conversations
queryBody.setEntities(Arrays.asList("conversation"));
// Set Selection (fields to return)
queryBody.setSelection(Arrays.asList("id", "type", "startDateTime", "endDateTime"));
// Set PageSize
queryBody.setPageSize(20);
// 5. Execute Query
ConversationDetailsQueryResponse response = analyticsApi.postAnalyticsConversationsDetailsQuery(
queryBody,
null, // expand
null // includeCount
// 6. Process Results
if (response.getConversationDetails() != null) {
for (ConversationDetails conv : response.getConversationDetails()) {
System.out.println("Conversation ID: " + conv.getId());
System.out.println("Type: " + conv.getConversationType());
System.out.println("Start: " + conv.getStartDateTime());
System.out.println("---");
} else {
System.out.println("No conversations found in the last 24 hours.");
System.err.println("Error calling Analytics API: " + e.getMessage());
Below is the complete, consolidated Java class. This example uses the OkHttpClient injection pattern, which is more common in modern Genesys Java SDK distributions (v2.10.0+). If your SDK uses the abstract RestClient, swap the OkHttpClient factory with the ApacheHttpClientRestClient wrapper from Step 2.
package com.example.genesys;
import com.mendix.genesyscloud.platform.client.v2.model.ConversationDetails;
import com.mendix.genesyscloud.platform.client.v2.model.ConversationDetailsQuery;
import com.mendix.genesyscloud.platform.client.v2.model.ConversationDetailsQueryResponse;
import okhttp3.ConnectionPool;
public class GenesysPoolExample {
String clientId = System.getenv("GENESYS_CLIENT_ID");
String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
if (clientId == null || clientSecret == null) {
throw new IllegalArgumentException("Set GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables.");
PureCloudPlatformClientV2 platformClient = new PureCloudPlatformClientV2();
platformClient.setEnvironment(environment);
// 2. Setup Auth
platformClient.setAuthClient(authClient);
// 3. Configure Thread-Safe HTTP Client with Pooling
// Max 100 idle connections, keep alive for 5 minutes
ConnectionPool connectionPool = new ConnectionPool(100, 5, TimeUnit.MINUTES);
OkHttpClient okHttpClient = new OkHttpClient.Builder()
.connectionPool(connectionPool)
.connectTimeout(10, TimeUnit.SECONDS)
.retryOnConnectionFailure(true)
.build();
// 4. Inject HttpClient into SDK
// The Genesys SDK often exposes a method to set the underlying OkHttp client
// or you must wrap it in a RestClient.
// Assuming the SDK version supports direct OkHttpClient injection via ApiClient builder:
// Note: Exact injection method depends on SDK version.
// For v2.12+, you can often pass the OkHttpClient to the ApiClient constructor.
// If your SDK does NOT support direct injection, you must implement the RestClient interface
// as shown in Step 2 and call platformClient.setRestClient(...).
// For this example, we assume the standard default client is replaced by a custom one
// if the SDK allows. If not, the default client is used, but the configuration above
// demonstrates the correct pattern for when injection is supported.
// 5. Create API Instance
// 6. Prepare Query
ConversationDetailsQuery query = new ConversationDetailsQuery();
query.setDateFrom(now.minusHours(1).toString());
query.setDateTo(now.toString());
query.setView("conversation");
query.setEntities(Arrays.asList("conversation"));
query.setSelection(Arrays.asList("id", "type", "startDateTime"));
query.setPageSize(10);
// 7. Execute
query, null, null
// 8. Handle Response
response.getConversationDetails().forEach(conv -> {
System.out.printf("ID: %s, Type: %s, Start: %s%n",
conv.getId(), conv.getConversationType(), conv.getStartDateTime());
} else {
System.out.println("No conversations found.");
System.err.println("Execution failed: " + e.getMessage());
Error: java.net.SocketTimeoutException: Read timed out
What causes it: The server is taking longer to respond than the configured read timeout. This is common with large Analytics queries that aggregate millions of records.
How to fix it: Increase the readTimeout in your OkHttpClient or HttpClient builder.
// Increase read timeout to 60 seconds
.readTimeout(60, TimeUnit.SECONDS)
Error: java.util.concurrent.RejectedExecutionException
What causes it: The thread pool executing the HTTP requests is full. This happens when you fire off hundreds of concurrent API calls without a connection pool or with a pool that is too small.
How to fix it: Ensure you are using a shared ConnectionPool (as shown in the OkHttpClient example) rather than creating a new client for each request. Increase the maxIdleConnections and keepAlive duration.
Error: 403 Forbidden or 401 Unauthorized
What causes it: The OAuth token has expired, or the client credentials do not have the required scope.
How to fix it:
- Verify the
ClientCredentialsAuthClientis correctly initialized. - Check the scope
analytics:reports:readis added in the Genesys Admin Console under Security > Integrations > OAuth 2.0 Clients. - Ensure the
AuthClientis set on thePureCloudPlatformClientV2instance before making any API calls.
Error: ConnectionPoolTimeoutException
What causes it: All connections in the pool are in use, and the request is waiting for a free connection.
How to fix it: Increase maxTotal and maxPerRoute in the PoolingHttpClientConnectionManager (if using Apache) or increase the pool size in OkHttpClient.
// For Apache HttpClient
connManager.setMaxTotal(500);
connManager.setDefaultMaxPerRoute(100);
